[QGIS Commit] r15111 - trunk/qgis/src/mapserver
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jan 31 05:47:19 EST 2011
Author: mhugent
Date: 2011-01-31 02:47:19 -0800 (Mon, 31 Jan 2011)
New Revision: 15111
   trunk/qgis/src/mapserver/qgsconfigparser.cpp
Change getPrint syntax to use several parameters for composer maps, e.g. map0:extent=xmin,ymin,xmax,ymax or map0:rotation=45
Modified: trunk/qgis/src/mapserver/qgsconfigparser.cpp
--- trunk/qgis/src/mapserver/qgsconfigparser.cpp	2011-01-31 10:46:46 UTC (rev 15110)
+++ trunk/qgis/src/mapserver/qgsconfigparser.cpp	2011-01-31 10:47:19 UTC (rev 15111)
@@ -302,69 +302,83 @@
       continue;
-    //search composer map title in parameter map-> string
-    QMap< QString, QString >::const_iterator titleIt = parameterMap.find( "MAP" + QString::number( currentMap->id() ) );
-    if ( titleIt == parameterMap.constEnd() )
+    QString mapId = "MAP" + QString::number( currentMap->id() );
+    QMap< QString, QString >::const_iterator extentIt = parameterMap.find( mapId + ":EXTENT" );
+    if ( extentIt == parameterMap.constEnd() ) //map extent is mandatory
       //remove map from composition if not referenced by the request
-      c->removeItem( *mapIt );
-      delete( *mapIt );
-      continue;
+      c->removeItem( *mapIt ); delete( *mapIt ); continue;
-    QString replaceString = titleIt.value();
-    QStringList replacementList = replaceString.split( "/" );
-    //get map extent from string
-    if ( replacementList.size() > 0 )
+    QStringList coordList = extentIt.value().split( "," );
+    if ( coordList.size() < 4 )
-      QStringList coordList = replacementList.at( 0 ).split( "," );
-      if ( coordList.size() > 3 )
+      c->removeItem( *mapIt ); delete( *mapIt ); continue; //need at least four coordinates
+    bool xMinOk, yMinOk, xMaxOk, yMaxOk;
+    double xmin = coordList.at( 0 ).toDouble( &xMinOk );
+    double ymin = coordList.at( 1 ).toDouble( &yMinOk );
+    double xmax = coordList.at( 2 ).toDouble( &xMaxOk );
+    double ymax = coordList.at( 3 ).toDouble( &yMaxOk );
+    if ( !xMinOk || !yMinOk || !xMaxOk || !yMaxOk )
+    //Change x- and y- of extent for WMS 1.3.0 and geographic coordinate systems
+    QMap<QString, QString>::const_iterator versionIt = parameterMap.find( "VERSION" );
+    if ( versionIt != parameterMap.end() )
+      if ( mapRenderer && versionIt.value() == "1.3.0" && mapRenderer->destinationSrs().geographicFlag() )
-        bool xMinOk, yMinOk, xMaxOk, yMaxOk;
-        double xmin = coordList.at( 0 ).toDouble( &xMinOk );
-        double ymin = coordList.at( 1 ).toDouble( &yMinOk );
-        double xmax = coordList.at( 2 ).toDouble( &xMaxOk );
-        double ymax = coordList.at( 3 ).toDouble( &yMaxOk );
-        if ( xMinOk && yMinOk && xMaxOk && yMaxOk )
-          currentMap->setNewExtent( QgsRectangle( xmin, ymin, xmax, ymax ) );
+        //switch coordinates of extent
+        double tmp;
+        tmp = xmin;
+        xmin = ymin; ymin = tmp;
+        tmp = xmax;
+        xmax = ymax; ymax = tmp;
+    currentMap->setNewExtent( QgsRectangle( xmin, ymin, xmax, ymax ) );
-    //get rotation from string
-    if ( replacementList.size() > 1 )
+    //scale
+    QMap< QString, QString >::const_iterator scaleIt = parameterMap.find( mapId + ":SCALE" );
+    if ( scaleIt != parameterMap.constEnd() )
-      bool rotationOk;
-      double rotation = replacementList.at( 1 ).toDouble( &rotationOk );
-      if ( rotationOk )
+      bool scaleOk;
+      double scale = scaleIt->toDouble( &scaleOk );
+      if ( scaleOk )
-        currentMap->setMapRotation( rotation );
+        currentMap->setNewScale( scale );
-    //get forced scale from string
-    if ( replacementList.size() > 2 )
+    //rotation
+    QMap< QString, QString >::const_iterator rotationIt = parameterMap.find( mapId + ":ROTATION" );
+    if ( rotationIt != parameterMap.constEnd() )
-      bool conversionOk;
-      double scale = replacementList.at( 2 ).toDouble( &conversionOk );
-      if ( conversionOk )
+      bool rotationOk;
+      double rotation = rotationIt->toDouble( &rotationOk );
+      if ( rotationOk )
-        currentMap->setNewScale( scale );
+        currentMap->setMapRotation( rotation );
-    //get layer list from string
-    if ( replacementList.size() > 3 )
+    //layers / styles
+    QMap< QString, QString >::const_iterator layersIt = parameterMap.find( mapId + ":LAYERS" );
+    QMap< QString, QString >::const_iterator stylesIt = parameterMap.find( mapId + ":STYLES" );
+    if ( layersIt != parameterMap.constEnd() )
       QStringList layerSet;
-      QStringList wmsLayerList = replacementList.at( 3 ).split( "," );
+      QStringList wmsLayerList = layersIt->split( "," );
       QStringList wmsStyleList;
-      if ( replacementList.size() > 4 )
+      if ( stylesIt != parameterMap.constEnd() )
-        wmsStyleList = replacementList.at( 4 ).split( "," );
+        wmsStyleList = stylesIt->split( "," );
       for ( int i = 0; i < wmsLayerList.size(); ++i )
         QString styleName;
More information about the QGIS-commit mailing list
