[QGIS Commit] r15897 - in docs/trunk/english_us/user_guide: . plugins_dxf2shape_converter_images plugins_gdaltools_images plugins_gps_images plugins_offline_editing_images plugins_raster_terrain_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jul 29 15:46:13 EDT 2011
Author: dassau
Date: 2011-07-29 12:46:13 -0700 (Fri, 29 Jul 2011)
New Revision: 15897
Added:
   docs/trunk/english_us/user_guide/plugins_offline_editing_images/create_offline_project.png
   docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex
   docs/trunk/english_us/user_guide/plugins_dxf2shape_converter_images/dxf2shape_dialog.png
   docs/trunk/english_us/user_guide/plugins_evis.tex
   docs/trunk/english_us/user_guide/plugins_ftools.tex
   docs/trunk/english_us/user_guide/plugins_gdaltools.tex
   docs/trunk/english_us/user_guide/plugins_gdaltools_images/gdalinfo.png
   docs/trunk/english_us/user_guide/plugins_gdaltools_images/raster_menu.png
   docs/trunk/english_us/user_guide/plugins_georeferencer.tex
   docs/trunk/english_us/user_guide/plugins_gps.tex
   docs/trunk/english_us/user_guide/plugins_gps_images/download.png
   docs/trunk/english_us/user_guide/plugins_gps_images/loadgpx.png
   docs/trunk/english_us/user_guide/plugins_interpolation.tex
   docs/trunk/english_us/user_guide/plugins_mapserver_export.tex
   docs/trunk/english_us/user_guide/plugins_offline_editing.tex
   docs/trunk/english_us/user_guide/plugins_openstreetmap.tex
   docs/trunk/english_us/user_guide/plugins_oracle_raster.tex
   docs/trunk/english_us/user_guide/plugins_raster_terrain.tex
   docs/trunk/english_us/user_guide/plugins_raster_terrain_images/raster_terrain_dialog.png
updates to core plugin sections
Modified: docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex
--- docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_dxf2shape_converter.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
 % when the revision of a section has been finalized,
 % comment out the following line:
-\updatedisclaimer
+% \updatedisclaimer
 The dxf2shape converter plugin can be used to convert vector data from DXF to Shapefile
 format. It requires the following parameters to be specified before running:
Modified: docs/trunk/english_us/user_guide/plugins_dxf2shape_converter_images/dxf2shape_dialog.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/plugins_evis.tex
--- docs/trunk/english_us/user_guide/plugins_evis.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_evis.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -2,7 +2,7 @@
-\updatedisclaimer
 \section{eVis Plugin}\label{sec:evis}
Modified: docs/trunk/english_us/user_guide/plugins_ftools.tex
--- docs/trunk/english_us/user_guide/plugins_ftools.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_ftools.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 The goal of the fTools python plugin is to provide a one-stop resource for
 many common vector-based GIS tasks, without the need for additional software,
@@ -25,7 +25,7 @@
 \begin{table}[ht]\index{Analysis tools}
 \centering
- \begin{tabular}{|m{1cm}|m{3cm}|m{9cm}|}
+ \begin{tabular}{|m{1cm}|m{3cm}|m{12cm}|}
 \hline \multicolumn{3}{|c|}{\textbf{Analysis tools available via the fTools plugin}} \\
  \hline \textbf{Icon} & \textbf{Tool} & \textbf{Purpose} \\
  \hline \includegraphics[width=0.7cm]{matrix} & Distance Matrix &
@@ -58,7 +58,7 @@
 \begin{table}[ht]\index{Research tools}
 \centering
  \hline \multicolumn{3}{|c|}{\textbf{Research tools available via the fTools plugin}} \\
  \hline \includegraphics[width=0.7cm]{random_selection} & Random selection & Randomly
@@ -83,7 +83,7 @@
 \begin{table}[ht]\index{Geoprocessing tools}
 \centering
  \hline \multicolumn{3}{|c|}{\textbf{Geoprocessing tools available via the fTools plugin}} \\
  \hline \includegraphics[width=0.7cm]{convex_hull} & Convex hull(s) & Create
@@ -111,7 +111,7 @@
 \begin{table}[ht]\index{Geometry tools}
 \centering
-\begin{tabular}{|m{1cm}|m{3cm}|m{9cm}|}
+\begin{tabular}{|m{1cm}|m{3cm}|m{12cm}|}
  \hline \multicolumn{3}{|c|}{\textbf{Geometry tools available via the fTools plugin}} \\
  \hline \includegraphics[width=0.7cm]{check_geometry} & Check geometry &
@@ -123,6 +123,8 @@
