[QGIS Commit] r15213 - in trunk/qgis/src: analysis/raster core gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Feb 19 12:17:06 EST 2011
Author: jef
Date: 2011-02-19 09:17:06 -0800 (Sat, 19 Feb 2011)
New Revision: 15213
   trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
   trunk/qgis/src/core/qgssearchstringlexer.ll
   trunk/qgis/src/gui/CMakeLists.txt
fix msvc fixes
Modified: trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy
--- trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy	2011-02-19 16:21:35 UTC (rev 15212)
+++ trunk/qgis/src/analysis/raster/qgsrastercalcparser.yy	2011-02-19 17:17:06 UTC (rev 15213)
@@ -20,8 +20,8 @@
   #include "qgsrastercalcnode.h"
 #ifdef _MSC_VER
-#  pragma warnings( disable: 4065 )  // switch statement contains 'default' but no 'case' labels
-#  pragma warnings( disable: 4701 )  // Potentially uninitialized local variable 'name' used
+#  pragma warning( disable: 4065 )  // switch statement contains 'default' but no 'case' labels
+#  pragma warning( disable: 4701 )  // Potentially uninitialized local variable 'name' used
 #endif
   // don't redeclare malloc/free
Modified: trunk/qgis/src/core/qgssearchstringlexer.ll
--- trunk/qgis/src/core/qgssearchstringlexer.ll	2011-02-19 16:21:35 UTC (rev 15212)
+++ trunk/qgis/src/core/qgssearchstringlexer.ll	2011-02-19 17:17:06 UTC (rev 15213)
@@ -36,7 +36,9 @@
 // which doesn't in MSVC compiler
 #define YY_NEVER_INTERACTIVE 1
+#ifndef YY_NO_UNPUT
 #define YY_NO_UNPUT	// unused
+#endif
 #ifdef _MSC_VER
 #define YY_NO_UNISTD_H
Modified: trunk/qgis/src/gui/CMakeLists.txt
--- trunk/qgis/src/gui/CMakeLists.txt	2011-02-19 16:21:35 UTC (rev 15212)
+++ trunk/qgis/src/gui/CMakeLists.txt	2011-02-19 17:17:06 UTC (rev 15213)
@@ -135,10 +135,12 @@
   ENDIF (MSVC)
 ENDIF (WIN32)
-IF(NOT MSVC)
-  # disable deprecation warnings for qgisinterface (re-exporting deprecated methods)
+# disable deprecation warnings for qgisinterface (re-exporting deprecated methods)
+IF(MSVC)
+  SET_SOURCE_FILES_PROPERTIES(${CMAKE_BINARY_DIR}/src/gui/moc_qgisinterface.cxx PROPERTIES COMPILE_FLAGS "-wd4996")
+ELSE(MSVC)
   SET_SOURCE_FILES_PROPERTIES(${CMAKE_BINARY_DIR}/src/gui/moc_qgisinterface.cxx PROPERTIES COMPILE_FLAGS "-w")
-ENDIF(NOT MSVC)
+ENDIF(MSVC)
 # qgis_gui library
More information about the QGIS-commit mailing list
