[QGIS Commit] r15171 - in branches/Release-1_6_0/src:
analysis/raster analysis/vector app/ogr core/raster mapserver
plugins/georeferencer plugins/ogr_converter
plugins/oracle_raster plugins/spit providers/ogr
svn_qgis at osgeo.org
Mon Feb 14 13:53:38 EST 2011
Author: jef
Date: 2011-02-14 10:53:38 -0800 (Mon, 14 Feb 2011)
New Revision: 15171
branches/Release-1_6_0/src/analysis/raster/qgsninecellfilter.cpp
branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.cpp
branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.h
branches/Release-1_6_0/src/analysis/vector/qgszonalstatistics.cpp
branches/Release-1_6_0/src/app/ogr/qgsnewogrconnection.cpp
branches/Release-1_6_0/src/core/raster/qgsrasterlayer.cpp
branches/Release-1_6_0/src/mapserver/qgssldparser.cpp
branches/Release-1_6_0/src/plugins/georeferencer/qgsimagewarper.cpp
branches/Release-1_6_0/src/plugins/ogr_converter/dialog.cpp
branches/Release-1_6_0/src/plugins/ogr_converter/translator.cpp
branches/Release-1_6_0/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp
branches/Release-1_6_0/src/plugins/spit/qgsshapefile.cpp
branches/Release-1_6_0/src/providers/ogr/qgsogrprovider.cpp
backport r15148
Modified: branches/Release-1_6_0/src/analysis/raster/qgsninecellfilter.cpp
--- branches/Release-1_6_0/src/analysis/raster/qgsninecellfilter.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/analysis/raster/qgsninecellfilter.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -19,6 +19,11 @@
#include "cpl_string.h"
#include <QProgressDialog>
+#if defined(GDAL_VERSION_NUM) && GDAL_VERSION_NUM >= 1800
+#define TO8(x) (x).toUtf8().constData()
+#else
+#define TO8(x) (x).toLocal8Bit().constData()
+#endif
QgsNineCellFilter::QgsNineCellFilter( const QString& inputFile, const QString& outputFile, const QString& outputFormat ): \
mInputFile( inputFile ), mOutputFile( outputFile ), mOutputFormat( outputFormat ), mCellSizeX( -1 ), mCellSizeY( -1 ), mInputNodataValue( -1 ), mOutputNodataValue( -1 )
@@ -191,7 +196,7 @@
GDALDatasetH QgsNineCellFilter::openInputFile( int& nCellsX, int& nCellsY )
- GDALDatasetH inputDataset = GDALOpen( mInputFile.toLocal8Bit().data(), GA_ReadOnly );
+ GDALDatasetH inputDataset = GDALOpen( TO8( mInputFile ), GA_ReadOnly );
if ( inputDataset != NULL )
nCellsX = GDALGetRasterXSize( inputDataset );
Modified: branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.cpp
--- branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -22,6 +22,12 @@
+#else
+#endif
QgsRasterCalculator::QgsRasterCalculator( const QString& formulaString, const QString& outputFile, const QString& outputFormat,
const QgsRectangle& outputExtent, int nOutputColumns, int nOutputRows, const QVector<QgsRasterCalculatorEntry>& rasterEntries ): mFormulaString( formulaString ), mOutputFile( outputFile ), mOutputFormat( outputFormat ),
mOutputRectangle( outputExtent ), mNumOutputColumns( nOutputColumns ), mNumOutputRows( nOutputRows ), mRasterEntries( rasterEntries )
@@ -57,7 +63,7 @@
return 2;
- GDALDatasetH inputDataset = GDALOpen( it->raster->source().toLocal8Bit().data(), GA_ReadOnly );
+ GDALDatasetH inputDataset = GDALOpen( TO8( it->raster->source() ), GA_ReadOnly );
if( inputDataset == NULL )
return 2;
Modified: branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.h
--- branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.h 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/analysis/raster/qgsrastercalculator.h 2011-02-14 18:53:38 UTC (rev 15171)