 Calculate the true centroids for each polygon in an input polygon layer. \\
  \hline \includegraphics[width=0.7cm]{delaunay} & Delaunay triangulation &
 Calculate and output (as polygons) the delaunay triangulation of an input point vector layer. \\
+ \hline  & Voronoi Polygons &
+Calculate voronoi polygons of an input point vector layer. \\
  \hline \includegraphics[width=0.7cm]{simplify} & Simplify geometry &
 Generalise lines or polygons with a modified Douglas-Peucker algorithm. \\
  \hline \includegraphics[width=0.7cm]{multi_to_single} & Multipart to
@@ -133,6 +135,8 @@
 on a unique ID field. \\
  \hline \includegraphics[width=0.7cm]{to_lines} & Polygons to lines
 & Convert polygons to lines, multipart polygons to multiple singlepart lines. \\
+ \hline \includegraphics[width=0.7cm]{to_lines} & Lines to polygons
+& Convert lines to polygons, multipart lines to multiple singlepart polygons. \\
  \hline \includegraphics[width=0.7cm]{extract_nodes} & Extract nodes &
 Extract nodes from line and polygon layers and output them as points. \\
  \hline
@@ -142,17 +146,13 @@
 \begin{table}[ht]\index{Data management tools}
 \centering
  \hline \multicolumn{3}{|c|}{\textbf{Data management tools available via the fTools plugin}} \\
  \hline \includegraphics[width=0.7cm]{export_projection} & Export to projection &
 Project features to new CRS and export as new shapefile. \\
  \hline \includegraphics[width=0.7cm]{define_projection} & Define projection &
 Specify the CRS for shapefiles whose CRS has not been defined. \\
- \hline \includegraphics[width=0.7cm]{join_attributes} & Join attributes & Join
-additional attributes to vector layer attribute table based on a dbf or csv file
-and output results to a new shapefile. Additional attributes can be from a
-vector layer or stand-alone dbf table. \\
  \hline \includegraphics[width=0.7cm]{join_location} & Join attributes by
 location & Join additional attributes to vector layer based on spatial
 relationship. Attributes from one vector layer are appended to the attribute
Modified: docs/trunk/english_us/user_guide/plugins_gdaltools.tex
--- docs/trunk/english_us/user_guide/plugins_gdaltools.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_gdaltools.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -39,6 +39,8 @@
 The extents of the output file. If not specified the aggregate extents of all input files will be used. \\
 \hline RGB to PCT &  This utility will compute an optimal pseudo-color table for a given RGB image using a median cut algorithm on a downsampled RGB histogram. Then it converts the image into a pseudo-colored image using the color table. This conversion utilizes Floyd-Steinberg dithering (error diffusion) to maximize output image visual quality. \\
 \hline PCT to RGB &  This utility will convert a pseudocolor band on the input file into an output RGB file of the desired format.\\
+\hline Tile Index &  This program builds a shapefile with a record for each input raster file, an attribute containing the filename, and a polygon geometry outlining the raster.\\
+\hline DEM terrain models &  Tools to analyze and visualize DEMs. It can create  a shaded relief, a slope, an aspect, a color relief, a Terrain Ruggedness Index, a  Topographic Position Index and a roughness map from any GDAL-supported elevation raster.\\
 \hline
 \end{longtable}
@@ -54,7 +56,7 @@
 \begin{figure}[ht]
    \centering
    \caption{The \emph{Information} dialog window \nixcaption}\label{gdalinfo}
-   \includegraphics[clip=true, width=12cm]{plugins_gdaltools_images/gdalinfo}
+   \includegraphics[clip=true, width=10cm]{plugins_gdaltools_images/gdalinfo}
 \end{figure}
 \subsubsection{Creating contour lines}
Modified: docs/trunk/english_us/user_guide/plugins_gdaltools_images/gdalinfo.png
Modified: docs/trunk/english_us/user_guide/plugins_gdaltools_images/raster_menu.png
Modified: docs/trunk/english_us/user_guide/plugins_georeferencer.tex
--- docs/trunk/english_us/user_guide/plugins_georeferencer.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_georeferencer.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 The Georeferencer Plugin is a tool for generating world files for rasters.
