[QGIS Commit] r15180 - in trunk/qgis: python/core src/app/legend src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Feb 17 04:15:25 EST 2011
Author: mhugent
Date: 2011-02-17 01:15:25 -0800 (Thu, 17 Feb 2011)
New Revision: 15180
   trunk/qgis/python/core/qgsvectorlayer.sip
   trunk/qgis/src/app/legend/qgslegendlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
Safer handling of layers with unknown geometry
Modified: trunk/qgis/python/core/qgsvectorlayer.sip
--- trunk/qgis/python/core/qgsvectorlayer.sip	2011-02-16 23:11:04 UTC (rev 15179)
+++ trunk/qgis/python/core/qgsvectorlayer.sip	2011-02-17 09:15:25 UTC (rev 15180)
@@ -145,6 +145,10 @@
   /** Returns point, line or polygon */
   QGis::GeometryType geometryType() const;
+  /** Returns true if this is a geometry layer and false in case of NoGeometry (table only) or UnknownGeometry
+  @note added in 1.7*/
+  bool hasGeometryType() const;
   /**Returns the WKBType or WKBUnknown in case of error*/
   QGis::WkbType wkbType() const;
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp	2011-02-16 23:11:04 UTC (rev 15179)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp	2011-02-17 09:15:25 UTC (rev 15180)
@@ -63,7 +63,7 @@
   Qt::ItemFlags flags = Qt::ItemIsEditable | Qt::ItemIsEnabled | Qt::ItemIsSelectable;
   QgsVectorLayer *vlayer = qobject_cast<QgsVectorLayer *>( layer );
-  if ( !vlayer || vlayer->geometryType() != QGis::NoGeometry )
+  if ( !vlayer || vlayer->hasGeometryType() )
     flags |= Qt::ItemIsUserCheckable;
@@ -195,7 +195,7 @@
   SymbologyList itemList;
-  if ( layer->geometryType() != QGis::NoGeometry )
+  if ( layer->hasGeometryType() )
     //add the new items
     QString lw, uv, label;
@@ -288,13 +288,17 @@
   QSize iconSize( 16, 16 );
-  SymbologyList itemList = layer->rendererV2()->legendSymbologyItems( iconSize );
-  if ( mShowFeatureCount )
+  QgsFeatureRendererV2* renderer = layer->rendererV2();
+  if ( renderer )
-    updateItemListCountV2( itemList, layer );
+    SymbologyList itemList = renderer->legendSymbologyItems( iconSize );
+    if ( mShowFeatureCount )
+      updateItemListCountV2( itemList, layer );
+    changeSymbologySettings( layer, itemList );
-  changeSymbologySettings( layer, itemList );
 void QgsLegendLayer::rasterLayerSymbology( QgsRasterLayer* layer )
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2011-02-16 23:11:04 UTC (rev 15179)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2011-02-17 09:15:25 UTC (rev 15180)
@@ -127,7 +127,7 @@
     setCoordinateSystem();
     QSettings settings;
-    if ( settings.value( "/qgis/use_symbology_ng", false ).toBool() && geometryType() != QGis::NoGeometry )
+    if ( settings.value( "/qgis/use_symbology_ng", false ).toBool() && hasGeometryType() )
       // using symbology-ng!
       setUsingRendererV2( true );
@@ -142,7 +142,7 @@
     // if the default style failed to load or was disabled use some very basic defaults
-    if ( !defaultLoadedFlag && geometryType() != QGis::NoGeometry )
+    if ( !defaultLoadedFlag && hasGeometryType() )
       // add single symbol renderer
       if ( mUsingRendererV2 )
@@ -240,7 +240,7 @@
 void QgsVectorLayer::setDisplayField( QString fldName )
-  if ( geometryType() == QGis::NoGeometry )
+  if ( !hasGeometryType() )
     return;
   // If fldName is provided, use it as the display field, otherwise
@@ -320,7 +320,7 @@
 // This method will probably be removed again in the near future!
