[QGIS Commit] r15816 - trunk/qgiswebclient/js
svn_qgis at osgeo.org
Sun Apr 24 07:59:39 EDT 2011
Author: pcav
Date: 2011-04-24 04:59:39 -0700 (Sun, 24 Apr 2011)
New Revision: 15816
trunk/qgiswebclient/js/Translations.js
ES, FR, IT translation - first run
Modified: trunk/qgiswebclient/js/Translations.js
--- trunk/qgiswebclient/js/Translations.js 2011-04-23 19:55:59 UTC (rev 15815)
+++ trunk/qgiswebclient/js/Translations.js 2011-04-24 11:59:39 UTC (rev 15816)
@@ -1,66 +1,131 @@
//list of available languages
var availableLanguages = new Array();
availableLanguages["en"] = {names:[], translator:"Andreas Neumann"}; //a(dot)neumann(at)carto(dot)net
+availableLanguages["es"] = {names:[], translator:"Samuel Mesa"}; //
availableLanguages["de"] = {names:[], translator:"Andreas Neumann"}; //a(dot)neumann(at)carto(dot)net
+availableLanguages["fr"] = {names:[], translator:"Mayeul Kauffmann"}; //mayeul(_dot_)kauffmann(at)free(dot)fr
+availableLanguages["it"] = {names:[], translator:"Paolo Cavallini, Faunalia"}; //cavallini(at)faunalia(dot)it
+availableLanguages["pt_PT"] = {names:[], translator:"Giovanni Manghi, Faunalia"}; //giovanni(dot)manghi(at)faunalia(dot)pt
//translations of languages
-//english; first language index is fixed, second variable
-availableLanguages["en"].names["en"] = "english";
+// first language index is fixed, second variable
+// The string is the name of the first language translated in the second language.
+//English;
+availableLanguages["en"].names["en"] = "English";
availableLanguages["en"].names["de"] = "Englisch";
-//german
-availableLanguages["de"].names["en"] = "german";
+availableLanguages["en"].names["es"] = "Inglés";
+availableLanguages["en"].names["fr"] = "Anglais";
+availableLanguages["en"].names["it"] = "Inglese";
+availableLanguages["en"].names["pt_PT"] = "Anglais";
+//German
+availableLanguages["de"].names["en"] = "German";
availableLanguages["de"].names["de"] = "Deutsch";
+availableLanguages["de"].names["es"] = "Alemán";
+availableLanguages["de"].names["fr"] = "Allemand";
+availableLanguages["de"].names["it"] = "Tedesco";
+availableLanguages["de"].names["pt_PT"] = "Anglais";
+//French
+availableLanguages["fr"].names["en"] = "French";
+availableLanguages["fr"].names["de"] = "Französisch";
+availableLanguages["fr"].names["es"] = "Francés";
+availableLanguages["fr"].names["fr"] = "Français";
+availableLanguages["fr"].names["it"] = "Francese";
+availableLanguages["fr"].names["pt_PT"] = "Anglais";
+//Italian
+availableLanguages["it"].names["en"] = "Italian";
+availableLanguages["it"].names["de"] = "Italienisch";
+availableLanguages["it"].names["es"] = "Inglés";
+availableLanguages["it"].names["fr"] = "Italien";
+availableLanguages["it"].names["it"] = "Italiano";
+availableLanguages["it"].names["pt_PT"] = "Anglais";
+//Portuguese
+availableLanguages["pt_PT"].names["en"] = "English";
+availableLanguages["pt_PT"].names["de"] = "Englisch";
+availableLanguages["pt_PT"].names["es"] = "Inglés";
+availableLanguages["pt_PT"].names["fr"] = "Anglais";
+availableLanguages["pt_PT"].names["it"] = "Portoghese";
+availableLanguages["pt_PT"].names["pt_PT"] = "Anglais";
Status messages
//map loading string displayed when starting the map application
var mapAppLoadingString = new Array();
-mapAppLoadingString["en"] = "Loading map application ...";
-mapAppLoadingString["de"] = "Kartenapplikation wird geladen ...";
+mapAppLoadingString["en"] = "Loading map application...";
+mapAppLoadingString["es"] = "Cargando aplicación de mapa...";
+mapAppLoadingString["de"] = "Kartenapplikation wird geladen...";
+mapAppLoadingString["fr"] = "Chargement de l'application cartographique...";