@@ -61,8 +61,22 @@
GDALDatasetH openOutputFile( GDALDriverH outputDriver );
/**Reads raster pixels from a dataset/band
- @param targetGeotransformation transformation parameters of the requested raster array (not necessarily the same as the transform of the source dataset */
- void readRasterPart( double* targetGeotransform, int xOffset, int yOffset, int nCols, int nRows, double* sourceTransform, GDALRasterBandH sourceBand, float* rasterBuffer );
+ @param targetGeotransform transformation parameters of the requested raster array
+ (not necessarily the same as the transform of the source dataset)
+ @param xOffset x offset
+ @param yOffset y offset
+ @param nCols number of columns
+ @param nRows number of rows
+ @param sourceTransform source transformation
+ @param sourceBand source band
+ @param rasterBuffer raster buffer
+ void readRasterPart( double* targetGeotransform,
+ int xOffset, int yOffset,
+ int nCols, int nRows,
+ double* sourceTransform,
+ GDALRasterBandH sourceBand,
+ float* rasterBuffer );
/**Compares two geotransformations (six parameter double arrays*/
bool transformationsEqual( double* t1, double* t2 ) const;
Modified: branches/Release-1_6_0/src/analysis/vector/qgszonalstatistics.cpp
--- branches/Release-1_6_0/src/analysis/vector/qgszonalstatistics.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/analysis/vector/qgszonalstatistics.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -23,6 +23,12 @@
+#else
+#endif
QgsZonalStatistics::QgsZonalStatistics( QgsVectorLayer* polygonLayer, const QString& rasterFile, const QString& attributePrefix, int rasterBand )
: mRasterFilePath( rasterFile )
, mRasterBand( rasterBand )
@@ -60,7 +66,7 @@
//open the raster layer and the raster band
GDALAllRegister();
- GDALDatasetH inputDataset = GDALOpen( mRasterFilePath.toLocal8Bit().data(), GA_ReadOnly );
+ GDALDatasetH inputDataset = GDALOpen( TO8( mRasterFilePath ), GA_ReadOnly );
if ( inputDataset == NULL )
return 3;
Modified: branches/Release-1_6_0/src/app/ogr/qgsnewogrconnection.cpp
--- branches/Release-1_6_0/src/app/ogr/qgsnewogrconnection.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/app/ogr/qgsnewogrconnection.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -29,6 +29,11 @@
#include <ogr_api.h>
#include <cpl_error.h>
+#define TO8F(x) (x).toUtf8().constData()
+#else
+#define TO8F(x) QFile::encodeName( x ).constData()
+#endif
QgsNewOgrConnection::QgsNewOgrConnection( QWidget *parent, const QString& connType, const QString& connName, Qt::WFlags fl )
: QDialog( parent, fl ),
@@ -83,7 +88,7 @@
OGRDataSourceH poDS;
OGRSFDriverH pahDriver;
CPLErrorReset();
- poDS = OGROpen( QFile::encodeName( uri ).constData(), false, &pahDriver );
+ poDS = OGROpen( TO8F( uri ), false, &pahDriver );
if ( poDS == NULL )
QMessageBox::information( this, tr( "Test connection" ), tr( "Connection failed - Check settings and try again.\n\nExtended error information:\n%1" ).arg( QString::fromUtf8( CPLGetLastErrorMsg() ) ) );
Modified: branches/Release-1_6_0/src/core/raster/qgsrasterlayer.cpp
--- branches/Release-1_6_0/src/core/raster/qgsrasterlayer.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/core/raster/qgsrasterlayer.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -74,6 +74,11 @@
// doubles can take for the current system. (Yes, 20 was arbitrary.)
