[QGIS Commit] r15286 - trunk/qgis/i18n
svn_qgis at osgeo.org
Mon Feb 28 14:14:57 EST 2011
Author: jef
Date: 2011-02-28 11:14:57 -0800 (Mon, 28 Feb 2011)
New Revision: 15286
trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2011-02-28 19:09:44 UTC (rev 15285)
+++ trunk/qgis/i18n/qgis_de.ts 2011-02-28 19:14:57 UTC (rev 15286)
@@ -5520,7 +5520,7 @@
<translation>Eine Erweiterung die räumliche Abfragen von Vektorlayern ermöglicht</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="325"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="331"/>
<source>SQLite DB (*.sqlite *.db);;All files (*)</source>
<translation>SQLite DB (*.sqlite *.db);;Alle Dateien (*)</translation>
</message>
@@ -12684,27 +12684,31 @@
<translation>Löschen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="85"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="82"/>
+ <source>Allow geometryless tables</source>
+ <translation>Geometrielose Tabellen erlauben</translation>
+ </message>
+ <message>
<source>Build query</source>
<translation>Abfrage erstellen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="92"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="89"/>
<source>Search options</source>
<translation>Suchoptionen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="116"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="113"/>
<source>Search</source>
<translation>Suchen</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="129"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="126"/>
<source>Search mode</source>
<translation>Suchmodus</translation>
</message>
<message>
- <location filename="../src/ui/qgsdbsourceselectbase.ui" line="149"/>
+ <location filename="../src/ui/qgsdbsourceselectbase.ui" line="146"/>
<source>Search in columns</source>
<translation>In Spalten suchen</translation>
</message>
@@ -22702,116 +22706,126 @@
<name>QgsPgSourceSelect</name>
<message>
<location filename="../src/app/postgres/qgspgsourceselect.cpp" line="54"/>
+ <source>&Build query</source>
+ <translation>&Abfrage erstellen</translation>
+ </message>
+ <message>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="55"/>
+ <source>Build query</source>
+ <translation>Abfrage erstellen</translation>
+ </message>
+ <message>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="60"/>
<source>&Add</source>
<translation>&Hinzufügen</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="58"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="65"/>
<source>&Save</source>
<translation>&Speichern</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="59"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="66"/>
<source>Save connections</source>
<translation>Verbindungen speichern</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="63"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="70"/>
<source>&Load</source>
<translation>&Laden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="64"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="167"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="71"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="177"/>
<source>Load connections</source>
<translation>Verbindungen laden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="71"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="224"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="78"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="243"/>
<source>Wildcard</source>
<translation>Platzhalter</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="72"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="228"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="79"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="247"/>
<source>RegExp</source>
<translation>RegAusdr</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="74"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="236"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="81"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="255"/>
<source>All</source>
<translation>Alle</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="75"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="240"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="82"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="259"/>
<source>Schema</source>
<translation>Schema</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="76"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="244"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="83"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="263"/>
<source>Table</source>
<translation>Tabelle</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="77"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="248"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="84"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="267"/>
<source>Type</source>
<translation>Typ</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="78"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="252"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="85"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="271"/>
<source>Geometry column</source>
<translation>Geometriespalte</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="79"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="256"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="86"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="275"/>
<source>Primary key column</source>
<translation>Primärschlüsselspalte</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="80"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="260"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="87"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="279"/>
<source>Sql</source>
<translation>SQL</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="136"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="145"/>
<source>Are you sure you want to remove the %1 connection and all associated settings?</source>
<translation>Sind Sie sicher, dass Sie die Verbindung %1 und alle zugehörigen Einstellungen löschen wollen?</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="138"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="147"/>
<source>Confirm Delete</source>
<translation>Löschen bestätigen</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="168"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="178"/>
<source>XML files (*.xml *XML)</source>
<translation>XML-Dateien (*.xml *.XML)</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="403"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="422"/>
<source>Select Table</source>
<translation>Tabelle wählen</translation>
</message>
<message>
<source>You must select a table in order to add a layer.</source>
<translation>Um einen Layer hinzuzufügen, muss eine Tabelle gewählt sein.</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="524"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="555"/>
<source>Connection failed</source>
<translation>Verbindungsfehler</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="525"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="556"/>
<source>Connection to %1 on %2 failed. Either the database is down or your settings are incorrect.