+mapAppLoadingString["it"] = "Caricamento dell'applicazione cartografica...";
//indicating that map app was loaded and we are now loading the map
var mapLoadingString = new Array();
-mapLoadingString["en"] = "Loading Map ...";
-mapLoadingString["de"] = "Karte wird geladen ...";
+mapLoadingString["en"] = "Loading Map...";
+mapLoadingString["es"] = "Cargando mapa...";
+mapLoadingString["de"] = "Karte wird geladen...";
+mapLoadingString["fr"] = "Chargement de la carte...";
+mapLoadingString["it"] = "Caricamento della mappa...";
//mode string for navigation
var modeNavigationString = new Array();
modeNavigationString["en"] = "Mode: navigation. Shift/rectangle or mouse wheel for zooming.";
+modeNavigationString["es"] = "Modo: navegación. Shift/rectángulo o rueda del ratón para Zoom.";
modeNavigationString["de"] = "Modus: Navigation. Shift/Rechteck aufziehen oder Mausrad zum zoomen.";
+modeNavigationString["fr"] = "Mode: navigation. Majuscule+tracer un rectangle ou roulette de la souris pour zoomer.";
+modeNavigationString["it"] = "Modalità: navigazione. Shift+rettangolo o rotella del mouse per zommare.";
//mode string for rectangle zoom
var modeZoomRectangle = new Array();
modeZoomRectangle["en"] = "Mode: zoom with rectangle. Draw rectangle over region you wish to zoom in.";
-modeZoomRectangle["de"] = "Modus: Zoom mit Rechteck. Ziehen Sie die gewünschte Region auf.";
+modeZoomRectangle["es"] = "Modo: zoom con rectángulo. Dibujar el rectángulo sobre la región para acercar.";
+modeZoomRectangle["de"] = "Modus: Zoom mit Rechteck. Ziehen Sie die gewünschte Region auf.";
+modeZoomRectangle["fr"] = "Mode: zoom rectangle. Dessiner un rectangle sur la zone sur laquelle zoomer.";
+modeZoomRectangle["it"] = "Modalità: zoom con rettangolo. Disegnare un rettangolo sulla zona da ingrandire.";
//mode string for attribute data detailed
var modeObjectIdentificationString = new Array();
-modeObjectIdentificationString["en"] = "Mode: object identification. attribute data view with mouse click.";
-modeObjectIdentificationString["de"] = "Modus: Objektidentifikation. Attributdatenabfrage über Mausklick.";
+modeObjectIdentificationString["en"] = "Mode: object identification. View attribute data with mouse click.";
+modeObjectIdentificationString["es"] = "Modo: Identificación de objeto. Ver atributos de datos con el click del ratón.";
+modeObjectIdentificationString["de"] = "Modus: Objektidentifikation. Attributdatenabfrage über Mausklick.";
+modeObjectIdentificationString["fr"] = "Mode: identification d'entité. Identifier une entité en cliquant.";
+modeObjectIdentificationString["it"] = "Modalità: identificazione di elementi. Identificare un elemento tramite il click.";
//mode string for map tips (display main attribute with tooltips)
var modeMapTipsString = new Array();
modeMapTipsString["en"] = "Mode: MapTips. Display on mouse over with Tooltips.";
-modeMapTipsString["de"] = "Modus: MapTips. Anzeige mit Mouseover über tooltips.";
+modeMapTipsString["es"] = "Modo: MapTips. Desplegar textos emergentes con el cursor del mouse.";
+modeMapTipsString["de"] = "Modus: MapTips. Anzeige mit Mouseover über tooltips.";
+modeMapTipsString["fr"] = "Mode: infobulles. Montrer une infobulle sous le curseur de la souris.";
+modeMapTipsString["it"] = "Modalità: suggerimenti. Mostrare i suggerimenti con il cursore del mouse.";
//mode measure distance
var modeMeasureDistanceString = new Array();
modeMeasureDistanceString["en"] = "Mode: measure distance. Finish with double click.";
+modeMeasureDistanceString["es"] = "Modo: medir distancia. Finalizar con doble click.";
modeMeasureDistanceString["de"] = "Modus: Distanzmessung. Beenden mit Doppelklick.";
