[QGIS Commit] r15809 - in trunk/qgis/src: app app/legend core
providers/postgres
svn_qgis at osgeo.org
Fri Apr 22 10:02:32 EDT 2011
Author: jef
Date: 2011-04-22 07:02:32 -0700 (Fri, 22 Apr 2011)
New Revision: 15809
trunk/qgis/src/app/legend/qgslegend.cpp
trunk/qgis/src/app/qgsvectorlayerproperties.cpp
trunk/qgis/src/core/qgscoordinatetransform.cpp
trunk/qgis/src/core/qgsrectangle.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
improve handling of empty extents (fixes #2997)
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp 2011-04-22 14:00:10 UTC (rev 15808)
+++ trunk/qgis/src/app/legend/qgslegend.cpp 2011-04-22 14:02:32 UTC (rev 15809)
@@ -1805,6 +1805,11 @@
+ if( extent.isEmpty() )
+ return;
// Increase bounding box with 5%, so that layer is a bit inside the borders
extent.scale( 1.05 );
Modified: trunk/qgis/src/app/qgsvectorlayerproperties.cpp
--- trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-04-22 14:00:10 UTC (rev 15808)
+++ trunk/qgis/src/app/qgsvectorlayerproperties.cpp 2011-04-22 14:02:32 UTC (rev 15809)
@@ -907,44 +907,51 @@
// - for all smaller numbers let the OS decide which format to use (it will
// generally use non-scientific unless the number gets much less than 1).
- QString xMin, yMin, xMax, yMax;
- double changeoverValue = 99999; // The 'largest' 5 digit number
- if ( qAbs( myExtent.xMinimum() ) > changeoverValue )
+ if ( !myExtent.isEmpty() )
- xMin = QString( "%1" ).arg( myExtent.xMinimum(), 0, 'f', 2 );
+ QString xMin, yMin, xMax, yMax;
+ double changeoverValue = 99999; // The 'largest' 5 digit number
+ if ( qAbs( myExtent.xMinimum() ) > changeoverValue )
+ xMin = QString( "%1" ).arg( myExtent.xMinimum(), 0, 'f', 2 );
+ else
+ xMin = QString( "%1" ).arg( myExtent.xMinimum() );
+ if ( qAbs( myExtent.yMinimum() ) > changeoverValue )
+ yMin = QString( "%1" ).arg( myExtent.yMinimum(), 0, 'f', 2 );
+ else
+ yMin = QString( "%1" ).arg( myExtent.yMinimum() );
+ if ( qAbs( myExtent.xMaximum() ) > changeoverValue )
+ xMax = QString( "%1" ).arg( myExtent.xMaximum(), 0, 'f', 2 );
+ else
+ xMax = QString( "%1" ).arg( myExtent.xMaximum() );
+ if ( qAbs( myExtent.yMaximum() ) > changeoverValue )
+ yMax = QString( "%1" ).arg( myExtent.yMaximum(), 0, 'f', 2 );
+ else
+ yMax = QString( "%1" ).arg( myExtent.yMaximum() );
+ myMetadata += tr( "In layer spatial reference system units : " )
+ + tr( "xMin,yMin %1,%2 : xMax,yMax %3,%4" )
+ .arg( xMin ).arg( yMin ).arg( xMax ).arg( yMax );
else
- xMin = QString( "%1" ).arg( myExtent.xMinimum() );
+ myMetadata += tr( "In layer spatial reference system units : " ) + tr( "Empty" );
- if ( qAbs( myExtent.yMinimum() ) > changeoverValue )
- yMin = QString( "%1" ).arg( myExtent.yMinimum(), 0, 'f', 2 );
- else
- yMin = QString( "%1" ).arg( myExtent.yMinimum() );
- if ( qAbs( myExtent.xMaximum() ) > changeoverValue )
- xMax = QString( "%1" ).arg( myExtent.xMaximum(), 0, 'f', 2 );
- else
- xMax = QString( "%1" ).arg( myExtent.xMaximum() );
- if ( qAbs( myExtent.yMaximum() ) > changeoverValue )
- yMax = QString( "%1" ).arg( myExtent.yMaximum(), 0, 'f', 2 );
- else
- yMax = QString( "%1" ).arg( myExtent.yMaximum() );
- myMetadata += tr( "In layer spatial reference system units : " )
- + tr( "xMin,yMin %1,%2 : xMax,yMax %3,%4" )
- .arg( xMin ).arg( yMin ).arg( xMax ).arg( yMax );
myMetadata += "</td></tr>";
//extents in project cs
Modified: trunk/qgis/src/core/qgscoordinatetransform.cpp
--- trunk/qgis/src/core/qgscoordinatetransform.cpp 2011-04-22 14:00:10 UTC (rev 15808)
+++ trunk/qgis/src/core/qgscoordinatetransform.cpp 2011-04-22 14:02:32 UTC (rev 15809)
@@ -350,7 +350,7 @@
// This is done by looking at a number of points spread evenly
// across the rectangle
- if ( mShortCircuit || !mInitialisedFlag )
+ if ( mShortCircuit || !mInitialisedFlag || rect.isEmpty() )
return rect;
static const int numP = 8;
