[QGIS Commit] r15266 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Feb 27 00:57:02 EST 2011
Author: timlinux
Date: 2011-02-26 21:57:02 -0800 (Sat, 26 Feb 2011)
New Revision: 15266
trunk/qgis/src/app/qgstipfactory.cpp
Added a couple more tips
Modified: trunk/qgis/src/app/qgstipfactory.cpp
--- trunk/qgis/src/app/qgstipfactory.cpp 2011-02-26 20:39:19 UTC (rev 15265)
+++ trunk/qgis/src/app/qgstipfactory.cpp 2011-02-27 05:57:02 UTC (rev 15266)
@@ -142,6 +142,26 @@
" is more than one."
addGuiTip( myTip );
+ // by Tim
+ myTip.setTitle(tr("Using the mouse scroll wheel"));
+ myTip.setContent(tr("You can use the scroll wheel on your mouse to zoom in, "
+ " out and pan the map. Scroll forwards to zoom in, scroll backwards to "
+ " zoom out and press and hold the scroll wheel down to pan the map. You "
+ " can configure options for scroll wheel behaviour in the Options panel."
+ addGuiTip(myTip);
+ // by Tim
+ myTip.setTitle(tr("Stopping rendering"));
+ myTip.setContent(tr("Sometimes you have a very large dataset which takes ages "
+ " to draw. You can press 'esc' (the escape key), or click the small red "
+ " 'X' icon in the status bar to the bottom right of the window at any "
+ " time to halt rendering. If you are going to be performing several "
+ " actions (e.g. modifying symbology options) and wish to temporarily "
+ " disable map rendering while you do so, you can uncheck the 'Render' "
+ " checkbox in the bottom right of the status bar. Don't forget to check "
+ " it on again when you are ready to have the map draw itself again!"
+ addGuiTip(myTip);
/* Template for adding more tips
myTip.setTitle(tr(""));
myTip.setContent(tr(""