#define TINY_VALUE std::numeric_limits<double>::epsilon() * 20
+#else
+#endif
QgsRasterLayer::QgsRasterLayer(
QString const & path,
@@ -452,7 +457,7 @@
CPLErrorReset();
//open the file using gdal making sure we have handled locale properly
- myDataset = GDALOpen( QFile::encodeName( theFileNameQString ).constData(), GA_ReadOnly );
+ myDataset = GDALOpen( TO8F( theFileNameQString ), GA_ReadOnly );
if ( myDataset == NULL )
if ( CPLGetLastErrorNo() != CPLE_OpenFailed )
@@ -1002,12 +1007,12 @@
//close the gdal dataset and reopen it in read / write mode
GDALClose( mGdalDataset );
- mGdalBaseDataset = GDALOpen( QFile::encodeName( mDataSource ).constData(), GA_Update );
+ mGdalBaseDataset = GDALOpen( TO8F( mDataSource ), GA_Update );
// if the dataset couldn't be opened in read / write mode, tell the user
if ( !mGdalBaseDataset )
- mGdalBaseDataset = GDALOpen( QFile::encodeName( mDataSource ).constData(), GA_ReadOnly );
+ mGdalBaseDataset = GDALOpen( TO8F( mDataSource ), GA_ReadOnly );
//Since we are not a virtual warped dataset, mGdalDataSet and mGdalBaseDataset are supposed to be the same
mGdalDataset = mGdalBaseDataset;
return "ERROR_WRITE_FORMAT";
@@ -1077,7 +1082,7 @@
//something bad happenend
//QString myString = QString (CPLGetLastError());
GDALClose( mGdalBaseDataset );
@@ -1104,7 +1109,7 @@
//close the gdal dataset and reopen it in read only mode
@@ -5290,7 +5295,7 @@
mGdalDataset = NULL;
//open the dataset making sure we handle char encoding of locale properly
- mGdalBaseDataset = GDALOpen( QFile::encodeName( theFilename ).constData(), GA_ReadOnly );
+ mGdalBaseDataset = GDALOpen( TO8F( theFilename ), GA_ReadOnly );
if ( mGdalBaseDataset == NULL )
Modified: branches/Release-1_6_0/src/mapserver/qgssldparser.cpp
--- branches/Release-1_6_0/src/mapserver/qgssldparser.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/mapserver/qgssldparser.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -76,6 +76,12 @@
#include "qgsidwinterpolator.h"
#include "qgstininterpolator.h"
+#else
+#endif
QgsSLDParser::QgsSLDParser( QDomDocument* doc ): QgsConfigParser(), mXMLDoc( doc )
mSLDNamespace = "http://www.opengis.net/sld";
@@ -1279,15 +1285,6 @@
GDALRasterBandH hBand;
GDALDatasetH hSrcDS;
- QByteArray pszSrcData = rasterLayer->source().toLocal8Bit();
- QByteArray pszDstData = tmpFileName.toLocal8Bit();
- QByteArray pszElevData = propertyName.toLocal8Bit();
- const char *pszSrcFilename = pszSrcData.data();
- const char *pszDstFilename = pszDstData.data();
- const char *pszElevAttrib = pszElevData.data();
- const char *pszFormat = "ESRI Shapefile";
int numberOfLevels = 0;
double currentLevel = 0.0;
@@ -1315,7 +1312,7 @@
int b3D = FALSE, bNoDataSet = FALSE, bIgnoreNoData = FALSE;
- hSrcDS = GDALOpen( pszSrcFilename, GA_ReadOnly );
+ hSrcDS = GDALOpen( TO8( rasterLayer->source() ), GA_ReadOnly );
if ( hSrcDS == NULL )
exit( 2 );
@@ -1344,19 +1341,18 @@
/* Create the outputfile. */
OGRDataSourceH hDS;
- OGRSFDriverH hDriver = OGRGetDriverByName( pszFormat );
+ OGRSFDriverH hDriver = OGRGetDriverByName( "ESRI Shapefile" );
OGRFieldDefnH hFld;
OGRLayerH hLayer;
int nElevField = -1;
if ( hDriver == NULL )
- fprintf( FCGI_stderr, "Unable to find format driver named %s.\n",
- pszFormat );
+ fprintf( FCGI_stderr, "Unable to find format driver named 'ESRI Shapefile'.\n" );
exit( 10 );
- hDS = OGR_Dr_CreateDataSource( hDriver, pszDstFilename, NULL );
+ hDS = OGR_Dr_CreateDataSource( hDriver, TO8( tmpFileName ), NULL );
if ( hDS == NULL )
exit( 1 );
@@ -1371,9 +1367,9 @@
OGR_L_CreateField( hLayer, hFld, FALSE );
OGR_Fld_Destroy( hFld );
- if ( pszElevAttrib )
+ if ( !propertyName.isEmpty() )
- hFld = OGR_Fld_Create( pszElevAttrib, OFTReal );
+ hFld = OGR_Fld_Create( TO8( propertyName ), OFTReal );
OGR_Fld_SetWidth( hFld, 12 );
OGR_Fld_SetPrecision( hFld, 3 );
Modified: branches/Release-1_6_0/src/plugins/georeferencer/qgsimagewarper.cpp
--- branches/Release-1_6_0/src/plugins/georeferencer/qgsimagewarper.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/plugins/georeferencer/qgsimagewarper.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -31,6 +31,12 @@
#include "qgsimagewarper.h"
#include "qgsgeoreftransform.h"
+#else
+#endif
bool QgsImageWarper::mWarpCanceled = false;
QgsImageWarper::QgsImageWarper( QWidget *theParent )
@@ -44,7 +50,7 @@
// Open input file
GDALAllRegister();
- hSrcDS = GDALOpen( QFile::encodeName( input ).constData(), GA_ReadOnly );
+ hSrcDS = GDALOpen( TO8F( input ), GA_ReadOnly );
if ( hSrcDS == NULL ) return false;
// Setup warp options.
