[QGIS Commit] r15139 - in trunk/qgis: python/core
src/core/symbology-ng src/gui/symbology-ng src/ui/symbollayer
svn_qgis at osgeo.org
Tue Feb 8 05:00:09 EST 2011
Author: mhugent
Date: 2011-02-08 02:00:09 -0800 (Tue, 08 Feb 2011)
New Revision: 15139
trunk/qgis/python/core/symbology-ng-core.sip
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
trunk/qgis/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp
trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h
trunk/qgis/src/core/symbology-ng/qgssymbolv2.cpp
trunk/qgis/src/core/symbology-ng/qgssymbolv2.h
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
[FEATURE]: rotation for svg fills
Modified: trunk/qgis/python/core/symbology-ng-core.sip
--- trunk/qgis/python/core/symbology-ng-core.sip 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/python/core/symbology-ng-core.sip 2011-02-08 10:00:09 UTC (rev 15139)
@@ -589,6 +589,9 @@
void drawPreviewIcon(QgsSymbolV2RenderContext& context, QSize size);
+ void setAngle( double angle );
+ double angle() const;
protected:
QgsFillSymbolLayerV2(bool locked = false);
@@ -785,6 +788,7 @@
public:
QgsFillSymbolV2(QgsSymbolLayerV2List layers /Transfer/ = QgsSymbolLayerV2List());
void renderPolygon(const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context, int layer = -1, bool selected = false );
virtual QgsSymbolV2* clone() const /Factory/;
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.cpp 2011-02-08 10:00:09 UTC (rev 15139)
@@ -116,17 +116,20 @@
//QgsSVGFillSymbolLayer
-QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QString& svgFilePath, double width ): mPatternWidth( width ), mOutline( 0 )
+QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QString& svgFilePath, double width, double angle ): mPatternWidth( width ), mOutline( 0 )
setSvgFilePath( svgFilePath );
mOutlineWidth = 0.3;
+ mAngle = angle;
setSubSymbol( new QgsLineSymbolV2() );
-QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QByteArray& svgData, double width ): mPatternWidth( width ), mSvgData( svgData ), mOutline( 0 )
+QgsSVGFillSymbolLayer::QgsSVGFillSymbolLayer( const QByteArray& svgData, double width, double angle ): mPatternWidth( width ),
+ mSvgData( svgData ), mOutline( 0 )
storeViewBox();
+ mAngle = angle;
@@ -151,6 +154,7 @@
QByteArray data;
double width = 20;
QString svgFilePath;
+ double angle = 0.0;
if ( properties.contains( "width" ) )
@@ -163,10 +167,14 @@
QString savePath = QgsSvgMarkerSymbolLayerV2::symbolNameToPath( svgName );
svgFilePath = ( savePath.isEmpty() ? svgName : savePath );
+ if ( properties.contains( "angle" ) )
+ angle = properties["angle"].toDouble();
if ( !svgFilePath.isEmpty() )
- return new QgsSVGFillSymbolLayer( svgFilePath, width );
+ return new QgsSVGFillSymbolLayer( svgFilePath, width, angle );
else
@@ -175,7 +183,7 @@
data = QByteArray::fromHex( properties["data"].toLocal8Bit() );
- return new QgsSVGFillSymbolLayer( data, width );
+ return new QgsSVGFillSymbolLayer( data, width, angle );
@@ -205,6 +213,7 @@
return;
r.render( &p );
if ( context.alpha() < 1.0 )
@@ -246,7 +255,19 @@
p->setBrush( QBrush( selColor ) );
_renderPolygon( p, points, rings );
- p->setBrush( mBrush );
+ if ( doubleNear( mAngle, 0.0 ) )
+ p->setBrush( mBrush );
+ else
+ QTransform t;
+ t.rotate( mAngle );
+ QBrush rotatedBrush = mBrush;
+ rotatedBrush.setTransform( t );
+ p->setBrush( rotatedBrush );
if ( mOutline )
@@ -275,6 +296,7 @@
map.insert( "width", QString::number( mPatternWidth ) );
+ map.insert( "angle", QString::number( mAngle ) );
return map;
@@ -283,11 +305,11 @@
QgsSymbolLayerV2* clonedLayer = 0;
if ( !mSvgFilePath.isEmpty() )
- clonedLayer = new QgsSVGFillSymbolLayer( mSvgFilePath, mPatternWidth );
+ clonedLayer = new QgsSVGFillSymbolLayer( mSvgFilePath, mPatternWidth, mAngle );
else
- clonedLayer = new QgsSVGFillSymbolLayer( mSvgData, mPatternWidth );
+ clonedLayer = new QgsSVGFillSymbolLayer( mSvgData, mPatternWidth, mAngle );
if ( mOutline )
Modified: trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgsfillsymbollayerv2.h 2011-02-08 10:00:09 UTC (rev 15139)
@@ -72,8 +72,8 @@
class CORE_EXPORT QgsSVGFillSymbolLayer: public QgsFillSymbolLayerV2
public:
- QgsSVGFillSymbolLayer( const QString& svgFilePath = "", double width = 20 );
- QgsSVGFillSymbolLayer( const QByteArray& svgData, double width = 20 );
+ QgsSVGFillSymbolLayer( const QString& svgFilePath = "", double width = 20, double rotation = 0.0 );
+ QgsSVGFillSymbolLayer( const QByteArray& svgData, double width = 20, double rotation = 0.0 );
~QgsSVGFillSymbolLayer();
static QgsSymbolLayerV2* create( const QgsStringMap& properties = QgsStringMap() );
@@ -91,7 +91,7 @@
QgsSymbolLayerV2* clone() const;