 It allows you to reference rasters to geographic or projected coordinate
@@ -162,6 +162,8 @@
 modern georeferencing  method, which is able to introduce local
 deformations in the data. This algorithm is useful when very low
 quality originals are being georeferenced.
+\item The \textbf{Projective transformation} is a linear rotation and
+translation of coordinates.
 \end{itemize}
 \minisec{Define the Resampling method}
Modified: docs/trunk/english_us/user_guide/plugins_gps.tex
--- docs/trunk/english_us/user_guide/plugins_gps.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_gps.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 \subsection{What is GPS?}\label{whatsgps}
Modified: docs/trunk/english_us/user_guide/plugins_gps_images/download.png
Modified: docs/trunk/english_us/user_guide/plugins_gps_images/loadgpx.png
Modified: docs/trunk/english_us/user_guide/plugins_interpolation.tex
--- docs/trunk/english_us/user_guide/plugins_interpolation.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_interpolation.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 The Interplation plugin can be used to generate a TIN or IDW interpolation of a
 point vector layer. It is very simple to handle and provides an intiuitive graphical
Modified: docs/trunk/english_us/user_guide/plugins_mapserver_export.tex
--- docs/trunk/english_us/user_guide/plugins_mapserver_export.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_mapserver_export.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
+%\updatedisclaimer
 You can use QGIS to ``compose'' your map by adding and arranging layers,
 symbolizing them, customizing the colors and then creating a map file
Modified: docs/trunk/english_us/user_guide/plugins_offline_editing.tex
--- docs/trunk/english_us/user_guide/plugins_offline_editing.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_offline_editing.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,8 +4,35 @@
-\updatedisclaimer
+%\updatedisclaimer
-The \toolbtntwo{offline_editing_copy}{Offline Editing} Plugin ...
+For data collection, it is a common situation to work with a laptop or a cell
+phone offline in the field. Upon returning to the network, the changes need to
+be synchronized with the master data source, e.g. a PostGIS database. If several
+persons are working simultaneously on the same datasets, it is difficult to
+merge the edits by hand, even if people don’t change the same features.
+The \toolbtntwo{offline_editing_copy}{Offline Editing} Plugin automates the synchronisation by copying the content of a datasource (usually PostGIS or
+WFS-T) to a spatialite database and storing the offline edits to dedicated
+tables. After being connected to the network again, it is possible to apply the offline edits to the master dataset.
+\minisec{Using the plugin}
+\begin{itemize}
+\item Open some vector layers, e.g. from a PostGIS or WFS-T datasource
+\item Save it as a project
+\item Press the 'Convert to offline project' button and select the layers to
+save. The content of the layers is saved to spatialite tables.
+\item Edit the layers offline.
+\item After being connected again, upload the changes with the 'Synchronize'
+button.
