[QGIS Commit] r15596 - trunk/qgis/src/providers/postgres
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 25 02:45:35 EDT 2011
Author: jef
Date: 2011-03-24 23:45:35 -0700 (Thu, 24 Mar 2011)
New Revision: 15596
   trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
update postgis capabilities detection
Modified: trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp
--- trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2011-03-25 06:43:27 UTC (rev 15595)
+++ trunk/qgis/src/providers/postgres/qgspostgresprovider.cpp	2011-03-25 06:45:35 UTC (rev 15596)
@@ -2207,30 +2207,44 @@
   postgisVersionMajor = postgisVersionParts[0].toInt();
   postgisVersionMinor = postgisVersionParts[1].toInt();
-  // assume no capabilities
-  geosAvailable = false;
-  gistAvailable = false;
-  projAvailable = false;
+  mUseWkbHex = postgisVersionMajor < 1;
-  // parse out the capabilities and store them
-  QStringList geos = postgisParts.filter( "GEOS" );
-  if ( geos.size() == 1 )
+  // apparently postgis 1.5.2 doesn't report capabilities in postgis_version() anymore
+  if ( postgisVersionMajor > 1 || ( postgisVersionMajor == 1 && postgisVersionMinor >= 5 ) )
-    geosAvailable = ( geos[0].indexOf( "=1" ) > -1 );
+    result = PQexec( "select postgis_geos_version(),postgis_proj_version()" );
+    geosAvailable = PQntuples( result ) == 1 && !PQgetisnull( result, 0, 0 );
+    projAvailable = PQntuples( result ) == 1 && !PQgetisnull( result, 0, 1 );
+    QgsDebugMsg( QString( "geos:%1 proj:%2" )
+                 .arg( geosAvailable ? PQgetvalue( result, 0, 0 ) : "none" )
+                 .arg( projAvailable ? PQgetvalue( result, 0, 1 ) : "none" ) );
+    gistAvailable = true;
-  QStringList gist = postgisParts.filter( "STATS" );
-  if ( gist.size() == 1 )
+  else
-    gistAvailable = ( geos[0].indexOf( "=1" ) > -1 );
+    // assume no capabilities
+    geosAvailable = false;
+    gistAvailable = false;
+    projAvailable = false;
+    // parse out the capabilities and store them
+    QStringList geos = postgisParts.filter( "GEOS" );
+    if ( geos.size() == 1 )
+      geosAvailable = ( geos[0].indexOf( "=1" ) > -1 );
+    QStringList gist = postgisParts.filter( "STATS" );
+    if ( gist.size() == 1 )
+      gistAvailable = ( geos[0].indexOf( "=1" ) > -1 );
+    QStringList proj = postgisParts.filter( "PROJ" );
+    if ( proj.size() == 1 )
+      projAvailable = ( proj[0].indexOf( "=1" ) > -1 );
-  QStringList proj = postgisParts.filter( "PROJ" );
-  if ( proj.size() == 1 )
-    projAvailable = ( proj[0].indexOf( "=1" ) > -1 );
-  mUseWkbHex = postgisVersionMajor < 1;
   gotPostgisVersion = true;
   return postgisVersionInfo;
More information about the QGIS-commit mailing list
