[QGIS Commit] r15745 - in trunk/qgis/src: app ui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sun Apr 17 09:23:23 EDT 2011
Author: alexbruy
Date: 2011-04-17 06:23:23 -0700 (Sun, 17 Apr 2011)
New Revision: 15745
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/app/qgsrasterlayerproperties.h
   trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
disable Build Pyramids button if no pyramids levels selected. Also reset progressbar state after building pyramids
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2011-04-17 11:21:45 UTC (rev 15744)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2011-04-17 13:23:23 UTC (rev 15745)
@@ -91,6 +91,8 @@
   connect( leBlueMin, SIGNAL( textEdited( QString ) ), this, SLOT( userDefinedMinMax_textEdited( QString ) ) );
   connect( leBlueMax, SIGNAL( textEdited( QString ) ), this, SLOT( userDefinedMinMax_textEdited( QString ) ) );
   connect( mColormapTreeWidget, SIGNAL( itemDoubleClicked( QTreeWidgetItem*, int ) ), this, SLOT( handleColormapTreeWidgetDoubleClick( QTreeWidgetItem*, int ) ) );
+  // enable or disable Build Pyramids button depending on selection in pyramid list
+  connect( lbxPyramidResolutions, SIGNAL( itemSelectionChanged() ), this, SLOT( toggleBuildPyramidsButton() ) );
   connect( mRasterLayer, SIGNAL( dataChanged( int ) ), this, SLOT( dataChanged( int ) ) );
@@ -1544,6 +1546,8 @@
                   cboResamplingMethod->currentText(),
                   myBuildInternalFlag );
   QApplication::restoreOverrideCursor();
+  mPyramidProgress->setValue( 0 );
+  buttonBuildPyramids->setEnabled( false );
   disconnect( mRasterLayer, SIGNAL( progressUpdate( int ) ), mPyramidProgress, SLOT( setValue( int ) ) );
   if ( !res.isNull() )
@@ -3039,4 +3043,17 @@
 void QgsRasterLayerProperties::dataChanged( int change )
   QgsDebugMsg( "entered." );
\ No newline at end of file
+void QgsRasterLayerProperties::toggleBuildPyramidsButton()
+  if ( lbxPyramidResolutions->selectedItems().empty() )
+  else
+    buttonBuildPyramids->setEnabled( true );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h	2011-04-17 11:21:45 UTC (rev 15744)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h	2011-04-17 13:23:23 UTC (rev 15745)
@@ -149,6 +149,8 @@
     void on_buttonBox_helpRequested() { QgsContextHelp::run( metaObject()->className() ); }
     /** This slot lets you save the histogram as an image to disk */
     void on_mSaveAsImageButton_clicked();
+    /**Enable or disable Build pyramids button depending on selection in pyramids list*/
+    void toggleBuildPyramidsButton();
   signals:
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2011-04-17 11:21:45 UTC (rev 15744)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui	2011-04-17 13:23:23 UTC (rev 15745)
@@ -1846,6 +1846,9 @@
        </item>
        <item row="3" column="4">
         <widget class="QPushButton" name="buttonBuildPyramids">
+         <property name="enabled">
+          <bool>false</bool>
+         </property>
          <property name="text">
           <string>Build pyramids</string>
          </property>
More information about the QGIS-commit mailing list
