[QGIS Commit] r15072 - in trunk/qgis/src: app/postgres
providers/postgres
svn_qgis at osgeo.org
Mon Jan 24 16:48:40 EST 2011
Author: jef
Date: 2011-01-24 13:48:40 -0800 (Mon, 24 Jan 2011)
New Revision: 15072
trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
postgres provider update: use st_ functions only with postgis>=2 and the old one with earlier postgis version
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
--- trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-01-24 16:33:27 UTC (rev 15071)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2011-01-24 21:48:40 UTC (rev 15072)
@@ -732,8 +732,8 @@
"pg_namespace.oid=pg_class.relnamespace"
" and pg_attribute.attrelid = pg_class.oid"
" and ("
- "pg_attribute.atttypid::regtype::text IN ('geometry','geography')"
- " or pg_attribute.atttypid IN (select oid FROM pg_type WHERE typbasetype::regtype::text IN ('geometry','geography'))"
+ " exists (select * from pg_type WHERE pg_type.oid=pg_attribute.atttypid AND pg_type.typname IN ('geometry','geography'))"
+ " or pg_attribute.atttypid IN (select oid FROM pg_type a WHERE EXISTS (SELECT * FROM pg_type b WHERE a.typbasetype=b.oid AND b.typname IN ('geometry','geography')))"
" and has_schema_privilege( pg_namespace.nspname, 'usage' )"
" and has_table_privilege( '\"' || pg_namespace.nspname || '\".\"' || pg_class.relname || '\"', 'select' )";
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-01-24 16:33:27 UTC (rev 15071)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp 2011-01-24 21:48:40 UTC (rev 15072)
@@ -372,7 +372,9 @@
else if ( type == "geometry" )
- return QString( "st_asewkt(%1)" ).arg( quotedIdentifier( fld.name() ) );
+ return QString( "%1(%2)" )
+ .arg( connectionRO->majorVersion() < 2 ? "asewkt" : "st_asewkt" )
+ .arg( quotedIdentifier( fld.name() ) );
else if ( type == "geography" )
@@ -403,11 +405,13 @@
if ( isGeography )
- query += QString( ",st_asbinary(%1)" ).arg( quotedIdentifier( geometryColumn ) );
+ query += QString( ",st_asbinary(%1)" )
+ .arg( quotedIdentifier( geometryColumn ) );
else
- query += QString( ",st_asbinary(%1,'%2')" )
+ query += QString( ",%1(%2,'%3')" )
+ .arg( connectionRO->majorVersion() < 2 ? "asbinary" : "st_asbinary" )
.arg( endianString() );
@@ -564,20 +568,22 @@
if ( whereClause.isEmpty() )
if ( useIntersect )
// Contributed by #qgis irc "creeping"
// This version actually invokes PostGIS's use of spatial indexes
- whereClause = QString( "%1 && st_setsrid('BOX3D(%2)'::box3d,%3) and st_intersects(%1,st_setsrid('BOX3D(%2)'::box3d,%3))" )
+ whereClause = QString( "%1 && %2('BOX3D(%3)'::box3d,%4) and %5(%1,%2('BOX3D(%3)'::box3d,%4))" )
+ .arg( connectionRO->majorVersion() < 2 ? "setsrid" : "st_setsrid" )
.arg( rect.asWktCoordinates() )
- .arg( srid );
+ .arg( srid )
+ .arg( connectionRO->majorVersion() < 2 ? "intersects" : "st_intersects" );
else
- whereClause = QString( "%1 && st_setsrid('BOX3D(%2)'::box3d,%3)" )
+ whereClause = QString( "%1 && %2('BOX3D(%3)'::box3d,%4)" )
.arg( srid );
@@ -2260,7 +2266,8 @@
if ( !geometryColumn.isNull() )
insert += quotedIdentifier( geometryColumn );
- values += QString( "st_geomfromwkb($%1%2,%3)" )
+ values += QString( "%1($%2%3,%4)" )
+ .arg( connectionRO->majorVersion() < 2 ? "geomfromwkb" : "st_geomfromwkb" )
