[QGIS Commit] r15077 - trunk/qgis/src/mapserver
svn_qgis at osgeo.org
Tue Jan 25 08:29:17 EST 2011
Author: mhugent
Date: 2011-01-25 05:29:16 -0800 (Tue, 25 Jan 2011)
New Revision: 15077
trunk/qgis/src/mapserver/qgis_map_serv.cpp
trunk/qgis/src/mapserver/qgsprojectparser.cpp
trunk/qgis/src/mapserver/qgswmsserver.cpp
trunk/qgis/src/mapserver/qgswmsserver.h
Improve GetLegendGraphics output in wms server
Modified: trunk/qgis/src/mapserver/qgis_map_serv.cpp
--- trunk/qgis/src/mapserver/qgis_map_serv.cpp 2011-01-25 08:23:52 UTC (rev 15076)
+++ trunk/qgis/src/mapserver/qgis_map_serv.cpp 2011-01-25 13:29:16 UTC (rev 15077)
@@ -374,7 +374,8 @@
else
- QgsMSDebugMsg( "Error, 0 image in GetLegendGraphics" )
+ //do some error handling
+ QgsMSDebugMsg( "result image is 0" )
delete result;
delete theRequestHandler;
Modified: trunk/qgis/src/mapserver/qgsprojectparser.cpp
--- trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-01-25 08:23:52 UTC (rev 15076)
+++ trunk/qgis/src/mapserver/qgsprojectparser.cpp 2011-01-25 13:29:16 UTC (rev 15077)
@@ -630,7 +630,7 @@
groupList.push_back( groupNodeList.at( i ).toElement() );
- return groupList;
+ return groupList;
QMap< QString, QDomElement > QgsProjectParser::projectLayerElementsById() const
@@ -1104,12 +1104,9 @@
contactInfoElem.appendChild( contactPersonPrimaryElem );
//Contact address
- QDomElement contactAddressElem = doc.createElement( "ContactAddress" );
+ //QDomElement contactAddressElem = doc.createElement( "ContactAddress" );
+ //contactInfoElem.appendChild( contactAddressElem );
- contactInfoElem.appendChild( contactAddressElem );
//phone
QDomElement phoneElem = propertiesElem.firstChildElement( "WMSContactPhone" );
if ( !phoneElem.isNull() )
Modified: trunk/qgis/src/mapserver/qgswmsserver.cpp
--- trunk/qgis/src/mapserver/qgswmsserver.cpp 2011-01-25 08:23:52 UTC (rev 15076)
+++ trunk/qgis/src/mapserver/qgswmsserver.cpp 2011-01-25 13:29:16 UTC (rev 15077)
@@ -261,7 +261,8 @@
iconLabelSpace = mConfigParser->legendIconLabelSpace() * mmToPixelFactor;
symbolWidth = mConfigParser->legendSymbolWidth() * mmToPixelFactor;
symbolHeight = mConfigParser->legendSymbolHeight() * mmToPixelFactor;
- double maxX = 0;
+ double maxTextWidth = 0;
+ double maxSymbolWidth = 0;
double currentY = 0;
double fontOversamplingFactor = 10.0;
QFont layerFont = mConfigParser->legendLayerFont();
@@ -288,14 +289,15 @@
QgsComposerLayerItem* layerItem = dynamic_cast<QgsComposerLayerItem*>( rootItem->child( i ) );
if ( layerItem )
- drawLegendLayerItem( layerItem, 0, maxX, currentY, layerFont, itemFont, boxSpace, layerSpace, symbolSpace,
+ drawLegendLayerItem( layerItem, 0, maxTextWidth, maxSymbolWidth, currentY, layerFont, itemFont, boxSpace, layerSpace, symbolSpace,
iconLabelSpace, symbolWidth, symbolHeight, fontOversamplingFactor, theImage->dotsPerMeterX() * 0.0254 );
currentY += boxSpace;
//create second image with the right dimensions
- QImage* paintImage = createImage( maxX, currentY );
+ QImage* paintImage = createImage( maxTextWidth + maxSymbolWidth, currentY );
//go through the items a second time for painting
QPainter p( paintImage );
@@ -307,7 +309,7 @@
if ( layerItem )
- drawLegendLayerItem( layerItem, &p, maxX, currentY, layerFont, itemFont, boxSpace, layerSpace, symbolSpace,
+ drawLegendLayerItem( layerItem, &p, maxTextWidth, maxSymbolWidth, currentY, layerFont, itemFont, boxSpace, layerSpace, symbolSpace,
@@ -1155,7 +1157,7 @@
return layerKeys;
-void QgsWMSServer::drawLegendLayerItem( QgsComposerLayerItem* item, QPainter* p, double& maxX, double& currentY, const QFont& layerFont,
+void QgsWMSServer::drawLegendLayerItem( QgsComposerLayerItem* item, QPainter* p, double& maxTextWidth, double& maxSymbolWidth, double& currentY, const QFont& layerFont,
const QFont& itemFont, double boxSpace, double layerSpace, double symbolSpace,
