[QGIS Commit] r15857 - in trunk/qgis/src: analysis/raster app app/ogr core core/composer core/gps core/pal gui mapserver plugins/dxf2shp_converter/dxflib/src plugins/grass plugins/grass/qtermwidget plugins/raster_terrain_analysis providers/grass
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Apr 30 08:09:19 EDT 2011
Author: jef
Date: 2011-04-30 05:09:19 -0700 (Sat, 30 Apr 2011)
New Revision: 15857
   trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp
   trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp
   trunk/qgis/src/app/qgisapp.cpp
   trunk/qgis/src/app/qgsattributetypedialog.cpp
   trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
   trunk/qgis/src/app/qgslabelpropertydialog.cpp
   trunk/qgis/src/app/qgsrasterlayerproperties.cpp
   trunk/qgis/src/core/composer/qgscomposeritem.cpp
   trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
   trunk/qgis/src/core/gps/gmath.c
   trunk/qgis/src/core/pal/feature.cpp
   trunk/qgis/src/core/pal/pointset.cpp
   trunk/qgis/src/core/pal/problem.cpp
   trunk/qgis/src/core/qgsgeometry.cpp
   trunk/qgis/src/core/qgsmaprenderer.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/gui/qgsannotationitem.cpp
   trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
   trunk/qgis/src/gui/qgsquickprint.cpp
   trunk/qgis/src/mapserver/qgssldparser.cpp
   trunk/qgis/src/mapserver/qgssoaprequesthandler.cpp
   trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_dxf.cpp
   trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp
   trunk/qgis/src/plugins/grass/qgsgrassedit.cpp
   trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
   trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
   trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp
   trunk/qgis/src/providers/grass/qgis.d.rast.c
fix gcc 4.6 warnings
Modified: trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp
--- trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/analysis/raster/qgsrastercalculator.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -120,9 +120,7 @@
       char* crsWKT = 0;
       OGRSpatialReferenceH ogrSRS = OSRNewSpatialReference( NULL );
-      const QgsCoordinateReferenceSystem& outputCrs = rl->crs();
-      int epsgCode = outputCrs.epsg();
-      if ( epsgCode > 0 &&  OSRImportFromEPSG( ogrSRS, epsgCode ) == CE_None )
+      if ( OSRSetFromUserInput( ogrSRS, rl->crs().authid().toUtf8().constData() ) == OGRERR_NONE )
         OSRExportToWkt( ogrSRS, &crsWKT );
         GDALSetProjection( outputDataset, crsWKT );
Modified: trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp
--- trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/ogr/qgsopenvectorlayerdialog.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -240,12 +240,10 @@
   QSettings settings;
   QString toSelect = settings.value( "/ogr/connections/selectedtype" ).toString();
-  bool set = false;
   for ( int i = 0; i < cmbDatabaseTypes->count(); ++i )
     if ( cmbDatabaseTypes->itemText( i ) == toSelect )
       cmbDatabaseTypes->setCurrentIndex( i );
-      set = true;
       break;
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/qgisapp.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -3877,8 +3877,6 @@
   //make a first geometry union and notify the user straight away if the union geometry type does not match the layer one
-  QGis::WkbType originalType = vl->wkbType();
-  QGis::WkbType newType = unionGeom->wkbType();
   if ( providerChecksTypeStrictly && unionGeom->wkbType() != vl->wkbType() )
     QMessageBox::critical( 0, tr( "Union operation canceled" ), tr( "The union operation would result in a geometry type that is not compatible with the current layer and therefore is canceled" ) );
@@ -3918,8 +3916,6 @@
       return;
-    originalType = vl->wkbType();
-    newType = unionGeom->wkbType();
       QMessageBox::critical( 0, "Union operation canceled", tr( "The union operation would result in a geometry type that is not compatible with the current layer and therefore is canceled" ) );
Modified: trunk/qgis/src/app/qgsattributetypedialog.cpp
--- trunk/qgis/src/app/qgsattributetypedialog.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/qgsattributetypedialog.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -86,7 +86,6 @@
 void QgsAttributeTypeDialog::removeSelectedButtonPushed()
   QList<QTableWidgetItem *> list = tableWidget->selectedItems();
-  QList<QTableWidgetItem *>::iterator it = list.begin();
   QSet<int> rowsToRemove;
   int removed = 0;
   int i = 0;
Modified: trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp
--- trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/qgsgraduatedsymboldialog.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -157,8 +157,6 @@
     show();
     return;
-  std::map < QString, int >::iterator iter = mFieldMap.find( fieldstring );
 void QgsGraduatedSymbolDialog::apply()
Modified: trunk/qgis/src/app/qgslabelpropertydialog.cpp
--- trunk/qgis/src/app/qgslabelpropertydialog.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/qgslabelpropertydialog.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -55,7 +55,6 @@
     return;
   const QgsAttributeMap& attributeValues = f.attributeMap();
-  QgsAttributeMap::const_iterator attIt = attributeValues.constBegin();
   //get layerproperties. Problem: only for pallabeling...
