[QGIS Commit] r15060 - in branches/raster-providers/src: core
providers/grass
svn_qgis at osgeo.org
Thu Jan 20 16:06:43 EST 2011
Author: rblazek
Date: 2011-01-20 13:06:43 -0800 (Thu, 20 Jan 2011)
New Revision: 15060
branches/raster-providers/src/core/qgsrasterdataprovider.cpp
branches/raster-providers/src/core/qgsrasterprojector.cpp
branches/raster-providers/src/core/qgsrasterprojector.h
branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
better approx reprojection
Modified: branches/raster-providers/src/core/qgsrasterdataprovider.cpp
--- branches/raster-providers/src/core/qgsrasterdataprovider.cpp 2011-01-20 00:06:34 UTC (rev 15059)
+++ branches/raster-providers/src/core/qgsrasterdataprovider.cpp 2011-01-20 21:06:43 UTC (rev 15060)
@@ -20,6 +20,7 @@
#include "qgsrasterprojector.h"
#include "qgslogger.h"
+#include <QTime>
#include <QMap>
void QgsRasterDataProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *data )
@@ -32,30 +33,43 @@
return;
+ QTime time;
+ time.start();
QgsRasterProjector myProjector = QgsRasterProjector ( theSrcCRS, theDestCRS, viewExtent, height, width, extent().width()/xSize(), extent().height()/ySize() );
+ QgsDebugMsg( QString( "create projector time (ms): %1" ).arg( time.elapsed() ) );
// TODO: init data by nulls
// Allocate memory for not projected source data
int mySize = dataTypeSize(bandNo)/8;
void *mySrcData = malloc( mySize * myProjector.srcRows() * myProjector.srcCols() );
+ time.restart();
readBlock( bandNo, myProjector.srcExtent(), myProjector.srcCols(), myProjector.srcRows(), mySrcData );
+ QgsDebugMsg( QString( "read not projected block time (ms): %1" ).arg( time.elapsed() ) );
+ time.restart();
// Project data from source
- QVector<int> mySrcRowCol;
+ int mySrcRow;
+ int mySrcCol;
int mySrcOffset;
int myDestOffset;
for ( int r = 0; r < height; r++) {
//for ( int r = height-1; r < height; r++) {
for ( int c = 0; c < width; c++) {
- mySrcRowCol = myProjector.srcRowCol ( r, c );
- mySrcOffset = mySize * ( mySrcRowCol[0] * myProjector.srcCols() + mySrcRowCol[1] );
+ myProjector.srcRowCol ( r, c, &mySrcRow, &mySrcCol );
+ mySrcOffset = mySize * ( mySrcRow * myProjector.srcCols() + mySrcCol );
myDestOffset = mySize * ( r * width + c );
// retype to char is just to avoid g++ warning
memcpy( (char*) data + myDestOffset, (char*)mySrcData + mySrcOffset, mySize );
+ QgsDebugMsg( QString( "reproject block time (ms): %1" ).arg( time.elapsed() ) );
free( mySrcData );
Modified: branches/raster-providers/src/core/qgsrasterprojector.cpp
--- branches/raster-providers/src/core/qgsrasterprojector.cpp 2011-01-20 00:06:34 UTC (rev 15059)
+++ branches/raster-providers/src/core/qgsrasterprojector.cpp 2011-01-20 21:06:43 UTC (rev 15060)
@@ -40,22 +40,23 @@
// reverse transformation
mCoordinateTransform = new QgsCoordinateTransform( theDestCRS, theSrcCRS );
+ mDestXRes = mDestExtent.width() / (mDestCols);
+ mDestYRes = mDestExtent.height() / (mDestRows);
// Calculate tolerance
// TODO: Think it over better
- double myDestXRes = mDestExtent.width()/theDestCols;
- double myDestYRes = mDestExtent.height()/theDestRows;
- mTolerance = myDestXRes < myDestYRes ? myDestXRes : myDestYRes;
+ // Note: we are checking on matrix each even point, that means taht the real error
+ // in that moment is approximately half size
+ double myDestRes = mDestXRes < mDestYRes ? mDestXRes : mDestYRes;
+ mSqrTolerance = myDestRes * myDestRes;
- //mTolerance *= 0.5;
// Initialize the matrix by corners and middle points
- mCPCols = mCPRows = 4;
+ mCPCols = mCPRows = 3;
for ( int i = 0; i < mCPRows; i++) {
QList<QgsPoint> myRow;
myRow.append( QgsPoint() );
- myRow.append( QgsPoint() );
mCPMatrix.insert(i, myRow );
@@ -68,10 +69,15 @@
if ( !myColsOK ) {
insertRows();
- if ( myColsOK ) {
+ bool myRowsOK = checkRows();
+ if ( !myRowsOK ) {
+ insertCols();
+ if ( myColsOK && myRowsOK ) {
QgsDebugMsg("CP matrix within tolerance");
break;
+ // What is the maximum reasonable size of transformatio matrix?
