[QGIS Commit] [qgis/QGIS] b97977: Fix typo in renderchecker output
GitHub
noreply at github.com
Fri Feb 21 13:01:19 PST 2014
Branch: refs/heads/master
Home: https://github.com/qgis/QGIS
Commit: b979774dd3324e93a304c53e11166234c10ec917
https://github.com/qgis/QGIS/commit/b979774dd3324e93a304c53e11166234c10ec917
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2014-02-21 (Fri, 21 Feb 2014)
Changed paths:
M src/core/qgsrenderchecker.cpp
Log Message:
Commit: c4a60de06c786a230a204338d7cf7677f1b3080e
https://github.com/qgis/QGIS/commit/c4a60de06c786a230a204338d7cf7677f1b3080e
Changed paths:
M tests/src/python/test_qgspallabeling_base.py
M tests/src/python/test_qgspallabeling_canvas.py
M tests/src/python/test_qgspallabeling_server.py
M tests/src/python/test_qgspallabeling_tests.py
M tests/testdata/control_images/expected_pal_canvas/sp_default_label/sp_default_label.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_color/sp_text_color.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_size_map_unit/sp_text_size_map_unit.png
M tests/testdata/control_images/expected_pal_server/sp_default_label/sp_default_label.png
M tests/testdata/control_images/expected_pal_server/sp_text_color/sp_text_color.png
M tests/testdata/control_images/expected_pal_server/sp_text_size_map_unit/sp_text_size_map_unit.png
Log Message:
Update labeling canvas and server unit tests and output new control images
Commit: 203d67f628d275393425168e71ef73603cd308b6
https://github.com/qgis/QGIS/commit/203d67f628d275393425168e71ef73603cd308b6
Changed paths:
M tests/src/python/CMakeLists.txt
A tests/src/python/test_qgspallabeling_composer.py
A tests/testdata/control_images/expected_pal_composer/sp_default_label/sp_default_label.png
A tests/testdata/control_images/expected_pal_composer/sp_partials_labels_disabled/sp_partials_labels_disabled.png
A tests/testdata/control_images/expected_pal_composer/sp_partials_labels_enabled/sp_partials_labels_enabled.png
A tests/testdata/control_images/expected_pal_composer/sp_text_color/sp_text_color.png
A tests/testdata/control_images/expected_pal_composer/sp_text_size_map_unit/sp_text_size_map_unit.png
Log Message:
Add labeling composer unit tests and control images
- Initial support for image output at 72 dpi
- Comparison against canvas output has slight shift (needs fixed)
Compare: https://github.com/qgis/QGIS/compare/5748abfdf335...203d67f628d2
