[QGIS Commit] r15749 - in trunk/qgis/src: app core core/raster
providers/grass
svn_qgis at osgeo.org
Sun Apr 17 11:13:18 EDT 2011
Author: rblazek
Date: 2011-04-17 08:13:18 -0700 (Sun, 17 Apr 2011)
New Revision: 15749
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/qgsdataprovider.h
trunk/qgis/src/core/qgsrasterdataprovider.h
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
trunk/qgis/src/providers/grass/qgsgrassrasterprovider.h
completely reload provider if GRASS source data have changed
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2011-04-17 15:13:18 UTC (rev 15749)
@@ -94,8 +94,6 @@
// enable or disable Build Pyramids button depending on selection in pyramid list
connect( lbxPyramidResolutions, SIGNAL( itemSelectionChanged() ), this, SLOT( toggleBuildPyramidsButton() ) );
- connect( mRasterLayer, SIGNAL( dataChanged( int ) ), this, SLOT( dataChanged( int ) ) );
// set up the scale based layer visibility stuff....
chkUseScaleDependentRendering->setChecked( lyr->hasScaleBasedVisibility() );
leMinimumScale->setText( QString::number( lyr->minimumScale(), 'f' ) );
@@ -3040,11 +3038,6 @@
-void QgsRasterLayerProperties::dataChanged( int change )
- QgsDebugMsg( "entered." );
void QgsRasterLayerProperties::toggleBuildPyramidsButton()
if ( lbxPyramidResolutions->selectedItems().empty() )
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2011-04-17 15:13:18 UTC (rev 15749)
@@ -99,9 +99,6 @@
/** \brief this slot sets StdDev switch box to 0.00 when user enters min max values */
void userDefinedMinMax_textEdited( QString );
- /** \brief data changed reciever */
- void dataChanged( int change );
private slots:
/** This slow handles necessary interface modifications (i.e. loading min max values) */
void on_cboBlue_currentIndexChanged( const QString& );
Modified: trunk/qgis/src/core/qgsdataprovider.h
--- trunk/qgis/src/core/qgsdataprovider.h 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/core/qgsdataprovider.h 2011-04-17 15:13:18 UTC (rev 15749)
@@ -287,9 +287,6 @@
/** Current time stamp of data source */
virtual QDateTime dataTimestamp() const { return QDateTime(); }
- /** test if at least one of specified data/metadata changed since provider was loaded */
- virtual bool changed( int change ) { return false; }
signals:
@@ -313,6 +310,11 @@
+ protected:
+ * Timestamp of data in the moment when the data were loaded by provider.
+ QDateTime mTimestamp;
private:
@@ -320,11 +322,6 @@
* This could be a file, database, or server address.
QString mDataSourceURI;
- * Timestamp of data in the moment when the data were loaded by provider.
- QDateTime mTimestamp;
Modified: trunk/qgis/src/core/qgsrasterdataprovider.h
--- trunk/qgis/src/core/qgsrasterdataprovider.h 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/core/qgsrasterdataprovider.h 2011-04-17 15:13:18 UTC (rev 15749)
@@ -116,17 +116,6 @@
ProgressPyramids = 1
- enum Change
- NoChange = 0,
- ValuesChange = 1,
- ExtentChange = 1 << 1,
- CrsChange = 1 << 2,
- DataTypeChange = 1 << 3,
- ColorTableChange = 1 << 4,
- SizeChange = 1 << 5
QgsRasterDataProvider();
QgsRasterDataProvider( QString const & uri );
@@ -480,24 +469,17 @@
/** \brief Set null value in char */
QByteArray noValueBytes( int theBandNo );
+ /** Time stamp of data source in the moment when data/metadata were loaded by provider */
+ virtual QDateTime timestamp() const { return mTimestamp; }
- /** Give list of changed data/metadata since provider was loaded */
- virtual int changed( ) { return NoChange; }
signals:
/** Emit a signal to notify of the progress event.
