[QGIS Commit] r15692 - in trunk/qgis/src: app core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 11 16:01:17 EDT 2011
Author: mhugent
Date: 2011-04-11 13:01:17 -0700 (Mon, 11 Apr 2011)
New Revision: 15692
   trunk/qgis/src/app/qgsmaptoollabel.cpp
   trunk/qgis/src/app/qgsmaptoolmovelabel.cpp
   trunk/qgis/src/core/qgslabelsearchtree.cpp
   trunk/qgis/src/core/qgslabelsearchtree.h
   trunk/qgis/src/core/qgspallabeling.cpp
Fix label and diagram editing if otf reprojection is enabled (ticket #3685)
Modified: trunk/qgis/src/app/qgsmaptoollabel.cpp
--- trunk/qgis/src/app/qgsmaptoollabel.cpp	2011-04-10 00:56:17 UTC (rev 15691)
+++ trunk/qgis/src/app/qgsmaptoollabel.cpp	2011-04-11 20:01:17 UTC (rev 15692)
@@ -90,6 +90,15 @@
     QgsPoint fixPoint;
     if ( rotationPoint( fixPoint ) )
+      if ( mCanvas )
+        QgsMapRenderer* r = mCanvas->mapRenderer();
+        if ( r && r->hasCrsTransformEnabled() )
+          fixPoint = r->mapToLayerCoordinates( vlayer, fixPoint );
       QgsGeometry* pointGeom = QgsGeometry::fromPoint( fixPoint );
       mFixPointRubberBand = new QgsRubberBand( mCanvas, false );
       mFixPointRubberBand->setColor( Qt::blue );
Modified: trunk/qgis/src/app/qgsmaptoolmovelabel.cpp
--- trunk/qgis/src/app/qgsmaptoolmovelabel.cpp	2011-04-10 00:56:17 UTC (rev 15691)
+++ trunk/qgis/src/app/qgsmaptoolmovelabel.cpp	2011-04-11 20:01:17 UTC (rev 15692)
@@ -125,10 +125,30 @@
   else
+    //transform to map crs first, because xdiff,ydiff are in map coordinates
+      QgsPoint transformedPoint = r->layerToMapCoordinates( vlayer, QgsPoint( xPosOrig, yPosOrig ) );
+      xPosOrig = transformedPoint.x();
+      yPosOrig = transformedPoint.y();
     xPosNew = xPosOrig + xdiff;
     yPosNew = yPosOrig + ydiff;
+  //transform back to layer crs
+  if ( mCanvas )
+      QgsPoint transformedPoint = r->mapToLayerCoordinates( vlayer, QgsPoint( xPosNew, yPosNew ) );
+      xPosNew = transformedPoint.x();
+      yPosNew = transformedPoint.y();
   vlayer->beginEditCommand( tr( "Label moved" ) );
   vlayer->changeAttributeValue( mCurrentLabelPos.featureId, xCol, xPosNew, false );
   vlayer->changeAttributeValue( mCurrentLabelPos.featureId, yCol, yPosNew, false );
Modified: trunk/qgis/src/core/qgslabelsearchtree.cpp
--- trunk/qgis/src/core/qgslabelsearchtree.cpp	2011-04-10 00:56:17 UTC (rev 15691)
+++ trunk/qgis/src/core/qgslabelsearchtree.cpp	2011-04-11 20:01:17 UTC (rev 15692)
@@ -19,12 +19,22 @@
 void QgsLabelSearchTree::label( const QgsPoint& p, QList<QgsLabelPosition*>& posList )
-  double c_min[2]; c_min[0] = p.x() - 1; c_min[1] = p.y() - 1;
-  double c_max[2]; c_max[0] = p.x() + 1; c_max[1] = p.y() + 1;
+  double c_min[2]; c_min[0] = p.x() - 0.1; c_min[1] = p.y() - 0.1;
+  double c_max[2]; c_max[0] = p.x() + 0.1; c_max[1] = p.y() + 0.1;
-  mSearchResults.clear();
-  mSpatialIndex.Search( c_min, c_max, searchCallback, &mSearchResults );
-  posList = mSearchResults;
+  QList<QgsLabelPosition*> searchResults;
+  mSpatialIndex.Search( c_min, c_max, searchCallback, &searchResults );
+  //tolerance +-0.1 could be high in case of degree crs, so check if p is really contained in the results
+  posList.clear();
+  QList<QgsLabelPosition*>::const_iterator resultIt = searchResults.constBegin();
+  for ( ; resultIt != searchResults.constEnd(); ++resultIt )
+    if (( *resultIt )->labelRect.contains( p ) )
+      posList.push_back( *resultIt );
 bool QgsLabelSearchTree::insertLabel( LabelPosition* labelPos, int featureId, const QString& layerName, bool diagram )
Modified: trunk/qgis/src/core/qgslabelsearchtree.h
--- trunk/qgis/src/core/qgslabelsearchtree.h	2011-04-10 00:56:17 UTC (rev 15691)
+++ trunk/qgis/src/core/qgslabelsearchtree.h	2011-04-11 20:01:17 UTC (rev 15692)
@@ -48,7 +48,6 @@
   private:
     RTree<QgsLabelPosition*, double, 2, double> mSpatialIndex;
-    QList<QgsLabelPosition*> mSearchResults;
 #endif // QGSLABELTREE_H
Modified: trunk/qgis/src/core/qgspallabeling.cpp
--- trunk/qgis/src/core/qgspallabeling.cpp	2011-04-10 00:56:17 UTC (rev 15691)
+++ trunk/qgis/src/core/qgspallabeling.cpp	2011-04-11 20:01:17 UTC (rev 15692)
@@ -548,8 +548,16 @@
           ydiff = yd;
+        //project xPos and yPos from layer to map CRS
+        double z = 0;
+        if ( ct )
+          ct->transformInPlace( xPos, yPos, z );
         yPos += ydiff;
         xPos += xdiff;
@@ -786,7 +794,7 @@
   //convert geom to geos
   QgsGeometry* geom = feat.geometry();
-  if ( layerIt.value().ct ) // reproject the geometry if necessary
+  if ( layerIt.value().ct && !willUseLayer( layer ) ) // reproject the geometry if feature not already transformed for labeling
     geom->transform( *( layerIt.value().ct ) );
@@ -841,6 +849,15 @@
       ddPos = false;
+    else
+      const QgsCoordinateTransform* ct = layerIt.value().ct;
+      if ( ct )
+        double z = 0;
+        ct->transformInPlace( ddPosX, ddPosY, z );
   try
More information about the QGIS-commit mailing list
