[QGIS Commit] r15176 - in trunk/qgis/src: app core ui
svn_qgis at osgeo.org
Wed Feb 16 04:11:48 EST 2011
Author: mhugent
Date: 2011-02-16 01:11:48 -0800 (Wed, 16 Feb 2011)
New Revision: 15176
trunk/qgis/src/app/qgslabelinggui.cpp
trunk/qgis/src/core/qgspallabeling.cpp
trunk/qgis/src/core/qgspallabeling.h
trunk/qgis/src/ui/qgslabelingguibase.ui
[FEATURE]: possibility to set label distance in map units
Modified: trunk/qgis/src/app/qgslabelinggui.cpp
--- trunk/qgis/src/app/qgslabelinggui.cpp 2011-02-15 09:20:27 UTC (rev 15175)
+++ trunk/qgis/src/app/qgslabelinggui.cpp 2011-02-16 09:11:48 UTC (rev 15176)
@@ -74,12 +74,14 @@
populateDataDefinedCombos( lyr );
// placement
+ int distUnitIndex = lyr.distInMapUnits ? 1 : 0;
switch ( lyr.placement )
case QgsPalLayerSettings::AroundPoint:
radAroundPoint->setChecked( true );
radAroundCentroid->setChecked( true );
spinDistPoint->setValue( lyr.dist );
+ mPointDistanceUnitComboBox->setCurrentIndex( distUnitIndex );
//spinAngle->setValue(lyr.angle);
break;
case QgsPalLayerSettings::OverPoint:
@@ -107,6 +109,7 @@
if ( lyr.placement == QgsPalLayerSettings::Line || lyr.placement == QgsPalLayerSettings::Curved )
spinDistLine->setValue( lyr.dist );
+ mLineDistanceUnitComboBox->setCurrentIndex( distUnitIndex );
chkLineAbove->setChecked( lyr.placementFlags & QgsPalLayerSettings::AboveLine );
chkLineBelow->setChecked( lyr.placementFlags & QgsPalLayerSettings::BelowLine );
chkLineOn->setChecked( lyr.placementFlags & QgsPalLayerSettings::OnLine );
@@ -202,7 +205,7 @@
lyr.placement = QgsPalLayerSettings::AroundPoint;
lyr.dist = spinDistPoint->value();
- //lyr.angle = spinAngle->value();
+ lyr.distInMapUnits = ( mPointDistanceUnitComboBox->currentIndex() == 1 );
else if (( stackedPlacement->currentWidget() == pagePoint && radOverPoint->isChecked() )
|| ( stackedPlacement->currentWidget() == pagePolygon && radOverCentroid->isChecked() ) )
@@ -216,6 +219,7 @@
bool curved = ( stackedPlacement->currentWidget() == pageLine && radLineCurved->isChecked() );
lyr.placement = ( curved ? QgsPalLayerSettings::Curved : QgsPalLayerSettings::Line );
lyr.dist = spinDistLine->value();
+ lyr.distInMapUnits = ( mLineDistanceUnitComboBox->currentIndex() == 1 );
if ( chkLineAbove->isChecked() )
lyr.placementFlags |= QgsPalLayerSettings::AboveLine;
if ( chkLineBelow->isChecked() )
@@ -276,7 +280,6 @@
lyr.minFeatureSize = mMinSizeSpinBox->value();
lyr.fontSizeInMapUnits = ( mFontSizeUnitComboBox->currentIndex() == 1 );
//data defined labeling
setDataDefinedProperty( mSizeAttributeComboBox, QgsPalLayerSettings::Size, lyr );
setDataDefinedProperty( mColorAttributeComboBox, QgsPalLayerSettings::Color, lyr );
Modified: trunk/qgis/src/core/qgspallabeling.cpp
--- trunk/qgis/src/core/qgspallabeling.cpp 2011-02-15 09:20:27 UTC (rev 15175)
+++ trunk/qgis/src/core/qgspallabeling.cpp 2011-02-16 09:11:48 UTC (rev 15176)
@@ -135,6 +135,7 @@
rasterCompressFactor = 1.0;
addDirectionSymbol = false;
fontSizeInMapUnits = false;
+ distInMapUnits = false;
QgsPalLayerSettings::QgsPalLayerSettings( const QgsPalLayerSettings& s )
@@ -161,6 +162,7 @@
rasterCompressFactor = s.rasterCompressFactor;
addDirectionSymbol = s.addDirectionSymbol;
fontSizeInMapUnits = s.fontSizeInMapUnits;
+ distInMapUnits = s.distInMapUnits;
dataDefinedProperties = s.dataDefinedProperties;
fontMetrics = NULL;
@@ -286,6 +288,7 @@
addDirectionSymbol = layer->customProperty( "labeling/addDirectionSymbol" ).toBool();
minFeatureSize = layer->customProperty( "labeling/minFeatureSize" ).toDouble();
