[QGIS Commit] r15245 - in trunk/qgis/src: app gui/symbology-ng ui
svn_qgis at osgeo.org
Tue Feb 22 18:28:30 EST 2011
Author: jef
Date: 2011-02-22 15:28:30 -0800 (Tue, 22 Feb 2011)
New Revision: 15245
trunk/qgis/src/app/qgstipfactory.cpp
trunk/qgis/src/gui/symbology-ng/qgsstylev2exportimportdialog.cpp
trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
translation string fixes
Modified: trunk/qgis/src/app/qgstipfactory.cpp
--- trunk/qgis/src/app/qgstipfactory.cpp 2011-02-22 21:37:02 UTC (rev 15244)
+++ trunk/qgis/src/app/qgstipfactory.cpp 2011-02-22 23:28:30 UTC (rev 15245)
@@ -34,10 +34,10 @@
QgsTip myTip;
myTip.setTitle( tr( "Quantum GIS is open source" ) );
myTip.setContent( tr( "Quantum GIS is open source software."
- " This means that the software source code can be freely viewed "
- " and modified. The GPL places a restriction that any modifications "
- " you make must be made available to the Quantum GIS project, and "
- " that you can not create a new version of Quantum GIS under a "
+ " This means that the software source code can be freely viewed"
+ " and modified. The GPL places a restriction that any modifications"
+ " you make must be made available to the Quantum GIS project, and"
+ " that you can not create a new version of Quantum GIS under a"
" 'closed source' license. Visit <a href=\"http://qgis.org\">"
" the QGIS home page (http://qgis.org)</a> for more"
" information." ) );
@@ -53,8 +53,8 @@
myTip.setTitle( tr( "Become an QGIS translator" ) );
myTip.setContent( tr( "Would you like to see QGIS"
" in your native language? We are looking for more translators"
- " and would appreciate your help! The translation process is "
- " fairly straight forward - instructions are available in the "
+ " and would appreciate your help! The translation process is"
+ " fairly straight forward - instructions are available in the"
" QGIS wiki"
" <a href=\"http://www.qgis.org/wiki/GUI_Translation\">translator's page (http://www.qgis.org/wiki/GUI_Translation).</a>"
@@ -75,7 +75,7 @@
addGenericTip( myTip );
myTip.setTitle( tr( "How do I refer to Quantum GIS?" ) );
myTip.setContent( tr( "QGIS is spelled in all caps."
- " We have various subprojects of the QGIS project "
+ " We have various subprojects of the QGIS project"
" and it will help to avoid confusion if you refer to each by"
" its name:"
"<ul>"
@@ -88,60 +88,60 @@
// This tip contributed by Andreas Neumann
- myTip.setTitle(tr("Add the current date to a map layout"));
- myTip.setContent(tr("Content: You can add a current date variable to your map "
- " layout. Create a regular text label and add the string "
- " $CURRENT_DATE(yyyy-MM-dd) to the text box. See the "
- " <a href=\"http://doc.qt.nokia.com/latest/qdate.html#toString\">"
- " QDate::toString format documentation</a> for the possible date formats."
- addGuiTip(myTip);
- myTip.setTitle(tr("Moving Elements and Maps in the Print Composer"));
- myTip.setContent(tr("In the print composer tool bar you can find two "
- " buttons for moving elements. The left one (a selection cursor "
- " with the hand symbol) selects and moves elements in the layout. "
- " After selecting the element with this tool you can also move "
- " them around with the arrow keys. For accurate positioning use "
- " the <strong>Position and Size</strong> dialogue, which can be "
- " found in the tab <strong>Item --> General Options --> Position "
- " and Size</strong>. For easier positioning you can also set "
- " specific anchor points of the element within this dialogue. "
- " The other move tool (the globe icon combined with the hand icon) "
- " allows to move the map content within a map frame. "
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Add the current date to a map layout" ) );
+ myTip.setContent( tr( "You can add a current date variable to your map"
+ " layout. Create a regular text label and add the string"
+ " $CURRENT_DATE(yyyy-MM-dd) to the text box. See the"
+ " <a href=\"http://doc.qt.nokia.com/latest/qdate.html#toString\">"
+ "QDate::toString format documentation</a> for the possible date formats."
+ addGuiTip( myTip );
+ myTip.setTitle( tr( "Moving Elements and Maps in the Print Composer" ) );
+ myTip.setContent( tr( "In the print composer tool bar you can find two"
+ " buttons for moving elements. The left one (a selection cursor"
+ " with the hand symbol) selects and moves elements in the layout."
+ " After selecting the element with this tool you can also move"
+ " them around with the arrow keys. For accurate positioning use"
+ " the <strong>Position and Size</strong> dialogue, which can be"
+ " found in the tab <strong>Item → General Options → Position"
+ " and Size</strong>. For easier positioning you can also set"
+ " specific anchor points of the element within this dialogue."
+ " The other move tool (the globe icon combined with the hand icon)"
+ " allows to move the map content within a map frame."
