[work] Re: [Qgis-community-team] Plugin icons
Otto Dassau otto.dassau at gmx.de
Fri Aug 1 13:28:58 EDT 2008
On Fri, 1 Aug 2008 19:15:49 +0200
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi Folks
> A small nomenclatural issue its probably better to call that dir
> 'operating_system' rather than 'operation_system'
thanks - I changed it
  Otto
> Regards
> Tim
> 2008/8/1 Otto Dassau <otto.dassau at gmx.de>:
> > Hi Tara,
> > On Fri, 01 Aug 2008 07:57:36 -0700
> > Tara Athan <tara_athan at alt2is.com> wrote:
> >> Otto- I updated my local copy of the user guid: creation of new folders
> >> such as operation_system_icon and moving those images is working OK.
> >> However when I try to clean up the old files, I see this:
> >> $ make updateicon
> >> (cd ./images && rm -f *.png *.eps && cp
> >> /software/qgis_head/src/plugins/../../images/themes/default/*.png .)
> >> cp: cannot stat
> >> `/software/qgis_head/src/plugins/../../images/themes/default/*.png': No
> >> such file or directory
> >> make: *** [updateicon] Error 1
> > you only need to adapt the path to qgis sources in the Makefiles on your
system
> > QGISPLUGINSOURCE=...
> >> I think we need to separate the removing of old eps files from the
> >> copying of new images.
> >> This is what I was thinking would be required:
> >> One person will need to get the new images from the software source and
> >> move them into their user guide local copy, then commit.
> > yes and he needs to adapt changes due to new names in the .tex files and
> > Makefiles and make sure it all compiles well again.
> >> Everyone else will need to remove their old eps files and update from SVN.
> > all other users only need to use these 2 commands to make everything work
again:
> > make clean -> removes all current eps files and the folder finalpix
> > svn up -> update to current images...
> > or am I missing something?
> >  regards,
> >  Otto
> >> Tara
> >> > I did following steps now:
> >> > - removed old png and eps image/icon files except screenies using
Makefile
> >> >   option 'updateicon'
> >> > - moved operation system icons nix.png, osx.png and win.png to its own
> > folder
> >> >   /operation_system_icons. Otherwise they would be deleted during 'make
> >> >   updateicon'.
> >> > - adapted all .tex files, where image names in QGIS sources changed to
make
> > it
> >> >   compile again.
> >> > I hope this is what you wanted to. The step 'make updateicon' and
'adaption
> > of
> >> > all .tex files with changed icon names' need to be repeated before 1.0
> > release,
> >> > but for now, i think we can move on with our task list.
> >> > regards,
> >> >  Otto
> >> >> regards,
> >> >>  Otto
> >> >>> Tara
> >> >>> Tim Sutton wrote:
> >> >>>> Hi Tara
> >> >>>> Ok so today I did the necessary changes so all plugin icons are named
> >> >>>> after their parent directory. The exception is GRASS which is a more
> >> >>>> complicated affair since the plugin supports themes. That said there
> >> >>>> should no longer be any name collisions on plugin icons. Hope that
> >> >>>> helps.
> >> >>>> Regards
> > Qgis-community-team mailing list
> > Qgis-community-team at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
