[QGIS Commit] r15197 - in trunk/qgis: cmake python/core
	python/pyspatialite/src src/analysis src/app src/app/legend
	src/core src/core/composer src/gui src/mapserver
	src/plugins/diagram_overlay src/plugins/georeferencer
	src/plugins/offline_editing src/plugins/ogr_converter
	src/plugins/spatialquery src/plugins/sqlanywhere
	src/providers/sqlanywhere
	src/providers/sqlanywhere/sqlanyconnection tests/src/core
    svn_qgis at osgeo.org
    Fri Feb 18 10:05:35 EST 2011
Author: jef
Date: 2011-02-18 07:05:35 -0800 (Fri, 18 Feb 2011)
New Revision: 15197
   trunk/qgis/cmake/SIPMacros.cmake
   trunk/qgis/python/core/conversions.sip
   trunk/qgis/python/pyspatialite/src/statement.c
   trunk/qgis/src/analysis/CMakeLists.txt
   trunk/qgis/src/app/CMakeLists.txt
   trunk/qgis/src/app/legend/qgslegend.cpp
   trunk/qgis/src/app/qgssnappingdialog.cpp
   trunk/qgis/src/core/composer/qgscomposerattributetable.cpp
   trunk/qgis/src/core/composer/qgslegendmodel.cpp
   trunk/qgis/src/core/qgis.h
   trunk/qgis/src/core/qgsapplication.h
   trunk/qgis/src/core/qgslabel.h
   trunk/qgis/src/core/qgsmaplayer.h
   trunk/qgis/src/core/qgsmaprenderer.h
   trunk/qgis/src/core/qgsoverlayobject.h
   trunk/qgis/src/core/qgssearchtreenode.h
   trunk/qgis/src/core/qgsvectordataprovider.cpp
   trunk/qgis/src/core/qgsvectordataprovider.h
   trunk/qgis/src/core/qgsvectorfilewriter.h
   trunk/qgis/src/core/qgsvectorlayer.cpp
   trunk/qgis/src/core/qgsvectorlayer.h
   trunk/qgis/src/gui/CMakeLists.txt
   trunk/qgis/src/gui/qgisinterface.h
   trunk/qgis/src/gui/qgsmapcanvasmap.h
   trunk/qgis/src/mapserver/qgis_map_serv.cpp
   trunk/qgis/src/mapserver/qgscomparisonfilter.cpp
   trunk/qgis/src/mapserver/qgsprojectparser.cpp
   trunk/qgis/src/mapserver/qgssldparser.cpp
   trunk/qgis/src/mapserver/qgswmsserver.cpp
   trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlayplugin.cpp
   trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
   trunk/qgis/src/plugins/offline_editing/offline_editing.cpp
   trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
   trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
   trunk/qgis/src/plugins/sqlanywhere/sanewconnectionbase.ui
   trunk/qgis/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp
   trunk/qgis/src/providers/sqlanywhere/sqlanyconnection/CMakeLists.txt
   trunk/qgis/tests/src/core/regression992.cpp
   trunk/qgis/tests/src/core/testqgsmaprenderer.cpp
   trunk/qgis/tests/src/core/testqgsrasterlayer.cpp
   trunk/qgis/tests/src/core/testqgsrenderers.cpp
   trunk/qgis/tests/src/core/testqgsvectorlayer.cpp
add QGISDEPRECATED macro and fix a bunch of warnings
Modified: trunk/qgis/cmake/SIPMacros.cmake
--- trunk/qgis/cmake/SIPMacros.cmake	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/cmake/SIPMacros.cmake	2011-02-18 15:05:35 UTC (rev 15197)
@@ -85,6 +85,17 @@
         ENDIF( ${CONCAT_NUM} LESS ${SIP_CONCAT_PARTS} )
     ENDFOREACH(CONCAT_NUM RANGE 0 ${SIP_CONCAT_PARTS} )
+    # Suppress warnings
+    IF(MSVC AND PEDANTIC)
+      # 4996 deprecation warnings (bindings re-export deprecated methods)
+      # 4701 potentially uninitialized variable used (sip generated code)
+      # 4702 unreachable code (sip generated code)
+      ADD_DEFINITIONS( /wd4996 /wd4701 /wd4702 )
+    ELSE(MSVC)
+      # disable all warnings
+      ADD_DEFINITIONS( -w )
+    ENDIF(MSVC)
     ADD_CUSTOM_COMMAND(
         OUTPUT ${_sip_output_files}
         COMMAND ${CMAKE_COMMAND} -E echo ${message}
Modified: trunk/qgis/python/core/conversions.sip
--- trunk/qgis/python/core/conversions.sip	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/python/core/conversions.sip	2011-02-18 15:05:35 UTC (rev 15197)
@@ -36,6 +36,8 @@
 #include <QVector>
 #if (SIP_VERSION >= 0x040900)
 #define sipClass_QString ((sipWrapperType *) sipTypeAsPyTypeObject (sipType_QString))
+#endif
+#if (SIP_VERSION >= 0x040900 && SIP_VERSION < 0x040c00)
 #define sipClass_QVariant ((sipWrapperType *) sipTypeAsPyTypeObject (sipType_QVariant))
 #endif
 %End
@@ -116,6 +118,8 @@
 #include <QVector>
+#endif
 #endif
 %End
@@ -274,6 +278,8 @@
 #include <QSet>
+#endif
 #endif
 %End
@@ -329,6 +335,8 @@
 #include <QSet>
+#endif
 #endif
 %End
@@ -404,6 +412,8 @@
 #include <QMap>
+#endif
 #endif
 %End
@@ -525,6 +535,8 @@
 #include <QMap>
+#endif
 #endif
 %End
@@ -630,6 +642,8 @@
 #include <QMap>
+#endif
 #endif
 %End
@@ -842,6 +856,8 @@
 #include <QMultiMap>
+#endif
 #endif
 %End
@@ -964,6 +980,8 @@
 #include <QMap>
+#endif
 #endif
 %End
Modified: trunk/qgis/python/pyspatialite/src/statement.c
--- trunk/qgis/python/pyspatialite/src/statement.c	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/python/pyspatialite/src/statement.c	2011-02-18 15:05:35 UTC (rev 15197)
@@ -490,8 +490,6 @@
         pos++;
-    return 0;
 PyTypeObject pysqlite_StatementType = {
Modified: trunk/qgis/src/analysis/CMakeLists.txt
--- trunk/qgis/src/analysis/CMakeLists.txt	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/analysis/CMakeLists.txt	2011-02-18 15:05:35 UTC (rev 15197)
@@ -42,6 +42,15 @@
 ADD_BISON_FILES_PREFIX(QGIS_ANALYSIS_SRCS raster raster/qgsrastercalcparser.yy)
+IF (MSVC AND PEDANTIC)
+# disable warnings
+# 4065 switch with default and no case
+# 4702 unreachable code
+SET_SOURCE_FILES_PROPERTIES(
+                ${CMAKE_BINARY_DIR}/src/analysis/qgsrastercalcparser.cpp
+                PROPERTIES COMPILE_FLAGS "-wd4065 -wd4702")
+ENDIF (MSVC AND PEDANTIC)
 SET(QGIS_ANALYSIS_MOC_HDRS
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/app/CMakeLists.txt	2011-02-18 15:05:35 UTC (rev 15197)
@@ -321,6 +321,9 @@
 IF (WIN32)
   IF (MSVC)
     SET (QGIS_APP_SRCS ${QGIS_APP_SRCS} ${CMAKE_CURRENT_SOURCE_DIR}/qgis_win32.rc)
+    # disable deprecation warnings
+    SET_SOURCE_FILES_PROPERTIES(qgisappinterface.cpp PROPERTIES COMPILE_FLAGS /wd4996)
