[QGIS Commit] r15276 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Feb 27 14:35:22 EST 2011
Author: jef
Date: 2011-02-27 11:35:22 -0800 (Sun, 27 Feb 2011)
New Revision: 15276
trunk/qgis/src/app/qgstipfactory.cpp
translation string fixes
Modified: trunk/qgis/src/app/qgstipfactory.cpp
--- trunk/qgis/src/app/qgstipfactory.cpp 2011-02-27 19:34:38 UTC (rev 15275)
+++ trunk/qgis/src/app/qgstipfactory.cpp 2011-02-27 19:35:22 UTC (rev 15276)
@@ -143,25 +143,25 @@
addGuiTip( myTip );
// by Tim
- myTip.setTitle(tr("Using the mouse scroll wheel"));
- myTip.setContent(tr("You can use the scroll wheel on your mouse to zoom in, "
- " out and pan the map. Scroll forwards to zoom in, scroll backwards to "
- " zoom out and press and hold the scroll wheel down to pan the map. You "
- " can configure options for scroll wheel behaviour in the Options panel."
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Using the mouse scroll wheel" ) );
+ myTip.setContent( tr( "You can use the scroll wheel on your mouse to zoom in,"
+ " out and pan the map. Scroll forwards to zoom in, scroll backwards to"
+ " zoom out and press and hold the scroll wheel down to pan the map. You"
+ " can configure options for scroll wheel behaviour in the Options panel."
+ addGuiTip( myTip );
// by Tim
- myTip.setTitle(tr("Stopping rendering"));
- myTip.setContent(tr("Sometimes you have a very large dataset which takes ages "
- " to draw. You can press 'esc' (the escape key), or click the small red "
- " 'X' icon in the status bar to the bottom right of the window at any "
- " time to halt rendering. If you are going to be performing several "
- " actions (e.g. modifying symbology options) and wish to temporarily "
- " disable map rendering while you do so, you can uncheck the 'Render' "
- " checkbox in the bottom right of the status bar. Don't forget to check "
- " it on again when you are ready to have the map draw itself again!"
- addGuiTip(myTip);
+ myTip.setTitle( tr( "Stopping rendering" ) );
+ myTip.setContent( tr( "Sometimes you have a very large dataset which takes ages"
+ " to draw. You can press 'esc' (the escape key), or click the small red"
+ " 'X' icon in the status bar to the bottom right of the window at any"
+ " time to halt rendering. If you are going to be performing several"
+ " actions (e.g. modifying symbology options) and wish to temporarily"
+ " disable map rendering while you do so, you can uncheck the 'Render'"
+ " checkbox in the bottom right of the status bar. Don't forget to check"
+ " it on again when you are ready to have the map draw itself again!"
/* Template for adding more tips
myTip.setTitle(tr(""));
myTip.setContent(tr(""