+modeMeasureDistanceString["fr"] = "Mode: mesure de distance. Terminer avec un double-clic.";
+modeMeasureDistanceString["it"] = "Modalità: misura delle distanze. Interrompere con un doppio clic.";
//mode measure area
var modeMeasureAreaString = new Array();
modeMeasureAreaString["en"] = "Mode: measure area. Finish with double click.";
-modeMeasureAreaString["de"] = "Modus: Flächenmessung. Beenden mit Doppelklick.";
+modeMeasureAreaString["es"] = "Modo: medir área. Finalizar con doble click.";
+modeMeasureAreaString["de"] = "Modus: Flächenmessung. Beenden mit Doppelklick.";
+modeMeasureAreaString["fr"] = "Mode: mesure de surface. Terminer avec un double-clic.";
+modeMeasureAreaString["it"] = "Modalità: misura delle superifici. Interrompere con un doppio clic.";
//mode printing
var modePrintingString = new Array();
-modePrintingString["en"] = "Mode: printing. Move or rotate the map extent. Print with the 'Print'-Button.";
-modePrintingString["de"] = "Modus: Drucken. Verschieben oder Rotieren Sie den Kartenausschnitt. Drucken mit 'Drucken'-Knopf.";
+modePrintingString["en"] = "Mode: printing. Move or rotate the map extent. Print with the 'Print'-Button.";
+modePrintingString["es"] = "Modo: imprimir. mueva o rote la extensión del mapa. Imprima con el botón 'imprimir'.";
+modePrintingString["de"] = "Modus: Drucken. Verschieben oder Rotieren Sie den Kartenausschnitt. Drucken mit 'Drucken'-Knopf.";
+modePrintingString["fr"] = "Mode: impression. Déplacer ou faire tourner la zone d'impression. Imprimer avec le bouton 'Imprimer'.";
+modePrintingString["it"] = "Modalità: stampa. Spostare o ruotare la zona di stampa. Stampare con il pulsante 'Stamap'.";
GUI stuff
@@ -68,98 +133,154 @@
//title of panel on the left
var leftPanelTitleString = new Array();
leftPanelTitleString["en"] = "Info and Tools";
+leftPanelTitleString["es"] = "Información y herramientas";
leftPanelTitleString["de"] = "Infos und Werkzeuge";
+leftPanelTitleString["fr"] = "Infos et outils";
+leftPanelTitleString["it"] = "Info e strumenti";
//title of map layer tree
var layerTreeTitleString = new Array();
layerTreeTitleString["en"] = "Map Layers";
+layerTreeTitleString["es"] = "Capas";
layerTreeTitleString["de"] = "Kartenebenen";
+layerTreeTitleString["fr"] = "Couches";
+layerTreeTitleString["it"] = "Layer";
//title of legend tab
var legendTabTitleString = new Array();
legendTabTitleString["en"] = "Legend";
+legendTabTitleString["es"] = "Leyenda";
legendTabTitleString["de"] = "Legende";
+legendTabTitleString["fr"] = "Légende";
+legendTabTitleString["it"] = "Legenda";
//title of metadata tab
var metadataTabTitleString = new Array();
metadataTabTitleString["en"] = "Metadata";
+metadataTabTitleString["es"] = "Metadatos";
metadataTabTitleString["de"] = "Metadaten";
+metadataTabTitleString["fr"] = "Métadonnées";
+metadataTabTitleString["it"] = "Metadati";
//label in main toolbar for object identification
var objectIdentificationTextLabel = new Array();
objectIdentificationTextLabel["en"] = "Object identification: ";
+objectIdentificationTextLabel["es"] = "Identificación de objetos: ";
objectIdentificationTextLabel["de"] = "Objektdentifikation: ";
+objectIdentificationTextLabel["fr"] = "Identification d'entité: ";
+objectIdentificationTextLabel["it"] = "Identificazione di entit&aagrave;: ";
//Coordinate text label (coordinate display in bottom toolbar of main map window)
var coordinateTextLabel = new Array();
coordinateTextLabel["en"] = "Coordinate:";
+coordinateTextLabel["es"] = "Coordenadas:";
coordinateTextLabel["de"] = "Koordinate:";
+coordinateTextLabel["fr"] = "Coordonnées:";
+coordinateTextLabel["it"] = "Coordinate:";
//title of attribute data tree
var attributeDataTreeTitleString = new Array();
attributeDataTreeTitleString["en"] = "Attribute Data";
+attributeDataTreeTitleString["es"] = "Atributos de datos";
attributeDataTreeTitleString["de"] = "Attributdaten";
+attributeDataTreeTitleString["fr"] = "Attributs";
+attributeDataTreeTitleString["it"] = "Attributi";
var attributeFeatureWithString = new Array();
attributeFeatureWithString["en"] = "Feature with ID:";
+attributeFeatureWithString["es"] = "Elemento con identificador: ";
attributeFeatureWithString["de"] = "Feature mit ID:";
+attributeFeatureWithString["fr"] = "Entité avec l'identifiant ";//intentionally left with no colon
+attributeFeatureWithString["it"] = "Elemento con ID ";//intentionally left with no colon
-//search
+//search
var searchFieldDefaultTextString = new Array();
searchFieldDefaultTextString["en"] = "Search (addresses, parcel-nrs, names, etc.)";
+searchFieldDefaultTextString["es"] = "Buscar (nombres, etc.)";
searchFieldDefaultTextString["de"] = "Suche (Adressen, Parzellenr, Flurnamen, etc.)";
+searchFieldDefaultTextString["fr"] = "Chercher (adresses, n° de parcelles, noms, etc.)";
+searchFieldDefaultTextString["it"] = "Ricerca (indirizzi, n° delle particelle, nomi, ecc.)";
//map tips no result
var mapTipsNoResultString = new Array();
mapTipsNoResultString["en"] = "No Result";
+mapTipsNoResultString["es"] = "Sin resultados";
mapTipsNoResultString["de"] = "Kein Resultat";
+mapTipsNoResultString["fr"] = "Pas de résultat";
+mapTipsNoResultString["it"] = "Nessun risultato";
//print settings toolbar title
var printSettingsToolbarTitleString = new Array();
printSettingsToolbarTitleString["en"] = "Print Settings";
+printSettingsToolbarTitleString["es"] = "Configuración de impresión";
printSettingsToolbarTitleString["de"] = "Druckeinstellungen";
+printSettingsToolbarTitleString["fr"] = "Configuration de l'impression";
+printSettingsToolbarTitleString["it"] = "Configurazione della stampa";
//print rotation text label
var printSettingsRotationTextlabelString = new Array();
printSettingsRotationTextlabelString["en"] = "Rotation: ";
+printSettingsRotationTextlabelString["es"] = "Rotación: ";
printSettingsRotationTextlabelString["de"] = "Rotation: ";
+printSettingsRotationTextlabelString["fr"] = "Rotation: ";
+printSettingsRotationTextlabelString["it"] = "Rotazione: ";
//print button text
var printButtonTextString = new Array();
printButtonTextString["en"] = "Print";
+printButtonTextString["es"] = "Imprimir";
printButtonTextString["de"] = "Drucken";
+printButtonTextString["fr"] = "Imprimer";
+printButtonTextString["it"] = "Stampa";
//print cancel button text
var printCancelButtonTextString = new Array();
printCancelButtonTextString["en"] = "Cancel";
+printCancelButtonTextString["es"] = "Cancelar";
printCancelButtonTextString["de"] = "Abbrechen";
+printCancelButtonTextString["fr"] = "Annuler";
+printCancelButtonTextString["it"] = "Annullare";
//objectIdentificationModeStrings
var objectIdentificationModeString = new Array();
objectIdentificationModeString["topMostHit"] = new Array();
objectIdentificationModeString["topMostHit"]["en"] = "Topmost hit";
+objectIdentificationModeString["topMostHit"]["es"] = "La capa superior";
objectIdentificationModeString["topMostHit"]["de"] = "Oberster Treffer";
+objectIdentificationModeString["topMostHit"]["fr"] = "Couche la plus haute";
+objectIdentificationModeString["topMostHit"]["it"] = "Layer in alto";
objectIdentificationModeString["allLayers"] = new Array();
objectIdentificationModeString["allLayers"]["en"] = "All layers";
+objectIdentificationModeString["allLayers"]["es"] = "Todas las capas";
objectIdentificationModeString["allLayers"]["de"] = "Alle Ebenen";
+objectIdentificationModeString["allLayers"]["fr"] = "Toutes les couches";
+objectIdentificationModeString["allLayers"]["it"] = "Toutti i layer";
objectIdentificationModeString["activeLayers"] = new Array();
objectIdentificationModeString["activeLayers"]["en"] = "Active Layer";
+objectIdentificationModeString["activeLayers"]["es"] = "Capa activa";
objectIdentificationModeString["activeLayers"]["de"] = "Aktive Ebene";
+objectIdentificationModeString["activeLayers"]["fr"] = "Couche active";
+objectIdentificationModeString["activeLayers"]["it"] = "Layer attivo";
//measure distance result prefix
var measureDistanceResultPrefixString = new Array();
measureDistanceResultPrefixString["en"] = "Distance";
+measureDistanceResultPrefixString["es"] = "Distancia";
measureDistanceResultPrefixString["de"] = "Distanz";
+measureDistanceResultPrefixString["fr"] = "Distance";
+measureDistanceResultPrefixString["it"] = "Distanza";
//distance prefix for result:
var measureAreaResultPrefixString = new Array();
measureAreaResultPrefixString["en"] = "Area";
-measureAreaResultPrefixString["de"] = "Fläche";
+measureAreaResultPrefixString["es"] = "Área";
+measureAreaResultPrefixString["de"] = "Fläche";
+measureAreaResultPrefixString["fr"] = "Surface";
+measureAreaResultPrefixString["it"] = "Area";
Tooltips
@@ -167,122 +288,189 @@
//zoom rectangle tooltip
var zoomRectangleTooltipString = new Array();
zoomRectangleTooltipString["en"] = "Zoom with rectangle";
+zoomRectangleTooltipString["es"] = "Zoom con rectángulo";
zoomRectangleTooltipString["de"] = "Zoom Rechteck aufziehen";
+zoomRectangleTooltipString["fr"] = "Zoomer sur un rectangle";
+zoomRectangleTooltipString["it"] = "Zoom su rettangolo";
//zoom to full view
var zoomFullViewTooltipString = new Array();
zoomFullViewTooltipString["en"] = "Zoom to the maximum map extent";
+zoomFullViewTooltipString["es"] = "Zoom a la máxima extensión";
zoomFullViewTooltipString["de"] = "Zoom zum maximalen Kartenausschnitt";
+zoomFullViewTooltipString["fr"] = "Zoomer sur l'étendue complète de la carte";
+zoomFullViewTooltipString["it"] = "Zoom all'estensione massima";
//navigation history backward
var navigationHistoryBackwardTooltipString = new Array();
navigationHistoryBackwardTooltipString["en"] = "Navigation history backward";
-navigationHistoryBackwardTooltipString["de"] = "Navigationshistorie zurück";
+navigationHistoryBackwardTooltipString["es"] = "Navegación zoom anterior";
+navigationHistoryBackwardTooltipString["de"] = "Navigationshistorie zurück";
+navigationHistoryBackwardTooltipString["fr"] = "Zone précédente dans l'historique";
+navigationHistoryBackwardTooltipString["it"] = "Inquadramento precedente";
//navigation history forward
var navigationHistoryForwardTooltipString = new Array();
navigationHistoryForwardTooltipString["en"] = "Navigation history forward";
-navigationHistoryForwardTooltipString["de"] = "Navigationshistorie vorwärts";
+navigationHistoryForwardTooltipString["es"] = "Navegación zoom posterior";
+navigationHistoryForwardTooltipString["de"] = "Navigationshistorie vorwärts";
+navigationHistoryForwardTooltipString["fr"] = "Zone suivante dans l'historique";
+navigationHistoryForwardTooltipString["it"] = "Inquadramento successivo";
//discrete zoom in button above zoom slider
var zoomInTooltipString = new Array();
zoomInTooltipString["en"] = "Zoom in (discrete step)";
+zoomInTooltipString["es"] = "Acercar";
zoomInTooltipString["de"] = "Einzoomen (eine Stufe)";
+zoomInTooltipString["fr"] = "Zoom avant";
+zoomInTooltipString["it"] = "Ingrandisci";
var zoomOutTooltipString = new Array();
zoomOutTooltipString["en"] = "Zoom out (discrete step)";
+zoomOutTooltipString["es"] = "Alejar";
zoomOutTooltipString["de"] = "Rauszoomen (eine Stufe)";