Modified: branches/Release-1_6_0/src/plugins/ogr_converter/dialog.cpp
--- branches/Release-1_6_0/src/plugins/ogr_converter/dialog.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/plugins/ogr_converter/dialog.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -32,6 +32,12 @@
+#else
+#endif
Dialog::Dialog( QWidget* parent, Qt::WFlags fl )
@@ -158,7 +164,7 @@
comboSrcLayer->clear();
- OGRDataSourceH ds = OGROpen( url.toAscii().constData(), 0, 0 );
+ OGRDataSourceH ds = OGROpen( TO8( url ), 0, 0 );
if ( 0 != ds )
QString lyrName;
@@ -199,7 +205,7 @@
bool success = false;
if ( 0 != ds )
success = true;
Modified: branches/Release-1_6_0/src/plugins/ogr_converter/translator.cpp
--- branches/Release-1_6_0/src/plugins/ogr_converter/translator.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/plugins/ogr_converter/translator.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -20,6 +20,14 @@
+#define FROM8(x) QString::fromUtf8(x)
+#else
+#define FROM8(x) QString::fromLocal8Bit(x)
+#endif
Translator::Translator()
: mDstUpdate( false ), mDstLayerOverwrite( true )
@@ -122,7 +130,7 @@
// TODO: Support translation of all layers from input data source
//for (int i = 0; i < OGR_DS_GetLayerCount(); ++i)
- OGRLayerH srcLayer = OGR_DS_GetLayerByName( srcDs, mSrcLayer.toAscii().constData() );
+ OGRLayerH srcLayer = OGR_DS_GetLayerByName( srcDs, TO8( mSrcLayer ) );
if ( 0 == srcLayer )
QgsDebugMsg( "Can not find layer: " + mSrcLayer );
@@ -198,8 +206,7 @@
// TODO: Implement SRS transformation
OGRSpatialReferenceH dstLayerSrs = OGR_L_GetSpatialRef( srcLayer );
- dstLayer = OGR_DS_CreateLayer( dstDs, mDstLayer.toAscii().constData(),
- dstLayerSrs, geomType, 0 );
+ dstLayer = OGR_DS_CreateLayer( dstDs, TO8( mDstLayer ), dstLayerSrs, geomType, 0 );
// TODO: Append and createion options not implemented
// else if (!mDstLayerAppend)
@@ -369,7 +376,8 @@
OGRDataSourceH Translator::openDataSource( QString const& url, bool readOnly )
- OGRDataSourceH ds = OGROpen( url.toAscii().constData(), !readOnly, 0 );
+ OGRDataSourceH ds = OGROpen( TO8( url ), !readOnly, 0 );
if ( 0 == ds )
QgsDebugMsg( "Failed to open: " + url );
@@ -400,7 +408,7 @@
// Create the output data source
// TODO: Add support for creation options
- ds = OGR_Dr_CreateDataSource( drv, url.toAscii().constData(), 0 );
+ ds = OGR_Dr_CreateDataSource( drv, TO8( url ), 0 );
if ( 0 == ds )
Modified: branches/Release-1_6_0/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp
--- branches/Release-1_6_0/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/plugins/oracle_raster/qgsselectgeoraster_ui.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -26,6 +26,12 @@
#include "qgsvectorlayer.h"
+#else
+#endif
QgsOracleSelectGeoraster::QgsOracleSelectGeoraster( QWidget* parent,
QgisInterface* iface,
Qt::WFlags fl ) : QDialog( parent, fl ), mIface( iface )