// TODO: consider better when to break - ratio
if ( mCPRows * mCPCols > 0.25 * mDestRows * mDestCols )
@@ -80,12 +86,15 @@
- QgsDebugMsg( QString("mCPRows = %1 mCPCols = %2").arg(mCPRows).arg(mCPCols) );
+ QgsDebugMsg( QString("CPMatrix size: mCPRows = %1 mCPCols = %2").arg(mCPRows).arg(mCPCols) );
+ mDestRowsPerMatrixRow = (float)mDestRows / (mCPRows - 1);
+ mDestColsPerMatrixCol = (float)mDestCols / (mCPCols - 1);
// Calculate source dimensions
calcSrcExtent();
calcSrcRowsCols();
+ mSrcXRes = mSrcExtent.height() / mSrcRows;
+ mSrcYRes = mSrcExtent.width() / mSrcCols;
QgsRasterProjector::~QgsRasterProjector ()
@@ -153,25 +162,25 @@
-QgsPoint QgsRasterProjector::destPointOnCPMatrix ( int theRow, int theCol )
+inline void QgsRasterProjector::destPointOnCPMatrix ( int theRow, int theCol, double *theX, double *theY )
//QgsDebugMsg( QString("theRow = %1 theCol = %2").arg(theRow).arg(theCol) );
- double x = mDestExtent.xMinimum() + theCol * mDestExtent.width() / (mCPCols-1);
- double y = mDestExtent.yMaximum() - theRow * mDestExtent.height() / (mCPRows-1);
+ *theX = mDestExtent.xMinimum() + theCol * mDestExtent.width() / (mCPCols-1);
+ *theY = mDestExtent.yMaximum() - theRow * mDestExtent.height() / (mCPRows-1);
//QgsDebugMsg( QString("x = %1 y = %2").arg(x).arg(y) );
- return QgsPoint(x, y);
-int QgsRasterProjector::matrixRow ( int theDestRow )
+inline int QgsRasterProjector::matrixRow ( int theDestRow )
//QgsDebugMsg( QString("theDestRow = %1 mDestRows = %2 mCPRows = %3").arg(theDestRow).arg( mDestRows).arg(mCPRows) );
- int myRow = (int) ( floor ( (theDestRow + 0.5) / ( (float)mDestRows / (mCPRows - 1) ) ) );
- return myRow;
+ //int myRow = (int) ( floor ( (theDestRow + 0.5) / ( (float)mDestRows / (mCPRows - 1) ) ) );
+ return (int) ( floor ( (theDestRow + 0.5) / mDestRowsPerMatrixRow ) );
-int QgsRasterProjector::matrixCol ( int theDestCol )
+inline int QgsRasterProjector::matrixCol ( int theDestCol )
//QgsDebugMsg( QString("theDestCol = %1 mDestCols = %2 mCPCols = %3").arg(theDestCol).arg( mDestCols).arg(mCPCols) );
- return (int) ( floor ( (theDestCol + 0.5) / ( (float)mDestCols / (mCPCols - 1) ) ) );
+ //return (int) ( floor ( (theDestCol + 0.5) / ( (float)mDestCols / (mCPCols - 1) ) ) );
+ return (int) ( floor ( (theDestCol + 0.5) / mDestColsPerMatrixCol ) );
QgsPoint QgsRasterProjector::srcPoint ( int theDestRow, int theCol )
@@ -179,11 +188,11 @@
return QgsPoint();
-QVector<int> QgsRasterProjector::srcRowCol ( int theDestRow, int theDestCol )
+void QgsRasterProjector::srcRowCol ( int theDestRow, int theDestCol, int *theSrcRow, int *theSrcCol )
//QgsDebugMsg( QString("theDestRow = %1 theDestCol = %2").arg( theDestRow).arg(theDestCol) );
- double myDestX = mDestExtent.xMinimum() + ( theDestCol + 0.5 ) * mDestExtent.width() / (mDestCols);