double iconLabelSpace, double symbolWidth, double symbolHeight, double fontOversamplingFactor,
double dpi ) const
@@ -1177,14 +1179,17 @@
p->drawText( boxSpace * fontOversamplingFactor, currentY * fontOversamplingFactor, item->text() );
p->restore();
- currentY += layerSpace;
- double layerItemWidth = layerFontMetrics.width( item->text() ) / fontOversamplingFactor + 2 * boxSpace;
- if ( layerItemWidth > maxX )
+ else
- maxX = layerItemWidth;
+ double layerItemWidth = layerFontMetrics.width( item->text() ) / fontOversamplingFactor + boxSpace;
+ if ( layerItemWidth > maxTextWidth )
+ maxTextWidth = layerItemWidth;
+ currentY += layerSpace;
int opacity = 0;
QgsMapLayer* layerInstance = QgsMapLayerRegistry::instance()->mapLayer( item->layerID() );
if ( layerInstance )
@@ -1192,7 +1197,7 @@
opacity = layerInstance->getTransparency(); //maplayer says transparency but means opacity
- //then draw all the childs
+ //then draw all the children
if ( p )
p->setFont( itemFont );
@@ -1211,7 +1216,8 @@
double currentSymbolHeight = symbolHeight;
- double currentSymbolWidth = symbolWidth;
+ double currentSymbolWidth = symbolWidth; //symbol width (without box space and icon/label space
+ double currentTextWidth = 0;
//if the font is larger than the standard symbol size, try to draw the symbol centered (shifting towards the bottom)
double symbolDownShift = ( itemFontMetrics.ascent() / fontOversamplingFactor - symbolHeight ) / 2.0;
@@ -1233,44 +1239,46 @@
drawRasterSymbol( currentComposerItem, p, boxSpace, currentY, currentSymbolWidth, currentSymbolHeight, symbolDownShift );
break;
case QgsComposerLegendItem::GroupItem:
- QgsDebugMsg( "GroupItem not handled" );
+ //QgsDebugMsg( "GroupItem not handled" );
break;
case QgsComposerLegendItem::LayerItem:
break;
//finally draw text
+ currentTextWidth = itemFontMetrics.width( currentComposerItem->text() ) / fontOversamplingFactor;
double symbolItemHeight = qMax( itemFontMetrics.ascent() / fontOversamplingFactor, currentSymbolHeight );
if ( p )
p->save();
p->scale( 1.0 / fontOversamplingFactor, 1.0 / fontOversamplingFactor );
- p->drawText(( boxSpace + currentSymbolWidth + iconLabelSpace ) * fontOversamplingFactor,
- ( currentY + symbolItemHeight / 2.0 ) * fontOversamplingFactor + itemFontMetrics.ascent() / 2.0, currentComposerItem->text() );
+ p->drawText( maxSymbolWidth * fontOversamplingFactor,
+ ( currentY + symbolItemHeight / 2.0 ) * fontOversamplingFactor + itemFontMetrics.ascent() / 2.0, currentComposerItem->text() );
p->restore();
+ else
+ if ( currentTextWidth > maxTextWidth )
+ maxTextWidth = currentTextWidth;
+ double symbolWidth = boxSpace + currentSymbolWidth + iconLabelSpace;
+ if ( symbolWidth > maxSymbolWidth )
+ maxSymbolWidth = symbolWidth;
currentY += symbolItemHeight;
- double symbolItemWidth = 2 * boxSpace + currentSymbolWidth + iconLabelSpace + itemFontMetrics.width( currentComposerItem->text() ) / fontOversamplingFactor;
currentY += symbolSpace;
- if ( symbolItemWidth > maxX )
- maxX = symbolItemWidth;
void QgsWMSServer::drawLegendSymbol( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double& symbolWidth, double& symbolHeight, double layerOpacity,
double dpi, double yDownShift ) const
- if ( !p )
- return;
QgsComposerSymbolItem* symbolItem = dynamic_cast< QgsComposerSymbolItem* >( item );
if ( !symbolItem )
@@ -1304,7 +1312,7 @@
void QgsWMSServer::drawPointSymbol( QPainter* p, QgsSymbol* s, double boxSpace, double currentY, double& symbolWidth, double& symbolHeight, double layerOpacity, double dpi ) const
- if ( !s || !p )
+ if ( !s )
return;
@@ -1371,14 +1379,9 @@
p->restore();
-void QgsWMSServer::drawLegendSymbolV2( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double symbolWidth,
- double symbolHeight, double dpi, double yDownShift ) const