Check your username and password and try again.
@@ -22826,20 +22840,20 @@
%3</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="725"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="785"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="847"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="756"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="816"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="878"/>
<source>Accessible tables could not be determined</source>
<translation>Zugreifbare Tabellen konnten nicht festgestellt werden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="726"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="757"/>
<source>Database connection was successful, but the accessible tables could not be determined.</source>
<translation>Die Datenbankverbindung war erfolgreich, jedoch konnten die zugänglichen Tabelle nicht bestimmt werden.</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="786"/>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="848"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="817"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="879"/>
The error message from the database was:
@@ -22852,22 +22866,22 @@
</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="812"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="843"/>
<source>Waiting</source>
<translation>Wartend</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="864"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="895"/>
<source>No geometry</source>
<translation>Keine Geometrie</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="876"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="907"/>
<source>No accessible tables found</source>
<translation>Keine zugänglichen Tabellen gefunden</translation>
</message>
<message>
- <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="877"/>
+ <location filename="../src/app/postgres/qgspgsourceselect.cpp" line="908"/>
<source>Database connection was successful, but no accessible tables were found.
Please verify that you have SELECT privilege on a table carrying PostGIS
@@ -23922,13 +23936,13 @@
<context>
<name>QgsPostgresProvider</name>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="984"/>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1022"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="989"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1046"/>
<source>Unable to access relation</source>
<translation>Auf die Relation kann nicht zugegriffen werden</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="985"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="990"/>
<source>Unable to access the %1 relation.
%2.
@@ -23939,7 +23953,7 @@
SQL: %3</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1023"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1047"/>
<source>Unable to determine table access privileges for the %1 relation.
%2.
@@ -23991,12 +24005,12 @@
<translation>Ihre Datenbank hat keine funktionsfähige PostGIS-Unterstützung.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="293"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="298"/>
<source>No GEOS Support!</source>
<translation>Keine GEOS Unterstützung!</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="294"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="299"/>
<source>Your PostGIS installation has no GEOS support.
Feature selection and identification will not work properly.
Please install PostGIS with GEOS support (http://geos.refractions.net)</source>
@@ -24005,24 +24019,38 @@
Bitte PostGIS mit GEOS-Unterstützung installieren (http://geos.refractions.net)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="958"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="963"/>
<source>Ambiguous field!</source>
<translation>Mehrdeutiger Feldname!</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="959"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="964"/>
<source>Duplicate field %1 found
</source>
<translation>Doppelter Feldname %1 gefunden
</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1113"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1004"/>
+ <source>PostgreSQL in recovery</source>
+ <translation>PostgreSQL in Wiederherstellung</translation>
+ </message>
+ <message>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1005"/>
+ <source>PostgreSQL is still in recovery after a database crash
+(or you are connected to a (read-only) slave).
+Write accesses will be denied.</source>
+ <translation>PostgreSQL ist noch bei der Wiederherstellung nach einem Datenbankabsturz
+(oder Sie sind mit einem (nur-lese) Slave verbunden).
+Schreibzugriffe werden verweigert.</translation>
+ </message>
+ <message>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1135"/>
<source>Unable execute the query</source>
<translation>Konnte die Abfrage nicht ausführen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1114"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1136"/>
<source>Unable to execute the query.
%1.
@@ -24033,12 +24061,12 @@
SQL: %2</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1217"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1239"/>
<source>No suitable key column in table</source>
<translation>Keine passende Schlüsselspalte in der Tabelle</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1218"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1240"/>
<source>The table has no column suitable for use as a key.
Quantum GIS requires that the table either has a column of type
@@ -24054,46 +24082,46 @@
mit einer 16bit-Blocknummer hat.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1294"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1316"/>
<source>The unique index on column '%1' is unsuitable because Quantum GIS does not currently support non-int4 type columns as a key into the table.
</source>
<translation>Der eindeutige Index auf Spalte '%1' ist ungeeignet, weil Quantum GIS zur Zeit nur Spalten vom Typ int4 als Tabellenschlüssel unterstützt.
</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1319"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1341"/>
<source>and </source>
<translation>und </translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1325"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1347"/>
<source>The unique index based on columns %1 is unsuitable because Quantum GIS does not currently support multiple columns as a key into the table.