- double myDestY = mDestExtent.yMaximum() - ( theDestRow + 0.5 ) * mDestExtent.height() / (mDestRows);
+ double myDestX = mDestExtent.xMinimum() + ( theDestCol + 0.5 ) * mDestXRes;
+ double myDestY = mDestExtent.yMaximum() - ( theDestRow + 0.5 ) * mDestYRes;
//QgsDebugMsg( QString("myDestX = %1 myDestY = %2").arg( myDestX ).arg( myDestY) );
int myMatrixRow = matrixRow ( theDestRow );
@@ -193,28 +202,36 @@
// See the schema in javax.media.jai.WarpGrid doc (but up side down)
// TODO: use some kind of cache of values which can be reused
- QgsPoint myDestLL = destPointOnCPMatrix ( myMatrixRow + 1, myMatrixCol );
- QgsPoint myDestUR = destPointOnCPMatrix ( myMatrixRow, myMatrixCol + 1 );
+ //QgsPoint myDestLL = destPointOnCPMatrix ( myMatrixRow + 1, myMatrixCol );
+ //QgsPoint myDestUR = destPointOnCPMatrix ( myMatrixRow, myMatrixCol + 1 );
+ double myDestXMin, myDestYMin, myDestXMax, myDestYMax;
+ destPointOnCPMatrix ( myMatrixRow + 1, myMatrixCol, &myDestXMin, &myDestYMin );
+ destPointOnCPMatrix ( myMatrixRow, myMatrixCol + 1, &myDestXMax, &myDestYMax );
//QgsDebugMsg( "myDestLL = " + myDestLL.toString() + " myDestUR = " + myDestUR.toString() );
- QgsPoint mySrcPoint0 = mCPMatrix[myMatrixRow+1][myMatrixCol];
- QgsPoint mySrcPoint1 = mCPMatrix[myMatrixRow+1][myMatrixCol+1];
- QgsPoint mySrcPoint2 = mCPMatrix[myMatrixRow][myMatrixCol];
- QgsPoint mySrcPoint3 = mCPMatrix[myMatrixRow][myMatrixCol+1];
+ QgsPoint *mySrcPoint0 = &(mCPMatrix[myMatrixRow+1][myMatrixCol]);
+ QgsPoint *mySrcPoint1 = &(mCPMatrix[myMatrixRow+1][myMatrixCol+1]);
+ QgsPoint *mySrcPoint2 = &(mCPMatrix[myMatrixRow][myMatrixCol]);
+ QgsPoint *mySrcPoint3 = &(mCPMatrix[myMatrixRow][myMatrixCol+1]);
//QgsDebugMsg( "mySrcPoint : " + mySrcPoint0.toString() + " " + mySrcPoint1.toString() + " " +mySrcPoint2.toString() + " " + mySrcPoint3.toString() + " " );
- double xfrac = ( myDestX - myDestLL.x() ) / ( myDestUR.x() - myDestLL.x() );
- double yfrac = ( myDestY - myDestLL.y() ) / ( myDestUR.y() - myDestLL.y() );
+ //double xfrac = ( myDestX - myDestLL.x() ) / ( myDestUR.x() - myDestLL.x() );
+ //double yfrac = ( myDestY - myDestLL.y() ) / ( myDestUR.y() - myDestLL.y() );
+ double xfrac = ( myDestX - myDestXMin ) / ( myDestXMax - myDestXMin );
+ double yfrac = ( myDestY - myDestYMin ) / ( myDestYMax - myDestYMin );
//QgsDebugMsg( QString("xfrac = %1 yfrac = %2").arg(xfrac).arg(yfrac) );
- assert ( xfrac >= 0 );
- assert ( yfrac >= 0 );
+ //assert ( xfrac >= 0 );
+ //assert ( yfrac >= 0 );
- double s = mySrcPoint0.x() + ( mySrcPoint1.x() - mySrcPoint0.x() ) * xfrac;
- double t = mySrcPoint0.y() + ( mySrcPoint1.y() - mySrcPoint0.y() ) * xfrac;
+ double s = mySrcPoint0->x() + ( mySrcPoint1->x() - mySrcPoint0->x() ) * xfrac;
+ double t = mySrcPoint0->y() + ( mySrcPoint1->y() - mySrcPoint0->y() ) * xfrac;
- double u = mySrcPoint2.x() + ( mySrcPoint3.x() - mySrcPoint2.x() ) * xfrac;
