[QGIS Commit] r15545 - trunk/qgis/src/app
svn_qgis at osgeo.org
Sun Mar 20 18:46:08 EDT 2011
Author: jef
Date: 2011-03-20 15:46:08 -0700 (Sun, 20 Mar 2011)
New Revision: 15545
trunk/qgis/src/app/qgssnappingdialog.cpp
trunk/qgis/src/app/qgssnappingdialog.h
optimize snapping dialog
Modified: trunk/qgis/src/app/qgssnappingdialog.cpp
--- trunk/qgis/src/app/qgssnappingdialog.cpp 2011-03-20 21:01:01 UTC (rev 15544)
+++ trunk/qgis/src/app/qgssnappingdialog.cpp 2011-03-20 22:46:08 UTC (rev 15545)
@@ -68,11 +68,19 @@
connect( mButtonBox, SIGNAL( accepted() ), this, SLOT( apply() ) );
connect( mButtonBox->button( QDialogButtonBox::Apply ), SIGNAL( clicked() ), this, SLOT( apply() ) );
- connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded( QgsMapLayer * ) ), this, SLOT( connectUpdate( QgsMapLayer * ) ) );
+ connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWasAdded( QgsMapLayer * ) ), this, SLOT( addLayer( QgsMapLayer * ) ) );
+ connect( QgsMapLayerRegistry::instance(), SIGNAL( layerWillBeRemoved( QString ) ), this, SLOT( layerWillBeRemoved( QString ) ) );
connect( cbxEnableTopologicalEditingCheckBox, SIGNAL( stateChanged( int ) ), this, SLOT( on_cbxEnableTopologicalEditingCheckBox_stateChanged( int ) ) );
- update();
+ mLayerTreeWidget->clear();
+ QMap< QString, QgsMapLayer *> mapLayers = QgsMapLayerRegistry::instance()->mapLayers();
+ QMap< QString, QgsMapLayer *>::iterator it;
+ for ( it = mapLayers.begin(); it != mapLayers.end() ; ++it )
+ addLayer( it.value() );
mLayerTreeWidget->setHeaderLabels( QStringList() << "" );
mLayerTreeWidget->resizeColumnToContents( 0 );
mLayerTreeWidget->setColumnWidth( 1, 200 ); //hardcoded for now
@@ -80,6 +88,17 @@
mLayerTreeWidget->resizeColumnToContents( 3 );
mLayerTreeWidget->resizeColumnToContents( 4 );
mLayerTreeWidget->setSortingEnabled( true );
+ // read the digitizing settings
+ int topologicalEditing = QgsProject::instance()->readNumEntry( "Digitizing", "/TopologicalEditing", 0 );
+ if ( topologicalEditing != 0 )
+ cbxEnableTopologicalEditingCheckBox->setCheckState( Qt::Checked );
+ else
+ cbxEnableTopologicalEditingCheckBox->setCheckState( Qt::Unchecked );
QgsSnappingDialog::QgsSnappingDialog()
@@ -108,150 +127,6 @@
-void QgsSnappingDialog::update()
- if ( !mMapCanvas )
- return;
- QSettings myQsettings;
- bool myDockFlag = myQsettings.value( "/qgis/dockSnapping", false ).toBool();
- double defaultSnappingTolerance = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
- int defaultSnappingUnit = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
- QString defaultSnappingString = myQsettings.value( "/qgis/digitizing/default_snap_mode", "to vertex" ).toString();
- int defaultSnappingStringIdx = 0;
- if ( defaultSnappingString == "to vertex" )
- defaultSnappingStringIdx = 0;
- else if ( defaultSnappingString == "to segment" )
- defaultSnappingStringIdx = 1;
- else //to vertex and segment
- defaultSnappingStringIdx = 2;
- bool layerIdListOk, enabledListOk, toleranceListOk, toleranceUnitListOk, snapToListOk, avoidIntersectionListOk;
- QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &layerIdListOk );
- QStringList enabledList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingEnabledList", &enabledListOk );
- QStringList toleranceList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceList", & toleranceListOk );