   ELSE(MSVC)
     # Icon for windows MINGW
Modified: trunk/qgis/src/app/legend/qgslegend.cpp
--- trunk/qgis/src/app/legend/qgslegend.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/app/legend/qgslegend.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -626,7 +626,7 @@
   setItemExpanded( llayer, true );
-  refreshLayerSymbology( layer->getLayerID() );
+  refreshLayerSymbology( layer->id() );
   updateMapCanvasLayerSet();
@@ -738,7 +738,7 @@
     QgsLegendGroup *cg = dynamic_cast<QgsLegendGroup *>( child );
     if ( cl )
-      QgsMapLayerRegistry::instance()->removeMapLayer( cl->layer()->getLayerID() );
+      QgsMapLayerRegistry::instance()->removeMapLayer( cl->layer()->id() );
     else if ( cg )
       removeGroup( cg );
@@ -755,7 +755,7 @@
   if ( !ml )
     return;
-  QgsLegendLayer *layer = findLegendLayer( ml->getLayerID() );
+  QgsLegendLayer *layer = findLegendLayer( ml->id() );
   if ( !layer )
     return;
@@ -915,7 +915,7 @@
       QDomElement legendlayerfilenode = document.createElement( "legendlayerfile" );
       // layer id
-      legendlayerfilenode.setAttribute( "layerid", layer->getLayerID() );
+      legendlayerfilenode.setAttribute( "layerid", layer->id() );
       layerfilegroupnode.appendChild( legendlayerfilenode );
       // visible flag
@@ -1022,7 +1022,7 @@
       // load symbology
-      refreshLayerSymbology( currentLayer->layer()->getLayerID() );
+      refreshLayerSymbology( currentLayer->layer()->id() );
       if ( isOpen )
@@ -1101,7 +1101,7 @@
     theLegendLayer = dynamic_cast<QgsLegendLayer *>( theItem );
     if ( theLegendLayer ) //item is a legend layer
-      if ( theLegendLayer->layer()->getLayerID() == layerKey )
+      if ( theLegendLayer->layer()->id() == layerKey )
         return theLegendLayer;
@@ -1221,7 +1221,7 @@
       if ( lLayer->layer() )
         QList<QString> layerList;
-        layerList.push_back( lLayer->layer()->getLayerID() );
+        layerList.push_back( lLayer->layer()->id() );
         groupLayerList.push_back( qMakePair( QString(), layerList ) );
@@ -1240,7 +1240,7 @@
@@ -1449,7 +1449,7 @@
     if ( ll )
       QgsMapLayer *lyr = ll->layer();
-      layers.push_front( lyr->getLayerID() );
+      layers.push_front( lyr->id() );
@@ -1729,8 +1729,8 @@
     layer->setMinimumMaximumUsingLastExtent();
-    layer->setCacheImage(NULL);
+    layer->setCacheImage( NULL );
     mMapCanvas->refresh();
@@ -1847,7 +1847,7 @@
     QgsLegendLayer *ll = dynamic_cast<QgsLegendLayer *>( item );
     if ( ll && ll->layer() )
-      QgsMapLayerRegistry::instance()->removeMapLayer( ll->layer()->getLayerID() );
+      QgsMapLayerRegistry::instance()->removeMapLayer( ll->layer()->id() );
       continue;
Modified: trunk/qgis/src/app/qgssnappingdialog.cpp
--- trunk/qgis/src/app/qgssnappingdialog.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/app/qgssnappingdialog.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -191,7 +191,7 @@
       mLayerTreeWidget->setItemWidget( item, 5, cbxAvoidIntersection );
-    int idx = layerIdList.indexOf( currentVectorLayer->getLayerID() );
+    int idx = layerIdList.indexOf( currentVectorLayer->id() );
     if ( idx < 0 )
       // no settings for this layer yet
@@ -218,7 +218,7 @@
     cbxUnits->setCurrentIndex( toleranceUnitList[idx].toInt() );
     if ( cbxAvoidIntersection )
-      cbxAvoidIntersection->setChecked( avoidIntersectionsList.contains( currentVectorLayer->getLayerID() ) );
+      cbxAvoidIntersection->setChecked( avoidIntersectionsList.contains( currentVectorLayer->id() ) );
Modified: trunk/qgis/src/core/composer/qgscomposerattributetable.cpp
--- trunk/qgis/src/core/composer/qgscomposerattributetable.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/composer/qgscomposerattributetable.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -231,7 +231,7 @@
   if ( mVectorLayer )
-    composerTableElem.setAttribute( "vectorLayer", mVectorLayer->getLayerID() );
+    composerTableElem.setAttribute( "vectorLayer", mVectorLayer->id() );
   //display attributes
Modified: trunk/qgis/src/core/composer/qgslegendmodel.cpp
--- trunk/qgis/src/core/composer/qgslegendmodel.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/composer/qgslegendmodel.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -242,7 +242,7 @@
     currentSymbolItem->setIcon( QIcon( rasterLayer->legendAsPixmap( true ) ) );
-  currentSymbolItem->setLayerID( rasterLayer->getLayerID() );
+  currentSymbolItem->setLayerID( rasterLayer->id() );
   int currentRowCount = layerItem->rowCount();
   layerItem->setChild( currentRowCount, 0, currentSymbolItem );
@@ -338,7 +338,7 @@
   QgsComposerLayerItem* layerItem = new QgsComposerLayerItem( theMapLayer->name() );
-  layerItem->setLayerID( theMapLayer->getLayerID() );
+  layerItem->setLayerID( theMapLayer->id() );
   layerItem->setFlags( Qt::ItemIsEnabled | Qt::ItemIsSelectable );
   invisibleRootItem()->setChild( invisibleRootItem()->rowCount(), layerItem );
Modified: trunk/qgis/src/core/qgis.h
--- trunk/qgis/src/core/qgis.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgis.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -189,4 +189,18 @@
 #endif
 #endif
+#ifndef QGISDEPRECATED
+#ifndef Q_MOC_RUN
+#ifdef _MSC_VER
+#  define QGISDEPRECATED __declspec(deprecated)
+#elif __GNUC__
+#  define QGISDEPRECATED __attribute__((__deprecated__))
+#else
 #endif
+#else
+#define QGISDEPRECATED
+#endif
+#endif
+#endif
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsapplication.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -18,6 +18,8 @@
 #include <QApplication>
+#include <qgis.h>
 /** \ingroup core
  * Extends QApplication to provide access to QGIS specific resources such
  * as theme paths, database paths etc.
