[QGIS Commit] r15899 - in docs/trunk/english_us/user_guide: .
plugins_spatial_query_images
svn_qgis at osgeo.org
Wed Aug 3 11:16:32 EDT 2011
Author: dassau
Date: 2011-08-03 08:16:31 -0700 (Wed, 03 Aug 2011)
New Revision: 15899
Added:
docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectcreatelayer.png
docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectesubsetlayer.png
docs/trunk/english_us/user_guide/plugins_spatial_query_images/spatial_query_sample.png
docs/trunk/english_us/user_guide/grass_integration.tex
docs/trunk/english_us/user_guide/plugins_spatial_query.tex
added section about spatial query plugin
Modified: docs/trunk/english_us/user_guide/grass_integration.tex
--- docs/trunk/english_us/user_guide/grass_integration.tex 2011-08-01 14:45:52 UTC (rev 15898)
+++ docs/trunk/english_us/user_guide/grass_integration.tex 2011-08-03 15:16:31 UTC (rev 15899)
@@ -791,7 +791,7 @@
\begin{itemize}[label=--]
\item Again using the Alaska data, refer to \ref{sec:import_loc_data} to
-import the trees shapefile from the \usertext{vmap0\_shapefiles} directory
+import the trees shapefile from the \usertext{shapefiles} directory
into GRASS.
\item Now an intermediary step is required: centroids must be added to the
imported trees map to make it a complete GRASS area vector (including both
Modified: docs/trunk/english_us/user_guide/plugins_spatial_query.tex
--- docs/trunk/english_us/user_guide/plugins_spatial_query.tex 2011-08-01 14:45:52 UTC (rev 15898)
+++ docs/trunk/english_us/user_guide/plugins_spatial_query.tex 2011-08-03 15:16:31 UTC (rev 15899)
@@ -4,8 +4,56 @@
% when the revision of a section has been finalized,
% comment out the following line:
-\updatedisclaimer
+% \updatedisclaimer
-The \toolbtntwo{spatialquery}{Spatial Query} Plugin ...
+The \toolbtntwo{spatialquery}{Spatial Query} plugin allows to make a spatial
+query (select features) in a target layer with reference to another layer. The
+functionality is based on the GEOS library and depends on the selected source
+feature layer.
+Possible operator are:
+\begin{itemize}[label=--]
+\item Crosses
+\item Intersects
+\item Is disjoint
+\item Touches
+\item Within
+\end{itemize}
+Polygon layers do not provide the 'Touches' and 'Crosses operator.
+\minisec{How to use the plugin}
+As an example we want to find regions in the Alaska dataset that contain
+airports. Following steps are necessary:
+\begin{enumerate}
+ \item Start QGIS and load the vector layers regions.shp and airports.shp.
+ \item Load the Spatial Query plugin in the Plugin Manager (see Section
+ \ref{sec:load_core_plugin}) and click on the \toolbtntwo{spatialquery}{Spatial Query}
+ icon which appears in the QGIS toolbar menu. The plugin dialog appears as shown
+ in Figure \ref{fig:spatialquerysample}.
+ \item Select layer regions as source layer and airports as reference feature layer.
+ \item Select 'Contains' as operator and click \button{Apply}.
+\end{enumerate}
+Now you get a list of feature IDs from the query and you have several options.
+\item Click on the \toolbtntwo{selectesubsetlayer}{Create layer with list of items}
+\item Select an ID from the list and click on \toolbtntwo{selectcreatelayer}{Create layer with selected}
+\item Select the \button{Remove from current selection} in the field 'And use the
+result to'.
+\item Additionally you can \checkbox{Zoom to item} or display \checkbox{Log messages}.
+\end{itemize}
+\begin{figure}[ht]
+ \centering
+ \includegraphics[clip=true, width=14cm]{spatial_query_sample}
+ \caption{Spatial Query analysis - regions contain airports \nixcaption}
+ \label{fig:spatialquerysample}
+\end{figure}
\FloatBarrier
Added: docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectcreatelayer.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectcreatelayer.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectesubsetlayer.png
Property changes on: docs/trunk/english_us/user_guide/plugins_spatial_query_images/selectesubsetlayer.png
Added: docs/trunk/english_us/user_guide/plugins_spatial_query_images/spatial_query_sample.png
Property changes on: docs/trunk/english_us/user_guide/plugins_spatial_query_images/spatial_query_sample.png
