[QGIS Commit] r15785 - trunk/qgis/i18n
svn_qgis at osgeo.org
Wed Apr 20 17:31:48 EDT 2011
Author: jef
Date: 2011-04-20 14:31:48 -0700 (Wed, 20 Apr 2011)
New Revision: 15785
trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2011-04-20 21:24:09 UTC (rev 15784)
+++ trunk/qgis/i18n/qgis_de.ts 2011-04-20 21:31:48 UTC (rev 15785)
@@ -1603,7 +1603,7 @@
</message>
<message>
<source>Select the mask file</source>
- <translation type="unfinished"></translation>
+ <translation>Maskendatei wählen</translation>
</message>
<message>
<source>Warning: CRS information for all raster in subfolders will be rewritten. Are you sure?</source>
@@ -1739,7 +1739,7 @@
</message>
<message>
<source>Select the input directory with files for convert</source>
+ <translation>Eingabeverzeichnis der zu konvertierenden Dateien wählen</translation>
</message>
<message>
<source>Convert paletted image to RGB</source>
@@ -1831,7 +1831,7 @@
<message>
<location filename="../python/plugins/GdalTools/tools/inOutSelector.ui" line="46"/>
<source>Select...</source>
- <translation type="unfinished">Wählen...</translation>
+ <translation>Wählen...</translation>
</message>
</context>
<context>
@@ -1992,7 +1992,7 @@
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="70"/>
<source>Clipping mode</source>
+ <translation>Ausschnittsmodus</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="76"/>
@@ -2005,7 +2005,7 @@
<location filename="../python/plugins/GdalTools/tools/widgetClipper.ui" line="126"/>
<location filename="../python/plugins/GdalTools/tools/widgetWarp.ui" line="181"/>
<source>Mask layer</source>
+ <translation>Maskenlayer</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetMerge.ui" line="87"/>
@@ -2084,7 +2084,7 @@
<message>
<location filename="../python/plugins/GdalTools/tools/widgetConvert.ui" line="82"/>
<source>Band to convert</source>
+ <translation>Umzuwandelnder Kanal</translation>
</message>
<message>
<location filename="../python/plugins/GdalTools/tools/widgetGrid.ui" line="38"/>
@@ -5650,7 +5650,7 @@
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1056"/>
<source>Cannot open GISRC file</source>
+ <translation>Kann GISRC-Datei nicht öffnen</translation>
</message>
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1076"/>
@@ -5660,12 +5660,12 @@
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1077"/>
<source>command: %1 %2</source>
+ <translation>Befehl: %1 %2</translation>
</message>
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1096"/>
<source>Cannot run module</source>
+ <translation>Kann Modul nicht ausführen</translation>
</message>
<message>
<location filename="../src/providers/grass/qgsgrass.cpp" line="1097"/>
@@ -17185,12 +17185,12 @@
<message>
<location filename="../src/providers/grass/qgsgrassrasterprovider.cpp" line="352"/>
<source>Out of extent</source>
+ <translation>Außerhalb der Grenzen</translation>
</message>
<message>
<location filename="../src/providers/grass/qgsgrassrasterprovider.cpp" line="356"/>
<source>null (no data)</source>
- <translation type="unfinished">Null (keine Daten)</translation>
+ <translation>Null (keine Daten)</translation>
</message>
</context>
<context>
@@ -31820,30 +31820,31 @@
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="786"/>
<source>Tile request error</source>
+ <translation>Tile-Anfragefehler</translation>
</message>
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="887"/>
<source>Status: %1
Reason phrase: %2</source>
+ <translation>Status: %1
+Grund: %2</translation>
</message>
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="805"/>
<source>response: %1</source>
+ <translation>Antwort: %1</translation>
</message>
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="912"/>
<source>Map request error</source>
+ <translation>Kartenanfragefehler</translation>
</message>
<message>
<source>Response: %1</source>
</message>
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="969"/>
@@ -31969,7 +31970,7 @@
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="2884"/>
<source>Map request error %1: %2</source>
+ <translation>Kartenanfragefehler %1: %2</translation>
</message>
<message>
<location filename="../src/providers/wms/qgswmsprovider.cpp" line="2334"/>
@@ -36157,7 +36158,7 @@
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="342"/>
<source>Rebuild topology of a vector in mapset</source>
+ <translation>Topologie eines Vektors des Mapsets neuberechnen</translation>
</message>
<message>
<location filename="../src/plugins/grass/grasslabels-i18n.cpp" line="343"/>
