[QGIS Commit] r15728 - trunk/qgis/src/core
svn_qgis at osgeo.org
Sat Apr 16 10:24:09 EDT 2011
Author: jef
Date: 2011-04-16 07:24:09 -0700 (Sat, 16 Apr 2011)
New Revision: 15728
trunk/qgis/src/core/qgsgeometry.cpp
fix #3439
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2011-04-16 13:58:57 UTC (rev 15727)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2011-04-16 14:24:09 UTC (rev 15728)
@@ -3233,125 +3233,126 @@
/**Replaces a part of this geometry with another line*/
int QgsGeometry::reshapeGeometry( const QList<QgsPoint>& reshapeWithLine )
- if ( reshapeWithLine.size() < 2 )
- return 1;
- if ( type() == QGis::Point )
- return 1; //cannot reshape points
- GEOSGeometry* reshapeLineGeos = createGeosLineString( reshapeWithLine.toVector() );
- //make sure this geos geometry is up-to-date
- if ( !mGeos || mDirtyGeos )
- exportWkbToGeos();
- //single or multi?
- int numGeoms = GEOSGetNumGeometries( mGeos );
- if ( numGeoms == -1 )
- return 1;
- bool isMultiGeom = false;
- int geosTypeId = GEOSGeomTypeId( mGeos );
- if ( geosTypeId == GEOS_MULTILINESTRING || geosTypeId == GEOS_MULTIPOLYGON )
- isMultiGeom = true;
- bool isLine = ( type() == QGis::Line );
- //polygon or multipolygon?
- if ( !isMultiGeom )
- GEOSGeometry* reshapedGeometry;
- if ( isLine )
+ if ( reshapeWithLine.size() < 2 )
- reshapedGeometry = reshapeLine( mGeos, reshapeLineGeos );
+ return 1;
- else
+ if ( type() == QGis::Point )
- reshapedGeometry = reshapePolygon( mGeos, reshapeLineGeos );
+ return 1; //cannot reshape points
- GEOSGeom_destroy( reshapeLineGeos );
- if ( reshapedGeometry )
+ GEOSGeometry* reshapeLineGeos = createGeosLineString( reshapeWithLine.toVector() );
+ //make sure this geos geometry is up-to-date
+ if ( !mGeos || mDirtyGeos )
- GEOSGeom_destroy( mGeos );
- mGeos = reshapedGeometry;
- mDirtyWkb = true;
- return 0;
+ exportWkbToGeos();
- else
+ //single or multi?
+ int numGeoms = GEOSGetNumGeometries( mGeos );
+ if ( numGeoms == -1 )
return 1;
- else
- //call reshape for each geometry part and replace mGeos with new geometry if reshape took place
- bool reshapeTookPlace = false;
- GEOSGeometry* currentReshapeGeometry = 0;
- GEOSGeometry** newGeoms = new GEOSGeometry*[numGeoms];
+ bool isMultiGeom = false;
+ int geosTypeId = GEOSGeomTypeId( mGeos );
+ if ( geosTypeId == GEOS_MULTILINESTRING || geosTypeId == GEOS_MULTIPOLYGON )
+ isMultiGeom = true;
- for ( int i = 0; i < numGeoms; ++i )
+ bool isLine = ( type() == QGis::Line );
+ //polygon or multipolygon?
