[QGIS Commit] r15814 - in trunk/qgis/src: core providers/spatialite
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 23 12:21:12 EDT 2011
Author: esseffe
Date: 2011-04-23 09:21:12 -0700 (Sat, 23 Apr 2011)
New Revision: 15814
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
fixing several issues related to SpatiaLite 3D Geometries
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2011-04-22 22:28:32 UTC (rev 15813)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2011-04-23 16:21:12 UTC (rev 15814)
@@ -1473,7 +1473,7 @@
             ptr += 2 * sizeof( double ) * ( vertexnr - pointindex );
             if ( hasZValue )
-              ptr += 3 * sizeof( double ) * ( vertexnr - pointindex );
+              ptr += sizeof( double ) * ( vertexnr - pointindex );
             memcpy( ptr, &x, sizeof( double ) );
             ptr += sizeof( double );
Modified: trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp
--- trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2011-04-22 22:28:32 UTC (rev 15813)
+++ trunk/qgis/src/providers/spatialite/qgsspatialiteprovider.cpp	2011-04-23 16:21:12 UTC (rev 15814)
@@ -402,12 +402,16 @@
             if ( sqlite3_column_type( stmt, ic ) == SQLITE_BLOB )
+              unsigned char *featureGeom = NULL;
+              size_t geom_size = 0;
               const void *blob = sqlite3_column_blob( stmt, ic );
               size_t blob_size = sqlite3_column_bytes( stmt, ic );
-              unsigned char *featureGeom = new unsigned char[blob_size + 1];
-              memset( featureGeom, '\0', blob_size + 1 );
-              memcpy( featureGeom, blob, blob_size );
-              feature.setGeometryAndOwnership( featureGeom, blob_size + 1 );
+              convertToGeosWKB ( (const unsigned char *)blob, blob_size,
+                                 &featureGeom, &geom_size );
+              if ( featureGeom )
+                   feature.setGeometryAndOwnership( featureGeom, geom_size );
+              else
+                   feature.setGeometryAndOwnership( 0, 0 );
             else
@@ -592,6 +596,7 @@
             break;
         case GAIA_LINESTRING:
             points = gaiaImport32 ( p_in, little_endian, endian_arch );
+            gsize += 4;
             switch ( nDims )
                 case GAIA_XY_Z_M:
@@ -609,10 +614,12 @@
         case GAIA_POLYGON:
             rings = gaiaImport32 ( p_in, little_endian, endian_arch );
             p_in += 4;
+            gsize += 4;
             for ( ib = 0; ib < rings; ib++ )
                 p_in += 4;
+                gsize += 4;
                 switch ( nDims )
                     case GAIA_XY_Z_M:
@@ -761,6 +768,7 @@
             break;
         case GEOS_3D_LINESTRING:
+            gsize += 4;
             switch ( nDims )
                 case GAIA_XY_Z_M:
@@ -778,10 +786,12 @@
         case GEOS_3D_POLYGON:
             p_in += 4;
+            gsize += 4;
                 p_in += 4;
+                gsize += 4;
                 switch ( nDims )
                     case GAIA_XY_Z_M:
@@ -933,7 +943,7 @@
     else
         return;
-    if ( gDims == 2 && nDims == 2 )
+    if ( gDims == 2 && nDims == GAIA_XY )
     // already 2D: simply copying is required
         unsigned char *wkbGeom = new unsigned char[blob_size + 1];
@@ -2148,16 +2158,19 @@
         case GAIA_LINESTRINGM:
         case GAIA_LINESTRINGZM:
+            gsize += 4;
             gsize += points * ( 3 * sizeof(double) );
             break;
         case GAIA_POLYGONZ:
         case GAIA_POLYGONM:
             p_in += 4;
+            gsize += 4;
                 p_in += 4;
+                gsize += 4;
                 p_in += points * ( 3 * sizeof(double) );
@@ -2165,10 +2178,12 @@
         case GAIA_POLYGONZM:
             p_in += 4;
+            gsize += 4;
                 p_in += 4;
+                gsize += 4;
                 p_in += points * ( 4 * sizeof(double) );
@@ -2473,7 +2488,7 @@
                     gaiaExport64 ( p_out, coord, 1, endian_arch );	// Z
                     p_in += sizeof(double);
                     p_out += sizeof(double);
-                    if (type == GAIA_LINESTRINGZM)
+                    if (type == GAIA_MULTILINESTRINGZM)
@@ -2552,7 +2567,7 @@
-                        if (type == GAIA_POLYGONZM)
+                        if (type == GAIA_MULTIPOLYGONZM)
@@ -2619,7 +2634,7 @@
-                        if (type == GAIA_POINTZM)
+                        if (type2 == GAIA_POINTZM)
                         break;
@@ -2662,7 +2677,7 @@
+                            if (type2 == GAIA_LINESTRINGZM)
                         break;
@@ -2719,7 +2734,7 @@
+                                if (type2 == GAIA_POLYGONZM)
More information about the QGIS-commit mailing list
