[Qgis-community-team] Plugin icons
Otto Dassau otto.dassau at gmx.de
Fri Aug 1 08:03:24 EDT 2008
On Thu, 31 Jul 2008 11:17:54 +0200
Otto Dassau <otto.dassau at gmx.de> wrote:
> Hi Tara,
> On Wed, 30 Jul 2008 17:28:28 -0700
> Tara Athan <tara_athan at alt2is.com> wrote:
> > Thanks, Tim!
> > The next step for the SVN user_guide directory is to replace the old
> > plugin icons with the new ones.
> > This means your checked out directory will have eps files left over from
> > the previous names.
> > These will be unversioned files, so however the SVN updates are done,
> > they will not take care of this clean up for you.
> > The makefile intentionally does not delete these so that when you are
> > editing the user guide and recompiling frequently, you don't have to
> > wait for the eps files to be created every time.
> > I can think of a couple of ways to make these icon flushes less of a
> > burden for us all.
> > A. Construct a script that wipes all eps files out of the image
> > directories (core, plugins and screenies). It will only be necessary to
> > run this when there has been a change in image files (in the user
> > guide), and in general this should happen only once every release. The
> > makefile will then start from scratch to create new eps files, but again
> > this will only happen once per release.
> you can use 'make clean'. It deletes all eps files from the image subfolders
> and removes the finalpix folder as well.
> > B. Put all icons files into the user_guide image directory, rather than
> > separate folders for each plugin.  The only reason I did this in the
> > first place was because of the name collisions- that is solved, and it
> > will be easy to identify which icon goes with which plugin directly from
> > the name. This makes it easy to simply delete all eps files from the
> > directory manually.
> I would keep it the way you just structured it, because within the qgis
sources
> the icons are also splitted in plugin dirs. Especially for all the GRASS
Module
> icons I would like to use the plugins_grass_module_images/ folder.
> > We could implement one of these or both.
> > Then I believe if I
> > 1. make the necessary changes in my local checkout, (deleting old pngs
> > and copying the new pngs into the right place)
> I added and committed a new Makefile option (updateicon). It removes all .eps
> and .png files from the image folders (not screenies) and copies the new icons
> from a defined QGIS source directories.
> So all you need to do is:
> - define variable QGISPLUGINSOURCE in the Makefile. In my case it is:
> QGISPLUGINSOURCE=/software/qgis_head/src/plugins
> - run make updateicon
> please check in the Makefile if all necessary icon folders are implemented in
> the Makefile updateicon option. I tried to get all folders but I am not sure.
> > 2. commit (Tortoise SVN) at the folder level, with checkboxes on for all
> > the png files
> > then this will allow everyone else to update in order to delete the old
> > icons and download the new icons into their local copies.
> > Is this correct?
> > I am less sure about the Tortoise SVN procedure if I create and delete
> > folders (as in plan B)- does this work the same way?
> I am not an expert and don't know if Tortoise supports this. But I guess that
> should work.
I did following steps now:
- removed old png and eps image/icon files except screenies using Makefile
  option 'updateicon'
- moved operation system icons nix.png, osx.png and win.png to its own folder
  /operation_system_icons. Otherwise they would be deleted during 'make
  updateicon'.
- adapted all .tex files, where image names in QGIS sources changed to make it
  compile again.
I hope this is what you wanted to. The step 'make updateicon' and 'adaption of
all .tex files with changed icon names' need to be repeated before 1.0 release,
but for now, i think we can move on with our task list.
regards,
 Otto
> regards,
>  Otto
> > Tara
> > Tim Sutton wrote:
> > > Hi Tara
> > > Ok so today I did the necessary changes so all plugin icons are named
> > > after their parent directory. The exception is GRASS which is a more
> > > complicated affair since the plugin supports themes. That said there
> > > should no longer be any name collisions on plugin icons. Hope that
> > > helps.
> > > Regards
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