@@ -111,7 +113,7 @@
     //! Returns the paths to svg applications svg directory.
     //! @deprecated since 1.4
-    static const QString svgPath();
+    QGISDEPRECATED static const QString svgPath();
     //! Returns the path to the application prefix directory.
     static const QString prefixPath();
Modified: trunk/qgis/src/core/qgslabel.h
--- trunk/qgis/src/core/qgslabel.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgslabel.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -103,11 +103,11 @@
      *  \param rasterScaleFactor raster scale
      *  \deprecated
-    void renderLabel( QPainter* painter, const QgsRectangle& viewExtent,
-                      QgsCoordinateTransform* coordinateTransform,
-                      const QgsMapToPixel *transform,
-                      QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes = 0,
-                      double sizeScale = 1., double rasterScaleFactor = 1.0 )
+    QGISDEPRECATED void renderLabel( QPainter* painter, const QgsRectangle& viewExtent,
+                                     QgsCoordinateTransform* coordinateTransform,
+                                     const QgsMapToPixel *transform,
+                                     QgsFeature &feature, bool selected, QgsLabelAttributes *classAttributes = 0,
+                                     double sizeScale = 1., double rasterScaleFactor = 1.0 )
       QgsRenderContext r;
       r.setExtent( viewExtent );
@@ -148,7 +148,7 @@
     /** Pointer to default attributes.
      * @deprecated in version 2 as it is badly named. Rather use attributes.
      * @see labelAttributes method rather */
-    QgsLabelAttributes *layerAttributes( void );
+    QGISDEPRECATED QgsLabelAttributes *layerAttributes( void );
      * @note this replaces the to-be-deprecated layerAttributes method.
Modified: trunk/qgis/src/core/qgsmaplayer.h
--- trunk/qgis/src/core/qgsmaplayer.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsmaplayer.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -25,6 +25,7 @@
 #include <QVariant>
 #include <QImage>
+#include "qgis.h"
 #include "qgsrectangle.h"
 class QgsRenderContext;
@@ -75,7 +76,7 @@
     /** Get this layer's unique ID, this ID is used to access this layer from map layer registry
      * @deprecated use id()
-    QString getLayerID() const { return id(); }
+    QGISDEPRECATED QString getLayerID() const { return id(); }
     /** Set the display name of the layer
      * @param name New name for the layer
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsmaprenderer.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -135,7 +135,7 @@
     //! Return the measuring object
     //! @deprecated
-    QgsDistanceArea* distanceArea() { return mDistArea; }
+    QGISDEPRECATED QgsDistanceArea *distanceArea() { return mDistArea; }
     QGis::UnitType mapUnits() const;
     void setMapUnits( QGis::UnitType u );
Modified: trunk/qgis/src/core/qgsoverlayobject.h
--- trunk/qgis/src/core/qgsoverlayobject.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsoverlayobject.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -43,11 +43,11 @@
     /**Returns the feature geometry in geos format. The calling function does _not_ take
      ownership of the generated object. The geometry is in map coordinates
      @deprecated Please use geometry() and QgsGeometry::asGeos instead*/
-    GEOSGeometry* getGeosGeometry();
+    QGISDEPRECATED GEOSGeometry* getGeosGeometry();
     /**Feature geometry is released when object is destructed so this function is empty.