- double v = mySrcPoint2.y() + ( mySrcPoint3.y() - mySrcPoint2.y() ) * xfrac;
+ double u = mySrcPoint2->x() + ( mySrcPoint3->x() - mySrcPoint2->x() ) * xfrac;
+ double v = mySrcPoint2->y() + ( mySrcPoint3->y() - mySrcPoint2->y() ) * xfrac;
double mySrcX = s + (u - s) * yfrac;
double mySrcY = t + (v - t) * yfrac;
@@ -227,21 +244,16 @@
// TODO: check again cell selection (coor is in the middle)
//QgsDebugMsg( QString("mSrcExtent.yMaximum() = %1 mySrcY = %2").arg(mSrcExtent.yMaximum()).arg(mySrcY)) ;
- int mySrcRow = (int) floor ( ( mSrcExtent.yMaximum() - mySrcY ) / ( mSrcExtent.height() / mSrcRows ) );
- int mySrcCol = (int) floor ( ( mySrcX - mSrcExtent.xMinimum() ) / ( mSrcExtent.width() / mSrcCols ) );
+ *theSrcRow = (int) floor ( ( mSrcExtent.yMaximum() - mySrcY ) / mSrcXRes );
+ *theSrcCol = (int) floor ( ( mySrcX - mSrcExtent.xMinimum() ) / mSrcYRes );
//QgsDebugMsg( QString("( mSrcExtent.yMaximum() - mySrcY ) / ( mSrcExtent.height() / mSrcRows ) = %1") .arg( ( mSrcExtent.yMaximum() - mySrcY ) / ( mSrcExtent.height() / mSrcRows ) ) );
//QgsDebugMsg( QString("mySrcY = %1 yMaximum = %2").arg(mySrcY).arg(mSrcExtent.yMaximum()) );
- //QgsDebugMsg( QString("mySrcRow = %1 mySrcCol = %2 mSrcRows = %3 mSrcCols = %4").arg( mySrcRow).arg( mySrcCol).arg(mSrcRows).arg(mSrcCols) );
+ //QgsDebugMsg( QString("theSrcRow = %1 theSrcCol = %2 mSrcRows = %3 mSrcCols = %4").arg( *theSrcRow ).arg( *theSrcCol ).arg(mSrcRows).arg(mSrcCols) );
- assert ( mySrcRow < mSrcRows );
- assert ( mySrcCol < mSrcCols );
- QVector<int> myPosition(2);
- myPosition[0] = mySrcRow;
- myPosition[1] = mySrcCol;
- return myPosition;
+ //assert ( *theSrcRow < mSrcRows );
+ //assert ( *theSrcCol < mSrcCols );
void QgsRasterProjector::insertRows()
@@ -262,13 +274,26 @@
void QgsRasterProjector::insertCols()
+ for ( int r = 0; r < mCPRows; r++) {
+ QList<QgsPoint> myRow;
+ for ( int c = 0; c < mCPCols-1; c++) {
+ mCPMatrix[r].insert( 1+c*2, QgsPoint() );
+ mCPCols += mCPCols-1;
+ for ( int c = 1; c < mCPCols-1; c += 2) {
+ calcCol( c );
void QgsRasterProjector::calcCP ( int theRow, int theCol )
- QgsPoint myDestPoint = destPointOnCPMatrix ( theRow, theCol );
+ //QgsPoint myDestPoint = destPointOnCPMatrix ( theRow, theCol );
+ double myDestX, myDestY;
+ destPointOnCPMatrix ( theRow, theCol, &myDestX, &myDestY );
+ QgsPoint myDestPoint ( myDestX, myDestY );
QgsDebugMsg( "myDestPoint : " + myDestPoint.toString() );
mCPMatrix[theRow][theCol] = mCoordinateTransform->transform( myDestPoint );
@@ -285,34 +310,55 @@
bool QgsRasterProjector::calcCol( int theCol )
+ QgsDebugMsg( QString("theCol = %1").arg(theCol) );
+ for ( int i = 0; i < mCPRows; i++) {
+ calcCP ( i, theCol );
-bool QgsRasterProjector::calcRows()
+bool QgsRasterProjector::checkCols()
+ QgsDebugMsg( "Entered" );
+ for ( int c = 0; c < mCPCols; c++) {
+ for ( int r = 1; r < mCPRows-1; r += 2 ) {
