[QGIS Commit] r15898 - in docs/trunk/english_us/user_guide: . plugins_road_graph_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Aug 1 10:45:52 EDT 2011
Author: dassau
Date: 2011-08-01 07:45:52 -0700 (Mon, 01 Aug 2011)
New Revision: 15898
Added:
   docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_sample.png
   docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_settings.png
   docs/trunk/english_us/user_guide/plugins_road_graph.tex
added road graph plugin section
Modified: docs/trunk/english_us/user_guide/plugins_road_graph.tex
--- docs/trunk/english_us/user_guide/plugins_road_graph.tex	2011-07-29 19:46:13 UTC (rev 15897)
+++ docs/trunk/english_us/user_guide/plugins_road_graph.tex	2011-08-01 14:45:52 UTC (rev 15898)
@@ -4,8 +4,56 @@
 % when the revision of a section has been finalized,
 % comment out the following line:
-\updatedisclaimer
+% \updatedisclaimer
-The \toolbtntwo{plugin}{Road Graph} Plugin ...
+The \toolbtntwo{plugin}{Road Graph} Plugin is a C++ plugin for QGIS, that calculates the shortest path
+between two points on any polyline layer and plots this path over the road network.
+\textbf{Main features}:
+\begin{itemize}
+\item calculate path, it's length and travel time
+\item optimize by length or by travel time
+\item export path to a vector layer
+\item highlight roads directions (this is slow and used mainly for debug purposes and for the settings
+testing)
+\end{itemize}
+As a roads layer you can use any polyline vector layer in any QGIS supported format. Two lines with
+a common point are considered connected. Please note, it is required to use layer CRS as project CRS
+while editing roads layer. This is due to the fact that recalculation of the coordinates between
+different CRS introduce some errors that can result in discontinuities, even when 'snapping' is used.
+\textbf{In the layer attribute table the following fields can be used}:
+\begin{itemize}
+\item speed on road section — numeric field;
+\item direction — any type, that can be casted to string. Forward and reverse directions are correspond
+to the one-way road, both directions — two-way road.
+\end{itemize}
+If some fields don't have any value or do not exists — default values are used. You can change defaults
+and some plugin settings in plugin settings dialog.
+\minisec{Usage}
+After plugin activation you will see additional panel on the left side of the main QGIS window. Now
+make some definitions to the \dialog{road graph plugin settings} dialog in the menu
+\mainmenuopt{Plugins} \arrow \dropmenuopt{Road Graph}.
+\begin{figure}[ht]
+    \centering
+    \includegraphics[clip=true, width=5cm]{roadgraph_settings}
+    \caption{Define settings for the road graph plugin \nixcaption}\label{fig:roadgraphsettings}
+\end{figure}
+Select a Start and a Stop point in the road network layer and click on \button{calculate}.
+\begin{figure}[ht]
+    \centering
+    \includegraphics[clip=true, width=12cm]{roadgraph_sample}
+    \caption{Road Graph Plugin \nixcaption}\label{fig:roadgraphsample}
+\end{figure}
 \FloatBarrier
Added: docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_sample.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_sample.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_settings.png
Property changes on: docs/trunk/english_us/user_guide/plugins_road_graph_images/roadgraph_settings.png
More information about the QGIS-commit mailing list