* Emited theProgress is in percents (0.0-100.0) */
void progress( int theType, double theProgress, QString theMessage );
- * This is emitted whenever data or metadata (e.g. color table, extent) has changed
- * @param changed binary combination of changes
- * @note added in 1.7
protected:
/**Dots per intch. Extended WMS (e.g. QGIS mapserver) support DPI dependent output and therefore
are suited for printing. A value of -1 means it has not been set
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-04-17 15:13:18 UTC (rev 15749)
@@ -127,6 +127,10 @@
, mInvertColor( false )
, mModified( false )
, mProviderKey( providerKey )
+ , mLayers( layers )
+ , mStyles( styles )
+ , mFormat( format )
+ , mCrs( crs )
QgsDebugMsg( "(8 arguments) starting. with layer list of " +
layers.join( ", " ) + " and style list of " + styles.join( ", " ) + " and format of " +
@@ -2531,6 +2535,21 @@
QgsDebugMsg( "exiting." );
} // QgsRasterLayer::setDataProvider
+void QgsRasterLayer::closeDataProvider()
+ mValid = false;
+ delete mRasterShader;
+ mRasterShader = 0;
+ delete mDataProvider;
+ mDataProvider = 0;
+ mRasterStatsList.clear();
+ mContrastEnhancementList.clear();
+ mHasPyramids = false;
+ mPyramidList.clear();
void QgsRasterLayer::setColorShadingAlgorithm( ColorShadingAlgorithm theShadingAlgorithm )
QgsDebugMsg( "called with [" + QString::number( theShadingAlgorithm ) + "]" );
@@ -4436,38 +4455,13 @@
// Check if data changed
- //if ( mLastModified < QgsRasterLayer::lastModified( source() ) )
- // TODO: lastModified to provider -> outdated
- // TODO: check what has to be cleard, rebuild
- int change = mDataProvider->changed();
- if ( change != QgsRasterDataProvider::NoChange )
+ if ( mDataProvider->dataTimestamp() > mDataProvider->timestamp() )
QgsDebugMsg( "reload data" );
- //mHasPyramids = false;
- //mPyramidList.clear();
- //mRasterStatsList.clear();
- mValid = mDataProvider->reload();
- for ( int i = 1; i <= mBandCount; i++ )
- // TODO : refresh all data, move to separate method from constructor
- // Reload color table
- if ( i - 1 < mRasterStatsList.size() )
- QList<QgsColorRampShader::ColorRampItem> ct;
- ct = mDataProvider->colorTable( i );
- mRasterStatsList[i-1].colorTable = ct;
- if ( mRasterType == Palette )
- QgsColorRampShader* myColorRampShader = ( QgsColorRampShader* ) mRasterShader->rasterShaderFunction();
- myColorRampShader->setColorRampItemList( *colorTable( 1 ) );
- emit dataChanged( change );
+ closeDataProvider();
+ init();
+ setDataProvider( mProviderKey, mLayers, mStyles, mFormat, mCrs );
+ emit dataChanged();
return mValid;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2011-04-17 15:13:18 UTC (rev 15749)
@@ -685,10 +685,9 @@
- * @param changed binary combination of changes, defined in QgsRasterDataProvider
+ void dataChanged();
protected:
@@ -767,8 +766,8 @@
const QgsMapToPixel* theQgsMapToPixel,
int theBandNoInt );
- /** \brief Close data set and release related data */
- void closeDataset();
+ /** \brief Close data provider and clear related members */
+ void closeDataProvider();
/** \brief helper function to create zero padded band names */
QString generateBandName( int );
@@ -913,6 +912,13 @@
/** \brief Flag indicating if the nodatavalue is valid*/
bool mValidNoDataValue;
+ /** WMS parameters */
+ /* TODO: put everything to URI */
+ QStringList mLayers;
+ QStringList mStyles;
+ QString mFormat;
+ QString mCrs;
/*#include <QColor>
Modified: trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/providers/grass/qgsgrassrasterprovider.cpp 2011-04-17 15:13:18 UTC (rev 15749)
@@ -74,6 +74,8 @@
QgsDebugMsg( QString( "mapset: %1" ).arg( mMapset ) );
QgsDebugMsg( QString( "mapName: %1" ).arg( mMapName ) );
+ mTimestamp = dataTimestamp();
mRasterValue.start( mGisdbase, mLocation, mMapset, mMapName );
mValidNoDataValue = true;
@@ -485,22 +487,25 @@
return PROVIDER_DESCRIPTION;
-int QgsGrassRasterProvider::changed()
+QDateTime QgsGrassRasterProvider::dataTimestamp() const
- QgsDebugMsg( "Entered" );
- // TODO
- return ValuesChange | ExtentChange | CrsChange | DataTypeChange | ColorTableChange | SizeChange;
+ QDateTime time;
+ QString mapset = mGisdbase + "/" + mLocation + "/" + mMapset;
+ QStringList dirs;
+ dirs << "cell" << "colr";
+ foreach( QString dir, dirs )
+ QString path = mapset + "/" + dir + "/" + mMapName;
+ QFileInfo fi( path );
+ if ( fi.exists() && fi.lastModified() > time )
+ time = fi.lastModified();
+ QgsDebugMsg( "timestamp = " + time.toString() );
+ return time;
-bool QgsGrassRasterProvider::reload()
- return true;
-//void QgsGrassRasterProvider::buildSupportedRasterFileFilter( QString & theFileFiltersString )
* Class factory to return a pointer to a newly created
* QgsGrassRasterProvider object
@@ -552,7 +557,14 @@
QgsGrassRasterValue::~QgsGrassRasterValue()
- if ( mProcess ) delete mProcess;
+ if ( mProcess )
+ QgsDebugMsg( "closing process" );
+ mProcess->closeWriteChannel();
+ mProcess->waitForFinished();
+ QgsDebugMsg( "process finished" );
+ delete mProcess;
QString QgsGrassRasterValue::value( double x, double y )
Modified: trunk/qgis/src/providers/grass/qgsgrassrasterprovider.h
--- trunk/qgis/src/providers/grass/qgsgrassrasterprovider.h 2011-04-17 14:00:45 UTC (rev 15748)
+++ trunk/qgis/src/providers/grass/qgsgrassrasterprovider.h 2011-04-17 15:13:18 UTC (rev 15749)
@@ -244,8 +244,7 @@
bool theThoroughBandScanFlag = false
- int changed( );
- bool reload( );
+ virtual QDateTime dataTimestamp() const;
private:
