Author: rblazek
Date: 2011-04-28 15:15:02 -0700 (Thu, 28 Apr 2011)
New Revision: 15846
trunk/qgis/src/core/qgsrasterprojector.cpp
fix for epsg 32661 Polar Stereographic
Modified: trunk/qgis/src/core/qgsrasterprojector.cpp
--- trunk/qgis/src/core/qgsrasterprojector.cpp 2011-04-28 20:57:01 UTC (rev 15845)
+++ trunk/qgis/src/core/qgsrasterprojector.cpp 2011-04-28 22:15:02 UTC (rev 15846)
@@ -102,8 +102,8 @@
// Calculate source dimensions
calcSrcExtent();
calcSrcRowsCols();
- mSrcXRes = mSrcExtent.height() / mSrcRows;
- mSrcYRes = mSrcExtent.width() / mSrcCols;
+ mSrcYRes = mSrcExtent.height() / mSrcRows;
+ mSrcXRes = mSrcExtent.width() / mSrcCols;
// init helper points
pHelperTop = new QgsPoint[mDestCols];
@@ -121,22 +121,21 @@
void QgsRasterProjector::calcSrcExtent()
/* Run around the mCPMatrix and find source extent */
+ // Attention, source limits are not necessarily on destination edges, e.g.
+ // for destination EPSG:32661 Polar Stereographic and source EPSG:4326,
+ // the maximum y may be in the middle of destination extent
+ // TODO: How to find extent exactly and quickly?
+ // For now, we runt through all matrix
QgsPoint myPoint = mCPMatrix[0][0];
mSrcExtent = QgsRectangle( myPoint.x(), myPoint.y(), myPoint.x(), myPoint.y() );
for ( int i = 0; i < mCPRows; i++ )
- myPoint = mCPMatrix[i][0];
- mSrcExtent.combineExtentWith( myPoint.x(), myPoint.y() );
- myPoint = mCPMatrix[i][mCPCols-1];
+ for ( int j = 1; j < mCPCols - 1; j++ )
+ myPoint = mCPMatrix[i][j];
+ mSrcExtent.combineExtentWith( myPoint.x(), myPoint.y() );
- for ( int i = 1; i < mCPCols - 1; i++ )
- myPoint = mCPMatrix[0][i];
- myPoint = mCPMatrix[mCPRows-1][i];
// Expand a bit to avoid possible approx coords falling out because of representation error?
// If mMaxSrcXRes, mMaxSrcYRes are defined (fixed src resolution)
@@ -301,16 +300,23 @@
void QgsRasterProjector::preciseSrcRowCol( int theDestRow, int theDestCol, int *theSrcRow, int *theSrcCol )
+ //QgsDebugMsg( QString( "theDestRow = %1" ).arg(theDestRow) );
+ //QgsDebugMsg( QString( "theDestRow = %1 mDestExtent.yMaximum() = %2 mDestYRes = %3" ).arg(theDestRow).arg(mDestExtent.yMaximum()).arg(mDestYRes) );
// Get coordinate of center of destination cell
double x = mDestExtent.xMinimum() + ( theDestCol + 0.5 ) * mDestXRes;
double y = mDestExtent.yMaximum() - ( theDestRow + 0.5 ) * mDestYRes;
double z = 0;
+ //QgsDebugMsg( QString( "x = %1 y = %2" ).arg(x).arg(y) );
mCoordinateTransform.transformInPlace( x, y, z );
// Get source row col
- *theSrcRow = ( int ) floor(( mSrcExtent.yMaximum() - y ) / mSrcXRes );
- *theSrcCol = ( int ) floor(( x - mSrcExtent.xMinimum() ) / mSrcYRes );
+ *theSrcRow = ( int ) floor(( mSrcExtent.yMaximum() - y ) / mSrcYRes );
+ *theSrcCol = ( int ) floor(( x - mSrcExtent.xMinimum() ) / mSrcXRes );
+ //QgsDebugMsg( QString( "mSrcExtent.yMaximum() = %1 mSrcYRes = %2" ).arg(mSrcExtent.yMaximum()).arg(mSrcYRes) );
+ //QgsDebugMsg( QString( "theSrcRow = %1 theSrcCol = %2" ).arg(*theSrcRow).arg(*theSrcCol) );
// With epsg 32661 (Polar Stereographic) it was happening that *theSrcCol == mSrcCols
// For now silently correct limits to avoid crashes
@@ -362,8 +368,8 @@
// TODO: check again cell selection (coor is in the middle)
- *theSrcRow = ( int ) floor(( mSrcExtent.yMaximum() - mySrcY ) / mSrcXRes );
- *theSrcCol = ( int ) floor(( mySrcX - mSrcExtent.xMinimum() ) / mSrcYRes );
+ *theSrcRow = ( int ) floor(( mSrcExtent.yMaximum() - mySrcY ) / mSrcYRes );
+ *theSrcCol = ( int ) floor(( mySrcX - mSrcExtent.xMinimum() ) / mSrcXRes );
// TODO: review