   QgsPalLabeling* lbl = dynamic_cast<QgsPalLabeling*>( mMapRenderer->labelingEngine() );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1886,8 +1886,6 @@
   // and max - scaled to image height. 1 line drawn per selected band
   const int BINCOUNT = 255;
-  enum GRAPH_TYPE { BAR_CHART, LINE_CHART } myGraphType;
-  myGraphType = BAR_CHART;
   bool myIgnoreOutOfRangeFlag = true;
   bool myThoroughBandScanFlag = false;
   int myBandCountInt = mRasterLayer->bandCount();
Modified: trunk/qgis/src/core/composer/qgscomposeritem.cpp
--- trunk/qgis/src/core/composer/qgscomposeritem.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/composer/qgscomposeritem.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -958,7 +958,6 @@
   //assume points 1 and 3 are on the rectangle boundaries. Calculate 2 and 4.
   double distM1 = sqrt(( x1 - midX ) * ( x1 - midX ) + ( y1 - midY ) * ( y1 - midY ) );
   QPointF p2 = pointOnLineWithDistance( QPointF( midX, midY ), QPointF( x2, y2 ), distM1 );
-  QPointF p4 = pointOnLineWithDistance( QPointF( midX, midY ), QPointF( x4, y4 ), distM1 );
   if ( p2.x() < width && p2.x() > 0 && p2.y() < height && p2.y() > 0 )
Modified: trunk/qgis/src/core/composer/qgscomposerscalebar.cpp
--- trunk/qgis/src/core/composer/qgscomposerscalebar.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/composer/qgscomposerscalebar.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -138,7 +138,6 @@
   if ( mComposerMap )
     //calculate mNumUnitsPerSegment
-    QRectF composerItemRect = mComposerMap->rect();
     QgsRectangle composerMapRect = mComposerMap->extent();
     double proposedScaleBarLength = composerMapRect.width() / 4;
Modified: trunk/qgis/src/core/gps/gmath.c
--- trunk/qgis/src/core/gps/gmath.c	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/gps/gmath.c	2011-04-30 12:09:19 UTC (rev 15857)
@@ -163,14 +163,13 @@
   while (( delta_lambda > 1e-12 ) && ( remaining_steps > 0 ) )
   { /* Iterate */
     /* Variables */
-    double tmp1, tmp2, tan_sigma, sin_alpha, cos_alpha, C, lambda_prev;
+    double tmp1, tmp2, sin_alpha, cos_alpha, C, lambda_prev;
     /* Calculation */
     tmp1 = cos_U2 * sin_lambda;
     tmp2 = cos_U1 * sin_U2 - sin_U1 * cos_U2 * cos_lambda;
     sin_sigma = sqrt( tmp1 * tmp1 + tmp2 * tmp2 );
     cos_sigma = sin_U1 * sin_U2 + cos_U1 * cos_U2 * cos_lambda;
-    tan_sigma = sin_sigma / cos_sigma;
     sin_alpha = cos_U1 * cos_U2 * sin_lambda / sin_sigma;
     cos_alpha = cos( asin( sin_alpha ) );
     sqr_cos_alpha = cos_alpha * cos_alpha;
@@ -261,7 +260,7 @@
   /* Variables */
   double f, a, b, sqr_a, sqr_b;
   double phi1, tan_U1, sin_U1, cos_U1, s, alpha1, sin_alpha1, cos_alpha1;
-  double tan_sigma1, sigma1, sin_alpha, cos_alpha, sqr_cos_alpha, sqr_u, A, B;
+  double sigma1, sin_alpha, sqr_cos_alpha, sqr_u, A, B;
   double sigma_initial, sigma, sigma_prev, sin_sigma, cos_sigma, cos_2_sigmam, sqr_cos_2_sigmam, delta_sigma;
   int remaining_steps;
   double tmp1, phi2, lambda, C, L;
@@ -293,11 +292,9 @@
   alpha1 = azimuth;
   sin_alpha1 = sin( alpha1 );
   cos_alpha1 = cos( alpha1 );
-  tan_sigma1 = tan_U1 / cos_alpha1;
   sigma1 = atan2( tan_U1, cos_alpha1 );
   sin_alpha = cos_U1 * sin_alpha1;
   sqr_cos_alpha = 1 - sin_alpha * sin_alpha;
-  cos_alpha = sqrt( sqr_cos_alpha );
   sqr_u = sqr_cos_alpha * ( sqr_a - sqr_b ) / sqr_b;
   A = 1 + sqr_u / 16384 * ( 4096 + sqr_u * ( -768 + sqr_u * ( 320 - 175 * sqr_u ) ) );
   B = sqr_u / 1024 * ( 256 + sqr_u * ( -128 + sqr_u * ( 74 - 47 * sqr_u ) ) );
Modified: trunk/qgis/src/core/pal/feature.cpp
--- trunk/qgis/src/core/pal/feature.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/pal/feature.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1010,7 +1010,6 @@
     if ( shapes_final->size() > 0 )