.arg( offset )
.arg( connectionRW->useWkbHex() ? "" : "::bytea" )
.arg( srid );
@@ -2332,11 +2339,16 @@
else if ( fit->typeName() == "geometry" )
- values += QString( "%1st_geomfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
+ values += QString( "%1%2(%3)" )
+ .arg( delim )
+ .arg( connectionRO->majorVersion() < 2 ? "geomfromewkt" : "st_geomfromewkt" )
+ .arg( quotedValue( it->toString() ) );
else if ( fit->typeName() == "geography" )
- values += QString( "%1st_geographyfromewkt(%2)" ).arg( delim ).arg( quotedValue( it->toString() ) );
+ values += QString( "%1st_geographyfromewkt(%2)" )
+ .arg( delim )
else
@@ -2348,15 +2360,22 @@
// value is not unique => add parameter
- values += QString( "%1st_geomfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
+ values += QString( "%1%2($%3)" )
+ .arg( delim )
+ .arg( defaultValues.size() + offset );
- values += QString( "%1st_geographyfromewkt($%2)" ).arg( delim ).arg( defaultValues.size() + offset );
+ values += QString( "%1st_geographyfromewkt($%2)" )
+ .arg( delim )
else
- values += QString( "%1$%2" ).arg( delim ).arg( defaultValues.size() + offset );
+ values += QString( "%1$%2" )
+ .arg( delim )
defaultValues.append( defVal );
fieldId.append( it.key() );
@@ -2618,11 +2637,23 @@
else
first = false;
- sql += QString( fld.typeName() == "geometry" ? "%1=st_geomfromewkt(%2)" :
- fld.typeName() == "geography" ? "%1=st_geographyfromewkt(%2)" :
- "%1=%2" )
- .arg( quotedIdentifier( fld.name() ) )
- .arg( quotedValue( siter->toString() ) );
+ sql += QString( "%1=" ).arg( quotedIdentifier( fld.name() ) );
+ if ( fld.typeName() == "geometry" )
+ sql += QString( "%1(%2)" )
+ .arg( quotedValue( siter->toString() ) );
+ else if ( fld.typeName() == "geography" )
+ sql += QString( "st_geographyfromewkt(%1)" )
+ else
+ sql += quotedValue( siter->toString() );
catch ( PGFieldNotFound )
@@ -2681,9 +2712,10 @@
// Start the PostGIS transaction
connectionRW->PQexecNR( "BEGIN" );
- QString update = QString( "UPDATE %1 SET %2=st_geomfromwkb($1%3,%4) WHERE %5=$2" )
+ QString update = QString( "UPDATE %1 SET %2=%3($1%4,%5) WHERE %6=$2" )
.arg( mQuery )
+ .arg( connectionRW->majorVersion() < 2 ? "geomfromwkb" : "st_geomfromwkb" )
.arg( srid )
.arg( quotedIdentifier( primaryKey ) );
@@ -2865,7 +2897,8 @@
if ( QString::fromUtf8( PQgetvalue( result, 0, 0 ) ).toInt() > 0 )
- sql = QString( "select st_estimated_extent(%1,%2,%3)" )
+ sql = QString( "select %1(%2,%3,%4)" )
+ .arg( connectionRO->majorVersion() < 2 ? "estimated_extent" : "st_estimated_extent" )
.arg( quotedValue( mSchemaName ) )
.arg( quotedValue( mTableName ) )
.arg( quotedValue( geometryColumn ) );
@@ -2893,7 +2926,8 @@
if ( ext.isEmpty() )
- sql = QString( "select st_extent(%1) from %2" )
+ sql = QString( "select %1(%2) from %3" )
+ .arg( connectionRO->majorVersion() < 2 ? "extent" : "st_extent" )
.arg( mQuery );
@@ -3111,7 +3145,8 @@
// Didn't find what we need in the geometry_columns table, so
// get stuff from the relevant column instead. This may (will?)
// fail if there is no data in the relevant table.
- sql = QString( "select st_srid(%1),geometrytype(%1) from %2" )
+ sql = QString( "select %1(%2),geometrytype(%2) from %3" )
+ .arg( connectionRO->majorVersion() < 2 ? "srid" : "st_srid" )
.arg( mQuery );
