[QGIS Commit] r15023 - in trunk/qgis/src: app/postgres plugins/spit
providers/postgres
svn_qgis at osgeo.org
Wed Jan 12 18:07:05 EST 2011
Author: jef
Date: 2011-01-12 15:07:05 -0800 (Wed, 12 Jan 2011)
New Revision: 15023
trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
trunk/qgis/src/plugins/spit/qgsshapefile.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
update postgis support to use st_ variants instead of old deprecated
(and now removed) versions.
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
--- trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-01-12 23:06:53 UTC (rev 15022)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-01-12 23:07:05 UTC (rev 15023)
@@ -328,15 +328,15 @@
if ( typeName == "POINT" )
- geomFilter = QString( "GeometryType(\"%1\") IN ('POINT','MULTIPOINT')" ).arg( geomColumnName );
+ geomFilter = QString( "st_geometrytype(\"%1\") IN ('POINT','MULTIPOINT')" ).arg( geomColumnName );
else if ( typeName == "LINESTRING" )
- geomFilter = QString( "GeometryType(\"%1\") IN ('LINESTRING','MULTILINESTRING')" ).arg( geomColumnName );
+ geomFilter = QString( "st_geometrytype(\"%1\") IN ('LINESTRING','MULTILINESTRING')" ).arg( geomColumnName );
else if ( typeName == "POLYGON" )
- geomFilter = QString( "GeometryType(\"%1\") IN ('POLYGON','MULTIPOLYGON')" ).arg( geomColumnName );
+ geomFilter = QString( "st_geometrytype(\"%1\") IN ('POLYGON','MULTIPOLYGON')" ).arg( geomColumnName );
if ( !geomFilter.isEmpty() && !sql.contains( geomFilter ) )
@@ -941,9 +941,9 @@
QString query = QString( "select distinct "
"case"
- " when geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
- " when geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
- " when geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
+ " when st_geometrytype(%1) IN ('POINT','MULTIPOINT') THEN 'POINT'"
+ " when st_geometrytype(%1) IN ('LINESTRING','MULTILINESTRING') THEN 'LINESTRING'"
+ " when st_geometrytype(%1) IN ('POLYGON','MULTIPOLYGON') THEN 'POLYGON'"
" end "
"from " ).arg( "\"" + columns[i] + "\"" );
if ( mUseEstimatedMetadata )
Modified: trunk/qgis/src/plugins/spit/qgsshapefile.cpp
--- trunk/qgis/src/plugins/spit/qgsshapefile.cpp 2011-01-12 23:06:53 UTC (rev 15022)
+++ trunk/qgis/src/plugins/spit/qgsshapefile.cpp 2011-01-12 23:07:05 UTC (rev 15023)
@@ -435,7 +435,7 @@
values += val;
query += "," + QgsPgUtil::quotedIdentifier( geom_col );
- values += QString( ",GeometryFromText(%1,%2)" )
+ values += QString( ",st_geometryfromtext(%1,%2)" )
.arg( QgsPgUtil::quotedValue( geometry ) )
.arg( srid );
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-01-12 23:06:53 UTC (rev 15022)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-01-12 23:07:05 UTC (rev 15023)
@@ -569,14 +569,14 @@
// Contributed by #qgis irc "creeping"
// This version actually invokes PostGIS's use of spatial indexes
- whereClause = QString( "%1 && setsrid('BOX3D(%2)'::box3d,%3) and intersects(%1,setsrid('BOX3D(%2)'::box3d,%3))" )
+ whereClause = QString( "%1 && st_setsrid('BOX3D(%2)'::box3d,%3) and st_intersects(%1,st_setsrid('BOX3D(%2)'::box3d,%3))" )
.arg( quotedIdentifier( geometryColumn ) )
.arg( rect.asWktCoordinates() )
.arg( srid );
else
- whereClause = QString( "%1 && setsrid('BOX3D(%2)'::box3d,%3)" )
+ whereClause = QString( "%1 && st_setsrid('BOX3D(%2)'::box3d,%3)" )
.arg( srid );
@@ -2032,12 +2032,12 @@
enumValues.clear();
//is it a domain type with a check constraint?