       LinkedList<LabelPosition*> *positions = new LinkedList<LabelPosition*> ( ptrLPosCompare );
-      int it;
       int id = 0; // ids for candidates
       double dlx, dly; // delta from label center and bottom-left corner
@@ -1037,7 +1036,6 @@
         j++;
-      it = 0;
       dx = dy = min( yrm, xrm ) / 2;
       int num_try = 0;
Modified: trunk/qgis/src/core/pal/pointset.cpp
--- trunk/qgis/src/core/pal/pointset.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/pal/pointset.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -611,7 +611,6 @@
     double cp;
     double best_cp;
     double distNearestPoint;
-    int nearestPoint;
     double area;
     double width;
@@ -689,14 +688,12 @@
         alpha_seg = (( i / 4 > 0 ? ( i / 4 ) - 1 : 3 ) ) * M_PI / 2 + alpha;
         best_cp = DBL_MAX;
-        nearestPoint = -1;
         for ( j = 0; j < nbPoints; j++ )
           cp = cross_product( bb[i+2], bb[i+3], bb[i], bb[i+1], x[cHull[j]], y[cHull[j]] );
           if ( cp < best_cp )
             best_cp = cp;
-            nearestPoint = cHull[j];
Modified: trunk/qgis/src/core/pal/problem.cpp
--- trunk/qgis/src/core/pal/problem.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/pal/problem.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -2138,7 +2138,6 @@
     double initial_cost;
     double cur_cost = 0;
     double best_cost = 0;
-    double bestChain;
     int nbOverlap = 0;
@@ -2166,7 +2165,6 @@
     int tenure = pal->tenure;
-    int itBest = -1;
     //int deltaIt = 0;
     Triple **candidates = new Triple*[probSize];
@@ -2208,10 +2206,7 @@
     sort(( void** ) candidates, probSize, decreaseCost );
-    int validCandidateId = -1;
     int candidateListSize;
-    int seedSh;
     candidateListSize = int ( pal->candListSize * ( double ) probSize + 0.5 );
     if ( candidateListSize > probSize )
@@ -2226,8 +2221,6 @@
     while ( it < stop_it )
       retainedChain = NULL;
-      bestChain = DBL_MAX;
-      validCandidateId = -1;
 #ifdef _DEBUG_FULL_
       std::cout << std::endl << std::endl << candidateListSize << std::endl;
@@ -2235,7 +2228,6 @@
       for ( itC = 0; itC < candidateListSize; itC++ )
         seed = candidates[itC]->feat_id;
-        seedSh = seed - borderSize;
 #ifdef _DEBUG_FULL_
         std::cout << "new candidates:" << std::endl;
@@ -2253,7 +2245,6 @@
             if ( !retainedChain )
               retainedChain = current_chain;
-              bestChain = current_chain->delta;
 #ifdef _DEBUG_FULL_
               std::cout << "New chain, delta = " << current_chain->delta << std::endl;
 #endif
@@ -2262,7 +2253,6 @@
               delete_chain( retainedChain );
 #ifdef _DEBUG_FULL_
               std::cout << "New best chain, delta = " << current_chain->delta << std::endl;
 #endif
@@ -2355,8 +2345,6 @@
           best_cost = cur_cost;
           memcpy( best_sol, sol, sizeof( int ) *subSize );
-          itBest = it;
           stop_it = ( it + itwimp > maxit ? maxit : it + itwimp );
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/qgsgeometry.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -3443,7 +3443,6 @@
   int numLineStrings;
   int idx, jdx, kdx;
   unsigned char *ptr;
-  char lsb;
   QgsPoint pt;
   QGis::WkbType wkbType;
   bool hasZValue = false;
@@ -3568,7 +3567,6 @@
       for ( jdx = 0; jdx < numLineStrings; jdx++ )
         // each of these is a wbklinestring so must handle as such
-        lsb = *ptr;
         ptr += 5;   // skip type since we know its 2
         nPoints = ( int * ) ptr;
         ptr += sizeof( int );
@@ -4135,7 +4133,6 @@
   int numLineStrings;
   int idx, jdx, kdx;
   unsigned char *ptr;
-  char lsb;
   QgsPoint pt;
   QGis::WkbType wkbtype;
@@ -4226,7 +4223,6 @@
           QgsPolyline sequence;