      * @deprecated nop
-    void releaseGeosGeometry( GEOSGeometry *the_geom ) { Q_UNUSED( the_geom ); }
+    QGISDEPRECATED void releaseGeosGeometry( GEOSGeometry *the_geom ) { Q_UNUSED( the_geom ); }
     //getters
     int width() const {return mWidth;}
Modified: trunk/qgis/src/core/qgssearchtreenode.h
--- trunk/qgis/src/core/qgssearchtreenode.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgssearchtreenode.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -26,6 +26,7 @@
 #include <QVariant>
 #include <QList>
+#include <qgis.h>
 #include <qgsfield.h>
 #include <qgsfeature.h>
@@ -155,7 +156,7 @@
     bool checkAgainst( const QgsFieldMap& fields, QgsFeature &f );
     //! @deprecated
-    bool checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
+    QGISDEPRECATED bool checkAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
     //! checks if there were errors during evaluation
     bool hasError() { return ( !mError.isEmpty() ); }
@@ -171,11 +172,11 @@
                    QgsFeature &f );
     //! @deprecated
-    bool getValue( QgsSearchTreeValue& value,
-                   QgsSearchTreeNode* node,
-                   const QgsFieldMap &fields,
-                   const QgsAttributeMap &attributes,
-                   QgsGeometry* geom = 0 );
+    QGISDEPRECATED bool getValue( QgsSearchTreeValue& value,
+                                  QgsSearchTreeNode* node,
+                                  const QgsFieldMap &fields,
+                                  const QgsAttributeMap &attributes,
+                                  QgsGeometry* geom = 0 );
     //! return a list of referenced columns in the tree
     //! @note added in 1.5
@@ -211,7 +212,7 @@
     QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, QgsFeature &f );
     //! @deprecated
-    QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
+    QGISDEPRECATED QgsSearchTreeValue valueAgainst( const QgsFieldMap& fields, const QgsAttributeMap& attributes, QgsGeometry* geom = 0 );
     //! strips mText when node is of string type
     void stripText();
Modified: trunk/qgis/src/core/qgsvectordataprovider.cpp
--- trunk/qgis/src/core/qgsvectordataprovider.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsvectordataprovider.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -87,15 +87,19 @@
 bool QgsVectorDataProvider::addAttributes( const QMap<QString, QString> &attributes )
-  const QMap<QString, QVariant::Type> &map = supportedNativeTypes();
+  const QList< NativeType > &types = nativeTypes();
   QList< QgsField > list;
   for ( QMap<QString, QString>::const_iterator it = attributes.constBegin(); it != attributes.constEnd(); it++ )
-    if ( !map.contains( it.value() ) )
+    int i;
+    for ( i = 0; i < types.size() && types[i].mTypeName != it.value(); i++ )
+    if ( i == types.size() )
       return false;
-    list << QgsField( it.key(), map[ it.value()], it.value() );
+    list << QgsField( it.key(), types[i].mType, it.value() );
   return addAttributes( list );
Modified: trunk/qgis/src/core/qgsvectordataprovider.h
--- trunk/qgis/src/core/qgsvectordataprovider.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsvectordataprovider.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -237,7 +237,7 @@
      * @return true in case of success and false in case of failure
      * @deprecated
-    virtual bool addAttributes( const QMap<QString, QString> &attributes );
+    QGISDEPRECATED virtual bool addAttributes( const QMap<QString, QString> &attributes );
      * Deletes existing attributes
@@ -345,9 +345,9 @@
      * Returns the names of the supported types
-     * @deprecated
+     * @deprecated use nativeTypes()
-    const QMap<QString, QVariant::Type> &supportedNativeTypes() const;
+    QGISDEPRECATED const QMap<QString, QVariant::Type> &supportedNativeTypes() const;
     /** Returns true if the provider is strict about the type of inserted features
           (e.g. no multipolygon in a polygon layer)
Modified: trunk/qgis/src/core/qgsvectorfilewriter.h
--- trunk/qgis/src/core/qgsvectorfilewriter.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsvectorfilewriter.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -58,15 +58,15 @@
     /** Write contents of vector layer to a shapefile
         @deprecated Use writeAsVectorFormat instead*/
-    static WriterError writeAsShapefile( QgsVectorLayer* layer,
-                                         const QString& shapefileName,
-                                         const QString& fileEncoding,
-                                         const QgsCoordinateReferenceSystem *destCRS,
-                                         bool onlySelected = false,
-                                         QString *errorMessage = 0,
-                                         const QStringList &datasourceOptions = QStringList(), // added in 1.6
-                                         const QStringList &layerOptions = QStringList() // added in 1.6
+    QGISDEPRECATED static WriterError writeAsShapefile( QgsVectorLayer* layer,
+        const QString& shapefileName,
+        const QString& fileEncoding,
+        const QgsCoordinateReferenceSystem *destCRS,
+        bool onlySelected = false,
+        QString *errorMessage = 0,
+        const QStringList &datasourceOptions = QStringList(), // added in 1.6
+        const QStringList &layerOptions = QStringList() // added in 1.6
     /** Write contents of vector layer to an (OGR supported) vector formt
         @note: this method was added in version 1.5*/
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -3263,12 +3263,13 @@
 bool QgsVectorLayer::addAttribute( QString name, QString type )
-  const QMap<QString, QVariant::Type> &map = mDataProvider->supportedNativeTypes();
+  const QList< QgsVectorDataProvider::NativeType > &types = mDataProvider->nativeTypes();
-  if ( !map.contains( type ) )
-    return false;
+  int i;
+  for ( i = 0; i < types.size() && types[i].mTypeName != type; i++ )
-  return addAttribute( QgsField( name, map[ type ], type ) );
+  return i < types.size() && addAttribute( QgsField( name, types[i].mType, type ) );
 void QgsVectorLayer::addAttributeAlias( int attIndex, QString aliasString )
Modified: trunk/qgis/src/core/qgsvectorlayer.h
--- trunk/qgis/src/core/qgsvectorlayer.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/core/qgsvectorlayer.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -494,7 +494,7 @@
     /** add an attribute field (but does not commit it)
       returns true if the field was added
       @deprecated */
-    bool addAttribute( QString name, QString type );
+    QGISDEPRECATED bool addAttribute( QString name, QString type );
     /**Sets an alias (a display name) for attributes to display in dialogs
       @note added in version 1.2*/
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/gui/CMakeLists.txt	2011-02-18 15:05:35 UTC (rev 15197)
@@ -104,6 +104,11 @@
 QT4_WRAP_CPP(QGIS_GUI_MOC_SRCS ${QGIS_GUI_MOC_HDRS})
+IF(MSVC AND PEDANTIC)