+ //QgsPoint myDestPoint = destPointOnCPMatrix ( r, c );
+ destPointOnCPMatrix ( r, c, &myDestX, &myDestY );
+ QgsPoint mySrcPoint1 = mCPMatrix[r-1][c];
+ QgsPoint mySrcPoint2 = mCPMatrix[r][c];
+ QgsPoint mySrcPoint3 = mCPMatrix[r+1][c];
-bool QgsRasterProjector::calcCols()
+ QgsPoint mySrcApprox( ( mySrcPoint1.x() + mySrcPoint3.x() ) / 2, (mySrcPoint1.y() + mySrcPoint3.y() ) / 2 );
+ QgsPoint myDestApprox = mCoordinateTransform->transform( mySrcApprox, QgsCoordinateTransform::ReverseTransform );
+ double mySqrDist = myDestApprox.sqrDist( myDestPoint );
+ QgsDebugMsg( QString("mySqrDist = %1 mSqrTolerance = %2").arg(mySqrDist).arg(mSqrTolerance) );
+ if ( mySqrDist > mSqrTolerance ) { return false; }
+ return true;
-bool QgsRasterProjector::checkCols()
+bool QgsRasterProjector::checkRows()
- for ( int c = 0; c < mCPCols; c++) {
- for ( int r = 1; r < mCPRows-1; r += 2 ) {
- QgsPoint myDestPoint = destPointOnCPMatrix ( r, c );
- QgsPoint mySrcPoint1 = mCPMatrix[r-1][c];
+ for ( int c = 1; c < mCPCols-1; c += 2 ) {
+ QgsPoint mySrcPoint1 = mCPMatrix[r][c-1];
- QgsPoint mySrcPoint3 = mCPMatrix[r+1][c];
+ QgsPoint mySrcPoint3 = mCPMatrix[r][c+1];
- QgsDebugMsg( QString("mySqrDist = %1 mTolerance = %2").arg(mySqrDist).arg(mTolerance) );
- if ( mySqrDist > mTolerance ) { return false; }
return true;
Modified: branches/raster-providers/src/core/qgsrasterprojector.h
--- branches/raster-providers/src/core/qgsrasterprojector.h 2011-01-20 00:06:34 UTC (rev 15059)
+++ branches/raster-providers/src/core/qgsrasterprojector.h 2011-01-20 21:06:43 UTC (rev 15060)
@@ -59,7 +59,7 @@
/** \brief get destination point for _current_ destination position */
- QgsPoint destPointOnCPMatrix ( int theRow, int theCol );
+ void destPointOnCPMatrix ( int theRow, int theCol, double *theX, double *theY );
/** \brief Get matrix upper left row/col indexes for destination row/col */
int matrixRow ( int theDestRow );
@@ -75,7 +75,7 @@
QgsPoint srcPoint ( int theRow, int theCol );
/** \brief Get source row and column indexes for current source extent and resolution */
- QVector<int> srcRowCol ( int theDestRow, int theDestCol );
+ void srcRowCol ( int theDestRow, int theDestCol, int *theSrcRow, int *theSrcCol );
/** \brief insert rows to matrix */
void insertRows();
@@ -92,14 +92,6 @@
/** \brief calculate matrix column */
bool calcCol( int theCol );
- /** \brief calculate odd (new) matrix rows
- * returns true if errors along those lines is within threshold
- bool calcRows();
- /** \brief calculate odd (new) matrix columns */
- bool calcCols();
/** \brief calculate source extent */
void calcSrcExtent();
@@ -110,15 +102,21 @@
* returns true if within threshold */
bool checkCols ();
+ /** \brief check error along rows
+ * returns true if within threshold */
+ bool checkRows ();
+ /** \brief get point for matrix position */