+zoomOutTooltipString["fr"] = "Zoom arrière";
+zoomOutTooltipString["it"] = "Rimpicciolisci";
//object identification tooltip
var objIdentificationTooltipString = new Array();
objIdentificationTooltipString["en"] = "Object identification (attribute data)";
+objIdentificationTooltipString["es"] = "Indentificación de objeto (atributos de datos)";
objIdentificationTooltipString["de"] = "Objektidentifizierung (Attributdaten)";
+objIdentificationTooltipString["fr"] = "Identification d'entité (attributs)";
+objIdentificationTooltipString["it"] = "Identificazione di oggetti (attributi)";
-//MapTips tooltip
+//MapTips tooltip // Those were with simple quotes?!
var mapTipsTooltipString = new Array();
-mapTipsTooltipString["en"] = 'Display MapTips (attribute data)';
-mapTipsTooltipString["de"] = 'MapTips anzeigen (Attributdaten)';
+mapTipsTooltipString["en"] = "Display MapTips (attribute data)";
+mapTipsTooltipString["es"] = "Desplegar textos emergentos (atributos de datos)";
+mapTipsTooltipString["de"] = "MapTips anzeigen (Attributdaten)";
+mapTipsTooltipString["fr"] = "Afficher les infobulles (attributs)";
+mapTipsTooltipString["it"] = "Mostrare leinformazioni (attributi)";
//Measure Distance
var measureDistanceTooltipString = new Array();
measureDistanceTooltipString["en"] = "Measure distance";
+measureDistanceTooltipString["es"] = "Medir distancia";
measureDistanceTooltipString["de"] = "Distanz messen";
+measureDistanceTooltipString["fr"] = "Mesurer une distance";
+measureDistanceTooltipString["it"] = "Misura distanza";
//Measure Area
var measureAreaTooltipString = new Array();
measureAreaTooltipString["en"] = "Measure area";
-measureAreaTooltipString["de"] = "Fläche messen";
+measureAreaTooltipString["es"] = "Medir área";
+measureAreaTooltipString["de"] = "Fläche messen";
+measureDistanceTooltipString["fr"] = "Mesurer une surface";
+measureDistanceTooltipString["it"] = "Misura superficie";
//Print Map
var printMapTooltipString = new Array();
printMapTooltipString["en"] = "Print Map";
+printMapTooltipString["es"] = "Imprimir mapa";
printMapTooltipString["de"] = "Karte drucken";
+printMapTooltipString["fr"] = "Imprimer la carte";
+printMapTooltipString["it"] = "Stampa la mappa";
//Reset Search Field
var resetSearchFieldTooltipString = new Array();
resetSearchFieldTooltipString["en"] = "Reset/empty Searchfield";
-resetSearchFieldTooltipString["de"] = "Suchfeld zurücksetzen";
+resetSearchFieldTooltipString["es"] = "Limpiar campo de búsqueda";
+resetSearchFieldTooltipString["de"] = "Suchfeld zurücksetzen";
+resetSearchFieldTooltipString["fr"] = "Réinitialiser la recherche";
+resetSearchFieldTooltipString["it"] = "Azzerare il campo di ricerca";
-//print window title
+//print window title
var printWindowTitleString = new Array();
-printWindowTitleString["en"] = "The server is generating a PDF file. For correct up to scale printing please deactivate the option 'Fit to Page'!";
-printWindowTitleString["de"] = "PDF wird vom Server generiert. Für massstäbliches Drucken deaktivieren Sie bitte das 'Anpassen der Seitengrösse'!";
+printWindowTitleString["en"] = "The server is generating a PDF file. For correct up to scale printing please deactivate the option 'Fit to Page'!";
+printWindowTitleString["es"] = "El servidor está generando un archivo PDF. Para corregir la escala de impresión desactive la opción 'Ajustar a página'!";
+printWindowTitleString["de"] = "PDF wird vom Server generiert. Für massstäbliches Drucken deaktivieren Sie bitte das 'Anpassen der Seitengrösse'!";
+printWindowTitleString["fr"] = "Le serveur génère le fichier PDF. Pour conserver l'échelle, ne pas activer l'option 'Ajuster à la page'!"