fontSizeInMapUnits = layer->customProperty( "labeling/fontSizeInMapUnits" ).toBool();
+ distInMapUnits = layer->customProperty( "labeling/distInMapUnits" ).toBool();
_readDataDefinedPropertyMap( layer, dataDefinedProperties );
@@ -320,6 +323,7 @@
layer->setCustomProperty( "labeling/addDirectionSymbol", addDirectionSymbol );
layer->setCustomProperty( "labeling/minFeatureSize", minFeatureSize );
layer->setCustomProperty( "labeling/fontSizeInMapUnits", fontSizeInMapUnits );
+ layer->setCustomProperty( "labeling/distInMapUnits", distInMapUnits );
_writeDataDefinedPropertyMap( layer, dataDefinedProperties );
@@ -574,7 +578,15 @@
if ( distance != 0 )
- feat->setDistLabel( qAbs( ptOne.x() - ptZero.x() )* distance * vectorScaleFactor );
+ if( distInMapUnits ) //convert distance from mm/map units to pixels
+ distance /= context.mapToPixel().mapUnitsPerPixel();
+ else //mm
+ distance *= vectorScaleFactor;
+ feat->setDistLabel( qAbs( ptOne.x() - ptZero.x() )* distance );
//add parameters for data defined labeling to QgsPalGeometry
Modified: trunk/qgis/src/core/qgspallabeling.h
--- trunk/qgis/src/core/qgspallabeling.h 2011-02-15 09:20:27 UTC (rev 15175)
+++ trunk/qgis/src/core/qgspallabeling.h 2011-02-16 09:11:48 UTC (rev 15176)
@@ -115,6 +115,7 @@
// Works only if Placement == Line
bool addDirectionSymbol;
bool fontSizeInMapUnits; //true if font size is in map units (otherwise in points)
+ bool distInMapUnits; //true if distance is in map units (otherwise in mm)
// called from register feature hook
void calculateLabelSize( const QFontMetricsF* fm, QString text, double& labelX, double& labelY );
Modified: trunk/qgis/src/ui/qgslabelingguibase.ui
--- trunk/qgis/src/ui/qgslabelingguibase.ui 2011-02-15 09:20:27 UTC (rev 15175)
+++ trunk/qgis/src/ui/qgslabelingguibase.ui 2011-02-16 09:11:48 UTC (rev 15176)
@@ -393,8 +393,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>640</width>
- <height>483</height>
+ <width>643</width>
+ <height>435</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_13">
@@ -658,7 +658,7 @@
<item>
<widget class="QStackedWidget" name="stackedOptions">
<property name="currentIndex">
- <number>1</number>
+ <number>0</number>
</property>
<widget class="QWidget" name="pageOptionsPoint">
<layout class="QGridLayout" name="gridLayout_7">
@@ -675,14 +675,10 @@
<item row="0" column="1">
<widget class="QDoubleSpinBox" name="spinDistPoint">
<property name="decimals">
- <number>2</number>
+ <number>4</number>
</property>
- </widget>
- </item>
- <item row="0" column="2">
- <widget class="QLabel" name="label_22">
- <property name="text">
- <string>mm</string>
+ <property name="maximum">
+ <double>999999999.000000000000000</double>
</property>
</widget>
</item>
@@ -710,6 +706,20 @@
</property>
</widget>
</item>
+ <item row="0" column="2">
+ <widget class="QComboBox" name="mPointDistanceUnitComboBox">
+ <item>
+ <property name="text">
+ <string>In mm</string>
+ </property>
+ </item>
+ <item>
+ <string>In map units</string>
+ </property>
+ </item>
+ </widget>
+ </item>
</layout>
</widget>
<widget class="QWidget" name="pageOptionsLine">
@@ -781,15 +791,25 @@
<item>
<widget class="QDoubleSpinBox" name="spinDistLine">
</property>
+ </property>
</widget>
</item>
<item>
- <widget class="QLabel" name="label_27">
- </property>
+ <widget class="QComboBox" name="mLineDistanceUnitComboBox">
+ <item>
+ </property>
+ </item>
+ <item>
+ </property>
+ </item>
</widget>
</item>
</layout>
@@ -827,8 +847,8 @@
<rect>
<x>0</x>
<y>0</y>
- <height>615</height>
+ <height>532</height>
</rect>
</property>
<layout class="QGridLayout" name="gridLayout_11">