+  # disable deprecation warnings for qgisinterface (re-exporting deprecated methods)
+  SET_SOURCE_FILES_PROPERTIES(${CMAKE_BINARY_DIR}/src/gui/moc_qgisinterface.cxx PROPERTIES COMPILE_FLAGS "-wd4996")
+ENDIF(MSVC AND PEDANTIC)
 INCLUDE_DIRECTORIES(
   ${QT_QTUITOOLS_INCLUDE_DIR}
Modified: trunk/qgis/src/gui/qgisinterface.h
--- trunk/qgis/src/gui/qgisinterface.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/gui/qgisinterface.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -25,12 +25,7 @@
 class QDockWidget;
 class QMainWindow;
 class QWidget;
-#include <QObject>
-#include <QPair>
-#include <map>
 class QgsComposerView;
 class QgsMapLayer;
 class QgsMapCanvas;
@@ -39,6 +34,13 @@
 class QgsLegendInterface;
 class QgsFeature;
+#include <QObject>
+#include <QPair>
+#include <map>
+#include <qgis.h>
 /** \ingroup gui
  * QgisInterface
  * Abstract base class defining interfaces exposed by QgisApp and
@@ -147,6 +149,9 @@
     /** refresh the legend of a layer
      \deprecated use QgsLegendInterface::refreshLayerSymbology
+#ifndef Q_MOC_RUN
+    QGISDEPRECATED
+#endif
     virtual void refreshLegend( QgsMapLayer *l ) = 0;
     /** open layer properties dialog
@@ -185,6 +190,9 @@
      * @param useQgisDocDirectory If true, the URL will be formed by concatenating
      * url to the QGIS documentation directory path (prefix/share/doc)
+#ifndef Q_MOC_RUN
+    QGISDEPRECATED
+#endif
     virtual void openURL( QString url, bool useQgisDocDirectory = true ) = 0;
Modified: trunk/qgis/src/gui/qgsmapcanvasmap.h
--- trunk/qgis/src/gui/qgsmapcanvasmap.h	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/gui/qgsmapcanvasmap.h	2011-02-18 15:05:35 UTC (rev 15197)
@@ -20,6 +20,7 @@
 #include <QGraphicsRectItem>
 #include <QPixmap>
+#include <qgis.h>
 class QgsMapRenderer;
 class QgsMapCanvas;
@@ -48,9 +49,8 @@
     void setPanningOffset( const QPoint& point );
-    //deprecated. Please use paintDevice() function
-    //which is also save in case QImage is used
-    QPixmap& pixmap() { return mPixmap; }
+    //! @deprecated Please use paintDevice() function which is also save in case QImage is used
+    QGISDEPRECATED QPixmap& pixmap() { return mPixmap; }
     QPaintDevice& paintDevice();
Modified: trunk/qgis/src/mapserver/qgis_map_serv.cpp
--- trunk/qgis/src/mapserver/qgis_map_serv.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/mapserver/qgis_map_serv.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -152,7 +152,7 @@
   // Instantiate the plugin directory so that providers are loaded
   QgsProviderRegistry::instance( QgsApplication::pluginPath() );
-#ifdef QGSMSDEBUG && !_MSC_VER
+#if defined(QGSMSDEBUG) && !defined(_MSC_VER)
   //write to qgis_wms_server.log in application directory
   QgsMapServerLogger::instance()->setLogFilePath( qgsapp.applicationDirPath() + "/qgis_wms_server.log" );
 #endif
Modified: trunk/qgis/src/mapserver/qgscomparisonfilter.cpp
--- trunk/qgis/src/mapserver/qgscomparisonfilter.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/mapserver/qgscomparisonfilter.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -108,7 +108,7 @@
       break;
     case UNKNOWN:
     default:
-      return false;
+      break;
   return false; //soon...
Modified: trunk/qgis/src/mapserver/qgsprojectparser.cpp
--- trunk/qgis/src/mapserver/qgsprojectparser.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/mapserver/qgsprojectparser.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -65,7 +65,7 @@
     if ( layer )
       QgsMSDebugMsg( QString( "add layer %1 to map" ).arg( layer->id() ) );
-      layerMap.insert( layer->getLayerID(), layer );
+      layerMap.insert( layer->id(), layer );
 #if QGSMSDEBUG
     else
@@ -208,7 +208,7 @@
         continue;
-      if ( nonIdentifiableLayers.contains( currentLayer->getLayerID() ) )
+      if ( nonIdentifiableLayers.contains( currentLayer->id() ) )
         layerElem.setAttribute( "queryable", "0" );
Modified: trunk/qgis/src/mapserver/qgssldparser.cpp
--- trunk/qgis/src/mapserver/qgssldparser.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/mapserver/qgssldparser.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -573,7 +573,7 @@
           // if there is a viable text textSymbolizerElement
           if ( !textSymbolizerElement.isNull() )
-            QgsLabelAttributes * myLabelAttributes = vec->label()->layerAttributes();
+            QgsLabelAttributes * myLabelAttributes = vec->label()->labelAttributes();
             //element <Label> contains the attribute name
             QDomNodeList labelNodeList = textSymbolizerElement.elementsByTagName( "Label" );
             // if a viable label element is provided
Modified: trunk/qgis/src/mapserver/qgswmsserver.cpp
--- trunk/qgis/src/mapserver/qgswmsserver.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/mapserver/qgswmsserver.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -632,7 +632,7 @@
       //is there alias info for this vector layer?
       QMap< int, QString > layerAliasInfo;
-      QMap< QString, QMap< int, QString > >::const_iterator aliasIt = aliasInfo.find( currentLayer->getLayerID() );
+      QMap< QString, QMap< int, QString > >::const_iterator aliasIt = aliasInfo.find( currentLayer->id() );
       if ( aliasIt != aliasInfo.constEnd() )
         layerAliasInfo = aliasIt.value();
@@ -640,7 +640,7 @@
       //hidden attributes for this layer
       QSet<QString> layerHiddenAttributes;
-      QMap< QString, QSet<QString> >::const_iterator hiddenIt = hiddenAttributes.find( currentLayer->getLayerID() );
+      QMap< QString, QSet<QString> >::const_iterator hiddenIt = hiddenAttributes.find( currentLayer->id() );
       if ( hiddenIt != hiddenAttributes.constEnd() )
         layerHiddenAttributes = hiddenIt.value();
@@ -1180,7 +1180,7 @@
           //set the sourceSRS to the same as the destSRS
           theMapLayer->setCrs( destCRS );
-        layerKeys.push_front( theMapLayer->getLayerID() );
+        layerKeys.push_front( theMapLayer->id() );
         QgsMapLayerRegistry::instance()->addMapLayer( theMapLayer, false );
       else
Modified: trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlayplugin.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlayplugin.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/diagram_overlay/qgsdiagramoverlayplugin.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -17,6 +17,7 @@
 #include "qgsdiagramoverlayplugin.h"
 #include "qgisinterface.h"
+#include "qgslegendinterface.h"
 #include "qgsdiagramdialog.h"
 #include "qgsdiagramoverlay.h"
 #include "qgsmaplayerregistry.h"
@@ -111,9 +112,9 @@
         currentVectorLayer->addOverlay( newDiagramOverlay );
         //notify the legend that the layer legend needs to be changed
-        if ( mInterface )
+        if ( mInterface && mInterface->legendInterface() )
-          mInterface->refreshLegend( currentVectorLayer );
+          mInterface->legendInterface()->refreshLayerSymbology( currentVectorLayer );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -252,7 +252,7 @@
