[QGIS Commit] [qgis/QGIS] b4f681: PEP8 cleanups for some unit test modules
GitHub
noreply at github.com
Thu Mar 6 11:39:10 PST 2014
Branch: refs/heads/master
Home: https://github.com/qgis/QGIS
Commit: b4f6813671134b9bcb09f01f2a18111543190945
https://github.com/qgis/QGIS/commit/b4f6813671134b9bcb09f01f2a18111543190945
Author: Larry Shaffer <larrys at dakotacarto.com>
Date: 2014-03-06 (Thu, 06 Mar 2014)
Changed paths:
M tests/src/python/qgis_local_server.py
M tests/src/python/test_qgspallabeling_tests.py
Log Message:
Commit: a49b9a7a454f76e2640fd5a8b1872bff2d67362e
https://github.com/qgis/QGIS/commit/a49b9a7a454f76e2640fd5a8b1872bff2d67362e
Changed paths:
M tests/src/python/utilities.py
Log Message:
Add some functions to Python unit test utilities
Commit: 6a1b706b48188fbcb5cb682bdbd8dc4d0a42ce74
https://github.com/qgis/QGIS/commit/6a1b706b48188fbcb5cb682bdbd8dc4d0a42ce74
Changed paths:
M tests/src/python/test_qgspallabeling_base.py
M tests/src/python/test_qgspallabeling_canvas.py
M tests/src/python/test_qgspallabeling_server.py
Log Message:
Update label tests to ensure setup happens only once and load/delete only layer to test
Commit: bad189813cb3b2c96332198f8b08ccf7d35aa386
https://github.com/qgis/QGIS/commit/bad189813cb3b2c96332198f8b08ccf7d35aa386
Changed paths:
M tests/src/python/test_qgspallabeling_composer.py
R tests/testdata/control_images/expected_pal_composer/sp_background_rect/sp_background_rect.png
R tests/testdata/control_images/expected_pal_composer/sp_background_rect_w_offset/sp_background_rect_w_offset.png
R tests/testdata/control_images/expected_pal_composer/sp_background_svg/sp_background_svg.png
R tests/testdata/control_images/expected_pal_composer/sp_background_svg_w_offset/sp_background_svg_w_offset.png
R tests/testdata/control_images/expected_pal_composer/sp_default_label/sp_default_label.png
A tests/testdata/control_images/expected_pal_composer/sp_img_background_rect/sp_img_background_rect.png
A tests/testdata/control_images/expected_pal_composer/sp_img_background_rect_w_offset/sp_img_background_rect_w_offset.png
A tests/testdata/control_images/expected_pal_composer/sp_img_background_svg/sp_img_background_svg.png
A tests/testdata/control_images/expected_pal_composer/sp_img_background_svg_w_offset/sp_img_background_svg_w_offset.png
A tests/testdata/control_images/expected_pal_composer/sp_img_default_label/sp_img_default_label.png
A tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_disabled/sp_img_partials_labels_disabled.png
A tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_enabled/sp_img_partials_labels_enabled.png
A tests/testdata/control_images/expected_pal_composer/sp_img_text_color/sp_img_text_color.png
A tests/testdata/control_images/expected_pal_composer/sp_img_text_size_map_unit/sp_img_text_size_map_unit.png
R tests/testdata/control_images/expected_pal_composer/sp_partials_labels_disabled/sp_partials_labels_disabled.png
R tests/testdata/control_images/expected_pal_composer/sp_partials_labels_enabled/sp_partials_labels_enabled.png
R tests/testdata/control_images/expected_pal_composer/sp_text_color/sp_text_color.png
R tests/testdata/control_images/expected_pal_composer/sp_text_size_map_unit/sp_text_size_map_unit.png
Log Message:
Refactor composer label test to work with svg, pdf and multi-resolution classes
- Initial (untested) svg and pdf render-to-image setup
Commit: 53cfa9e203d56501b0f58bb865b910ed1117c3c8
https://github.com/qgis/QGIS/commit/53cfa9e203d56501b0f58bb865b910ed1117c3c8
Changed paths:
M tests/testdata/control_images/expected_pal_canvas/sp_background_rect/sp_background_rect.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_rect_w_offset/sp_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_svg/sp_background_svg.png
M tests/testdata/control_images/expected_pal_canvas/sp_background_svg_w_offset/sp_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_canvas/sp_default_label/sp_default_label.png
M tests/testdata/control_images/expected_pal_canvas/sp_partials_labels_disabled/sp_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_canvas/sp_partials_labels_enabled/sp_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_color/sp_text_color.png
M tests/testdata/control_images/expected_pal_canvas/sp_text_size_map_unit/sp_text_size_map_unit.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_rect/sp_img_background_rect.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_rect_w_offset/sp_img_background_rect_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_svg/sp_img_background_svg.png
M tests/testdata/control_images/expected_pal_composer/sp_img_background_svg_w_offset/sp_img_background_svg_w_offset.png
M tests/testdata/control_images/expected_pal_composer/sp_img_default_label/sp_img_default_label.png
M tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_disabled/sp_img_partials_labels_disabled.png
M tests/testdata/control_images/expected_pal_composer/sp_img_partials_labels_enabled/sp_img_partials_labels_enabled.png
M tests/testdata/control_images/expected_pal_composer/sp_img_text_color/sp_img_text_color.png
M tests/testdata/control_images/expected_pal_composer/sp_img_text_size_map_unit/sp_img_text_size_map_unit.png
Log Message:
Convert label unit tests to using only QgsMapSettings
- Rebuild all control images
Commit: 803bc296da941ad2bd653766704fc3dd4855bc6a
https://github.com/qgis/QGIS/commit/803bc296da941ad2bd653766704fc3dd4855bc6a
Changed paths:
Log Message:
Condense labeling test class inheritance and set up local server params from map settings
Commit: 30bf3ecc9dbca1aa155983999ad8c7c4a5d7c7d8
https://github.com/qgis/QGIS/commit/30bf3ecc9dbca1aa155983999ad8c7c4a5d7c7d8
Changed paths:
M src/core/qgsrenderchecker.cpp
Log Message:
Add allowable mismatch to debug output for render checker
Commit: cb998399cf8d8fe69080817017d7058a36509d79
https://github.com/qgis/QGIS/commit/cb998399cf8d8fe69080817017d7058a36509d79
Changed paths:
Log Message:
Add allowable mismatch per group/test for labeling tests
Compare: https://github.com/qgis/QGIS/compare/7829e7aa856a...cb998399cf8d