+\end{itemize}
+\begin{figure}[ht]
+   \centering
+   \includegraphics[clip=true, width=12cm]{create_offline_project}
+   \caption{Create an offline project from PostGIS or WFS layers \nixcaption}
+   \label{fig:offlineproject}
+\end{figure}
 \FloatBarrier
Added: docs/trunk/english_us/user_guide/plugins_offline_editing_images/create_offline_project.png
Property changes on: docs/trunk/english_us/user_guide/plugins_offline_editing_images/create_offline_project.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: docs/trunk/english_us/user_guide/plugins_openstreetmap.tex
--- docs/trunk/english_us/user_guide/plugins_openstreetmap.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_openstreetmap.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 In recent years, the OpenStreetMap project has gained popularity because in many countries no free geodata such as digital roadmaps are available.
 The objective of the OSM project is to create a free editable map of the world from GPS data, aerial photography or from local knowledge. To
Modified: docs/trunk/english_us/user_guide/plugins_oracle_raster.tex
--- docs/trunk/english_us/user_guide/plugins_oracle_raster.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_oracle_raster.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,7 +4,7 @@
-\updatedisclaimer
 In Oracle databases, raster data can be stored in SDO\_GEORASTER objects available with the
 Oracle Spatial extension. In QGIS, the \toolbtntwo{oracle_raster}{Oracle GeoRaster Plugin}
Modified: docs/trunk/english_us/user_guide/plugins_raster_terrain.tex
--- docs/trunk/english_us/user_guide/plugins_raster_terrain.tex	2011-07-28 15:57:49 UTC (rev 15896)
+++ docs/trunk/english_us/user_guide/plugins_raster_terrain.tex	2011-07-29 19:46:13 UTC (rev 15897)
@@ -4,12 +4,12 @@
-\updatedisclaimer
-The Raster Terrain Modelling plugin can be used to calculate the slope, aspect, ruggedness, and
-total curvature for digital elevation models (DEM). It is very simple to handle and provides an
-intiuitive graphical user interface for creating new raster layers (See Figure
-\ref{fig:raster_terrain_dialog}).
+The Raster Terrain Modelling plugin can be used to calculate the slope, aspect,
+ruggedness, and total curvature for digital elevation models (DEM). It is very
+simple to handle and provides an intiuitive graphical user interface for
+creating new raster layers (See Figure \ref{fig:raster_terrain_dialog}).
 The plugin requires the following parameters to be specified before running:
 \begin{itemize}[label=--]
@@ -17,17 +17,19 @@
 \item \textbf{Input layer}: Specify the input raster from a list of loaded
 raster layers.
 \item \textbf{Output layer}: Specify a name and path for the output raster file.
-\item \textbf{Output format}: Specify a format type for the output raster file (Default is GeoTiff).
+\item \textbf{Output format}: Specify a format type for the output raster file
+(Default is GeoTiff).
 \end{itemize}
-Slope: Calculates slope angle for each cell in degrees (based on first order derivative estimation).
+Description of the analysis:
-Aspect: Exposition (starting with 0 for north direction, in degrees counterclockwise).
+\begin{itemize}[label=--]
+\item \textbf{Slope}: Calculates slope angle for each cell in degrees (based on first order derivative estimation).
+\item \textbf{Aspect}: Exposition (starting with 0 for north direction, in degrees counterclockwise).
+\item \textbf{Ruggedness factor}: A quantitative measurement of terrain heterogeneity.
+\item \textbf{Total curvature}: A curvature measure that combines plan- and profile curvature.
+\end{itemize}
-Ruggedness factor: A quantitative measurement of terrain heterogeneity.
-Total curvature: A curvature measure that combines plan- and profile curvature.
 \begin{figure}[ht]
    \centering
    \includegraphics[clip=true, width=9cm]{raster_terrain_dialog}
Modified: docs/trunk/english_us/user_guide/plugins_raster_terrain_images/raster_terrain_dialog.png
More information about the QGIS-commit mailing list