   //delete any old rasterlayers
   if ( mLayer )
-    QgsMapLayerRegistry::instance()->removeMapLayer( mLayer->getLayerID(), false );
+    QgsMapLayerRegistry::instance()->removeMapLayer( mLayer->id(), false );
   // Add raster
   addRaster( mRasterFileName );
@@ -775,7 +775,7 @@
 // Registry layer QGis
 void QgsGeorefPluginGui::layerWillBeRemoved( QString theLayerId )
-  mAgainAddRaster = mLayer && mLayer->getLayerID().compare( theLayerId ) == 0;
+  mAgainAddRaster = mLayer && mLayer->id().compare( theLayerId ) == 0;
 // ------------------------------ private ---------------------------------- //
Modified: trunk/qgis/src/plugins/offline_editing/offline_editing.cpp
--- trunk/qgis/src/plugins/offline_editing/offline_editing.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/offline_editing/offline_editing.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -547,7 +547,7 @@
         featureCount = 1;
         // update feature id lookup
-        int layerId = getOrCreateLayerId( db, newLayer->getLayerID() );
+        int layerId = getOrCreateLayerId( db, newLayer->id() );
         QList<int> offlineFeatureIds;
         newLayer->select( QgsAttributeList(), QgsRectangle(), false, false );
         while ( newLayer->nextFeature( f ) )
@@ -571,7 +571,7 @@
       // remove remote layer
-      QgsMapLayerRegistry::instance()->removeMapLayer( layer->getLayerID() );
+      QgsMapLayerRegistry::instance()->removeMapLayer( layer->id() );
Modified: trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui
--- trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/ogr_converter/ogrconverterguibase.ui	2011-02-18 15:05:35 UTC (rev 15197)
@@ -7,7 +7,7 @@
     <x>0</x>
     <y>0</y>
     <width>491</width>
-    <height>323</height>
+    <height>368</height>
    </rect>
   </property>
   <property name="sizePolicy">
@@ -43,6 +43,47 @@
       <string>Source</string>
      </property>
      <layout class="QGridLayout" name="gridLayout_2">
+      <item row="1" column="1" colspan="2">
+       <layout class="QGridLayout" name="gridLayout">
+        <property name="spacing">
+         <number>0</number>
+        </property>
+        <item row="0" column="0">
+         <widget class="QRadioButton" name="radioSrcFile">
+          <property name="text">
+           <string>File</string>
+          </property>
+         </widget>
+        </item>
+        <item row="0" column="2">
+         <widget class="QRadioButton" name="radioSrcProtocol">
+           <string>Remote source</string>
+          </property>
+         </widget>
+        </item>
+        <item row="0" column="1">
+         <widget class="QRadioButton" name="radioSrcDirectory">
+           <string>Directory</string>
+          </property>
+         </widget>
+        </item>
+        <item row="0" column="3">
+         <spacer name="horizontalSpacer">
+          <property name="orientation">
+           <enum>Qt::Horizontal</enum>
+          </property>
+          <property name="sizeHint" stdset="0">
+           <size>
+            <width>40</width>
+            <height>20</height>
+           </size>
+          </property>
+         </spacer>
+        </item>
+       </layout>
+      </item>
       <item row="5" column="0">
        <widget class="QLabel" name="labelSrcLayer">
         <property name="minimumSize">
@@ -125,60 +166,7 @@
         </property>
        </widget>
       </item>
-      <item row="1" column="1" colspan="2">
-       <layout class="QGridLayout" name="gridLayout">
-        <property name="spacing">
-         <number>0</number>
-        </property>
-        <item row="0" column="0">
-         <widget class="QRadioButton" name="radioSrcFile">
-          <property name="text">
-           <string>File</string>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="2">
-         <widget class="QRadioButton" name="radioSrcProtocol">
-           <string>Remote source</string>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="1">
-         <widget class="QRadioButton" name="radioSrcDirectory">
-           <string>Directory</string>
-          </property>
-         </widget>
-        </item>
-        <item row="0" column="3">
-         <spacer name="horizontalSpacer">
-          <property name="orientation">
-           <enum>Qt::Horizontal</enum>
-          </property>
-          <property name="sizeHint" stdset="0">
-           <size>
-            <width>40</width>
-            <height>20</height>
-           </size>
-          </property>
-         </spacer>
-        </item>
-       </layout>
-      </item>
      </layout>
-     <zorder>radioSrcFile</zorder>
-     <zorder>radioSrcDirectory</zorder>
-     <zorder>radioSrcProtocol</zorder>
-     <zorder>labelSrcLayer</zorder>
-     <zorder>labelSrcDataset</zorder>
-     <zorder>inputSrcDataset</zorder>
-     <zorder>comboSrcLayer</zorder>
-     <zorder>buttonSelectSrc</zorder>
-     <zorder></zorder>
-     <zorder>comboSrcFormats</zorder>
-     <zorder>labelSrcFormat</zorder>
     </widget>
    </item>
    <item>
Modified: trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp
--- trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/spatialquery/qgsspatialquerydialog.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -797,7 +797,7 @@
   addLayerCombobox( true, vectorLayer );
   addLayerCombobox( false, vectorLayer );
-  mMapIdVectorLayers.insert( vectorLayer->getLayerID(), vectorLayer );
+  mMapIdVectorLayers.insert( vectorLayer->id(), vectorLayer );
   // Verify is can enable buttonBox
   if ( !buttonBoxMain->button( QDialogButtonBox::Ok )->isEnabled() && targetLayerComboBox->count() > 1 )
Modified: trunk/qgis/src/plugins/sqlanywhere/sanewconnectionbase.ui
--- trunk/qgis/src/plugins/sqlanywhere/sanewconnectionbase.ui	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/plugins/sqlanywhere/sanewconnectionbase.ui	2011-02-18 15:05:35 UTC (rev 15197)
@@ -1,140 +1,141 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>SaNewConnectionBase</class>
- <widget class="QDialog" name="SaNewConnectionBase" >
-  <property name="geometry" >
+ <widget class="QDialog" name="SaNewConnectionBase">
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
     <width>323</width>
-    <height>274</height>
+    <height>436</height>
    </rect>
   </property>
-  <property name="sizePolicy" >
-   <sizepolicy vsizetype="MinimumExpanding" hsizetype="MinimumExpanding" >
+  <property name="sizePolicy">
+   <sizepolicy hsizetype="MinimumExpanding" vsizetype="MinimumExpanding">
     <horstretch>0</horstretch>
     <verstretch>0</verstretch>
    </sizepolicy>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Create a new SQL Anywhere connection</string>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <property name="modal" >
+  <property name="modal">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" >
-   <property name="margin" >
+  <layout class="QGridLayout">
+   <property name="margin">
     <number>9</number>