-          lsb = *ptr;
@@ -5165,7 +5161,6 @@
   GEOSGeometry** newInnerRings = new GEOSGeometry*[ringList.size()];
-  QList<GEOSGeometry*>::const_iterator it = ringList.constBegin();
   for ( int i = 0; i < ringList.size(); ++i )
     newInnerRings[i] = ringList.at( i );
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -320,13 +320,8 @@
-  bool placeOverlays = false;
   QgsOverlayObjectPositionManager* overlayManager = overlayManagerFromSettings();
   QList<QgsVectorOverlay*> allOverlayList; //list of all overlays, used to draw them after layers have been rendered
-  if ( overlayManager )
-    placeOverlays = true;
   // render all layers in the stack, starting at the base
   QListIterator<QString> li( mLayerSet );
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -4214,8 +4214,10 @@
   // used in all cases of the statement (otherwise they may get
   // executed, but never used, in a bit of code where performance is
   // critical).
-  if ( ! fet.isValid() ) { return; }
-  bool needToTrim = false;
+  if ( ! fet.isValid() )
+    return;
   QgsGeometry* geom = fet.geometry();
   if ( !geom )
@@ -4283,10 +4285,8 @@
         //QPointF pt( x, y );
         // Work around a +/- 32768 limitation on coordinates
-        if ( qAbs( x ) > QgsClipper::MAX_X ||
-             qAbs( y ) > QgsClipper::MAX_Y )
-          needToTrim = true;
-        else
+        if ( qAbs( x ) <= QgsClipper::MAX_X &&
+             qAbs( y ) <= QgsClipper::MAX_Y )
           p->drawImage( pt, *marker );
       p->restore();
Modified: trunk/qgis/src/gui/qgsannotationitem.cpp
--- trunk/qgis/src/gui/qgsannotationitem.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/gui/qgsannotationitem.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -216,7 +216,6 @@
     return;
-  QPointF canvasPoint = toCanvasCoordinates( mMapPosition );
   if ( mMarkerSymbol )
     mMarkerSymbol->startRender( renderContext );
Modified: trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
--- trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -240,7 +240,6 @@
 //  if (mPanningWidget->isHidden())
 //    return;
-  QSize size = mPanningWidget->size();
   mPanningWidget->move( pos.x() - mPanningCursorOffset.x(), pos.y() - mPanningCursorOffset.y() );
Modified: trunk/qgis/src/gui/qgsquickprint.cpp
--- trunk/qgis/src/gui/qgsquickprint.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/gui/qgsquickprint.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -247,11 +247,6 @@
 #endif
   QString myFontFamily = "Arial";
-  // Background color for pixmaps
-  QColor myLegendBackgroundColor = Qt::white;
-  //QColor myMapBackgroundColor = "#98dbf9"; // nice blue color
   // Draw the PageBorder
Modified: trunk/qgis/src/mapserver/qgssldparser.cpp
--- trunk/qgis/src/mapserver/qgssldparser.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/mapserver/qgssldparser.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -767,7 +767,6 @@
                   if ( !labelBufferElementList.item( 0 ).toElement().isNull() )
-                    double radius = 5.0;
                     QDomNodeList cssNodes = labelBufferElementList.item( 0 ).toElement().elementsByTagName( "CssParameter" );
                     QString cssName;
                     QDomElement currentElement;
@@ -833,6 +832,13 @@
+                    //QgsMapServerLogger::instance()->printMessage("radius " + QString::number(radius));
+                    myLabelAttributes->setBufferEnabled( true );
+                    myLabelAttributes->setBufferColor( QColor( polyColorRed, polyColorGreen, polyColorBlue, opacity ) );
+#if 0
+                    double radius = 5.0;
                     QDomElement radiusElement = labelBufferElementList.item( 0 ).toElement().elementsByTagName( "Radius" ).item( 0 ).toElement();