- QStringList toleranceUnitList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceUnitList", & toleranceUnitListOk );
- QStringList snapToList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnapToList", &snapToListOk );
- QStringList avoidIntersectionsList = QgsProject::instance()->readListEntry( "Digitizing", "/AvoidIntersectionsList", &avoidIntersectionListOk );
- mLayerTreeWidget->clear();
- QMap< QString, QgsMapLayer *> mapLayers = QgsMapLayerRegistry::instance()->mapLayers();
- QMap< QString, QgsMapLayer *>::iterator it;
- for ( it = mapLayers.begin(); it != mapLayers.end() ; ++it )
- QgsVectorLayer *currentVectorLayer = qobject_cast<QgsVectorLayer *>( it.value() );
- if ( !currentVectorLayer || currentVectorLayer->geometryType() == QGis::NoGeometry )
- continue;
- //snap to layer yes/no
- QTreeWidgetItem *item = new QTreeWidgetItem( mLayerTreeWidget );
- QCheckBox *cbxEnable = new QCheckBox( mLayerTreeWidget );
- mLayerTreeWidget->setItemWidget( item, 0, cbxEnable );
- item->setData( 0, Qt::UserRole, currentVectorLayer->id() );
- item->setText( 1, currentVectorLayer->name() );
- //snap to vertex/ snap to segment
- QComboBox *cbxSnapTo = new QComboBox( mLayerTreeWidget );
- cbxSnapTo->insertItem( 0, tr( "to vertex" ) );
- cbxSnapTo->insertItem( 1, tr( "to segment" ) );
- cbxSnapTo->insertItem( 2, tr( "to vertex and segment" ) );
- cbxSnapTo->setCurrentIndex( defaultSnappingStringIdx );
- mLayerTreeWidget->setItemWidget( item, 2, cbxSnapTo );
- //snapping tolerance
- QLineEdit *leTolerance = new QLineEdit( mLayerTreeWidget );
- QDoubleValidator *validator = new QDoubleValidator( leTolerance );
- leTolerance->setValidator( validator );
- leTolerance->setText( QString::number( defaultSnappingTolerance, 'f' ) );
- mLayerTreeWidget->setItemWidget( item, 3, leTolerance );
- QComboBox *cbxUnits = new QComboBox( mLayerTreeWidget );
- cbxUnits->insertItem( 0, tr( "map units" ) );
- cbxUnits->insertItem( 1, tr( "pixels" ) );
- cbxUnits->setCurrentIndex( defaultSnappingUnit );
- mLayerTreeWidget->setItemWidget( item, 4, cbxUnits );
- QCheckBox *cbxAvoidIntersection = 0;
- if ( currentVectorLayer->geometryType() == QGis::Polygon )
- cbxAvoidIntersection = new QCheckBox( mLayerTreeWidget );
- mLayerTreeWidget->setItemWidget( item, 5, cbxAvoidIntersection );
- int idx = layerIdList.indexOf( currentVectorLayer->id() );
- if ( idx < 0 )
- // no settings for this layer yet
- continue;
- cbxEnable->setChecked( enabledList[ idx ] == "enabled" );
- int snappingStringIdx = 0;
- if ( snapToList[idx] == "to_vertex" )
- snappingStringIdx = 0;
- else if ( snapToList[idx] == "to_segment" )
- snappingStringIdx = 1;
- snappingStringIdx = 2;
- cbxSnapTo->setCurrentIndex( snappingStringIdx );
- leTolerance->setText( QString::number( toleranceList[idx].toDouble(), 'f' ) );
- cbxUnits->setCurrentIndex( toleranceUnitList[idx].toInt() );
- if ( cbxAvoidIntersection )
- cbxAvoidIntersection->setChecked( avoidIntersectionsList.contains( currentVectorLayer->id() ) );
- // read the digitizing settings
- int topologicalEditing = QgsProject::instance()->readNumEntry( "Digitizing", "/TopologicalEditing", 0 );
- if ( topologicalEditing != 0 )
- cbxEnableTopologicalEditingCheckBox->setCheckState( Qt::Checked );
- else