    </property>
-   <property name="spacing" >
     <number>6</number>
    </property>
-   <item row="0" column="0" >
-    <widget class="QGroupBox" name="GroupBox1" >
-     <property name="title" >
+    <widget class="QGroupBox" name="GroupBox1">
+     <property name="title">
       <string>Connection Information</string>
      </property>
        <number>0</number>
       </property>
        <number>5</number>
       </property>
-       <layout class="QHBoxLayout" >
+       <layout class="QHBoxLayout">
          <number>6</number>
         </property>
          <number>0</number>
         </property>
         <item>
-         <layout class="QVBoxLayout" >
+         <layout class="QVBoxLayout">
            <number>6</number>
           </property>
            <number>0</number>
           </property>
           <item>
-           <widget class="QLabel" name="TextLabel1" >
-            <property name="text" >
+           <widget class="QLabel" name="TextLabel1">
              <string>Name</string>
             </property>
-            <property name="buddy" >
+            <property name="buddy">
              <cstring>txtName</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel2" >
+           <widget class="QLabel" name="TextLabel2">
              <string>Host</string>
             </property>
              <cstring>txtHost</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel3" >
-		<string>Port</string>
+           <widget class="QLabel" name="TextLabel3">
+             <string>Port</string>
             </property>
              <cstring>txtPort</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel4" >
+           <widget class="QLabel" name="TextLabel4">
              <string>Server</string>
             </property>
              <cstring>txtServer</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel5" >
+           <widget class="QLabel" name="TextLabel5">
              <string>Database</string>
             </property>
              <cstring>txtDatabase</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel6" >
+           <widget class="QLabel" name="TextLabel6">
              <string>Connection Parameters</string>
             </property>
              <cstring>txtParameters</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel7" >
+           <widget class="QLabel" name="TextLabel7">
              <string>Username</string>
             </property>
              <cstring>txtUsername</cstring>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLabel" name="TextLabel8" >
+           <widget class="QLabel" name="TextLabel8">
              <string>Password</string>
             </property>
              <cstring>txtPassword</cstring>
             </property>
            </widget>
@@ -142,136 +143,136 @@
          </layout>
         </item>
         <item>
            <number>6</number>
           </property>
            <number>0</number>
           </property>
           <item>
-           <widget class="QLineEdit" name="txtName" >
-            <property name="toolTip" >
+           <widget class="QLineEdit" name="txtName">
+            <property name="toolTip">
              <string>Name of the new connection</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtHost" >
+           <widget class="QLineEdit" name="txtHost">
              <string>Name or IP address of computer hosting the database server (leave blank for local connections)</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtPort" >
-		<string>Port number used by the database server (leave blank for default 2638)</string>
+           <widget class="QLineEdit" name="txtPort">
+             <string>Port number used by the database server (leave blank for default 2638)</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtServer" >
-		<string>Name of the database server (leave blank for default server on host)</string>
+           <widget class="QLineEdit" name="txtServer">
+             <string>Name of the database server (leave blank for default server on host)</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtDatabase" >
-		<string>Name of the database (leave blank for default database on server)</string>
+           <widget class="QLineEdit" name="txtDatabase">
+             <string>Name of the database (leave blank for default database on server)</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtParameters" >
-		<string>Additional connection parameters</string>
+           <widget class="QLineEdit" name="txtParameters">
+             <string>Additional connection parameters</string>
             </property>
            </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtUsername" >
-		<string>Database username</string>
+           <widget class="QLineEdit" name="txtUsername">
+             <string>Database username</string>
             </property>
-	   </widget>
+           </widget>
           </item>
           <item>
-           <widget class="QLineEdit" name="txtPassword" >
-            <property name="echoMode" >
+           <widget class="QLineEdit" name="txtPassword">
+             <string>Database password</string>
+            </property>
+            <property name="echoMode">
              <enum>QLineEdit::Password</enum>
             </property>
-		<string>Database password</string>
-            </property>
            </widget>
           </item>
          </layout>
         </item>
        </layout>
       </item>
-      <item row="1" column="0" >
-       <layout class="QGridLayout" name="gridLayout" >
+      <item row="1" column="0">
+       <layout class="QGridLayout" name="gridLayout_1">
          <number>0</number>
         </property>
-         <widget class="QCheckBox" name="chkStoreUsername" >
+         <widget class="QCheckBox" name="chkStoreUsername">
+           <string>Save the connection username in the registry</string>
+          </property>
            <string>Save Username</string>
           </property>
-	   <string>Save the connection username in the registry</string>
-          </property>
          </widget>
         </item>
-        <item rowspan="2" row="0" column="1" >
-         <widget class="QPushButton" name="btnConnect" >
+        <item row="0" column="1" rowspan="2">
+         <widget class="QPushButton" name="btnConnect">
            <string>&Test Connect</string>
           </property>
          </widget>
         </item>
-         <widget class="QCheckBox" name="chkStorePassword" >
+         <widget class="QCheckBox" name="chkStorePassword">
+           <string>Save the connection password in the registry (WARNING: NOT SECURE)</string>
+          </property>
            <string>Save Password</string>
           </property>
-	   <string>Save the connection password in the registry (WARNING: NOT SECURE)</string>
-          </property>
          </widget>
         </item>
-        <item row="2" column="0" >
-         <widget class="QCheckBox" name="chkSimpleEncryption" >
+        <item row="2" column="0">