 void QgsVectorLayer::drawLabels( QgsRenderContext& rendererContext )
     return;
   QgsDebugMsg( "Starting draw of labels" );
@@ -711,7 +711,7 @@
 void QgsVectorLayer::drawRendererV2( QgsRenderContext& rendererContext, bool labeling )
     return;
   QSettings settings;
@@ -776,7 +776,7 @@
 void QgsVectorLayer::drawRendererV2Levels( QgsRenderContext& rendererContext, bool labeling )
     return;
   QHash< QgsSymbolV2*, QList<QgsFeature> > features; // key = symbol, value = array of features
@@ -916,7 +916,7 @@
 bool QgsVectorLayer::draw( QgsRenderContext& rendererContext )
     return true;
   //set update threshold before each draw to make sure the current setting is picked up
@@ -1293,7 +1293,7 @@
 void QgsVectorLayer::setRenderer( QgsRenderer * r )
     return;
   if ( r != mRenderer )
@@ -1354,6 +1354,12 @@
   return QGis::UnknownGeometry;
+bool QgsVectorLayer::hasGeometryType() const
+  QGis::GeometryType t = geometryType();
+  return ( t != QGis::NoGeometry && t != QGis::UnknownGeometry );
 QGis::WkbType QgsVectorLayer::wkbType() const
   return ( QGis::WkbType )( mWkbType );
@@ -1422,7 +1428,7 @@
 void QgsVectorLayer::updateExtents()
     return;
   mLayerExtent.setMinimal();
@@ -1921,7 +1927,7 @@
 bool QgsVectorLayer::insertVertex( double x, double y, int atFeatureId, int beforeVertex )
     return false;
   if ( !mEditable )
@@ -1960,7 +1966,7 @@
 bool QgsVectorLayer::moveVertex( double x, double y, int atFeatureId, int atVertex )
     return false;
   if ( !mEditable )
@@ -2000,7 +2006,7 @@
 bool QgsVectorLayer::deleteVertex( int atFeatureId, int atVertex )
     return false;
   if ( !mEditable )
@@ -2074,7 +2080,7 @@
 int QgsVectorLayer::addRing( const QList<QgsPoint>& ring )
     return 5;
   int addRingReturnCode = 5; //default: return code for 'ring not inserted'
@@ -2111,7 +2117,7 @@
 int QgsVectorLayer::addIsland( const QList<QgsPoint>& ring )
     return 6;
   //number of selected features must be 1
@@ -2188,7 +2194,7 @@
 int QgsVectorLayer::translateFeature( int featureId, double dx, double dy )
     return 1;
   //look if geometry of selected feature already contains geometry changes
@@ -2246,7 +2252,7 @@
 int QgsVectorLayer::splitFeatures( const QList<QgsPoint>& splitLine, bool topologicalEditing )
     return 4;
   QgsFeatureList newFeatures; //store all the newly created features
@@ -2358,7 +2364,7 @@
 int QgsVectorLayer::removePolygonIntersections( QgsGeometry* geom )
     return 1;
   int returnValue = 0;
@@ -2393,7 +2399,7 @@
 int QgsVectorLayer::addTopologicalPoints( QgsGeometry* geom )
     return 1;
   if ( !geom )
@@ -2500,7 +2506,7 @@
 int QgsVectorLayer::addTopologicalPoints( const QgsPoint& p )
     return 1;
   QMultiMap<double, QgsSnappingResult> snapResults; //results from the snapper object
@@ -2825,7 +2831,7 @@
 bool QgsVectorLayer::readSymbology( const QDomNode& node, QString& errorMessage )
-  if ( geometryType() != QGis::NoGeometry )
+  if ( hasGeometryType() )
     // try renderer v2 first
     QDomElement rendererElement = node.firstChildElement( RENDERER_TAG_NAME );
@@ -3020,7 +3026,7 @@
   QDomElement mapLayerNode = node.toElement();
@@ -3198,7 +3204,7 @@
 bool QgsVectorLayer::changeGeometry( int fid, QgsGeometry* geom )
-  if ( !mEditable || !mDataProvider || geometryType() == QGis::NoGeometry )
+  if ( !mEditable || !mDataProvider || !hasGeometryType() )
     return false;
@@ -3831,7 +3837,7 @@
 bool QgsVectorLayer::copySymbologySettings( const QgsMapLayer& other )
     return false;
   const QgsVectorLayer* vl = qobject_cast<const QgsVectorLayer *>( &other );
@@ -3899,7 +3905,7 @@
 bool QgsVectorLayer::snapPoint( QgsPoint& point, double tolerance )
     return false;
@@ -3926,7 +3932,7 @@
                                      QMultiMap<double, QgsSnappingResult>& snappingResults,
                                      QgsSnapper::SnappingType snap_to )
     return 1;
   if ( snappingTolerance <= 0 || !mDataProvider )
@@ -4033,7 +4039,7 @@
 int QgsVectorLayer::insertSegmentVerticesForSnap( const QList<QgsSnappingResult>& snapResults )
     return 1;
   int returnval = 0;
@@ -4262,7 +4268,7 @@
   //we only nee to do that if the srs is not alreay valid
   if ( !mCRS->isValid() )
       mCRS->setValidationHint( tr( "Specify CRS for layer %1" ).arg( name() ) );
       mCRS->validate();
@@ -4456,7 +4462,7 @@
 void QgsVectorLayer::setRendererV2( QgsFeatureRendererV2* r )
     return;
   delete mRendererV2;
@@ -4468,7 +4474,7 @@
 void QgsVectorLayer::setUsingRendererV2( bool usingRendererV2 )
     return;
   mUsingRendererV2 = usingRendererV2;
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2011-02-16 23:11:04 UTC (rev 15179)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2011-02-17 09:15:25 UTC (rev 15180)
@@ -232,6 +232,10 @@
More information about the QGIS-commit mailing list
