[QGIS Commit] r15763 - in trunk/qgis/src: app core/raster gui
providers/wms
svn_qgis at osgeo.org
Mon Apr 18 18:34:36 EDT 2011
Author: jef
Date: 2011-04-18 15:34:36 -0700 (Mon, 18 Apr 2011)
New Revision: 15763
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/core/raster/qgsrasterlayer.cpp
trunk/qgis/src/gui/qgsmessageviewer.cpp
trunk/qgis/src/providers/wms/qgswmsprovider.cpp
trunk/qgis/src/providers/wms/qgswmsprovider.h
improve wms error and progress reporting (fixes #1576)
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2011-04-18 20:54:50 UTC (rev 15762)
+++ trunk/qgis/src/app/qgisapp.cpp 2011-04-18 22:34:36 UTC (rev 15763)
@@ -5522,7 +5522,15 @@
QgsRasterLayer *rlayer = qobject_cast<QgsRasterLayer *>( layer );
if ( rlayer )
+ // connect up any request the raster may make to update the app progress
+ connect( rlayer, SIGNAL( drawingProgress( int, int ) ), this, SLOT( showProgress( int, int ) ) );
+ // connect up any request the raster may make to update the statusbar message
+ connect( rlayer, SIGNAL( statusChanged( QString ) ), this, SLOT( showStatusMessage( QString ) ) );
provider = rlayer->dataProvider();
if ( provider )
@@ -6196,14 +6204,6 @@
// register this layer with the central layers registry
QgsMapLayerRegistry::instance()->addMapLayer( theRasterLayer );
- // connect up any request the raster may make to update the app progress
- connect( theRasterLayer, SIGNAL( drawingProgress( int, int ) ),
- this, SLOT( showProgress( int, int ) ) );
- // connect up any request the raster may make to update the statusbar message
- connect( theRasterLayer, SIGNAL( statusChanged( QString ) ),
- this, SLOT( showStatusMessage( QString ) ) );
return true;
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-04-18 20:54:50 UTC (rev 15762)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp 2011-04-18 22:34:36 UTC (rev 15763)
@@ -155,13 +155,6 @@
// TODO: Connect signals from the dataprovider to the qgisapp
- // Do a passthrough for the status bar text
-#if 0
- connect(
- mDataProvider, SIGNAL( statusChanged( QString ) ),
-#endif
QgsDebugMsg( "(8 arguments) exiting." );
emit statusChanged( tr( "QgsRasterLayer created" ) );
@@ -2199,7 +2192,7 @@
if ( !loaded )
- QgsLogger::warning( "QgsRasterLayer::setDataProvider: Failed to load " );
+ QgsLogger::warning( "QgsRasterLayer::loadProviderLibrary: Failed to load " );
return NULL;
QgsDebugMsg( "Loaded data provider library" );
@@ -2223,7 +2216,7 @@
if ( !classFactory )
- QgsLogger::warning( "QgsRasterLayer::setDataProvider: Cannot resolve the classFactory function" );
+ QgsLogger::warning( "QgsRasterLayer::loadProvider: Cannot resolve the classFactory function" );
return NULL;
QgsDebugMsg( "Getting pointer to a mDataProvider object from the library" );
@@ -2237,7 +2230,7 @@
if ( !myDataProvider )
- QgsLogger::warning( "QgsRasterLayer::setDataProvider: Unable to instantiate the data provider plugin" );
+ QgsLogger::warning( "QgsRasterLayer::loadProvider: Unable to instantiate the data provider plugin" );
return NULL;
QgsDebugMsg( "Data driver created" );
@@ -2506,6 +2499,12 @@
this, SLOT( onProgress( int, double, QString ) )
+ // Do a passthrough for the status bar text
+ connect(
+ mDataProvider, SIGNAL( statusChanged( QString ) ),
+ this, SIGNAL( statusChanged( QString ) )
//mark the layer as valid
mValid = true;
@@ -2895,6 +2894,7 @@
return mDataProvider->subLayers();
void QgsRasterLayer::thumbnailAsPixmap( QPixmap * theQPixmap )
//TODO: This should be depreciated and a new function written that just returns a new QPixmap, it will be safer
Modified: trunk/qgis/src/gui/qgsmessageviewer.cpp
--- trunk/qgis/src/gui/qgsmessageviewer.cpp 2011-04-18 20:54:50 UTC (rev 15762)
+++ trunk/qgis/src/gui/qgsmessageviewer.cpp 2011-04-18 22:34:36 UTC (rev 15763)
@@ -63,9 +63,15 @@
void QgsMessageViewer::showMessage( bool blocking )
if ( blocking )
+ QApplication::setOverrideCursor( Qt::ArrowCursor );
exec();
+ QApplication::restoreOverrideCursor();
else
show();
void QgsMessageViewer::setTitle( const QString& title )
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.cpp
--- trunk/qgis/src/providers/wms/qgswmsprovider.cpp 2011-04-18 20:54:50 UTC (rev 15762)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.cpp 2011-04-18 22:34:36 UTC (rev 15763)
@@ -32,6 +32,7 @@
#include "qgsrectangle.h"
#include "qgscoordinatereferencesystem.h"
#include "qgsnetworkaccessmanager.h"
+#include <qgsmessageoutput.h>
#include <QNetworkRequest>
#include <QNetworkReply>
@@ -772,16 +773,35 @@