+printWindowTitleString["it"] = "Il server sta generando il file PDF. Per stampare alla scala corretta disattivare l'opzione 'Ridimensiona alla pagina'!"
//print object data alternative string in case no pdf plugin is present in browser
//attention: single quotes around string, partially html formatting
var printingObjectDataAlternativeString1 = new Array();
-printingObjectDataAlternativeString1["en"] = 'It looks like your browser cannot open PDF files directly. Not a big problem -you can <a href="';
-printingObjectDataAlternativeString1["de"] = 'Es sieht so aus als ob Ihr Browser kein PDF Plugin unterstützt. Kein Problem, Sie können die <a href="';
+printingObjectDataAlternativeString1["en"] = 'It looks like your browser cannot open PDF files directly. Not a big problem - you can <a href="';
+printingObjectDataAlternativeString1["es"] = 'Su navegador no puede abrir archivos PDF directanmente. No es problema - usted puede <a href="';
+printingObjectDataAlternativeString1["de"] = 'Es sieht so aus als ob Ihr Browser kein PDF Plugin unterstützt. Kein Problem, Sie können die <a href="';
+printingObjectDataAlternativeString1["fr"] = 'Il semble que votre navigateur ne puisse pas ouvrir les fichiers PDF directement. Pas de problème, vous pouvez <a href="';
+printingObjectDataAlternativeString1["it"] = 'Sembra che il vostro browser non possa aprire direttamente i files PDF. Nessun problema - potete <a href="';
//the second part of the string after the URL
var printingObjectDataAlternativeString2 = new Array();
printingObjectDataAlternativeString2["en"] = '">download the PDF file here.</a>.</p></object>';
+printingObjectDataAlternativeString2["es"] = '">descargar el archivo PDF aquí.</a>.</p></object>';
printingObjectDataAlternativeString2["de"] = '">PDF-Datei hier herunterladen</a>.</p></object>';
+printingObjectDataAlternativeString2["fr"] = '">télécharger le fichier PDF ici</a>.</p></object>';
+printingObjectDataAlternativeString2["it"] = '">scaricare il PDF qui.</a>.</p></object>';
//print button tooltip
var printButtonTooltipString = new Array();
printButtonTooltipString["en"] = "Print (Generate PDF)";
+printButtonTooltipString["es"] = "Imprimir (Generar PDF)";
printButtonTooltipString["de"] = "Drucken (PDF generieren)";
+printButtonTooltipString["fr"] = "Imprimer (générer un PDF)";
+printButtonTooltipString["it"] = "Stampa (generare un PDF)";
//print cancel button tooltip
var printCancelButtonTooltipString = new Array();
printCancelButtonTooltipString["en"] = "Cancel Print (Close)";
+printCancelButtonTooltipString["es"] = "Cancelar impresión (Cerrar)";
printCancelButtonTooltipString["de"] = "Druck abbrechen (Schliesen)";
+printCancelButtonTooltipString["fr"] = "Annuler l'impression (fermer)";
+printCancelButtonTooltipString["it"] = "Annulla la stampa (chiudi)";
Error Messages
//error messages on startup
var errMessageStartupMapParamString = new Array();
-errMessageStartupMapParamString["en"] = "Startup-Parameter 'map' missing!";
-errMessageStartupMapParamString["de"] = "Start-Parameter 'map' fehlt!";
+errMessageStartupMapParamString["en"] = "Startup-Parameter 'map' missing!";
+errMessageStartupMapParamString["es"] = "Falta el parametro de inicio 'map'!";
+errMessageStartupMapParamString["de"] = "Start-Parameter 'map' fehlt!";
+errMessageStartupMapParamString["fr"] = "Le paramètre de démarrage 'map' est manquant!";
+errMessageStartupMapParamString["it"] = "Il parametro di inizializzazione manca!";
//additional startup error message
var errMessageStartupNotAllParamsFoundString = new Array();