- //gettersn and setters
+ //getters and setters
void setSvgFilePath( const QString& svgPath );
QString svgFilePath() const { return mSvgFilePath; }
void setPatternWidth( double width ) { mPatternWidth = width;}
Modified: trunk/qgis/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgssinglesymbolrendererv2.cpp 2011-02-08 10:00:09 UTC (rev 15139)
@@ -53,6 +53,12 @@
if ( mSizeScaleFieldIdx != -1 )
lineSymbol->setWidth( sizeScale * mOrigSize );
+ else if ( mTempSymbol->type() == QgsSymbolV2::Fill )
+ QgsFillSymbolV2* fillSymbol = static_cast<QgsFillSymbolV2*>( mTempSymbol );
+ if ( mRotationFieldIdx != -1 )
+ fillSymbol->setAngle( rotation );
return mTempSymbol;
Modified: trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h
--- trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgssymbollayerv2.h 2011-02-08 10:00:09 UTC (rev 15139)
@@ -120,10 +120,15 @@
void drawPreviewIcon( QgsSymbolV2RenderContext& context, QSize size );
+ void setAngle( double angle ) { mAngle = angle; }
+ double angle() const { return mAngle; }
protected:
QgsFillSymbolLayerV2( bool locked = false );
/**Default method to render polygon*/
void _renderPolygon( QPainter* p, const QPolygonF& points, const QList<QPolygonF>* rings );
+ double mAngle;
class QgsSymbolLayerV2Widget;
Modified: trunk/qgis/src/core/symbology-ng/qgssymbolv2.cpp
--- trunk/qgis/src/core/symbology-ng/qgssymbolv2.cpp 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgssymbolv2.cpp 2011-02-08 10:00:09 UTC (rev 15139)
@@ -512,3 +512,12 @@
cloneSymbol->setAlpha( mAlpha );
return cloneSymbol;
+void QgsFillSymbolV2::setAngle( double angle )
+ for ( QgsSymbolLayerV2List::iterator it = mLayers.begin(); it != mLayers.end(); ++it )
+ QgsFillSymbolLayerV2* layer = ( QgsFillSymbolLayerV2* ) * it;
+ layer->setAngle( angle );
Modified: trunk/qgis/src/core/symbology-ng/qgssymbolv2.h
--- trunk/qgis/src/core/symbology-ng/qgssymbolv2.h 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/core/symbology-ng/qgssymbolv2.h 2011-02-08 10:00:09 UTC (rev 15139)
@@ -202,7 +202,7 @@
public:
QgsFillSymbolV2( QgsSymbolLayerV2List layers = QgsSymbolLayerV2List() );
void renderPolygon( const QPolygonF& points, QList<QPolygonF>* rings, QgsRenderContext& context, int layer = -1, bool selected = false );
virtual QgsSymbolV2* clone() const;
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.cpp 2011-02-08 10:00:09 UTC (rev 15139)
@@ -678,6 +678,7 @@
double width = mLayer->patternWidth();
mTextureWidthSpinBox->setValue( width );
mSVGLineEdit->setText( mLayer->svgFilePath() );
+ mRotationSpinBox->setValue( mLayer->angle() );
updateOutlineIcon();
@@ -745,6 +746,15 @@
emit changed();
+void QgsSVGFillSymbolLayerWidget::on_mRotationSpinBox_valueChanged( double d )
+ if ( mLayer )
+ mLayer->setAngle( d );
+ emit changed();
void QgsSVGFillSymbolLayerWidget::updateOutlineIcon()
if ( mLayer )
Modified: trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h
--- trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/gui/symbology-ng/qgssymbollayerv2widget.h 2011-02-08 10:00:09 UTC (rev 15139)
@@ -247,6 +247,7 @@
void on_mSVGLineEdit_textChanged( const QString & text );
void setFile( const QModelIndex& item );
void on_mChangeOutlinePushButton_clicked();
+ void on_mRotationSpinBox_valueChanged( double d );
Modified: trunk/qgis/src/ui/symbollayer/widget_svgfill.ui
--- trunk/qgis/src/ui/symbollayer/widget_svgfill.ui 2011-02-08 08:40:37 UTC (rev 15138)
+++ trunk/qgis/src/ui/symbollayer/widget_svgfill.ui 2011-02-08 10:00:09 UTC (rev 15139)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>211</width>
- <height>199</height>
+ <width>185</width>
+ <height>221</height>
</rect>
</property>
<property name="windowTitle">
@@ -33,6 +33,24 @@
</layout>
</item>
<item row="1" column="0">
+ <layout class="QHBoxLayout" name="horizontalLayout_3">
+ <item>
+ <widget class="QLabel" name="mRotationLabel">
+ <property name="text">
+ <string>Rotation</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QDoubleSpinBox" name="mRotationSpinBox">
+ <property name="maximum">
+ <double>360.000000000000000</double>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ <item row="2" column="0">
<layout class="QHBoxLayout" name="horizontalLayout_4">
<item>
<widget class="QLabel" name="mOutlineLabel">
@@ -50,7 +68,7 @@
</item>
</layout>
</item>
- <item row="2" column="0">
+ <item row="3" column="0">
<widget class="QListView" name="mSvgListView">
<property name="flow">
<enum>QListView::LeftToRight</enum>
@@ -66,7 +84,7 @@
</property>
</widget>
</item>
- <item row="3" column="0">
+ <item row="4" column="0">
<layout class="QHBoxLayout" name="horizontalLayout">
<item>
<widget class="QLineEdit" name="mSVGLineEdit"/>