- myTip.setTitle(tr("Lock an element in the layout view"));
- myTip.setContent(tr(" By left clicking an element in the layout view you can "
- " select it, by right clicking an element you can lock it. A lock symbol "
- " will appear in the upper left corner of the selected element. This "
- " prevents the element from accidentally being moved with the mouse. While "
- " in a locked state, you cannot move an element with the mouse but you can "
- " still move it with the arrow keys or by absolutely positioning it by "
- " setting its <strong>Position and Size</strong>"
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Lock an element in the layout view" ) );
+ myTip.setContent( tr( "By left clicking an element in the layout view you can"
+ " select it, by right clicking an element you can lock it. A lock symbol"
+ " will appear in the upper left corner of the selected element. This"
+ " prevents the element from accidentally being moved with the mouse. While"
+ " in a locked state, you cannot move an element with the mouse but you can"
+ " still move it with the arrow keys or by absolutely positioning it by"
+ " setting its <strong>Position and Size</strong>."
- myTip.setTitle(tr("Rotating a map and linking a north arrow"));
- myTip.setContent(tr("You can rotate a map by setting its rotation value "
- " in the <strong>Item tab --> Map</strong> section. To place a north "
- " arrow in your layout you can use the <strong>Add Image</strong> "
- " tool, the button with the little camera icon. QGIS comes with a "
- " selection of north arrows. After the placement of the north arrow "
- " in the layout you can link it with a specific map frame by activating "
- " the <strong>Sync with map</strong> checkbox and selecting a map frame. "
- " Whenever you change the rotation value of a linked map, the north arrow "
- " will now automatically adjust its rotation. "
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Rotating a map and linking a north arrow" ) );
+ myTip.setContent( tr( "You can rotate a map by setting its rotation value"
+ " in the <strong>Item tab → Map</strong> section. To place a north"
+ " arrow in your layout you can use the <strong>Add Image</strong>"
+ " tool, the button with the little camera icon. QGIS comes with a"
+ " selection of north arrows. After the placement of the north arrow"
+ " in the layout you can link it with a specific map frame by activating"
+ " the <strong>Sync with map</strong> checkbox and selecting a map frame."
+ " Whenever you change the rotation value of a linked map, the north arrow"
+ " will now automatically adjust its rotation."
- myTip.setTitle(tr("Numeric scale value in map layout linked to map frame"));
- myTip.setContent(tr("If you want to place a text label as a placeholder for the "
- " current scale, linked to a map frame, you need to place a scalebar and "
- " set the style to 'Numeric'. You also need to select the map frame, if there "
- " is more than one."
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Numeric scale value in map layout linked to map frame" ) );
+ myTip.setContent( tr( "If you want to place a text label as a placeholder for the"
+ " current scale, linked to a map frame, you need to place a scalebar and"
+ " set the style to 'Numeric'. You also need to select the map frame, if there"
+ " is more than one."
/* Template for adding more tips
myTip.setTitle(tr(""));
myTip.setContent(tr(""
Modified: trunk/qgis/src/gui/symbology-ng/qgsstylev2exportimportdialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgsstylev2exportimportdialog.cpp 2011-02-22 21:37:02 UTC (rev 15244)
+++ trunk/qgis/src/gui/symbology-ng/qgsstylev2exportimportdialog.cpp 2011-02-22 23:28:30 UTC (rev 15245)
@@ -29,9 +29,11 @@
#include "qgssymbollayerv2utils.h"
#include "qgsvectorcolorrampv2.h"
-QgsStyleV2ExportImportDialog::QgsStyleV2ExportImportDialog( QgsStyleV2* style,
- QWidget *parent, Mode mode, QString fileName )
- : QDialog( parent ), mDialogMode( mode ), mQgisStyle( style ), mFileName( fileName )
+QgsStyleV2ExportImportDialog::QgsStyleV2ExportImportDialog( QgsStyleV2* style, QWidget *parent, Mode mode, QString fileName )
+ : QDialog( parent )
+ , mFileName( fileName )
+ , mDialogMode( mode )
+ , mQgisStyle( style )
setupUi( this );
@@ -134,7 +136,7 @@
if ( !mTempStyle->load( mFileName ) )
QMessageBox::warning( this, tr( "Import error" ),
- tr( "An error was occured during import:\n%1" ).arg( mTempStyle->errorString() ) );
+ tr( "An error occured during import:\n%1" ).arg( mTempStyle->errorString() ) );
return false;
Modified: trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui 2011-02-22 21:37:02 UTC (rev 15244)
+++ trunk/qgis/src/ui/qgscomposerpicturewidgetbase.ui 2011-02-22 23:28:30 UTC (rev 15245)
@@ -264,7 +264,7 @@
<item row="8" column="0">
<widget class="QCheckBox" name="mRotationFromComposerMapCheckBox">
<property name="text">
- <string>Sync from map</string>
+ <string>Sync with map</string>
</property>
</widget>
</item>