if ( !status.isNull() && status.toInt() >= 400 )
QVariant phrase = reply->attribute( QNetworkRequest::HttpReasonPhraseAttribute );
- mErrorFormat = "text/plain";
- mError = tr( "tile request err %1: %2" ).arg( status.toInt() ).arg( phrase.toString() );
- emit statusChanged( mError );
+ showMessageBox( tr( "Tile request error" ), tr( "Status: %1\nReason phrase: %2" ).arg( status.toInt() ).arg( phrase.toString() ) );
tileReplies.removeOne( reply );
reply->deleteLater();
return;
+ QString contentType = reply->header( QNetworkRequest::ContentTypeHeader ).toString();
+ QgsDebugMsg( "contentType: " + contentType );
+ if ( !contentType.startsWith( "image/" ) )
+ QByteArray text = reply->readAll();
+ if ( contentType == "text/xml" && parseServiceExceptionReportDom( text ) )
+ showMessageBox( mErrorCaption, mError );
+ else
+ showMessageBox( "Tile request error", tr( "response: %1" ).arg( QString::fromUtf8( text ) ) );
+ tileReplies.removeOne( reply );
+ reply->deleteLater();
+ return;
// only take results from current request number
if ( mTileReqNo == tileReqNo )
@@ -854,22 +874,41 @@
QVariant phrase = cacheReply->attribute( QNetworkRequest::HttpReasonPhraseAttribute );
- mError = tr( "map request error %1: %2" ).arg( status.toInt() ).arg( phrase.toString() );
+ showMessageBox( tr( "Map request error" ), tr( "Status: %1\nReason phrase: %2" ).arg( status.toInt() ).arg( phrase.toString() ) );
cacheReply->deleteLater();
cacheReply = 0;
return;
+ QString contentType = cacheReply->header( QNetworkRequest::ContentTypeHeader ).toString();
+ if ( contentType.startsWith( "image/" ) )
QImage myLocalImage = QImage::fromData( cacheReply->readAll() );
QPainter p( cachedImage );
p.drawImage( 0, 0, myLocalImage );
+ else
+ QByteArray text = cacheReply->readAll();
+ else
+ showMessageBox( tr( "Map request error" ), tr( "Response: %1" ).arg( QString::fromUtf8( text ) ) );
+ cacheReply->deleteLater();
+ cacheReply = 0;
+ return;
cacheReply = 0;
@@ -1015,12 +1054,16 @@
void QgsWmsProvider::capabilitiesReplyProgress( qint64 bytesReceived, qint64 bytesTotal )
- emit statusChanged( tr( "%1 of %2 bytes of capabilities downloaded." ).arg( bytesReceived ).arg( bytesTotal < 0 ? QString( "unknown number of" ) : QString::number( bytesTotal ) ) );
+ QString msg = tr( "%1 of %2 bytes of capabilities downloaded." ).arg( bytesReceived ).arg( bytesTotal < 0 ? QString( "unknown number of" ) : QString::number( bytesTotal ) );
+ QgsDebugMsg( msg );
+ emit statusChanged( msg );
void QgsWmsProvider::cacheReplyProgress( qint64 bytesReceived, qint64 bytesTotal )
- emit statusChanged( tr( "%1 of %2 bytes of map downloaded." ).arg( bytesReceived ).arg( bytesTotal < 0 ? QString( "unknown number of" ) : QString::number( bytesTotal ) ) );
+ QString msg = tr( "%1 of %2 bytes of map downloaded." ).arg( bytesReceived ).arg( bytesTotal < 0 ? QString( "unknown number of" ) : QString::number( bytesTotal ) );
bool QgsWmsProvider::parseCapabilitiesDom( QByteArray const &xml, QgsWmsCapabilitiesProperty& capabilitiesProperty )
@@ -2812,7 +2855,7 @@
QVariant redirect = mIdentifyReply->attribute( QNetworkRequest::RedirectionTargetAttribute );
if ( !redirect.isNull() )
- emit statusChanged( QString( "identify request redirected to %1" ).arg( redirect.toString() ) );
+ QgsDebugMsg( QString( "identify request redirected to %1" ).arg( redirect.toString() ) );
emit statusChanged( tr( "identify request redirected." ) );
mIdentifyReply->deleteLater();
@@ -2829,7 +2872,7 @@
QVariant phrase = mIdentifyReply->attribute( QNetworkRequest::HttpReasonPhraseAttribute );
+ mError = tr( "Map request error %1: %2" ).arg( status.toInt() ).arg( phrase.toString() );
mIdentifyResult = "";
@@ -2895,6 +2938,14 @@
+void QgsWmsProvider::showMessageBox( const QString& title, const QString& text )
+ QgsMessageOutput *message = QgsMessageOutput::createMessageOutput();
+ message->setTitle( title );
+ message->setMessage( text, QgsMessageOutput::MessageText );
+ message->showMessage();
* Class factory to return a pointer to a newly created
* QgsWmsProvider object
Modified: trunk/qgis/src/providers/wms/qgswmsprovider.h
--- trunk/qgis/src/providers/wms/qgswmsprovider.h 2011-04-18 20:54:50 UTC (rev 15762)
+++ trunk/qgis/src/providers/wms/qgswmsprovider.h 2011-04-18 22:34:36 UTC (rev 15763)
@@ -650,6 +650,8 @@
void tileReplyFinished();
private:
+ void showMessageBox( const QString& title, const QString& text );
* \brief Retrieve and parse the (cached) Capabilities document from the server
