[QGIS Commit] r15042 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Fri Jan 14 05:42:15 EST 2011
Author: mhugent
Date: 2011-01-14 02:42:15 -0800 (Fri, 14 Jan 2011)
New Revision: 15042
trunk/qgis/src/ui/qgsattributeselectiondialogbase.ui
Add scroll area to composer table attribute selection dialog. Fix for bug #3406
Modified: trunk/qgis/src/ui/qgsattributeselectiondialogbase.ui
--- trunk/qgis/src/ui/qgsattributeselectiondialogbase.ui 2011-01-14 10:23:15 UTC (rev 15041)
+++ trunk/qgis/src/ui/qgsattributeselectiondialogbase.ui 2011-01-14 10:42:15 UTC (rev 15042)
@@ -7,49 +7,13 @@
<x>0</x>
<y>0</y>
<width>322</width>
- <height>283</height>
+ <height>373</height>
</rect>
</property>
<property name="windowTitle">
<string>Select attributes</string>
</property>
<layout class="QGridLayout" name="gridLayout_2">
- <item row="0" column="0" colspan="3">
- <layout class="QGridLayout" name="mAttributeGridLayout">
- <property name="sizeConstraint">
- <enum>QLayout::SetDefaultConstraint</enum>
- </property>
- <item row="0" column="0">
- <widget class="QLabel" name="mAttributeLabel">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <property name="text">
- <string><b>Attribute</b></string>
- </property>
- </widget>
- </item>
- <item row="0" column="1">
- <widget class="QLabel" name="mAliasLabel">
- </sizepolicy>
- </property>
- <string><b>Alias</b></string>
- </property>
- <property name="textFormat">
- <enum>Qt::AutoText</enum>
- </property>
- </widget>
- </item>
- </layout>
- </item>
<item row="1" column="0">
<widget class="QPushButton" name="mSelectAllButton">
@@ -164,6 +128,61 @@
</property>
</widget>
</item>
+ <item row="0" column="0" colspan="3">
+ <widget class="QScrollArea" name="scrollArea">
+ <property name="widgetResizable">
+ <bool>true</bool>
+ </property>
+ <widget class="QWidget" name="scrollAreaWidgetContents">
+ <property name="geometry">
+ <rect>
+ <x>0</x>
+ <y>0</y>
+ <width>300</width>
+ <height>90</height>
+ </rect>
+ </property>
+ <layout class="QGridLayout" name="gridLayout_3">
+ <item row="0" column="0">
+ <layout class="QGridLayout" name="mAttributeGridLayout">
+ <property name="sizeConstraint">
+ <enum>QLayout::SetDefaultConstraint</enum>
+ </property>
+ <widget class="QLabel" name="mAttributeLabel">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="text">
+ <string><b>Attribute</b></string>
+ </property>
+ </widget>
+ </item>
+ <item row="0" column="1">
+ <widget class="QLabel" name="mAliasLabel">
+ </sizepolicy>
+ </property>
+ <string><b>Alias</b></string>
+ </property>
+ <property name="textFormat">
+ <enum>Qt::AutoText</enum>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </item>
+ </layout>
+ </widget>
+ </widget>
+ </item>
</layout>
</widget>
<resources>
