[QGIS Commit] r15758 - in trunk/qgis/src: plugins/grass providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Apr 18 10:48:33 EDT 2011
Author: rblazek
Date: 2011-04-18 07:48:33 -0700 (Mon, 18 Apr 2011)
New Revision: 15758
   trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
   trunk/qgis/src/providers/grass/qgsgrass.cpp
   trunk/qgis/src/providers/grass/qgsgrass.h
   trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
GRASS region transformation resent on mapset change
Modified: trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp	2011-04-18 13:04:08 UTC (rev 15757)
+++ trunk/qgis/src/plugins/grass/qgsgrassplugin.cpp	2011-04-18 14:48:33 UTC (rev 15758)
@@ -115,6 +115,8 @@
   mCanvas = qGisInterface->mapCanvas();
   QWidget* qgis = qGisInterface->mainWindow();
+  connect( mCanvas->mapRenderer(), SIGNAL( destinationSrsChanged() ), this, SLOT( setTransform() ) );
   // Connect project
   connect( qgis, SIGNAL( projectRead() ), this, SLOT( projectRead() ) );
   connect( qgis, SIGNAL( newProject() ), this, SLOT( newProject() ) );
@@ -244,6 +246,20 @@
       mTools->mapsetChanged();
+    QString gisdbase = QgsGrass::getDefaultGisdbase();
+    QString location = QgsGrass::getDefaultLocation();
+    try
+      mCrs = QgsGrass::crsDirect( gisdbase, location );
+    catch ( QgsGrass::Exception &e )
+      QgsDebugMsg( "Cannot read GRASS CRS : " + QString( e.what() ) );
+      mCrs = QgsCoordinateReferenceSystem();
+    QgsDebugMsg( "mCrs: " + mCrs.toWkt() );
+    setTransform();
+    redrawRegion();
@@ -590,15 +606,6 @@
   QgsGrass::setLocation( gisdbase, location );
-  // TODO: check better if we have to init + maybe the location can change -> mCrs must be reloaded
-  if ( !mCrs.isValid() )
-    mCrs = QgsGrass::crs( gisdbase, location );
-    QgsDebugMsg( "mCrs: " + mCrs.toWkt() );
-    setTransform();
-    connect( mCanvas->mapRenderer(), SIGNAL( destinationSrsChanged() ), this, SLOT( setTransform() ) );
   struct Cell_head window;
   char *err = G__get_window( &window, ( char * ) "", ( char * ) "WIND", mapset.toLatin1().data() );
@@ -877,6 +884,8 @@
   if ( mCrs.isValid() && mCanvas->mapRenderer()->destinationCrs().isValid() )
+    QgsDebugMsg( "srcCrs: " + mCrs.toWkt() );
+    QgsDebugMsg( "destCrs " + mCanvas->mapRenderer()->destinationCrs().toWkt() );
     mCoordinateTransform.setSourceCrs( mCrs );
     mCoordinateTransform.setDestCRS( mCanvas->mapRenderer()->destinationCrs() );
Modified: trunk/qgis/src/providers/grass/qgsgrass.cpp
--- trunk/qgis/src/providers/grass/qgsgrass.cpp	2011-04-18 13:04:08 UTC (rev 15757)
+++ trunk/qgis/src/providers/grass/qgsgrass.cpp	2011-04-18 14:48:33 UTC (rev 15758)
@@ -38,6 +38,7 @@
 #ifndef _MSC_VER
 #include <unistd.h>
 #endif
+#include <grass/gprojects.h>
 #include <grass/Vect.h>
 #include <grass/version.h>
@@ -1160,6 +1161,47 @@
   return crs;
+QgsCoordinateReferenceSystem GRASS_EXPORT QgsGrass::crsDirect( QString gisdbase, QString location )
+  QString Wkt;
+  struct Cell_head cellhd;
+  QgsGrass::resetError();
+  QgsGrass::setLocation( gisdbase, location );
+  const char *oldlocale = setlocale( LC_NUMERIC, NULL );
+  setlocale( LC_NUMERIC, "C" );
+  try
+    G_get_default_window( &cellhd );
+    Q_UNUSED( e );
+    setlocale( LC_NUMERIC, oldlocale );
+    QgsDebugMsg( QString( "Cannot get default window: %1" ).arg( e.what() ) );
+    return QgsCoordinateReferenceSystem();
+  if ( cellhd.proj != PROJECTION_XY )
+    struct Key_Value *projinfo = G_get_projinfo();
+    struct Key_Value *projunits = G_get_projunits();
+    char *wkt = GPJ_grass_to_wkt( projinfo, projunits,  0, 0 );
+    Wkt = QString( wkt );
+    G_free( wkt );
+  QgsCoordinateReferenceSystem srs;
+  srs.createFromWkt( Wkt );
+  return srs;
 QgsRectangle GRASS_EXPORT QgsGrass::extent( QString gisdbase, QString location, QString mapset, QString map, MapType type )
   QgsDebugMsg( QString( "gisdbase = %1 location = %2" ).arg( gisdbase ).arg( location ) );
Modified: trunk/qgis/src/providers/grass/qgsgrass.h
--- trunk/qgis/src/providers/grass/qgsgrass.h	2011-04-18 13:04:08 UTC (rev 15757)
+++ trunk/qgis/src/providers/grass/qgsgrass.h	2011-04-18 14:48:33 UTC (rev 15758)
@@ -196,6 +196,9 @@
     // ! Get location projection
     static GRASS_EXPORT QgsCoordinateReferenceSystem crs( QString gisdbase, QString location );
+    // ! Get location projection calling directly GRASS library
+    static GRASS_EXPORT QgsCoordinateReferenceSystem crsDirect( QString gisdbase, QString location );
     // ! Get map extent
     static GRASS_EXPORT QgsRectangle extent( QString gisdbase, QString location,
         QString mapset, QString map, MapType type = None );
Modified: trunk/qgis/src/providers/grass/qgsgrassprovider.cpp
--- trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2011-04-18 13:04:08 UTC (rev 15757)
+++ trunk/qgis/src/providers/grass/qgsgrassprovider.cpp	2011-04-18 14:48:33 UTC (rev 15758)
@@ -1316,43 +1316,7 @@
 QgsCoordinateReferenceSystem QgsGrassProvider::crs()
-  QString Wkt;
-  struct Cell_head cellhd;
-  QgsGrass::resetError();
-  QgsGrass::setLocation( mGisdbase, mLocation );
-  const char *oldlocale = setlocale( LC_NUMERIC, NULL );
-  setlocale( LC_NUMERIC, "C" );
-  try
-    G_get_default_window( &cellhd );
-  catch ( QgsGrass::Exception &e )
-    Q_UNUSED( e );
-    setlocale( LC_NUMERIC, oldlocale );
-    QgsDebugMsg( QString( "Cannot get default window: %1" ).arg( e.what() ) );
-    return QgsCoordinateReferenceSystem();
-  if ( cellhd.proj != PROJECTION_XY )
-    struct Key_Value *projinfo = G_get_projinfo();
-    struct Key_Value *projunits = G_get_projunits();
-    char *wkt = GPJ_grass_to_wkt( projinfo, projunits,  0, 0 );
-    Wkt = QString( wkt );
-    G_free( wkt );
-  QgsCoordinateReferenceSystem srs;
-  srs.createFromWkt( Wkt );
-  return srs;
+  return QgsGrass::crs( mGisdbase, mLocation );
 int QgsGrassProvider::grassLayer()
More information about the QGIS-commit mailing list