                     if ( !radiusElement.isNull() )
@@ -843,10 +849,8 @@
                         radius = 5.0;
-                    //QgsMapServerLogger::instance()->printMessage("radius " + QString::number(radius));
-                    myLabelAttributes->setBufferEnabled( true );
-                    myLabelAttributes->setBufferColor( QColor( polyColorRed, polyColorGreen, polyColorBlue, opacity ) );
-                    //myLabelAttributes->setBufferSize(radius, QgsLabelAttributes::PointUnits);
+                    myLabelAttributes->setBufferSize( radius, QgsLabelAttributes::PointUnits );
+#endif
                     // ******** BUG ************  see why setting buffersize dows not work (is a problem in QGIS vector layer rendering)
@@ -1397,14 +1401,12 @@
   /*      Invoke.                                                         */
-  CPLErr eErr;
+  GDALContourGenerate( hBand, dfInterval, dfOffset,
+                       nFixedLevelCount, adfFixedLevels,
+                       bNoDataSet, dfNoData,
+                       hLayer, 0, nElevField,
+                       GDALTermProgress, NULL );
-  eErr = GDALContourGenerate( hBand, dfInterval, dfOffset,
-                              nFixedLevelCount, adfFixedLevels,
-                              bNoDataSet, dfNoData,
-                              hLayer, 0, nElevField,
-                              GDALTermProgress, NULL );
   delete adfFixedLevels;
   OGR_DS_Destroy( hDS );
Modified: trunk/qgis/src/mapserver/qgssoaprequesthandler.cpp
--- trunk/qgis/src/mapserver/qgssoaprequesthandler.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/mapserver/qgssoaprequesthandler.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -102,11 +102,6 @@
   // if xml reading was successfull, save the inputXML in a file
-  time_t t;
-  struct tm *currentTime;
-  time( &t );
-  currentTime = localtime( &t );
   QFile soapFile;
   QTextStream soapStream;
Modified: trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_dxf.cpp
--- trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_dxf.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/dxf2shp_converter/dxflib/src/dl_dxf.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1483,9 +1483,6 @@
 bool DL_Dxf::handleHatchData( DL_CreationInterface* /*creationInterface*/ )
-  static int firstPolylineStatus = 0;
   // Allocate hatch loops (group code 91):
   if ( groupCode == 91 && toInt( groupValue ) > 0 )
@@ -1552,16 +1549,13 @@
       dropEdges = false;
       hatchLoopIndex++;
-      hatchLoops[hatchLoopIndex]
-      = DL_HatchLoopData( toInt( groupValue ) );
+      hatchLoops[hatchLoopIndex] = DL_HatchLoopData( toInt( groupValue ) );
       maxHatchEdges[hatchLoopIndex] = toInt( groupValue );
       hatchEdgeIndex[hatchLoopIndex] = -1;
-      hatchEdges[hatchLoopIndex]
-      = new DL_HatchEdgeData[toInt( groupValue )];
+      hatchEdges[hatchLoopIndex] = new DL_HatchEdgeData[toInt( groupValue )];
 // QgsDebugMsg(QString("hatchEdges[%1] = new %2").arg(hatchLoopIndex).arg(toInt(groupValue)));
-      firstPolylineStatus = 0;
     else
Modified: trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/grass/qgsgrassbrowser.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -137,7 +137,6 @@
   QgsDebugMsg( "entered." );
   QModelIndexList indexes = mTree->selectionModel()->selectedIndexes();
-  bool mapSelected = false;
   QList<QModelIndex>::const_iterator it = indexes.begin();
   for ( ; it != indexes.end(); ++it )
@@ -152,7 +151,6 @@
       //mIface->addRasterLayer( uri, map );
       mIface->addRasterLayer( uri, map, "grassraster", QStringList(), QStringList(),
                               QString(), QString() );
-      mapSelected = true;
     else if ( type == QgsGrassModel::Vector )
@@ -177,7 +175,6 @@
