[QGIS Commit] r15908 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Sun Aug 14 14:51:09 EDT 2011
Author: dassau
Date: 2011-08-14 11:51:09 -0700 (Sun, 14 Aug 2011)
New Revision: 15908
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/plugins.tex
docs/trunk/english_us/user_guide/print_composer.tex
some more updates from th ewiki list
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2011-08-14 16:44:04 UTC (rev 15907)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2011-08-14 18:51:09 UTC (rev 15908)
@@ -902,7 +902,7 @@
\index{measure:angles}
\includegraphics[width=0.7cm]{mActionMeasure}
-QGIS is also able to measure real distances between given
+QGIS is able to measure real and unprojected distances between given
points according to a defined ellipsoid. To configure this, choose menu option
\mainmenuopt{Settings} \arrow \dropmenuopt{Options},
click on the \tab{Map tools} tab and choose the appropriate ellipsoid. There
Modified: docs/trunk/english_us/user_guide/plugins.tex
--- docs/trunk/english_us/user_guide/plugins.tex 2011-08-14 16:44:04 UTC (rev 15907)
+++ docs/trunk/english_us/user_guide/plugins.tex 2011-08-14 18:51:09 UTC (rev 15908)
@@ -84,7 +84,7 @@
the QGIS sources, and are automatically loaded and enabled inside the QGIS
Plugin Manager (see Section~\ref{sec:load_external_plugin}).}
-Currently (at the time of testing version 1.7 of QGIS) there are over 100 external
+Currently (at the time of testing version 1.7 of QGIS) there are over 120 external
plugins available from thirteen listed repositories. Some of these plugins offer
functionality that will be required by many users (for example : providing the user
with the ability to view and edit Open Street Map data, or to add Google Map layers)
@@ -132,8 +132,9 @@
\begin{itemize}[label=--]
\item \textbf{not installed} - this means the plugin is available in the repository, but is not installed yet. In order to install it, select the plugin from the list and click the \button{Install plugin} button.
\item \textbf{new} - this means that the plugin is newly available in the repository.
-\item \textbf{installed} - this indicates that the plugin is already installed. If it is also available in any repository the \button{Reinstall plugin} button will be enabled. If the available version is older than the installed version, the \button{Downgrade plugin} button will appear instead.
-\item \textbf{upgradeable} - this means that the plugin is installed, but there is an updated version available. In this case, the \button{Upgrade plugin} button will be enabled.
+\item \textbf{installed} - this indicates that the plugin is already installed. If it is also available in any repository the \button{Reinstall plugin} button will be enabled. If the available version is older than the installed version, the \button{Downgrade plugin}
+button will appear instead.
+\item \textbf{upgradeable} - this means that the plugin is installed, but there is an updated version available. In this case, the \button{Upgrade plugin} and \button{Upgrade all} buttons will be enabled.
\item \textbf{invalid} - this means that the plugin is installed, but is unavailable or broken. The reason will be explained in the plugin description field.
\end{itemize}
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex 2011-08-14 16:44:04 UTC (rev 15907)
+++ docs/trunk/english_us/user_guide/print_composer.tex 2011-08-14 18:51:09 UTC (rev 15908)
@@ -198,7 +198,9 @@
\item The \textbf{Map} area allows to resize the map element specifying the
width and height or the scale. The \selectstring{Rotation}{0} field allows to
rotate the map element content clockwise in degrees. Note, a coordinate frame
-can only be added with the default value 0.
+can only be added with the default value 0. Furthermore you can enable the
+checkboxes \checkbox{Lock layers for map items} and \checkbox{Draw map canvas
+items}.
\end{itemize}
If you change the view on the QGIS map canvas by zooming or panning or