</source>
<translation>Der eindeutige Index auf den Spalten '%1' ist ungeeignet, weil Quantum GIS zur Zeit nur einzelne Spalten als Tabellenschlüssel unterstützt.
</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1368"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1390"/>
<source>Unable to find a key column</source>
<translation>Kann die Schlüsselspalte nicht finden</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1510"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1532"/>
<source>and is suitable.</source>
<translation>und ist geeignet.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1516"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1538"/>
<source> and has a suitable constraint)</source>
<translation> und hat einen geeigneten Constraint)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1518"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1540"/>
<source> and does not have a suitable constraint)</source>
<translation> und hat keinen geeigneten Constraint)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1613"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1635"/>
<source>The view '%1.%2' has no column suitable for use as a unique key.
Quantum GIS requires that the view has a column that can be used as a unique key. Such a column should be derived from a table column of type int4 and be a primary key, have a unique constraint on it, or be a PostgreSQL oid column. To improve performance the column should also be indexed.
The view you selected has the following columns, none of which satisfy the above conditions:</source>
@@ -24102,39 +24130,39 @@
Der ausgewählte View hat folgende Spalten von denen keine die obigen Bedingungen erfüllt:</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1621"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1643"/>
<source>No suitable key column in view</source>
<translation>Keine geeignete Schlüsselspalte im View</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3236"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3258"/>
<source>Unknown geometry type</source>
<translation>Unbekannter Geometrietyp</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3237"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3259"/>
<source>Column %1 in %2 has a geometry type of %3, which Quantum GIS does not currently support.</source>
<translation>Spalte %1 in %2 hat den Geometrietyp %3, den Quantum GIS zur Zeit nicht unterstützt.</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3244"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3266"/>
<source>Quantum GIS was unable to determine the type and srid of column %1 in %2. The database communication log was:
%3</source>
<translation>Quantum GIS konnte den Typ und die SRID der Spalte %1 in %2 nicht bestimmen. Das Datenbankkommunikationsprotokoll war:
%3</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3248"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3270"/>
<source>Unable to get feature type and srid</source>
<translation>Kann den Objekttyp und die SRID nicht ermitteln</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3367"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3389"/>
<source>Query failed</source>
<translation>Abfrage gescheitert</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3368"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="3390"/>
<source>%1 cursor states lost.
SQL: %2
Result: %3 (%4)</source>
@@ -24143,32 +24171,32 @@
Ergebnis: %3 (%4)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2438"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2460"/>
<source>Error while adding features</source>
<translation>Fehler beim Hinzufügen von Objekten</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2481"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2503"/>
<source>Error while deleting features</source>
<translation>Fehler beim Löschen von Objekten</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2544"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2566"/>
<source>Error while adding attributes</source>
<translation>Fehler beim Hinzufügen von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2592"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2614"/>
<source>Error while deleting attributes</source>
<translation>Fehler beim Löschen von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2677"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2699"/>
<source>Error while changing attributes</source>
<translation>Fehler beim Ändern von Attributen</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2767"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="2789"/>
<source>Error while changing geometry values</source>
<translation>Fehler beim Ändern von Geometrien</translation>
</message>
@@ -24178,17 +24206,17 @@
<translation>Nicht erwarteter PostgeSQL-Fehler</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1506"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1528"/>
<source>'%1' derives from '%2.%3.%4' </source>
<translation>'%1' ist von '%2.%3.%4' abgeleitet </translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1514"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1536"/>
<source>and is not suitable (type is %1)</source>
<translation>und ist ungeeignet (Typ ist %1)</translation>
</message>
<message>
- <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1602"/>
+ <location filename="../src/providers/postgres/qgspostgresprovider.cpp" line="1624"/>
<source>Note: '%1' initially appeared suitable but does not contain unique data, so is not suitable.
