[QGIS Commit] [qgis/QGIS] 3fce4a: Add extra CXXFLAGS flags set by user; can be -D CX...
GitHub noreply at github.com
Tue Sep 24 14:50:51 PDT 2013
  Branch: refs/heads/master
  Home:   https://github.com/qgis/QGIS
  Commit: 3fce4a5c0a7e84f485a4b090dd94b07bec4987c5
      https://github.com/qgis/QGIS/commit/3fce4a5c0a7e84f485a4b090dd94b07bec4987c5
  Author: Larry Shaffer <larrys at dakotacarto.com>
  Date:   2013-09-24 (Tue, 24 Sep 2013)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Add extra CXXFLAGS flags set by user; can be -D CXX_EXTRA_FLAGS or environment variable
- Command line -D option overrides environment variable
- Useful for suppressing transient upstream warnings in dependencies, like Qt
  Commit: 4c1b95ba9ee0d5f0e4c9664bd293003ef280ba31
      https://github.com/qgis/QGIS/commit/4c1b95ba9ee0d5f0e4c9664bd293003ef280ba31
  Changed paths:
    M src/python/qgspythonutilsimpl.cpp
  Log Message:
  Add support for PYTHONSTARTUP-like environment variable, PYQGIS_STARTUP
- Different than user's 'startup.py,' since it is loaded just after Py_Initialize, specifically from env variable
- Useful for cleaning sys.path, e.g. isolating/loading the initial environ without requiring a virt env, like homebrew or MacPorts installs on Mac
  Commit: 87163c609859b50f4d7ddaf2bf181ab517b51a62
      https://github.com/qgis/QGIS/commit/87163c609859b50f4d7ddaf2bf181ab517b51a62
  Changed paths:
    M tests/src/python/test_qgsappstartup.py
  Log Message:
  Add unit test for PYQGIS_STARTUP environment variable
- Make PyQgsAppStartup test more general and PEP8 compliant
Compare: https://github.com/qgis/QGIS/compare/1ca2258a5bfc...87163c609859
More information about the QGIS-commit mailing list