- QString domainSql = QString( "SELECT domain_name from information_schema.columns where table_name = %1 and column_name = %2" ).arg( quotedValue( mTableName ) ).arg( quotedValue( attributeName ) );
+ QString domainSql = QString( "SELECT domain_name from information_schema.columns where table_name=%1 and column_name=%2" ).arg( quotedValue( mTableName ) ).arg( quotedValue( attributeName ) );
Result domainResult = connectionRO->PQexec( domainSql );
if ( PQresultStatus( domainResult ) == PGRES_TUPLES_OK && PQntuples( domainResult ) > 0 )
//a domain type
- QString domainCheckDefinitionSql = QString( "SELECT consrc FROM pg_constraint where conname = (SELECT constraint_name FROM information_schema.domain_constraints WHERE domain_name = %1)" ).arg( quotedValue( PQgetvalue( domainResult, 0, 0 ) ) );
+ QString domainCheckDefinitionSql = QString( "SELECT consrc FROM pg_constraint where conname=(SELECT constraint_name FROM information_schema.domain_constraints WHERE domain_name=%1)" ).arg( quotedValue( PQgetvalue( domainResult, 0, 0 ) ) );
Result domainCheckRes = connectionRO->PQexec( domainCheckDefinitionSql );
if ( PQresultStatus( domainCheckRes ) == PGRES_TUPLES_OK && PQntuples( domainCheckRes ) > 0 )
@@ -2048,7 +2048,7 @@
//normally, postgresql creates that if the contstraint has been specified as 'VALUE in ('a', 'b', 'c', 'd')
//todo: ANY must occure before ARRAY
- int anyPos = checkDefinition.indexOf( "VALUE = ANY" );
+ int anyPos = checkDefinition.indexOf( "VALUE=ANY" );
int arrayPosition = checkDefinition.lastIndexOf( "ARRAY[" );
int closingBracketPos = checkDefinition.indexOf( "]", arrayPosition + 6 );
@@ -2274,7 +2274,7 @@
if ( !geometryColumn.isNull() )
insert += quotedIdentifier( geometryColumn );
- values += QString( "GeomFromWKB($%1%2,%3)" )
+ values += QString( "st_geomfromwkb($%1%2,%3)" )
.arg( offset )
.arg( connectionRW->useWkbHex() ? "" : "::bytea" )
.arg( srid );
@@ -2346,7 +2346,7 @@
else if ( fit->typeName() == "geometry" )
- values += QString( "%1geomfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
+ values += QString( "%1st_geomfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
else if ( fit->typeName() == "geography" )
@@ -2362,7 +2362,7 @@
// value is not unique => add parameter
- values += QString( "%1geomfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
+ values += QString( "%1st_geomfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
@@ -2632,7 +2632,7 @@
else
first = false;
- sql += QString( fld.typeName() == "geometry" ? "%1=geomfromewkt(%2)" :
+ sql += QString( fld.typeName() == "geometry" ? "%1=st_geomfromewkt(%2)" :
fld.typeName() == "geography" ? "%1=st_geographyfromewkt(%2)" :
"%1=%2" )
.arg( quotedIdentifier( fld.name() ) )
@@ -2695,7 +2695,7 @@
// Start the PostGIS transaction
connectionRW->PQexecNR( "BEGIN" );
- QString update = QString( "UPDATE %1 SET %2=GeomFromWKB($1%3,%4) WHERE %5=$2" )
+ QString update = QString( "UPDATE %1 SET %2=st_geomfromwkb($1%3,%4) WHERE %5=$2" )
.arg( mQuery )
@@ -2879,7 +2879,7 @@
if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
- sql = QString( "select estimated_extent(%1,%2,%3)" )
+ sql = QString( "select st_estimated_extent(%1,%2,%3)" )
.arg( quotedValue( mSchemaName ) )
.arg( quotedValue( geometryColumn ) );
@@ -2907,7 +2907,7 @@
if ( ext.isEmpty() )
- sql = QString( "select extent(%1) from %2" )
+ sql = QString( "select st_extent(%1) from %2" )
.arg( mQuery );
@@ -3125,7 +3125,7 @@
// Didn't find what we need in the geometry_columns table, so
// get stuff from the relevant column instead. This may (will?)
// fail if there is no data in the relevant table.
- sql = QString( "select srid(%1), geometrytype(%1) from %2" )
+ sql = QString( "select st_srid(%1),st_geometrytype(%1) from %2" )
.arg( mQuery );
@@ -3154,9 +3154,9 @@
// check to see if there is a unique geometry type
sql = QString( "select distinct "
"case"
" end "
"from " ).arg( quotedIdentifier( geometryColumn ) );
