[QGIS Commit] r15005 - in branches/raster-providers/src: core
core/raster providers/gdal providers/grass providers/wms
svn_qgis at osgeo.org
Sat Jan 8 11:35:21 EST 2011
Author: rblazek
Date: 2011-01-08 08:35:21 -0800 (Sat, 08 Jan 2011)
New Revision: 15005
branches/raster-providers/src/core/qgsrasterdataprovider.h
branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
branches/raster-providers/src/core/raster/qgsrasterviewport.h
branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
branches/raster-providers/src/providers/wms/qgswmsprovider.cpp
branches/raster-providers/src/providers/wms/qgswmsprovider.h
enabled source CRS overwriting
Modified: branches/raster-providers/src/core/qgsrasterdataprovider.h
--- branches/raster-providers/src/core/qgsrasterdataprovider.h 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/core/qgsrasterdataprovider.h 2011-01-08 16:35:21 UTC (rev 15005)
@@ -298,7 +298,7 @@
virtual void readBlock( int bandNo, int xBlock, int yBlock, void *data ){}
/** read block of data using give extent and size */
- virtual void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theDestCRS, void *data ) {};
+ virtual void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *data ) {};
/** value representing null data */
virtual double noDataValue() const { return 0; }
Modified: branches/raster-providers/src/core/raster/qgsrasterlayer.cpp
--- branches/raster-providers/src/core/raster/qgsrasterlayer.cpp 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/core/raster/qgsrasterlayer.cpp 2011-01-08 16:35:21 UTC (rev 15005)
@@ -877,8 +877,10 @@
myRasterViewPort->mDrawnExtent = myRasterExtent;
if ( rendererContext.coordinateTransform() )
+ myRasterViewPort->mSrcCRS = crs();
myRasterViewPort->mDestCRS = rendererContext.coordinateTransform()->destCRS();
} else {
+ myRasterViewPort->mSrcCRS = QgsCoordinateReferenceSystem(); // will be invalid
myRasterViewPort->mDestCRS = QgsCoordinateReferenceSystem(); // will be invalid
@@ -4707,7 +4709,7 @@
viewPort->mDrawnExtent.xMaximum(),
viewPort->mDrawnExtent.yMaximum()
- mDataProvider->readBlock ( bandNo, partExtent, viewPort->drawableAreaXDim, viewPort->drawableAreaYDim, QgsCoordinateReferenceSystem(), data );
+ mDataProvider->readBlock ( bandNo, partExtent, viewPort->drawableAreaXDim, viewPort->drawableAreaYDim, QgsCoordinateReferenceSystem(), QgsCoordinateReferenceSystem(), data );
return data;
@@ -5088,7 +5090,7 @@
QgsRectangle myPartExtent ( mViewPort->mDrawnExtent.xMinimum(), yMin,
mViewPort->mDrawnExtent.xMaximum(), yMax );
QgsDebugMsg( "myPartExtent is " + myPartExtent.toString() );
- mDataProvider->readBlock ( mBandNo, myPartExtent, xSize, ySize, mViewPort->mDestCRS, mCurrentGDALData );
+ mDataProvider->readBlock ( mBandNo, myPartExtent, xSize, ySize, mViewPort->mSrcCRS, mViewPort->mDestCRS, mCurrentGDALData );
// TODO - error check - throw exception
Modified: branches/raster-providers/src/core/raster/qgsrasterviewport.h
--- branches/raster-providers/src/core/raster/qgsrasterviewport.h 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/core/raster/qgsrasterviewport.h 2011-01-08 16:35:21 UTC (rev 15005)
@@ -86,6 +86,9 @@
// intersection of current map extent and layer extent
QgsRectangle mDrawnExtent;
+ // Source coordinate system
+ QgsCoordinateReferenceSystem mSrcCRS;
// Target coordinate system
QgsCoordinateReferenceSystem mDestCRS;
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.cpp 2011-01-08 16:35:21 UTC (rev 15005)
@@ -464,12 +464,13 @@
GDALReadBlock( myGdalBand, xBlock, yBlock, block );
-void QgsGdalProvider::readBlock( int theBandNo, QgsRectangle const & theExtent, int thePixelWidth, int thePixelHeight, QgsCoordinateReferenceSystem theDestCRS, void *theBlock )
+void QgsGdalProvider::readBlock( int theBandNo, QgsRectangle const & theExtent, int thePixelWidth, int thePixelHeight, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *theBlock )
QgsDebugMsg( "thePixelWidth = " + QString::number( thePixelWidth ) );
QgsDebugMsg( "thePixelHeight = " + QString::number( thePixelHeight ) );
QgsDebugMsg( "theExtent: " + theExtent.toString() );