</source>
<translation>Bemerkung: '%1' schien anfänglich geeignet, ist es allerdings nicht, da sie keine eindeutigen Daten enthält.</translation>
@@ -27562,62 +27590,67 @@
</message>
<message>
<location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="50"/>
+ <source>&Build Query</source>
+ </message>
+ <message>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="55"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="57"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="120"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="62"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="126"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="58"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="124"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="63"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="130"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="60"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="132"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="65"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="138"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="61"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="136"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="66"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="142"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="62"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="140"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="67"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="146"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="63"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="144"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="68"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="150"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="64"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="148"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="69"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="154"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="198"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="266"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="280"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="204"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="272"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="286"/>
<source>SpatiaLite DB Open Error</source>
<translation>SpatiaLite-DB-Fehler beim Öffnen</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="199"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="267"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="281"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="205"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="273"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="287"/>
<source>Failure while connecting to: %1
%2</source>
@@ -27626,56 +27659,56 @@
%2</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="265"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="271"/>
<source>seems to be a valid SQLite DB, but not a SpatiaLite's one ...</source>
<translation>scheint eine gültige SQLite-DB zu sein, jedoch ohne SpatiaLite ...</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="274"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="650"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="854"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="280"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="656"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="860"/>
<source>unknown error cause</source>
<translation>unbekannte Fehlerursache</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="302"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="308"/>
<source>@</source>
<translation>@</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="324"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="330"/>
<source>Choose a SpatiaLite/SQLite DB to open</source>
<translation>Zu öffnende SpatiaLite/SQLite-DB wählen</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="404"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="410"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="406"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="412"/>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="453"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="459"/>
</message>
<message>
<source>You must select a table in order to add a Layer.</source>
<translation>Zum Hinzufügen eines Layers müssen Sie eine Tabelle wählen.</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="656"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="860"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="662"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="866"/>
<source>SpatiaLite getTableInfo Error</source>
<translation>SpatiaLite-getTableInfo-Fehler</translation>
</message>
<message>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="657"/>
- <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="861"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="663"/>
+ <location filename="../src/app/spatialite/qgsspatialitesourceselect.cpp" line="867"/>
<source>Failure exploring tables from: %1
%2</source>
@@ -28220,28 +28253,28 @@
<message>
<location filename="../src/plugins/spit/qgsspit.cpp" line="383"/>
<location filename="../src/plugins/spit/qgsspit.cpp" line="418"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="502"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="527"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="537"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="562"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="583"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="603"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="622"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="645"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="683"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="722"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="739"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="768"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="795"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="801"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="817"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="822"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="513"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="538"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="548"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="573"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="594"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="614"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="633"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="656"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="694"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="733"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="750"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="779"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="806"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="812"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="828"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="833"/>
<source>Import Shapefiles</source>
<translation>Shapedateien importieren</translation>
</message>
<message>
<source>You need to specify a Connection first</source>
<translation>Es müssen zuerst Shapedateien in die Liste eingefügt werden</translation>
</message>
@@ -28261,56 +28294,56 @@
<translation>Verbindung fehlgeschlagen - Bitte Einstellungen überprüfen und erneut versuchen</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="458"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="469"/>
<source>PostGIS not available</source>
<translation>PostGIS nicht verfügbar</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="459"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="470"/>
<source><p>The chosen database does not have PostGIS installed, but this is required for storage of spatial data.</p></source>
<translation><p>In der gewählte Datenbank ist PostGIS nicht installiert. PostGIS wird jedoch zum Speichern von räumlichen Daten benötigt.</p></translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="503"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="514"/>
<source>You need to add shapefiles to the list first</source>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="508"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="519"/>
<source>Importing files</source>
<translation>Importiere Dateien</translation>
</message>
<message>
<source>Cancel</source>
<translation>Abbrechen</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="512"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="523"/>
<source>Progress</source>
<translation>Fortschritt</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="521"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="532"/>
<source>Problem inserting features from file:</source>
<translation>Problem beim Einfügen von Objekten aus der Datei:</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="528"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="539"/>
<source>%1
Invalid table name.</source>
<translation>%1