Modified: trunk/qgis/src/core/qgsrectangle.cpp
--- trunk/qgis/src/core/qgsrectangle.cpp 2011-04-22 14:00:10 UTC (rev 15808)
+++ trunk/qgis/src/core/qgsrectangle.cpp 2011-04-22 14:02:32 UTC (rev 15809)
@@ -229,17 +229,18 @@
// Return a string representation of the rectangle with high precision
QString QgsRectangle::toString( int thePrecision ) const
+ QString rep;
+ if ( isEmpty() )
+ rep = "Empty";
+ else
+ rep = QString( "%1,%2 : %3,%4" )
+ .arg( xmin, 0, 'f', thePrecision )
+ .arg( ymin, 0, 'f', thePrecision )
+ .arg( xmax, 0, 'f', thePrecision )
+ .arg( ymax, 0, 'f', thePrecision );
- QString rep = QString::number( xmin, 'f', thePrecision ) +
- QString( "," ) +
- QString::number( ymin, 'f', thePrecision ) +
- QString( " : " ) +
- QString::number( xmax, 'f', thePrecision ) +
- QString( "," ) +
- QString::number( ymax, 'f', thePrecision ) ;
-#ifdef QGISDEBUG
-// QgsDebugMsg(QString("Extents : %1").arg(rep));
-#endif
+ QgsDebugMsgLevel( QString( "Extents : %1" ).arg( rep ), 4 );
return rep;
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-04-22 14:00:10 UTC (rev 15808)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-04-22 14:02:32 UTC (rev 15809)
@@ -438,12 +438,19 @@
if ( !whereClause.isEmpty() )
query += QString( " where %1" ).arg( whereClause );
- return connectionRO->openCursor( cursorName, query );
+ if ( !connectionRO->openCursor( cursorName, query ) )
+ // reloading the fields might help next time around
+ rewind();
+ return false;
catch ( PGFieldNotFound )
return false;
+ return true;
bool QgsPostgresProvider::getFeature( PGresult *queryResult, int row, bool fetchGeometry,
@@ -2937,25 +2944,37 @@
if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
- sql = QString( "select %1(%2,%3,%4)" )
- .arg( connectionRO->majorVersion() < 2 ? "estimated_extent" : "st_estimated_extent" )
- .arg( quotedValue( mSchemaName ) )
- .arg( quotedValue( mTableName ) )
- .arg( quotedValue( geometryColumn ) );
+ sql = QString( "select reltuples::int from pg_catalog.pg_class where oid=regclass(%1)::oid" ).arg( quotedValue( mQuery ) );
result = connectionRO->PQexec( sql );
- if ( PQresultStatus( result ) == PGRES_TUPLES_OK && PQntuples( result ) == 1 )
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK &&
+ PQntuples( result ) == 1 &&
+ QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toLong() > 0 )
- ext = PQgetvalue( result, 0, 0 );
+ sql = QString( "select %1(%2,%3,%4)" )
+ .arg( connectionRO->majorVersion() < 2 ? "estimated_extent" : "st_estimated_extent" )
+ .arg( quotedValue( mSchemaName ) )
+ .arg( quotedValue( mTableName ) )
+ .arg( quotedValue( geometryColumn ) );
+ result = connectionRO->PQexec( sql );
+ if ( PQresultStatus( result ) == PGRES_TUPLES_OK && PQntuples( result ) == 1 )
+ ext = PQgetvalue( result, 0, 0 );
- // fix for what might be a postgis bug: when the extent crosses the
- // dateline extent() returns -180 to 180 (which appears right), but
- // estimated_extent() returns eastern bound of data (>-180) and
- // 180 degrees.
- if ( !ext.startsWith( "-180 " ) && ext.contains( ",180 " ) )
- ext.clear();
+ // fix for what might be a postgis bug: when the extent crosses the
+ // dateline extent() returns -180 to 180 (which appears right), but
+ // estimated_extent() returns eastern bound of data (>-180) and
+ // 180 degrees.
+ if ( !ext.startsWith( "-180 " ) && ext.contains( ",180 " ) )
+ ext.clear();
+ else
+ // no features => ignore estimated extent
+ ext.clear();
else
@@ -3322,8 +3341,8 @@
if ( value.isNull() )
return "NULL";
- // FIXME: use PQescapeStringConn
value.replace( "'", "''" );
+ value.replace( "\\\"", "\\\\\"" );
return value.prepend( "'" ).append( "'" );
@@ -3482,7 +3501,7 @@
return sqlWhereClause;
-PGconn * QgsPostgresProvider::pgConnection()
+PGconn *QgsPostgresProvider::pgConnection()
connectRW();
return connectionRW->pgConnection();