QgsDebugMsg( "crs(): " + crs().toWkt() );
+ QgsDebugMsg( "theSrcCRS: " + theDestCRS.toWkt() );
QgsDebugMsg( "theDestCRS: " + theDestCRS.toWkt() );
@@ -538,7 +539,8 @@
myWarpOptions->nBandCount = 1;
myWarpOptions->panSrcBands =
(int *) CPLMalloc(sizeof(int) * myWarpOptions->nBandCount );
- myWarpOptions->panSrcBands[0] = 1;
+ //myWarpOptions->panSrcBands[0] = 1;
+ myWarpOptions->panSrcBands[0] = theBandNo;
myWarpOptions->panDstBands =
myWarpOptions->panDstBands[0] = 1;
@@ -551,12 +553,14 @@
myWarpOptions->pTransformerArg =
GDALCreateGenImgProjTransformer(
mGdalDataset,
- GDALGetProjectionRef(mGdalDataset),
//mySrcCRSChar,
+ //GDALGetProjectionRef(mGdalDataset),
+ theSrcCRS.toWkt().toAscii().constData(),
myGdalMemDataset,
GDALGetProjectionRef(myGdalMemDataset),
FALSE, 0.0, 1
CPLAssert( myWarpOptions->pTransformerArg != NULL);
myWarpOptions->pfnTransformer = GDALGenImgProjTransform;
@@ -567,6 +571,7 @@
myWarpOptions->padfDstNoDataReal = (double *) CPLMalloc( myWarpOptions->nBandCount * sizeof(double));
myWarpOptions->padfDstNoDataImag = (double *) CPLMalloc( myWarpOptions->nBandCount * sizeof(double));
for ( int i = 0; i < myWarpOptions->nBandCount; i++ )
@@ -578,13 +583,22 @@
myWarpOptions->padfDstNoDataReal[i] );
+ myWarpOptions->padfDstNoDataReal[0] = mNoDataValue;
+ myWarpOptions->padfDstNoDataImag[0] = 0.0;
+ GDALSetRasterNoDataValue( GDALGetRasterBand( myGdalMemDataset,
+ myWarpOptions->panDstBands[0] ),
+ myWarpOptions->padfDstNoDataReal[0] );
// TODO optimize somehow to avoid no data init if not necessary
// i.e. no projection, but there is also the problem with margine
- //myWarpOptions->papszWarpOptions =
- // CSLSetNameValue(myWarpOptions->papszWarpOptions,"INIT_DEST", "NO_DATA" );
+ myWarpOptions->papszWarpOptions =
+ CSLSetNameValue(myWarpOptions->papszWarpOptions,"INIT_DEST", "NO_DATA" );
+ myWarpOptions->eResampleAlg = GRA_NearestNeighbour;
GDALWarpOperation myOperation;
myOperation.Initialize( myWarpOptions );
Modified: branches/raster-providers/src/providers/gdal/qgsgdalprovider.h
--- branches/raster-providers/src/providers/gdal/qgsgdalprovider.h 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/gdal/qgsgdalprovider.h 2011-01-08 16:35:21 UTC (rev 15005)
@@ -200,7 +200,7 @@
void readBlock( int bandNo, int xBlock, int yBlock, void *data );
- void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theDestCRS, void *data );
+ void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *data );
double noDataValue() const;
void computeMinMax(int bandNo);
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp 2011-01-08 16:35:21 UTC (rev 15005)
@@ -201,7 +201,7 @@
memcpy( block, data.data(), size );
-void QgsGrassRasterProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, QgsCoordinateReferenceSystem theDestCRS, void *block )
+void QgsGrassRasterProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *block )
QgsDebugMsg( "Entered" );
QgsDebugMsg( "pixelWidth = " + QString::number( pixelWidth ) );
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h 2011-01-08 16:35:21 UTC (rev 15005)
@@ -191,7 +191,7 @@
double minimumValue(int bandNo)const;
Modified: branches/raster-providers/src/providers/wms/qgswmsprovider.cpp
--- branches/raster-providers/src/providers/wms/qgswmsprovider.cpp 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/wms/qgswmsprovider.cpp 2011-01-08 16:35:21 UTC (rev 15005)
@@ -678,7 +678,7 @@
return cachedImage;
-void QgsWmsProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, QgsCoordinateReferenceSystem theDestCRS, void *block )
+void QgsWmsProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *block )
// TODO: optimize to avoid writing to QImage
Modified: branches/raster-providers/src/providers/wms/qgswmsprovider.h
--- branches/raster-providers/src/providers/wms/qgswmsprovider.h 2011-01-07 16:56:07 UTC (rev 15004)
+++ branches/raster-providers/src/providers/wms/qgswmsprovider.h 2011-01-08 16:35:21 UTC (rev 15005)
@@ -459,7 +459,7 @@
QImage *draw( QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight );
/** Return the extent for this data layer