                        map, layer, list.size() );
       mIface->addVectorLayer( uri, name, "grass" );
     else if ( type == QgsGrassModel::Region )
Modified: trunk/qgis/src/plugins/grass/qgsgrassedit.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassedit.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/grass/qgsgrassedit.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1463,12 +1463,6 @@
       else
-        int size;
-        if ( atts->size() < ( int ) cols->size() )
-          size = atts->size();
-        else
-          size = cols->size();
         for ( unsigned int j = 0; j < cols->size(); j++ )
           QgsField col = ( *cols )[j];
Modified: trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp
--- trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/grass/qgsgrassnewmapset.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1147,7 +1147,6 @@
   QDir d( locationPath );
   // Add all subdirs containing WIND
-  QTreeWidgetItem *lvi;
   for ( unsigned int i = 0; i < d.count(); i++ )
     if ( d[i] == "." || d[i] == ".." ) continue;
@@ -1158,7 +1157,7 @@
     if ( QFile::exists( windPath ) )
-      lvi = new QTreeWidgetItem( mMapsetsListView, QStringList() << d[i] << mapsetInfo.owner() );
+      new QTreeWidgetItem( mMapsetsListView, QStringList() << d[i] << mapsetInfo.owner() );
Modified: trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp
--- trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/grass/qtermwidget/TerminalDisplay.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -1747,7 +1747,6 @@
   // this widget.
   // Adjust position within text area bounds. See FIXME above.
-  QPoint oldpos = pos;
   if ( pos.x() < tLx + _leftMargin )
     pos.setX( tLx + _leftMargin );
   if ( pos.x() > tLx + _leftMargin + _usedColumns*_fontWidth - 1 )
Modified: trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp
--- trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/plugins/raster_terrain_analysis/qgsrasterterrainanalysisplugin.cpp	2011-04-30 12:09:19 UTC (rev 15857)
@@ -82,7 +82,6 @@
     QString analysisMethod = d.selectedAnalysisMethod();
     QString selectedFormat = d.selectedDriverKey();
     QString outputFile = d.selectedOuputFilePath();
-    int returnValue;
     QgsNineCellFilter* filter = 0;
     if ( d.selectedAnalysisMethod() == tr( "Slope" ) )
@@ -106,7 +105,7 @@
       QProgressDialog p( tr( "Calculating " ) + d.selectedAnalysisMethod() + "...", tr( "Abort..." ), 0, 0 );
       p.setWindowModality( Qt::WindowModal );
-      returnValue = filter->processRaster( &p );
+      filter->processRaster( &p );
       delete filter;
       if ( d.addLayerToProject() )
Modified: trunk/qgis/src/providers/grass/qgis.d.rast.c
--- trunk/qgis/src/providers/grass/qgis.d.rast.c	2011-04-30 06:47:46 UTC (rev 15856)
+++ trunk/qgis/src/providers/grass/qgis.d.rast.c	2011-04-30 12:09:19 UTC (rev 15857)
@@ -27,7 +27,6 @@
   char *mapset;
   char *name;
-  int fp;
   struct GModule *module;
   struct Option *map;
   struct Option *win;
@@ -81,14 +80,7 @@
   G_set_window( &window );
   raster_type = G_raster_map_type( name, "" );
-  fp = G_raster_map_is_fp( name, mapset );
-  /* use DCELL even if the map is FCELL */
-  // Why? It would break dataType in provider.
-  //if ( fp )
-  //  display( name, mapset, DCELL_TYPE, format->answer );
-  //else
-  //  display( name, mapset, CELL_TYPE, format->answer );
   display( name, mapset, raster_type, format->answer );
   exit( EXIT_SUCCESS );
@@ -198,9 +190,6 @@
       else
-        int *val;
-        val = ( int* )( ptr );
-        //G_debug ( 0, "val = %d", *val );
         if ( data_type == CELL_TYPE )
           //G_debug ( 0, "valx = %d", *((CELL *) ptr));
More information about the QGIS-commit mailing list
