[QGIS Commit] r15050 - in trunk/qgis/src: core gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jan 14 18:24:26 EST 2011
Author: jef
Date: 2011-01-14 15:24:26 -0800 (Fri, 14 Jan 2011)
New Revision: 15050
   trunk/qgis/src/core/qgsmaprenderer.cpp
   trunk/qgis/src/core/qgsmaprenderer.h
   trunk/qgis/src/gui/qgsmapcanvas.cpp
   trunk/qgis/src/gui/qgsmapcanvas.h
   trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
   trunk/qgis/src/gui/qgsmapoverviewcanvas.h
fix #2884:
crashed when two map renderers are simultaneously rendering the layers
for the canvas and overview (eg. on resize, when overview is docked).
This might fix it.
Modified: trunk/qgis/src/core/qgsmaprenderer.cpp
--- trunk/qgis/src/core/qgsmaprenderer.cpp	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/core/qgsmaprenderer.cpp	2011-01-14 23:24:26 UTC (rev 15050)
@@ -38,9 +38,8 @@
 #include <QListIterator>
 #include <QSettings>
 #include <QTime>
-#include "qgslogger.h"
+#include <QCoreApplication>
 QgsMapRenderer::QgsMapRenderer()
   mScaleCalculator = new QgsScaleCalculator;
@@ -229,14 +228,22 @@
     return;
-  if ( mDrawing )
+  QPaintDevice* thePaintDevice = painter->device();
+  if ( !thePaintDevice )
     return;
-  QPaintDevice* thePaintDevice = painter->device();
-  if ( !thePaintDevice )
+  // wait
+  if( mDrawing )
+    QgsDebugMsg( "already rendering" );
+    QCoreApplication::processEvents();
+  if( mDrawing )
+    QgsDebugMsg( "still rendering - skipping" );
     return;
@@ -599,7 +606,6 @@
   QgsDebugMsg( "Rendering completed in (seconds): " + QString( "%1" ).arg( renderTime.elapsed() / 1000.0 ) );
   mDrawing = false;
 void QgsMapRenderer::setMapUnits( QGis::UnitType u )
@@ -1073,3 +1079,5 @@
   mLabelingEngine = iface;
+bool QgsMapRenderer::mDrawing = false;
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/core/qgsmaprenderer.h	2011-01-14 23:24:26 UTC (rev 15050)
@@ -249,7 +249,7 @@
   protected:
     //! indicates drawing in progress
-    bool mDrawing;
+    static bool mDrawing;
     //! map units per pixel
     double mMapUnitsPerPixel;
Modified: trunk/qgis/src/gui/qgsmapcanvas.cpp
--- trunk/qgis/src/gui/qgsmapcanvas.cpp	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/gui/qgsmapcanvas.cpp	2011-01-14 23:24:26 UTC (rev 15050)
@@ -932,52 +932,59 @@
 void QgsMapCanvas::resizeEvent( QResizeEvent * e )
-  static bool isAlreadyIn = false;
-  static QSize lastSize = QSize( -1, -1 );
+  mNewSize = e->size();
-  lastSize = e->size();
+void QgsMapCanvas::paintEvent( QPaintEvent *e )
+  if( mNewSize.isValid() )
+    static bool isAlreadyIn = false;
+    static QSize lastSize = QSize();
-  if ( isAlreadyIn || mDrawing )
-    //cancel current render progress
-    if ( mMapRenderer )
+    lastSize = mNewSize;
+    mNewSize = QSize();
+    if ( isAlreadyIn || mDrawing )
-      QgsRenderContext* theRenderContext = mMapRenderer->rendererContext();
-      if ( theRenderContext )
+      //cancel current render progress
+      if ( mMapRenderer )
-        theRenderContext->setRenderingStopped( true );
+        QgsRenderContext* theRenderContext = mMapRenderer->rendererContext();
+        if ( theRenderContext )
+          theRenderContext->setRenderingStopped( true );
+      return;
-    return;
-  isAlreadyIn = true;
+    isAlreadyIn = true;
-  while ( lastSize != QSize( -1, -1 ) )
-    int width = lastSize.width();
-    int height = lastSize.height();
-    lastSize = QSize( -1, -1 );