@@ -187,7 +193,7 @@
* Try to open georaster dataset
- hDS = GDALOpenShared( identification.toAscii(), eAccess );
+ hDS = GDALOpenShared( TO8( identification ), eAccess );
buttonBox->button( QDialogButtonBox::Ok )->setEnabled( false );
if ( hDS == NULL )
Modified: branches/Release-1_6_0/src/plugins/spit/qgsshapefile.cpp
--- branches/Release-1_6_0/src/plugins/spit/qgsshapefile.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/plugins/spit/qgsshapefile.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -47,13 +47,18 @@
#include <netinet/in.h>
#endif
+#else
+#endif
QgsShapeFile::QgsShapeFile( QString name, QString encoding )
fileName = name;
features = 0;
QgsApplication::registerOgrDrivers();
- ogrDataSource = OGROpen( QFile::encodeName( fileName ).constData(), false, NULL );
+ ogrDataSource = OGROpen( TO8F( fileName ), false, NULL );
if ( ogrDataSource != NULL )
valid = true;
Modified: branches/Release-1_6_0/src/providers/ogr/qgsogrprovider.cpp
--- branches/Release-1_6_0/src/providers/ogr/qgsogrprovider.cpp 2011-02-14 17:19:31 UTC (rev 15170)
+++ branches/Release-1_6_0/src/providers/ogr/qgsogrprovider.cpp 2011-02-14 18:53:38 UTC (rev 15171)
@@ -54,6 +54,16 @@
+ GDALVersionInfo( "RELEASE_NAME" )
+#else
+#endif
class QgsCPLErrorHandler
static void CPL_STDCALL showError( CPLErr errClass, int errNo, const char *msg )
@@ -146,12 +156,12 @@
QgsDebugMsg( "mLayerName: " + mLayerName );
QgsDebugMsg( "mSubsetString: " + mSubsetString );
CPLSetConfigOption( "OGR_ORGANIZE_POLYGONS", "ONLY_CCW" ); // "SKIP" returns MULTIPOLYGONs for multiringed POLYGONs
- ogrDataSource = OGROpen( QFile::encodeName( mFilePath ).constData(), true, &ogrDriver );
+ ogrDataSource = OGROpen( TO8F( mFilePath ), true, &ogrDriver );
if ( ogrDataSource == NULL )
// try to open read-only
- ogrDataSource = OGROpen( QFile::encodeName( mFilePath ).constData(), false, &ogrDriver );
+ ogrDataSource = OGROpen( TO8F( mFilePath ), false, &ogrDriver );
//TODO Need to set a flag or something to indicate that the layer
//TODO is in read-only mode, otherwise edit ops will fail
@@ -175,7 +185,7 @@
else
- ogrOrigLayer = OGR_DS_GetLayerByName( ogrDataSource, mLayerName.toLocal8Bit().data() );
+ ogrOrigLayer = OGR_DS_GetLayerByName( ogrDataSource, TO8( mLayerName ) );
ogrLayer = ogrOrigLayer;
@@ -306,7 +316,7 @@
for ( unsigned int i = 0; i < layerCount() ; i++ )
- QString theLayerName = QString::fromLocal8Bit( OGR_FD_GetName( OGR_L_GetLayerDefn( OGR_DS_GetLayer( ogrDataSource, i ) ) ) );
+ QString theLayerName = FROM8( OGR_FD_GetName( OGR_L_GetLayerDefn( OGR_DS_GetLayer( ogrDataSource, i ) ) ) );
OGRwkbGeometryType layerGeomType = OGR_FD_GetGeomType( OGR_L_GetLayerDefn( OGR_DS_GetLayer( ogrDataSource, i ) ) );
int theLayerFeatureCount = OGR_L_GetFeatureCount( OGR_DS_GetLayer( ogrDataSource, i ), 1 ) ;
