[QGIS Commit] r15210 - in trunk/qgis/src: analysis/raster app
app/gps/qwtpolar core gui plugins/diagram_overlay providers/osm
svn_qgis at osgeo.org
Sat Feb 19 08:27:35 EST 2011
Author: jef
Date: 2011-02-19 05:27:35 -0800 (Sat, 19 Feb 2011)
New Revision: 15210
trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
trunk/qgis/src/app/CMakeLists.txt
trunk/qgis/src/app/gps/qwtpolar/qwt_polar_itemdict.cpp
trunk/qgis/src/app/qgisappinterface.h
trunk/qgis/src/core/CMakeLists.txt
trunk/qgis/src/core/qgssearchstringlexer.ll
trunk/qgis/src/core/qgssearchstringparser.yy
trunk/qgis/src/gui/CMakeLists.txt
trunk/qgis/src/gui/qgisinterface.h
trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp
trunk/qgis/src/providers/osm/osmstyle.cpp
fix internal use of deprecated methods and fix related warnings
Modified: trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
--- trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy 2011-02-19 13:27:35 UTC (rev 15210)
@@ -19,6 +19,11 @@
#include "qgsrastercalcnode.h"
+#ifdef _MSC_VER
+# pragma warnings( disable: 4065 ) // switch statement contains 'default' but no 'case' labels
+# pragma warnings( disable: 4701 ) // Potentially uninitialized local variable 'name' used
+#endif
// don't redeclare malloc/free
#define YYINCLUDED_STDLIB_H 1
Modified: trunk/qgis/src/app/CMakeLists.txt
--- trunk/qgis/src/app/CMakeLists.txt 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/app/CMakeLists.txt 2011-02-19 13:27:35 UTC (rev 15210)
@@ -349,11 +349,9 @@
IF(PEDANTIC)
# disable deprecation warnings
- IF(MSVC)
- SET_SOURCE_FILES_PROPERTIES(qgisappinterface.cpp PROPERTIES COMPILE_FLAGS /wd4996)
- ELSE(MSVC)
+ IF(NOT MSVC)
SET_SOURCE_FILES_PROPERTIES(qgisappinterface.cpp PROPERTIES COMPILE_FLAGS -Wno-deprecated)
- ENDIF(MSVC)
+ ENDIF(NOT MSVC)
ENDIF(PEDANTIC)
INCLUDE_DIRECTORIES(
Modified: trunk/qgis/src/app/gps/qwtpolar/qwt_polar_itemdict.cpp
--- trunk/qgis/src/app/gps/qwtpolar/qwt_polar_itemdict.cpp 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/app/gps/qwtpolar/qwt_polar_itemdict.cpp 2011-02-19 13:27:35 UTC (rev 15210)
@@ -28,9 +28,7 @@
// for lists in Qt4. The implementation below
// is slow, but there shouldn't be many plot items.
-#ifdef __GNUC__
-#warning binary search missing
-#endif
+ // TODO add binary search
#if QT_VERSION < 0x040000
QValueListIterator<QwtPolarItem *> it;
Modified: trunk/qgis/src/app/qgisappinterface.h
--- trunk/qgis/src/app/qgisappinterface.h 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/app/qgisappinterface.h 2011-02-19 13:27:35 UTC (rev 15210)
@@ -24,6 +24,11 @@
class QgisApp;
+#ifdef _MSC_VER
+# pragma warning( push )
+# pragma warning( disable: 4996 ) // declared deprecated
+#endif
/** \class QgisAppInterface
* \brief Interface class to provide access to private methods in QgisApp
* for use by plugins.
@@ -304,5 +309,8 @@
QgsAppLegendInterface legendIface;
+#ifdef _MSC_VER
+# pragma warning( pop )
+#endif
#endif //#define QGISAPPINTERFACE_H
Modified: trunk/qgis/src/core/CMakeLists.txt
--- trunk/qgis/src/core/CMakeLists.txt 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/core/CMakeLists.txt 2011-02-19 13:27:35 UTC (rev 15210)
@@ -212,20 +212,6 @@
ADD_BISON_FILES(QGIS_CORE_SRCS qgssearchstringparser.yy)
-# Disable compiler warnings for lex generated sources
-SET_SOURCE_FILES_PROPERTIES(
- ${CMAKE_BINARY_DIR}/src/core/flex_qgssearchstringlexer.cpp
- PROPERTIES COMPILE_FLAGS -w)
-IF (MSVC AND PEDANTIC)
-# disable warnings
-# 4065 switch with default and no case
-# 4702 unreachable code
- ${CMAKE_BINARY_DIR}/src/core/qgssearchstringparser.cpp
- PROPERTIES COMPILE_FLAGS "-wd4065 -wd4702")
-ENDIF (MSVC AND PEDANTIC)
SET(QGIS_CORE_MOC_HDRS
qgsapplication.h
qgscontexthelp.h
Modified: trunk/qgis/src/core/qgssearchstringlexer.ll
--- trunk/qgis/src/core/qgssearchstringlexer.ll 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/core/qgssearchstringlexer.ll 2011-02-19 13:27:35 UTC (rev 15210)
@@ -20,6 +20,7 @@
%option noyywrap
%option case-insensitive
%option never-interactive
+%option nounput
// ensure that lexer will be 8-bit (and not just 7-bit)
%option 8bit
@@ -35,6 +36,8 @@
