[QGIS Commit] r15096 - trunk/qgis
svn_qgis at osgeo.org
Fri Jan 28 11:59:02 EST 2011
Author: jef
Date: 2011-01-28 08:59:02 -0800 (Fri, 28 Jan 2011)
New Revision: 15096
trunk/qgis/CMakeLists.txt
build with -fno-strict-aliasing on powerpc (see bugs.debian.org/603986)
Modified: trunk/qgis/CMakeLists.txt
--- trunk/qgis/CMakeLists.txt 2011-01-28 16:20:37 UTC (rev 15095)
+++ trunk/qgis/CMakeLists.txt 2011-01-28 16:59:02 UTC (rev 15096)
@@ -226,6 +226,11 @@
ENDIF (MSVC)
ENDIF (PEDANTIC)
+IF(CMAKE_SYSTEM_PROCESSOR MATCHES "^(powerpc|ppc)")
+ # spatialite crashes on ppc - see bugs.debian.org/603986
+ ADD_DEFINITIONS( -fno-strict-aliasing )
+ENDIF(CMAKE_SYSTEM_PROCESSOR MATCHES "^(powerpc|ppc)")
IF (CMAKE_BUILD_TYPE MATCHES Debug OR CMAKE_BUILD_TYPE MATCHES RelWithDebInfo)
MESSAGE (STATUS "Debug output enabled")
ADD_DEFINITIONS(-DQGISDEBUG=1)
@@ -403,13 +408,13 @@
INCLUDE(PyQt4Macros)
# setup SIP variables
- separate_arguments(PYQT4_SIP_FLAGS) # convert space separated values to a list
- set(SIP_INCLUDES ${PYQT4_SIP_DIR} ${CMAKE_SOURCE_DIR}/python)
- set(SIP_CONCAT_PARTS 4)
- set(SIP_EXTRA_OPTIONS ${PYQT4_SIP_FLAGS})
+ SEPARATE_ARGUMENTS(PYQT4_SIP_FLAGS) # convert space separated values to a list
+ SET(SIP_INCLUDES ${PYQT4_SIP_DIR} ${CMAKE_SOURCE_DIR}/python)
+ SET(SIP_CONCAT_PARTS 4)
+ SET(SIP_EXTRA_OPTIONS ${PYQT4_SIP_FLAGS})
IF (NOT BINDINGS_GLOBAL_INSTALL)
- set(PYTHON_SITE_PACKAGES_DIR ${QGIS_DATA_DIR}/python)
+ SET(PYTHON_SITE_PACKAGES_DIR ${QGIS_DATA_DIR}/python)
ENDIF (NOT BINDINGS_GLOBAL_INSTALL)
ENDIF (WITH_BINDINGS)