+ if ( !isMultiGeom )
+ GEOSGeometry* reshapedGeometry;
if ( isLine )
- currentReshapeGeometry = reshapeLine( GEOSGetGeometryN( mGeos, i ), reshapeLineGeos );
+ reshapedGeometry = reshapeLine( mGeos, reshapeLineGeos );
else
- currentReshapeGeometry = reshapePolygon( GEOSGetGeometryN( mGeos, i ), reshapeLineGeos );
+ reshapedGeometry = reshapePolygon( mGeos, reshapeLineGeos );
- if ( currentReshapeGeometry )
+ GEOSGeom_destroy( reshapeLineGeos );
+ if ( reshapedGeometry )
- newGeoms[i] = currentReshapeGeometry;
- reshapeTookPlace = true;
+ GEOSGeom_destroy( mGeos );
+ mGeos = reshapedGeometry;
+ mDirtyWkb = true;
+ return 0;
else
- newGeoms[i] = GEOSGeom_clone( GEOSGetGeometryN( mGeos, i ) );
+ return 1;
- GEOSGeometry* newMultiGeom = 0;
- if ( isLine )
+ else
- newMultiGeom = GEOSGeom_createCollection( GEOS_MULTILINESTRING, newGeoms, numGeoms );
- else //multipolygon
- newMultiGeom = GEOSGeom_createCollection( GEOS_MULTIPOLYGON, newGeoms, numGeoms );
+ //call reshape for each geometry part and replace mGeos with new geometry if reshape took place
+ bool reshapeTookPlace = false;
- delete[] newGeoms;
- if ( ! newMultiGeom )
- return 3;
+ GEOSGeometry* currentReshapeGeometry = 0;
+ GEOSGeometry** newGeoms = new GEOSGeometry*[numGeoms];
- if ( reshapeTookPlace )
- mGeos = newMultiGeom;
- mDirtyWkb = true;
- return 0;
+ for ( int i = 0; i < numGeoms; ++i )
+ if ( isLine )
+ currentReshapeGeometry = reshapeLine( GEOSGetGeometryN( mGeos, i ), reshapeLineGeos );
+ else
+ currentReshapeGeometry = reshapePolygon( GEOSGetGeometryN( mGeos, i ), reshapeLineGeos );
+ if ( currentReshapeGeometry )
+ newGeoms[i] = currentReshapeGeometry;
+ reshapeTookPlace = true;
+ else
+ newGeoms[i] = GEOSGeom_clone( GEOSGetGeometryN( mGeos, i ) );
+ GEOSGeometry* newMultiGeom = 0;
+ if ( isLine )
+ newMultiGeom = GEOSGeom_createCollection( GEOS_MULTILINESTRING, newGeoms, numGeoms );
+ else //multipolygon
+ newMultiGeom = GEOSGeom_createCollection( GEOS_MULTIPOLYGON, newGeoms, numGeoms );
+ delete[] newGeoms;
+ if ( ! newMultiGeom )
+ return 3;
+ if ( reshapeTookPlace )
+ mGeos = newMultiGeom;
+ mDirtyWkb = true;
+ return 0;
+ else
+ GEOSGeom_destroy( newMultiGeom );
+ return 1;
- else
- GEOSGeom_destroy( newMultiGeom );
- return 1;
int QgsGeometry::makeDifference( QgsGeometry* other )
@@ -5065,16 +5066,25 @@
//do inner rings intersect?
const GEOSGeometry **innerRings = new const GEOSGeometry*[nRings];
- for ( int i = 0; i < nRings; ++i )
+ try
- innerRings[i] = GEOSGetInteriorRingN( polygon, i );
- if ( GEOSIntersects( innerRings[i], reshapeLineGeos ) == 1 )
+ for ( int i = 0; i < nRings; ++i )
- ++nIntersections;
- lastIntersectingRing = i;
- lastIntersectingGeom = innerRings[i];
+ innerRings[i] = GEOSGetInteriorRingN( polygon, i );
+ if ( GEOSIntersects( innerRings[i], reshapeLineGeos ) == 1 )
+ ++nIntersections;
+ lastIntersectingRing = i;
+ lastIntersectingGeom = innerRings[i];
+ catch ( GEOSException &e )
+ Q_UNUSED( e );
+ nIntersections = 0;
if ( nIntersections != 1 ) //reshape line is only allowed to intersect one ring
@@ -5173,10 +5183,21 @@
return 0;
- //make sure there are at least two intersection between line and reshape geometry
- GEOSGeometry* intersectGeom = GEOSIntersection( line, reshapeLineGeos );
- bool atLeastTwoIntersections = ( GEOSGeomTypeId( intersectGeom ) == GEOS_MULTIPOINT && GEOSGetNumGeometries( intersectGeom ) > 1 );
- GEOSGeom_destroy( intersectGeom );
+ bool atLeastTwoIntersections;
+ try
+ //make sure there are at least two intersection between line and reshape geometry
+ GEOSGeometry* intersectGeom = GEOSIntersection( line, reshapeLineGeos );
+ atLeastTwoIntersections = ( GEOSGeomTypeId( intersectGeom ) == GEOS_MULTIPOINT && GEOSGetNumGeometries( intersectGeom ) > 1 );
+ GEOSGeom_destroy( intersectGeom );
+ Q_UNUSED( e );
+ atLeastTwoIntersections = false;
if ( !atLeastTwoIntersections )
return 0;