+ //QgsPoint matrixPoint ( int theRow, int theCol ) { return QgsPoint ( mCPMatrix[theRow][theCol][0], mCPMatrix[theRow][theCol][1] ); }
/** get source extent */
QgsRectangle srcExtent() { return mSrcExtent; }
/** get/set source width/height */
int srcRows() { return mSrcRows; }
int srcCols() { return mSrcCols; }
- void setSrcRows( int theRows ) { mSrcRows = theRows; }
- void setSrcCols( int theCols ) { mSrcCols = theCols; }
+ void setSrcRows( int theRows ) { mSrcRows = theRows; mSrcXRes = mSrcExtent.height() / mSrcRows; }
+ void setSrcCols( int theCols ) { mSrcCols = theCols; mSrcYRes = mSrcExtent.width() / mSrcCols; }
private:
/** Source CRS */
@@ -143,14 +141,35 @@
/** Number of destination columns */
int mDestCols;
+ /** Destination x resolution */
+ double mDestXRes;
+ /** Destination y resolution */
+ double mDestYRes;
/** Number of source rows */
int mSrcRows;
/** Number of source columns */
int mSrcCols;
+ /** Source x resolution */
+ double mSrcXRes;
+ /** Source y resolution */
+ double mSrcYRes;
+ /** number of destination rows per matrix row */
+ double mDestRowsPerMatrixRow;
+ /** number of destination cols per matrix col */
+ double mDestColsPerMatrixCol;
/** Grid of source control points */
+ // using QList< QList<double *> > mCPMatrix; takes however a more time (about 20%) than QList< QList<QgsPoint> > mCPMatrix; - why?
+ //QList< QList<double *> > mCPMatrix;
/** Number of mCPMatrix columns */
int mCPCols;
@@ -158,7 +177,7 @@
int mCPRows;
/** Maximum tolerance in destination units */
- double mTolerance;
+ double mSqrTolerance;
/** Maximum source resolution */
double mMaxSrcXRes;
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp 2011-01-20 00:06:34 UTC (rev 15059)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.cpp 2011-01-20 21:06:43 UTC (rev 15060)
@@ -201,7 +201,7 @@
memcpy( block, data.data(), size );
-void QgsGrassRasterProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *block )
+void QgsGrassRasterProvider::readBlock( int bandNo, QgsRectangle const & viewExtent, int pixelWidth, int pixelHeight, void *block )
QgsDebugMsg( "pixelWidth = " + QString::number( pixelWidth ) );
Modified: branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h
--- branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h 2011-01-20 00:06:34 UTC (rev 15059)
+++ branches/raster-providers/src/providers/grass/qgsgrassrasterprovider.h 2011-01-20 21:06:43 UTC (rev 15060)
@@ -191,7 +191,7 @@
void readBlock( int bandNo, int xBlock, int yBlock, void *data );
- void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, QgsCoordinateReferenceSystem theSrcCRS, QgsCoordinateReferenceSystem theDestCRS, void *data );
+ void readBlock( int bandNo, QgsRectangle const & viewExtent, int width, int height, void *data );
double noDataValue() const;
double minimumValue(int bandNo)const;