+         <widget class="QCheckBox" name="chkSimpleEncryption">
+           <string>Encrypt packets using simple encryption</string>
+          </property>
            <string>Simple Encryption</string>
           </property>
-	   <string>Encrypt packets using simple encryption</string>
-          </property>
          </widget>
         </item>
-        <item row="3" column="0" >
-         <widget class="QCheckBox" name="chkEstimateMetadata" >
+        <item row="3" column="0">
+         <widget class="QCheckBox" name="chkEstimateMetadata">
+           <string>Use estimates for certain layer properties such as cardinality, extent, etc. (improves performance)</string>
+          </property>
            <string>Estimate table metadata</string>
           </property>
-	   <string>Use estimates for certain layer properties such as cardinality, extent, etc. (improves performance)</string>
-          </property>
          </widget>
         </item>
-        <item row="4" column="0" >
-         <widget class="QCheckBox" name="chkOtherSchemas" >
+        <item row="4" column="0">
+         <widget class="QCheckBox" name="chkOtherSchemas">
+           <string>Search for geometry columns in tables owned by other users</string>
+          </property>
            <string>Search other users' tables</string>
           </property>
-	   <string>Search for geometry columns in tables owned by other users</string>
-          </property>
          </widget>
         </item>
        </layout>
@@ -279,16 +280,16 @@
      </layout>
     </widget>
    </item>
-    <widget class="QDialogButtonBox" name="buttonBox" >
-     <property name="standardButtons" >
-      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Ok|QDialogButtonBox::Help</set>
+    <widget class="QDialogButtonBox" name="buttonBox">
+     <property name="standardButtons">
+      <set>QDialogButtonBox::Cancel|QDialogButtonBox::Help|QDialogButtonBox::Ok</set>
      </property>
     </widget>
    </item>
   </layout>
  </widget>
- <layoutdefault spacing="6" margin="11" />
+ <layoutdefault spacing="6" margin="11"/>
  <tabstops>
   <tabstop>txtName</tabstop>
   <tabstop>txtHost</tabstop>
@@ -314,11 +315,11 @@
    <receiver>SaNewConnectionBase</receiver>
    <slot>reject()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>313</x>
      <y>501</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>451</x>
      <y>312</y>
     </hint>
@@ -330,11 +331,11 @@
    <slot>accept()</slot>
    <hints>
      <x>395</x>
      <y>501</y>
     </hint>
      <x>450</x>
      <y>287</y>
     </hint>
Modified: trunk/qgis/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp
--- trunk/qgis/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/providers/sqlanywhere/qgssqlanywhereprovider.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -550,7 +550,7 @@
   if ( !mKeyColumn.isEmpty() )
     bool  keyIsValid = true;
-    unsigned int colId;
+    unsigned int colId = 0;
     // test whether key column is a member of table and appropriate type
     sql = QString( "SELECT FIRST column_id "
@@ -1392,9 +1392,9 @@
 bool
 QgsSqlAnywhereProvider::changeAttributeValues( const QgsChangedAttributesMap & attr_map )
-  bool     ok = true;
-  sacapi_i32     code;
-  char     errbuf[SACAPI_ERROR_SIZE];
+  bool       ok = true;
+  sacapi_i32 code = 0;
+  char       errbuf[SACAPI_ERROR_SIZE];
   if ( !( mCapabilities & QgsVectorDataProvider::ChangeAttributeValues ) )
@@ -2089,7 +2089,7 @@
     // attempt to find a compatible planar srs
     bool foundProjection = false;
-    int projSrid;
+    int projSrid = -1;
     QString projStr;
     QString projMsg;
Modified: trunk/qgis/src/providers/sqlanywhere/sqlanyconnection/CMakeLists.txt
--- trunk/qgis/src/providers/sqlanywhere/sqlanyconnection/CMakeLists.txt	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/src/providers/sqlanywhere/sqlanyconnection/CMakeLists.txt	2011-02-18 15:05:35 UTC (rev 15197)
@@ -10,6 +10,7 @@
 IF (WIN32)
   IF (MSVC)
     ADD_DEFINITIONS("-DSACONN_EXPORT=__declspec(dllexport)")
+    SET_SOURCE_FILES_PROPERTIES(sacapi/sacapidll.c PROPERTIES COMPILE_FLAGS "-wd4152 -wd4055")
   ELSE (MSVC)
     ADD_DEFINITIONS("-USACONN_EXPORT \"-DSACONN_EXPORT=__declspec(dllexport)\"")
   ENDIF (MSVC)
Modified: trunk/qgis/tests/src/core/regression992.cpp
--- trunk/qgis/tests/src/core/regression992.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/tests/src/core/regression992.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -78,7 +78,7 @@
   // add the test layer to the maprender
   mpMapRenderer = new QgsMapRenderer();
   QStringList myLayers;
-  myLayers << mpRasterLayer->getLayerID();
+  myLayers << mpRasterLayer->id();
   mpMapRenderer->setLayerSet(myLayers);
   mReport += "<h1>Regression 992 Test</h1>\n";
   mReport += "<p>See <a href=\"https://trac.osgeo.org/qgis/ticket/992\">"
Modified: trunk/qgis/tests/src/core/testqgsmaprenderer.cpp
--- trunk/qgis/tests/src/core/testqgsmaprenderer.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/tests/src/core/testqgsmaprenderer.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -170,7 +170,7 @@
-  myLayers << mpPolysLayer->getLayerID();
+  myLayers << mpPolysLayer->id();
   mpMapRenderer->setLayerSet( myLayers );
   mReport += "<h1>Map Render Tests</h1>\n";
Modified: trunk/qgis/tests/src/core/testqgsrasterlayer.cpp
--- trunk/qgis/tests/src/core/testqgsrasterlayer.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/tests/src/core/testqgsrasterlayer.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -93,7 +93,7 @@
   mReport += "<h1>Raster Layer Tests</h1>\n";
@@ -134,7 +134,7 @@
 void TestQgsRasterLayer::landsatBasic()
-  myLayers << mpLandsatRasterLayer->getLayerID();
+  myLayers << mpLandsatRasterLayer->id();
   mpMapRenderer->setExtent( mpLandsatRasterLayer->extent() );
   QVERIFY( render( "landsat_basic" ) );
@@ -143,7 +143,7 @@
   //a qml that orders the rgb bands as 8,7,5
   QVERIFY( setQml( "875" ) );
@@ -218,7 +218,7 @@
       myRasterFileInfo.completeBaseName() );
   QgsMapLayerRegistry::instance()->addMapLayer( mypLayer, false );
-  QgsMapLayerRegistry::instance()->removeMapLayer( mypLayer->getLayerID() );
+  QgsMapLayerRegistry::instance()->removeMapLayer( mypLayer->id() );
   //cleanup
   //delete mypLayer;
Modified: trunk/qgis/tests/src/core/testqgsrenderers.cpp
--- trunk/qgis/tests/src/core/testqgsrenderers.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/tests/src/core/testqgsrenderers.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -119,9 +119,9 @@
-  myLayers << mpPointsLayer->getLayerID();
-  myLayers << mpLinesLayer->getLayerID();
+  myLayers << mpPointsLayer->id();
+  myLayers << mpLinesLayer->id();
   mReport += "<h1>Vector Renderer Tests</h1>\n";
Modified: trunk/qgis/tests/src/core/testqgsvectorlayer.cpp
--- trunk/qgis/tests/src/core/testqgsvectorlayer.cpp	2011-02-18 15:03:34 UTC (rev 15196)
+++ trunk/qgis/tests/src/core/testqgsvectorlayer.cpp	2011-02-18 15:05:35 UTC (rev 15197)
@@ -119,9 +119,9 @@