+    while ( lastSize.isValid() )
+      int width = lastSize.width();
+      int height = lastSize.height();
+      lastSize = QSize();
-    //set map size before scene size helps keep scene indexes updated properly
-    // this was the cause of rubberband artifacts
-    mMap->resize( QSize( width, height ) );
-    mScene->setSceneRect( QRectF( 0, 0, width, height ) );
+      //set map size before scene size helps keep scene indexes updated properly
+      // this was the cause of rubberband artifacts
+      mMap->resize( QSize( width, height ) );
+      mScene->setSceneRect( QRectF( 0, 0, width, height ) );
-    // notify canvas items of change
-    updateCanvasItemPositions();
+      // notify canvas items of change
+      updateCanvasItemPositions();
-    updateScale();
-#if QT_VERSION >= 0x40600
-    // FIXME: temporary workaround for #2714
-    QTimer::singleShot( 1, this, SLOT( refresh() ) );
-#else
-    refresh();
-#endif
-    emit extentsChanged();
+      updateScale();
+      refresh();
+      emit extentsChanged();
+  isAlreadyIn = false;
-  isAlreadyIn = false;
-} // resizeEvent
+  QGraphicsView::paintEvent( e );
+} // paintEvent
 void QgsMapCanvas::updateCanvasItemPositions()
Modified: trunk/qgis/src/gui/qgsmapcanvas.h
--- trunk/qgis/src/gui/qgsmapcanvas.h	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/gui/qgsmapcanvas.h	2011-01-14 23:24:26 UTC (rev 15050)
@@ -368,6 +368,9 @@
     //! Overridden resize event
     void resizeEvent( QResizeEvent * e );
+    //! Overridden paint event
+    void paintEvent( QPaintEvent * e );
     //! called when panning is in action, reset indicates end of panning
     void moveCanvasContents( bool reset = false );
@@ -451,6 +454,9 @@
     //! Mouse wheel action
     WheelAction mWheelAction;
+    //! resize canvas size
+    QSize mNewSize;
 }; // class QgsMapCanvas
Modified: trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp
--- trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/gui/qgsmapoverviewcanvas.cpp	2011-01-14 23:24:26 UTC (rev 15050)
@@ -85,12 +85,24 @@
 void QgsMapOverviewCanvas::resizeEvent( QResizeEvent* e )
-  mPixmap = QPixmap( e->size() );
-  mMapRenderer->setOutputSize( e->size(), mPixmap.logicalDpiX() );
-  refresh();
+void QgsMapOverviewCanvas::paintEvent( QPaintEvent* pe )
+    mPixmap = QPixmap( mNewSize );
+    mMapRenderer->setOutputSize( mNewSize, mPixmap.logicalDpiX() );
+    refresh();
+  QPainter paint( this );
+  paint.drawPixmap( pe->rect().topLeft(), mPixmap, pe->rect() );
 void QgsMapOverviewCanvas::drawExtentRect()
   const QgsRectangle& extent = mMapCanvas->extent();
@@ -233,16 +245,9 @@
-void QgsMapOverviewCanvas::paintEvent( QPaintEvent * pe )
-  QPainter paint( this );
-  paint.drawPixmap( pe->rect().topLeft(), mPixmap, pe->rect() );
 void QgsMapOverviewCanvas::refresh()
-  if ( mPixmap.isNull() )
+  if ( mPixmap.isNull() || mPixmap.paintingActive() )
     return;
   mPixmap.fill( mBgColor ); //palette().color(backgroundRole());
Modified: trunk/qgis/src/gui/qgsmapoverviewcanvas.h
--- trunk/qgis/src/gui/qgsmapoverviewcanvas.h	2011-01-14 23:24:15 UTC (rev 15049)
+++ trunk/qgis/src/gui/qgsmapoverviewcanvas.h	2011-01-14 23:24:26 UTC (rev 15050)
@@ -108,6 +108,9 @@
     //! indicates whether antialiasing will be used for rendering
     bool mAntiAliasing;
+    //! resized canvas size
+    QSize mNewSize;
 #endif
More information about the QGIS-commit mailing list
