[QGIS Commit] r15224 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Feb 20 16:43:59 EST 2011
Author: jef
Date: 2011-02-20 13:43:59 -0800 (Sun, 20 Feb 2011)
New Revision: 15224
trunk/qgis/src/app/qgspluginregistry.cpp
set plugin name and parent of c++ plugins - to allow other plugins to connect via mainWindow().findChild()
Modified: trunk/qgis/src/app/qgspluginregistry.cpp
--- trunk/qgis/src/app/qgspluginregistry.cpp 2011-02-20 18:10:05 UTC (rev 15223)
+++ trunk/qgis/src/app/qgspluginregistry.cpp 2011-02-20 21:43:59 UTC (rev 15224)
@@ -29,6 +29,7 @@
#include "qgspluginmetadata.h"
#include "qgisplugin.h"
#include "qgspythonutils.h"
+#include "qgisapp.h"
#include "qgslogger.h"
@@ -274,7 +275,7 @@
QLibrary myLib( theFullPathName );
QString myError; //we will only show detailed diagnostics if something went wrong
- myError += "Library name is " + myLib.fileName() + " " + QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
+ myError += QObject::tr( "Library name is %1\n" ).arg( myLib.fileName() );
bool loaded = myLib.load();
if ( ! loaded )
@@ -283,7 +284,7 @@
return;
- myError += "Attempting to resolve the classFactory function " + QString( __LINE__ ) + " in " + QString( __FUNCTION__ ) + "\n";
+ myError += QObject::tr( "Attempting to resolve the classFactory function\n" );
type_t *pType = ( type_t * ) cast_to_fptr( myLib.resolve( "type" ) );
name_t *pName = ( name_t * ) cast_to_fptr( myLib.resolve( "name" ) );
@@ -306,6 +307,31 @@
addPlugin( baseName, QgsPluginMetadata( myLib.fileName(), pName(), pl ) );
//add it to the qsettings file [ts]
settings.setValue( "/Plugins/" + baseName, true );
+ QObject *o = dynamic_cast<QObject *>( pl );
+ if ( o )
+ QgsDebugMsg( QString( "plugin object name: %1" ).arg( o->objectName() ) );
+ if ( o->objectName().isEmpty() )
+#ifndef WIN32
+ baseName = baseName.mid( 3 );
+#endif
+ QgsDebugMsg( QString( "object name to %1" ).arg( baseName ) );
+ o->setObjectName( QString( "qgis_plugin_%1" ).arg( baseName ) );
+ QgsDebugMsg( QString( "plugin object name now: %1" ).arg( o->objectName() ) );
+ if ( !o->parent() )
+ QgsDebugMsg( QString( "setting plugin parent" ) );
+ o->setParent( QgisApp::instance() );
+ else
+ QgsDebugMsg( QString( "plugin parent already set" ) );
else
