[QGIS Commit] r15156 - trunk/qgis/src/plugins/spit
svn_qgis at osgeo.org
Fri Feb 11 14:17:22 EST 2011
Author: jef
Date: 2011-02-11 11:17:22 -0800 (Fri, 11 Feb 2011)
New Revision: 15156
Removed:
trunk/qgis/src/plugins/spit/qgsdbfbase.h
trunk/qgis/src/plugins/spit/qgsshapefile.cpp
fix #2551
Deleted: trunk/qgis/src/plugins/spit/qgsdbfbase.h
--- trunk/qgis/src/plugins/spit/qgsdbfbase.h 2011-02-11 16:23:17 UTC (rev 15155)
+++ trunk/qgis/src/plugins/spit/qgsdbfbase.h 2011-02-11 19:17:22 UTC (rev 15156)
@@ -1,90 +0,0 @@
- qgsbdfbase.h - Dbase IV Header
- Date : 25-Dec-2003
- Copyright : (C) 2003 by Gary E.Sherman
- email : sherman at mrcc.com
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-/* $Id$ */
-// Dbase header structure
-#ifndef _MSC_VER
-#include <stdint.h>
-#else
-typedef __int32 int32_t;
-typedef __int16 int16_t;
-#endif
-struct DbaseHeader
- unsigned char valid_dbf;
- char year;
- char month;
- char day;
- int32_t num_recs;
- int16_t size_hdr;
- int16_t size_rec;
- char reserved[3];
- char lan[13];
- char reserved2[4];
-// Field descriptor array - defines a field and its attributes (type,
-// length, etc.
-struct FieldDescriptorArray
- char field_name[11];
- char field_type;
- int32_t field_addr; /* used only in memory */
- unsigned char field_length;
- unsigned char field_decimal;
- char reserved[2];
- char work_area;
- char lan[2];
- char set_fields;
- char reserved2[8];
-// Typedefs
-typedef struct FieldDescriptorArray Fda;
-typedef struct DbaseHeader DbH;
-// Field Array class
-class DbaseFieldArray
- public:
- DbaseFieldArray( int numberOfFields );
- void addField( char *name, char type, unsigned char length,
- unsigned char decimal );
- int getNumFields();
- Fda *getField( int index );
- private:
- struct FieldDescriptorArray *fda;
- unsigned int fieldCount;
- int numFields;
-// Dbase file class (incomplete implementation)
-class DbaseFile
- public:
- DbaseFile( char *fileName, int numRecords, int recordSize, DbaseFieldArray &fda );
- void writeHeader();
- void writeFieldDescriptors();
- void writeRecord( const char *data );
- void closeFile();
- struct DbaseHeader header;
- private:
- char * fileName;
- int numRecords;
- int recordSize;
- DbaseFieldArray fieldArray;
- long pos;
- bool firstRecord;
Modified: trunk/qgis/src/plugins/spit/qgsshapefile.cpp
--- trunk/qgis/src/plugins/spit/qgsshapefile.cpp 2011-02-11 16:23:17 UTC (rev 15155)
+++ trunk/qgis/src/plugins/spit/qgsshapefile.cpp 2011-02-11 19:17:22 UTC (rev 15156)
@@ -19,9 +19,6 @@
#include <QApplication>
#include <ogr_api.h>
#include <cpl_conv.h>
-#include <string>
-#include <fstream>
-#include <cstdio>
#include <QFile>
#include <QProgressDialog>
@@ -31,7 +28,6 @@
#include <QFileInfo>
#include "qgsapplication.h"
-#include "qgsdbfbase.h"
#include "cpl_error.h"
#include "qgsshapefile.h"
#include "qgis.h"
@@ -40,13 +36,6 @@
#include "qgspgutil.h"
#include "qgslogger.h"
-// for htonl
-#ifdef WIN32
-#include <winsock.h>
-#else
-#include <netinet/in.h>
-#endif
#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1800
#define TO8F(x) (x).toUtf8().constData()
#else
@@ -187,59 +176,36 @@
QgsDebugMsg( "After escaping, geom_type is : " + geom_type );
delete[] esc_str;
- QString file( fileName );
- file.replace( file.length() - 3, 3, "dbf" );
- // open the dbf file
- std::ifstream dbf( file.toUtf8(), std::ios::in | std::ios::binary );
- // read header
- DbaseHeader dbh;
- dbf.read(( char * )&dbh, sizeof( dbh ) );
- // Check byte order
- if ( htonl( 1 ) == 1 )
+ int numFields = OGR_F_GetFieldCount( feat );
+ for ( int n = 0; n < numFields; n++ )
- /* DbaseHeader is stored in little-endian format.
- * The num_recs, size_hdr and size_rec fields must be byte-swapped when read
- * on a big-endian processor. Currently only size_hdr is used.
- unsigned char *byte = reinterpret_cast<unsigned char *>( &dbh.size_hdr );
- unsigned char t = *byte; *byte = *( byte + 1 ); *( byte + 1 ) = t;
- Fda fda;
- QString str_type = "varchar(";
- for ( int field_count = 0, bytes_read = sizeof( dbh ); bytes_read < dbh.size_hdr - 1; field_count++, bytes_read += sizeof( fda ) )
- dbf.read(( char * )&fda, sizeof( fda ) );
- switch ( fda.field_type )
+ OGRFieldDefnH fld = OGR_F_GetFieldDefnRef( feat, n );
+ column_names.push_back( codec->toUnicode( OGR_Fld_GetNameRef( fld ) ) );
+ switch ( OGR_Fld_GetType( fld ) )
- case 'N':
- if (( int )fda.field_decimal > 0 )
- column_types.push_back( "float" );
- else
- column_types.push_back( "int" );
+ case OFTInteger:
+ column_types.push_back( "int" );
break;
- case 'F': column_types.push_back( "float" );
+ case OFTReal:
+ column_types.push_back( "float" );
break;
- case 'D': column_types.push_back( "date" );
+ case OFTString:
+ column_types.push_back( QString( "varchar(%1)" ).arg( OGR_Fld_GetWidth( fld ) ) );
break;
- case 'C':
- str_type = QString( "varchar(%1)" ).arg( fda.field_length );
- column_types.push_back( str_type );
+ case OFTDate:
+ column_types.push_back( "date" );
break;
- case 'L': column_types.push_back( "boolean" );
+ case OFTTime:
+ column_types.push_back( "time" );
break;
+ case OFTDateTime:
+ column_types.push_back( "timestamp" );
+ break;
default:
column_types.push_back( "varchar(256)" );
break;
- dbf.close();
- int numFields = OGR_F_GetFieldCount( feat );
- for ( int n = 0; n < numFields; n++ )
- QString s = codec->toUnicode( OGR_Fld_GetNameRef( OGR_F_GetFieldDefnRef( feat, n ) ) );
- column_names.push_back( s );
else valid = false;