Ungültiger Tabellenname.</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="538"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="549"/>
<source>%1
No fields detected.</source>
<translation>%1
Keine Spalten erkannt.</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="563"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="574"/>
<source>%1
The following fields are duplicates:
%2</source>
@@ -28319,34 +28352,34 @@
%2</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="571"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="582"/>
%1</source>
%1</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="584"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="604"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="623"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="647"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="684"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="723"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="740"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="769"/>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="802"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="595"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="615"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="634"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="658"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="695"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="734"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="751"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="780"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="813"/>
<source>%1
<p>Error while executing the SQL:</p><p>%2</p><p>The database said:%3</p></source>
<translation>%1
<p>Fehler bei der SQL-Ausführung:</p><p>%2</p><p>Meldung der Datenbank:%3</p></translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="662"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="673"/>
<source>Import Shapefiles - Relation Exists</source>
<translation>Shapedateien importieren - Relation vorhanden</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="663"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="674"/>
<source>The Shapefile:
%1
will use [%2] relation for its data,
@@ -28366,7 +28399,7 @@
Wollen Sie die Relation [%2] überschreiben?</translation>
</message>
<message>
- <location filename="../src/plugins/spit/qgsspit.cpp" line="818"/>
+ <location filename="../src/plugins/spit/qgsspit.cpp" line="829"/>
<source>%1 of %2 shapefiles could not be imported.</source>
<translation>%1 von %2 Shapedateien konnten nicht importiert werden.</translation>
</message>
@@ -31904,24 +31937,11 @@
<translation>Richtungsfeld</translation>
</message>
<message>
- <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="64"/>
- <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="101"/>
- <source>Direct direction</source>
- <translation>Vorwärts</translation>
- </message>
- <message>
- <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="70"/>
<location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="102"/>
<source>Reverse direction</source>
<translation>Rückwärts</translation>
</message>
<message>
- <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="76"/>
- <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="100"/>
- <source>Both direction</source>
- <translation>Beide Richtungen</translation>
- </message>
- <message>
<location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="82"/>
<source>Speed field</source>
<translation>Geschwindigkeitsfeld</translation>
@@ -31937,6 +31957,16 @@
<translation>Richtung</translation>
</message>
<message>
+ <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="100"/>
+ <source>Two-way direction</source>
+ <translation>Beide Richtungen</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="101"/>
+ <source>Forward direction</source>
+ <translation>Vorwärts</translation>
+ </message>
+ <message>
<location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="110"/>
<source>Cost</source>
<translation>Kosten</translation>
@@ -31957,6 +31987,21 @@
<translation>km/h</translation>
</message>
<message>
+ <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="64"/>
+ <source>Value for forward direction</source>
+ <translation>Wert für Vorwärts</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="70"/>
+ <source>Value for reverse direction</source>
+ <translation>Wert für Rückwärts</translation>
+ </message>
+ <message>
+ <location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="76"/>
+ <source>Value two-way direction</source>
+ <translation>Wert für beide Richtungen</translation>
+ </message>
+ <message>
<location filename="../src/plugins/roadgraph/linevectorlayerwidget.cpp" line="90"/>
<source>m/s</source>
<translation>m/s</translation>
@@ -32456,101 +32501,106 @@
<name>SaSourceSelect</name>
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="62"/>
+ </message>
+ <message>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="67"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="69"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="188"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="74"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="193"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="70"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="192"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="75"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="197"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="72"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="200"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="77"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="205"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="73"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="204"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="78"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="209"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="74"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="208"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="79"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="213"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="75"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="212"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="80"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="217"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="76"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="216"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="81"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="221"/>
<source>SRID</source>
<translation>SRID</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="77"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="220"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="82"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="225"/>
<source>Line Interpretation</source>
<translation>Linieninterpretation</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="78"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="224"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="83"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="229"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="79"/>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="228"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="84"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="233"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="130"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="135"/>
<translation>Sind Sie sicher, dass Sie die Verbindung %1 und alle dazugehörigen Einstellungen löschen wollen?</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="132"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="137"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="326"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="331"/>
</message>
<message>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="352"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="357"/>
<source>Failed to load interface</source>
<translation>Konnte Schnittstelle nicht laden</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="409"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="414"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="410"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="415"/>
<source>Connection to database %1 failed. Check settings and try again.
SQL Anywhere error code: %2
@@ -32561,22 +32611,22 @@
Beschreibung: %3</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="562"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="567"/>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="563"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="568"/>
<source>Database connection was successful, but no tables containing geometry columns were %1.</source>
<translation>Die Datenbankverbindung war erfolgreich, jedoch wurde keine Tabelle mit Geometriespalten %1.</translation>
</message>
<message>
- <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="566"/>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="571"/>
<source>found</source>
<translation>gefunden</translation>
</message>
<message>
<source>found in your schema</source>
<translation>in Ihrem Schema gefunden</translation>
</message>