// which doesn't in MSVC compiler
#define YY_NEVER_INTERACTIVE 1
+#define YY_NO_UNPUT // unused
#ifdef _MSC_VER
#define YY_NO_UNISTD_H
#endif
Modified: trunk/qgis/src/core/qgssearchstringparser.yy
--- trunk/qgis/src/core/qgssearchstringparser.yy 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/core/qgssearchstringparser.yy 2011-02-19 13:27:35 UTC (rev 15210)
@@ -23,6 +23,11 @@
#include <cstdlib>
#include "qgssearchtreenode.h"
+#ifdef _MSC_VER
+# pragma warning( disable: 4065 ) // switch statement contains 'default' but no 'case' labels
+# pragma warning( disable: 4702 ) // unreachable code
+#endif
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/gui/CMakeLists.txt 2011-02-19 13:27:35 UTC (rev 15210)
@@ -104,10 +104,6 @@
QT4_WRAP_CPP(QGIS_GUI_MOC_SRCS ${QGIS_GUI_MOC_HDRS})
-IF(MSVC AND PEDANTIC)
- # disable deprecation warnings for qgisinterface (re-exporting deprecated methods)
- SET_SOURCE_FILES_PROPERTIES(${CMAKE_BINARY_DIR}/src/gui/moc_qgisinterface.cxx PROPERTIES COMPILE_FLAGS "-wd4996")
-ENDIF(MSVC AND PEDANTIC)
${QT_QTUITOOLS_INCLUDE_DIR}
@@ -139,11 +135,14 @@
ENDIF (MSVC)
ENDIF (WIN32)
+IF(NOT MSVC)
+ # disable deprecation warnings for qgisinterface (re-exporting deprecated methods)
+ SET_SOURCE_FILES_PROPERTIES(${CMAKE_BINARY_DIR}/src/gui/moc_qgisinterface.cxx PROPERTIES COMPILE_FLAGS "-w")
+ENDIF(NOT MSVC)
# qgis_gui library
ADD_LIBRARY(qgis_gui SHARED ${QGIS_GUI_SRCS} ${QGIS_GUI_MOC_SRCS})
SET_TARGET_PROPERTIES(qgis_gui PROPERTIES VERSION ${COMPLETE_VERSION} SOVERSION ${COMPLETE_VERSION})
Modified: trunk/qgis/src/gui/qgisinterface.h
--- trunk/qgis/src/gui/qgisinterface.h 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/gui/qgisinterface.h 2011-02-19 13:27:35 UTC (rev 15210)
@@ -40,6 +40,10 @@
#include <qgis.h>
+#ifdef _MSC_VER
+# pragma warning( disable: 4996 ) // was declared deprecated
+#endif
/** \ingroup gui
* QgisInterface
@@ -367,14 +371,15 @@
+#ifdef _MSC_VER
+# pragma warning( disable: 4190 )
+#endif
// FIXME: also in core/qgis.h
#ifndef QGISEXTERN
#ifdef WIN32
# define QGISEXTERN extern "C" __declspec( dllexport )
-# ifdef _MSC_VER
-// do not warn about C bindings returning QString
-# pragma warning(disable:4190)
-# endif
#else
#endif
Modified: trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp
--- trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/plugins/diagram_overlay/qgssvgdiagramfactorywidget.cpp 2011-02-19 13:27:35 UTC (rev 15210)
@@ -217,19 +217,22 @@
void QgsSVGDiagramFactoryWidget::addStandardDirectoriesToPreview()
//list all directories in $prefix/share/qgis/svg
- QDir svgDirectory( QgsApplication::svgPath() );
- if ( !svgDirectory.exists() || !svgDirectory.isReadable() )
+ foreach( QString path, QgsApplication::svgPaths() )
- return; //error
+ QDir svgDirectory( path );
+ if ( !svgDirectory.exists() || !svgDirectory.isReadable() )
+ continue; //error
- QFileInfoList directoryList = svgDirectory.entryInfoList( QDir::Dirs | QDir::NoDotAndDotDot );
- QFileInfoList::const_iterator dirIt = directoryList.constBegin();
- for ( ; dirIt != directoryList.constEnd(); ++dirIt )
- if ( addDirectoryToPreview( dirIt->absoluteFilePath() ) == 0 )
+ QFileInfoList directoryList = svgDirectory.entryInfoList( QDir::Dirs | QDir::NoDotAndDotDot );
+ QFileInfoList::const_iterator dirIt = directoryList.constBegin();
+ for ( ; dirIt != directoryList.constEnd(); ++dirIt )
- mSearchDirectoriesComboBox->addItem( dirIt->absoluteFilePath() );
+ if ( addDirectoryToPreview( dirIt->absoluteFilePath() ) == 0 )
+ mSearchDirectoriesComboBox->addItem( dirIt->absoluteFilePath() );
Modified: trunk/qgis/src/providers/osm/osmstyle.cpp
--- trunk/qgis/src/providers/osm/osmstyle.cpp 2011-02-19 13:24:24 UTC (rev 15209)
+++ trunk/qgis/src/providers/osm/osmstyle.cpp 2011-02-19 13:27:35 UTC (rev 15210)
@@ -139,7 +139,7 @@
QColor mSelectionColor( 255, 255, 0 );
QgsSymbol sym( QGis::Point );
- sym.setNamedPointSymbol( QString( "svg:%1%2" ).arg( QgsApplication::svgPath() ).arg( name ) );
+ sym.setNamedPointSymbol( QString( "svg:%1" ).arg( name ) );
sym.setPointSize( size.toFloat() );
QImage img = sym.getPointSymbolAsImage( widthScale, selected, mSelectionColor );