+void QgsWMSServer::drawLegendSymbolV2( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double& symbolWidth,
+ double& symbolHeight, double dpi, double yDownShift ) const
- if ( !p )
- return;
QgsComposerSymbolV2Item* symbolItem = dynamic_cast< QgsComposerSymbolV2Item* >( item );
if ( !symbolItem )
@@ -1390,13 +1393,24 @@
return;
+ //markers might have a different size
+ QgsMarkerSymbolV2* markerSymbol = dynamic_cast< QgsMarkerSymbolV2* >( symbol );
+ if ( markerSymbol )
+ symbolWidth = markerSymbol->size() * dpi / 25.4;
+ symbolHeight = markerSymbol->size() * dpi / 25.4;
double rasterScaleFactor = dpi / 2.0 / 25.4;
- p->save();
- p->translate( boxSpace, currentY + yDownShift );
- p->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
- symbol->drawPreviewIcon( p, QSize( symbolWidth * rasterScaleFactor, symbolHeight * rasterScaleFactor ) );
- p->restore();
+ if ( p )
+ p->save();
+ p->translate( boxSpace, currentY + yDownShift );
+ p->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
+ symbol->drawPreviewIcon( p, QSize( symbolWidth * rasterScaleFactor, symbolHeight * rasterScaleFactor ) );
+ p->restore();
void QgsWMSServer::drawRasterSymbol( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double symbolWidth, double symbolHeight, double yDownShift ) const
Modified: trunk/qgis/src/mapserver/qgswmsserver.h
--- trunk/qgis/src/mapserver/qgswmsserver.h 2011-01-25 08:23:52 UTC (rev 15076)
+++ trunk/qgis/src/mapserver/qgswmsserver.h 2011-01-25 13:29:16 UTC (rev 15077)
@@ -118,7 +118,12 @@
QStringList layerSet( const QStringList& layersList, const QStringList& stylesList, const QgsCoordinateReferenceSystem& destCRS ) const;
//helper functions for GetLegendGraphics
- void drawLegendLayerItem( QgsComposerLayerItem* item, QPainter* p, double& maxX, double& currentY, const QFont& layerFont,
+ /**Draws layer item and subitems
+ @param p painter if the item should be drawn, if 0 the size parameters are calculated only
+ @param maxTextWidth Includes boxSpace (on the right side). If p==0: maximumTextWidth is calculated, if p: maxTextWidth parameter is used for rendering
+ @param maxSymbolWidth Includes boxSpace and iconLabelSpace. If p==0: maximum Symbol width is calculated, if p: maxSymbolWidth is input parameter
+ void drawLegendLayerItem( QgsComposerLayerItem* item, QPainter* p, double& maxTextWidth, double& maxSymbolWidth, double& currentY, const QFont& layerFont,
const QFont& itemFont, double boxSpace, double layerSpace, double symbolSpace, double iconLabelSpace,
double symbolWidth, double symbolHeight, double fontOversamplingFactor, double dpi ) const;
/**Draws a (old generation) symbol. Optionally, maxHeight is adapted (e.g. for large point markers) */
@@ -127,7 +132,7 @@
void drawPointSymbol( QPainter* p, QgsSymbol* s, double boxSpace, double currentY, double& symbolWidth, double& symbolHeight, double layerOpacity, double dpi ) const;
void drawLineSymbol( QPainter* p, QgsSymbol* s, double boxSpace, double currentY, double symbolWidth, double symbolHeight, double layerOpacity, double yDownShift ) const;
void drawPolygonSymbol( QPainter* p, QgsSymbol* s, double boxSpace, double currentY, double symbolWidth, double symbolHeight, double layerOpacity, double yDownShift ) const;
- void drawLegendSymbolV2( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double symbolWidth, double symbolHeight, double dpi, double yDownShift ) const;
+ void drawLegendSymbolV2( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double& symbolWidth, double& symbolHeight, double dpi, double yDownShift ) const;
void drawRasterSymbol( QgsComposerLegendItem* item, QPainter* p, double boxSpace, double currentY, double symbolWidth, double symbolHeight, double yDownShift ) const;
/**Map containing the WMS parameters*/
