[QGIS Commit] r15104 - trunk/qgis/ms-windows/osgeo4w
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Jan 29 10:16:57 EST 2011
Author: jef
Date: 2011-01-29 07:16:57 -0800 (Sat, 29 Jan 2011)
New Revision: 15104
Added:
   trunk/qgis/ms-windows/osgeo4w/package-nightly.cmd
   trunk/qgis/ms-windows/osgeo4w/package.cmd
update osgeo4w build to use standard GDAL (now 1.8) to build
Added: trunk/qgis/ms-windows/osgeo4w/package-nightly.cmd
--- trunk/qgis/ms-windows/osgeo4w/package-nightly.cmd	                        (rev 0)
+++ trunk/qgis/ms-windows/osgeo4w/package-nightly.cmd	2011-01-29 15:16:57 UTC (rev 15104)
@@ -0,0 +1,181 @@
+ at echo off
+set GRASS_VERSION=6.4.0
+set SVNVERSION=c:/cygwin/bin/svnversion
+set BUILDDIR=%CD%\build
+REM set BUILDDIR=%TEMP%\qgis_unstable
+set LOG=%BUILDDIR%\build.log
+if not exist "%BUILDDIR%" mkdir %BUILDDIR%
+if not exist "%BUILDDIR%" goto error
+set VERSION=%1
+set PACKAGE=%2
+set PACKAGENAME=%3
+if "%VERSION%"=="" goto error
+if "%PACKAGE%"=="" goto error
+if "%PACKAGENAME%"=="" set PACKAGENAME=qgis-dev
+path %SYSTEMROOT%\system32;%SYSTEMROOT%;%SYSTEMROOT%\System32\Wbem;%PROGRAMFILES%\CMake 2.8\bin
+set PYTHONPATH=
+set VS90COMNTOOLS=%PROGRAMFILES%\Microsoft Visual Studio 9.0\Common7\Tools\
+call "%PROGRAMFILES%\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86
+if "%OSGEO4W_ROOT%"=="" set OSGEO4W_ROOT=%PROGRAMFILES%\OSGeo4W
+if not exist "%OSGEO4W_ROOT%\bin\o4w_env.bat" goto error
+call "%OSGEO4W_ROOT%\bin\o4w_env.bat"
+set O4W_ROOT=%OSGEO4W_ROOT:\=/%
+set LIB_DIR=%O4W_ROOT%
+set DEVENV=
+if exist "%DevEnvDir%\vcexpress.exe" set DEVENV=vcexpress
+if exist "%DevEnvDir%\devenv.exe" set DEVENV=devenv
+if "%DEVENV%"=="" goto error
+PROMPT qgis%VERSION%$g
+set BUILDCONF=RelWithDebInfo
+REM set BUILDCONF=Release
+cd ..\..
+set SRCDIR=%CD%
+if "%BUILDDIR:~1,1%"==":" %BUILDDIR:~0,2%
+cd %BUILDDIR%
+if not exist build.log goto build
+REM
+REM try renaming the logfile to see if it's locked
+REM
+if exist build.tmp del build.tmp
+if exist build.tmp goto error
+ren build.log build.tmp
+if exist build.log goto locked
+if not exist build.tmp goto locked
+ren build.tmp build.log
+if exist build.tmp goto locked
+if not exist build.log goto locked
+goto build
+:locked
+echo Logfile locked
+goto error
+:build
+echo Logging to %LOG%
+echo BEGIN: %DATE% %TIME%>>%LOG% 2>&1
+if errorlevel 1 goto error
+set >buildenv.log
+if exist CMakeCache.txt goto skipcmake
+echo CMAKE: %DATE% %TIME%>>%LOG% 2>&1
+set LIB=%LIB%;%OSGEO4W_ROOT%\lib
+set INCLUDE=%INCLUDE%;%OSGEO4W_ROOT%\include
+cmake -G "Visual Studio 9 2008" ^
+	-D PEDANTIC=TRUE ^
+	-D WITH_SPATIALITE=TRUE ^
+	-D WITH_MAPSERVER=TRUE ^
+	-D WITH_INTERNAL_SPATIALITE=TRUE ^
+	-D CMAKE_BUILD_TYPE=%BUILDCONF% ^
+	-D CMAKE_CONFIGURATION_TYPES=%BUILDCONF% ^
+	-D GEOS_LIBRARY=%OSGEO4W_ROOT%/lib/geos_c_i.lib ^
+	-D PYTHON_EXECUTABLE=%O4W_ROOT%/bin/python.exe ^
+	-D PYTHON_INCLUDE_PATH=%O4W_ROOT%/apps/Python25/include ^
+	-D PYTHON_LIBRARY=%O4W_ROOT%/apps/Python25/libs/python25.lib ^
+	-D SIP_BINARY_PATH=%O4W_ROOT%/apps/Python25/sip.exe ^
+	-D GRASS_PREFIX=%O4W_ROOT%/apps/grass/grass-%GRASS_VERSION% ^
+	-D QT_BINARY_DIR=%O4W_ROOT%/bin ^
+	-D QT_LIBRARY_DIR=%O4W_ROOT%/lib ^
+	-D QT_HEADERS_DIR=%O4W_ROOT%/include/qt4 ^
+	-D QT_ZLIB_LIBRARY=%O4W_ROOT%/lib/zlib.lib ^
+	-D QT_PNG_LIBRARY=%O4W_ROOT%/lib/libpng13.lib ^
+	-D QWT_INCLUDE_DIR=%O4W_ROOT%/include/qwt ^
+	-D QWT_LIBRARY=%O4W_ROOT%/lib/qwt5.lib ^
+	-D CMAKE_INSTALL_PREFIX=%O4W_ROOT%/apps/%PACKAGENAME% ^
+	-D CMAKE_CXX_FLAGS_RELWITHDEBINFO="/MD /ZI /Od /D NDEBUG" ^
+	-D FCGI_INCLUDE_DIR=%O4W_ROOT%/include ^
+	-D FCGI_LIBRARY=%O4W_ROOT%/lib/libfcgi.lib ^
+	-D SVNVERSION="%SVNVERSION%" ^
+	%SRCDIR%>>%LOG% 2>&1
+REM bail out if python or grass was not found
+grep -Eq "^(Python not being built|Could not find GRASS)" %LOG%
+if not errorlevel 1 goto error
+:skipcmake
+echo ZERO_CHECK: %DATE% %TIME%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project ZERO_CHECK /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+echo ALL_BUILD: %DATE% %TIME%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project ALL_BUILD /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+echo INSTALL: %DATE% %TIME%>>%LOG% 2>&1
+%DEVENV% qgis%VERSION%.sln /Project INSTALL /Build %BUILDCONF% /Out %LOG%>>%LOG% 2>&1
+echo PACKAGE: %DATE% %TIME%>>%LOG% 2>&1
+cd ..
+sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' postinstall.bat >%OSGEO4W_ROOT%\etc\postinstall\%PACKAGENAME%.bat
+sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' preremove.bat >%OSGEO4W_ROOT%\etc\preremove\%PACKAGENAME%.bat
+sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' qgis.bat.tmpl >%OSGEO4W_ROOT%\bin\%PACKAGENAME%.bat.tmpl
+sed -e 's/@package@/%PACKAGENAME%/g' -e 's/@version@/%VERSION%/g' qgis.reg.tmpl >%OSGEO4W_ROOT%\apps\%PACKAGENAME%\bin\qgis.reg.tmpl
+REM sed -e 's/%OSGEO4W_ROOT:\=\\\\\\\\%/@osgeo4w@/' %OSGEO4W_ROOT%\apps\%PACKAGENAME%\python\qgis\qgisconfig.py >%OSGEO4W_ROOT%\apps\%PACKAGENAME%\python\qgis\qgisconfig.py.tmpl
+REM if errorlevel 1 goto error
+REM del %OSGEO4W_ROOT%\apps\%PACKAGENAME%\python\qgis\qgisconfig.py
+touch exclude
+tar -C %OSGEO4W_ROOT% -cjf %PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2 ^
+	--exclude-from exclude ^
+	apps/%PACKAGENAME% ^
+	bin/%PACKAGENAME%.bat.tmpl ^
+	etc/postinstall/%PACKAGENAME%.bat ^
+	etc/preremove/%PACKAGENAME%.bat ^
+	>>%LOG% 2>&1
+REM tar -C %OSGEO4W_ROOT% -cjf %PACKAGENAME%-grass-%VERSION%-%PACKAGE%.tar.bz2 ^
+REM 	--exclude-from exclude ^
+REM 	"apps/%PACKAGENAME%/themes/classic/grass" ^
+REM 	"apps/%PACKAGENAME%/themes/default/grass" ^
+REM 	"apps/%PACKAGENAME%/themes/gis/grass" ^
+REM 	"apps/%PACKAGENAME%/grass" ^
+REM 	"apps/%PACKAGENAME%/bin/qgisgrass.dll" ^
+REM 	"apps/%PACKAGENAME%/plugins/grassrasterprovider.dll" ^
+REM 	"apps/%PACKAGENAME%/plugins/grassplugin.dll" ^
+REM 	"apps/%PACKAGENAME%/plugins/grassprovider.dll" ^
+REM 	>>%LOG% 2>&1
+goto end
+:error
+echo BUILD ERROR %ERRORLEVEL%: %DATE% %TIME%
+echo BUILD ERROR %ERRORLEVEL%: %DATE% %TIME%>>%LOG% 2>&1
+if exist %PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2 del %PACKAGENAME%-%VERSION%-%PACKAGE%.tar.bz2
+REM if exist %PACKAGENAME%-grass-plugin-%VERSION%-%PACKAGE%.tar.bz2 del %PACKAGENAME%-grass-plugin-%VERSION%-%PACKAGE%.tar.bz2
+:end
+echo FINISHED: %DATE% %TIME% >>%LOG% 2>&1
Property changes on: trunk/qgis/ms-windows/osgeo4w/package-nightly.cmd
___________________________________________________________________
Added: svn:executable
Modified: trunk/qgis/ms-windows/osgeo4w/package.cmd
--- trunk/qgis/ms-windows/osgeo4w/package.cmd	2011-01-29 11:35:49 UTC (rev 15103)
+++ trunk/qgis/ms-windows/osgeo4w/package.cmd	2011-01-29 15:16:57 UTC (rev 15104)
@@ -16,7 +16,7 @@
-path %SYSTEMROOT%\system32;%SYSTEMROOT%;%SYSTEMROOT%\System32\Wbem;%PROGRAMFILES%\CMake 2.6\bin
 set PYTHONPATH=
@@ -83,6 +83,9 @@
 	-D PEDANTIC=TRUE ^
@@ -90,8 +93,7 @@
-	-D GDAL_INCLUDE_DIR=%O4W_ROOT%/apps/gdal-17/include ^
-	-D GDAL_LIBRARY=%O4W_ROOT%/apps/gdal-17/lib/gdal_i.lib ^
More information about the QGIS-commit mailing list