- cbxEnableTopologicalEditingCheckBox->setCheckState( Qt::Unchecked );
- if ( myDockFlag )
- for ( int i = 0; i < mLayerTreeWidget->topLevelItemCount(); ++i )
- QTreeWidgetItem *item = mLayerTreeWidget->topLevelItem( i );
- connect( mLayerTreeWidget->itemWidget( item, 0 ), SIGNAL( stateChanged( int ) ), this, SLOT( apply() ) );
- connect( mLayerTreeWidget->itemWidget( item, 2 ), SIGNAL( currentIndexChanged( int ) ), this, SLOT( apply() ) );
- connect( mLayerTreeWidget->itemWidget( item, 3 ), SIGNAL( textEdited( const QString ) ), this, SLOT( apply() ) );
- connect( mLayerTreeWidget->itemWidget( item, 4 ), SIGNAL( currentIndexChanged( int ) ), this, SLOT( apply() ) );
- QCheckBox *cbxAvoidIntersection = qobject_cast<QCheckBox*>( mLayerTreeWidget->itemWidget( item, 5 ) );
- connect( cbxAvoidIntersection, SIGNAL( stateChanged( int ) ), this, SLOT( apply() ) );
void QgsSnappingDialog::apply()
QStringList layerIdList;
@@ -312,9 +187,136 @@
QDialog::show();
+void QgsSnappingDialog::addLayer( QgsMapLayer * theMapLayer )
+ QgsVectorLayer *currentVectorLayer = qobject_cast<QgsVectorLayer *>( theMapLayer );
+ if ( !currentVectorLayer || currentVectorLayer->geometryType() == QGis::NoGeometry )
+ return;
-void QgsSnappingDialog::connectUpdate( QgsMapLayer * theMapLayer )
+ QSettings myQsettings;
+ bool myDockFlag = myQsettings.value( "/qgis/dockSnapping", false ).toBool();
+ double defaultSnappingTolerance = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance", 0 ).toDouble();
+ int defaultSnappingUnit = myQsettings.value( "/qgis/digitizing/default_snapping_tolerance_unit", 0 ).toInt();
+ QString defaultSnappingString = myQsettings.value( "/qgis/digitizing/default_snap_mode", "to vertex" ).toString();
+ int defaultSnappingStringIdx = 0;
+ if ( defaultSnappingString == "to vertex" )
+ defaultSnappingStringIdx = 0;
+ else if ( defaultSnappingString == "to segment" )
+ defaultSnappingStringIdx = 1;
+ else //to vertex and segment
+ defaultSnappingStringIdx = 2;
+ bool layerIdListOk, enabledListOk, toleranceListOk, toleranceUnitListOk, snapToListOk, avoidIntersectionListOk;
+ QStringList layerIdList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingList", &layerIdListOk );
+ QStringList enabledList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingEnabledList", &enabledListOk );
+ QStringList toleranceList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceList", & toleranceListOk );
+ QStringList toleranceUnitList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnappingToleranceUnitList", & toleranceUnitListOk );
+ QStringList snapToList = QgsProject::instance()->readListEntry( "Digitizing", "/LayerSnapToList", &snapToListOk );
+ QStringList avoidIntersectionsList = QgsProject::instance()->readListEntry( "Digitizing", "/AvoidIntersectionsList", &avoidIntersectionListOk );
+ //snap to layer yes/no
+ QTreeWidgetItem *item = new QTreeWidgetItem( mLayerTreeWidget );
+ QCheckBox *cbxEnable = new QCheckBox( mLayerTreeWidget );
+ mLayerTreeWidget->setItemWidget( item, 0, cbxEnable );
+ item->setData( 0, Qt::UserRole, currentVectorLayer->id() );
+ item->setText( 1, currentVectorLayer->name() );
+ //snap to vertex/ snap to segment
+ QComboBox *cbxSnapTo = new QComboBox( mLayerTreeWidget );
+ cbxSnapTo->insertItem( 0, tr( "to vertex" ) );