errMessageStartupNotAllParamsFoundString["en"] = "Some mandatory startup paramaters are missing";
+errMessageStartupNotAllParamsFoundString["es"] = "Faltan algunos parametros obligatorios";
errMessageStartupNotAllParamsFoundString["de"] = "Es wurden nicht alle notwendigen Web-GIS-Parameter gefunden.";
+errMessageStartupNotAllParamsFoundString["fr"] = "Certains paramètres indispensables manquent.";
+errMessageStartupNotAllParamsFoundString["it"] = "Alcuni parametri necessari mancano.";
//error message invalid language code, part 1
var errMessageInvalidLanguageCodeString1 = new Array();
errMessageInvalidLanguageCodeString1["en"] = "Invalid language code provided: ";
-errMessageInvalidLanguageCodeString1["de"] = "Falscher Sprachparameter übergeben: ";
+errMessageInvalidLanguageCodeString1["es"] = "Inválido el c&ooacute;digo de idioma proveído: ";
+errMessageInvalidLanguageCodeString1["de"] = "Falscher Sprachparameter übergeben: ";
+errMessageInvalidLanguageCodeString1["fr"] = "Identifiant de langue incorrect: ";
+errMessageInvalidLanguageCodeString1["it"] = "Identificativo della lingua non corretto: ";
//error message invalid language code, part 2
var errMessageInvalidLanguageCodeString2 = new Array();
errMessageInvalidLanguageCodeString2["en"] = "Switching back to default language ";
-errMessageInvalidLanguageCodeString2["de"] = "Wechsle zurück zur Standardsprache ";
+errMessageInvalidLanguageCodeString2["es"] = "Se reestablece el idioma por defecto ";
+errMessageInvalidLanguageCodeString2["de"] = "Wechsle zurück zur Standardsprache ";
+errMessageInvalidLanguageCodeString2["fr"] = "La langue par défaut sera utilisée ";
+errMessageInvalidLanguageCodeString2["it"] = "Si utilizza la lingua di default ";
//error message of search combo network request title
var errMessageSearchComboNetworkRequestFailureTitleString = new Array();
errMessageSearchComboNetworkRequestFailureTitleString["en"] = "Network request failed";
+errMessageSearchComboNetworkRequestFailureTitleString["es"] = "Falló la solicitud de red";
errMessageSearchComboNetworkRequestFailureTitleString["de"] = "Netzwerk-Request fehlgeschlagen";
+errMessageSearchComboNetworkRequestFailureTitleString["fr"] = "La requête réseau a échoué";
+errMessageSearchComboNetworkRequestFailureTitleString["it"] = "La richiesta di rete è fallita";
-//error message of search combo network request detailed message - don not forget the \n at the end of the string!
+//error message of search combo network request detailed message - do not forget the \n at the end of the string!
var errMessageSearchComboNetworkRequestFailureString = new Array();
-errMessageSearchComboNetworkRequestFailureString["en"] = "Network request for the geometry of the search result failed.\n";
-errMessageSearchComboNetworkRequestFailureString["de"] = "Netzwerk-Request für Geometrie des gesuchten Objekts fehlgeschlagen:\n";
+errMessageSearchComboNetworkRequestFailureString["en"] = "The network request for the geometry of the search result failed:\n";
+errMessageSearchComboNetworkRequestFailureString["es"] = "Falló la solicitud de red para el resultado de la búsqueda de la geometrí:\n";
+errMessageSearchComboNetworkRequestFailureString["de"] = "Netzwerk-Request für Geometrie des gesuchten Objekts fehlgeschlagen:\n";
+errMessageSearchComboNetworkRequestFailureString["fr"] = "La requête réseau pour la géométrie du résultat de la recherche a échoué:\n";
+errMessageSearchComboNetworkRequestFailureString["it"] = "La richiesta di rete è fallita per la geometria del risultato di ricerca:\n";