+ cbxSnapTo->insertItem( 1, tr( "to segment" ) );
+ cbxSnapTo->insertItem( 2, tr( "to vertex and segment" ) );
+ cbxSnapTo->setCurrentIndex( defaultSnappingStringIdx );
+ mLayerTreeWidget->setItemWidget( item, 2, cbxSnapTo );
+ //snapping tolerance
+ QLineEdit *leTolerance = new QLineEdit( mLayerTreeWidget );
+ QDoubleValidator *validator = new QDoubleValidator( leTolerance );
+ leTolerance->setValidator( validator );
+ leTolerance->setText( QString::number( defaultSnappingTolerance, 'f' ) );
+ mLayerTreeWidget->setItemWidget( item, 3, leTolerance );
+ QComboBox *cbxUnits = new QComboBox( mLayerTreeWidget );
+ cbxUnits->insertItem( 0, tr( "map units" ) );
+ cbxUnits->insertItem( 1, tr( "pixels" ) );
+ cbxUnits->setCurrentIndex( defaultSnappingUnit );
+ mLayerTreeWidget->setItemWidget( item, 4, cbxUnits );
+ QCheckBox *cbxAvoidIntersection = 0;
+ if ( currentVectorLayer->geometryType() == QGis::Polygon )
+ cbxAvoidIntersection = new QCheckBox( mLayerTreeWidget );
+ mLayerTreeWidget->setItemWidget( item, 5, cbxAvoidIntersection );
+ if ( myDockFlag )
+ connect( cbxEnable, SIGNAL( stateChanged( int ) ), this, SLOT( apply() ) );
+ connect( cbxSnapTo, SIGNAL( currentIndexChanged( int ) ), this, SLOT( apply() ) );
+ connect( leTolerance, SIGNAL( textEdited( const QString ) ), this, SLOT( apply() ) );
+ connect( cbxUnits, SIGNAL( currentIndexChanged( int ) ), this, SLOT( apply() ) );
+ if ( cbxAvoidIntersection )
+ connect( cbxAvoidIntersection, SIGNAL( stateChanged( int ) ), this, SLOT( apply() ) );
+ int idx = layerIdList.indexOf( currentVectorLayer->id() );
+ if ( idx < 0 )
+ // no settings for this layer yet
+ return;
+ cbxEnable->setChecked( enabledList[ idx ] == "enabled" );
+ int snappingStringIdx = 0;
+ if ( snapToList[idx] == "to_vertex" )
+ snappingStringIdx = 0;
+ else if ( snapToList[idx] == "to_segment" )
+ snappingStringIdx = 1;
+ snappingStringIdx = 2;
+ cbxSnapTo->setCurrentIndex( snappingStringIdx );
+ leTolerance->setText( QString::number( toleranceList[idx].toDouble(), 'f' ) );
+ cbxUnits->setCurrentIndex( toleranceUnitList[idx].toInt() );
+ cbxAvoidIntersection->setChecked( avoidIntersectionsList.contains( currentVectorLayer->id() ) );
+void QgsSnappingDialog::layerWillBeRemoved( QString theLayerId )
- connect( theMapLayer, SIGNAL( destroyed() ), this, SLOT( update() ) );
- update();
+ QTreeWidgetItem *item;
+ for ( int i = 0; i < mLayerTreeWidget->topLevelItemCount(); ++i )
+ item = mLayerTreeWidget->topLevelItem( i );
+ if ( item && item->data( 0, Qt::UserRole ).toString() == theLayerId )
+ break;
+ item = 0;
+ if ( item )
+ delete item;
Modified: trunk/qgis/src/app/qgssnappingdialog.h
--- trunk/qgis/src/app/qgssnappingdialog.h 2011-03-20 21:01:01 UTC (rev 15544)
+++ trunk/qgis/src/app/qgssnappingdialog.h 2011-03-20 22:46:08 UTC (rev 15545)
@@ -45,9 +45,12 @@
//! show dialog or dock
void show();
- //! connect to the layers destroyed() and then update()
- void connectUpdate( QgsMapLayer* theMapLayer );
+ //! add layer to tree
+ void addLayer( QgsMapLayer* theMapLayer );
+ //! layer removed
+ void layerWillBeRemoved( QString );
void on_cbxEnableTopologicalEditingCheckBox_stateChanged( int );
protected:
@@ -74,10 +77,6 @@
QgsMapCanvas* mMapCanvas;
QDockWidget *mDock;
- private slots:
- //! update the Dialog
- void update();
#endif
