[Qgis-community-team] Re: Plugins??
Tim Sutton tim at linfiniti.com
Fri Aug 8 18:33:00 EDT 2008
Hi
2008/8/8 Agustin Lobo <Agustin.Lobo at ija.csic.es>:
> Sorry I could not answer earlier.
No problem
> Note that the plugin mentioned by Tim is a C++ plugin, not
> a python plugin. In order to get this new C++ plugin,
> you have to either compile the development version using
> svn (a bit involved) or wait until the new version 1.0 around 15/09/2008.
> Please, Tim, correct me if I'm wrong.
You are correct. We will probably be making some preview releases so
you may get to use it sooner than the date stated above.
> (Regarding C++ plugins: eVIS is another example of C++ plugin, ready
> for current 0.11. You download a binary and copy it in the
> appropriate directory specified in the directions. From there
> on, you manage it using the "plugin manager", but you cannot
> install it using the "plugin installer". Note that this
> plugin has nothing to see with the coordinates
> problem, it is just to explain the difference between C++ plugins and
> python plugins).
Correct
> Tim et al.:, you see that we do need a different term? It's not
> a conceptual problem, it's an operational problem. If we keep
> the same term we'll see this type of confusion over an over.
> From the point of view of a user, they are different because
> you install them in a totally different way, and if they
> are different they should have different names.
I'm not convinced we need to change terms. A plugin is a plugin
regardless of the language it was created in. Rather I think we need
to try to make things so that it is more obvious to the user what is
going on. I prefer to wait until Tom merges in his menu changes before
I tackle anything like this though.
> Michael: if you cannot wait, go for the development version, it's
> a bit involved but not impossible. Directions in
> http://wiki.qgis.org/qgiswiki/BuildingFromSource
> and select your OS there (if it's Win, it's harder, I think).
If you are on ubuntu heron I or Jef could probably whip up a preview
build for you in the next few days.
Regards
Tim
> Agus
> Michael Neubauer wrote:
>> Hi Augus,
>> so I am an idiot! I did not have python-gis installed, and therefore did
>> not see the "plugin installer"...
>> So far I never installed any "experimental" plugins.
>> But I still do not know where to find the plugin Tim wrote for us...
>> Does he hava his own plugin-repository? I did not find anything like
>> this...
>> hope you can help me with that... it should not be too difficult  ;-)
>> bye
>> Michael
> Dr. Agustin Lobo
> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
> LLuis Sole Sabaris s/n
> 08028 Barcelona
> Spain
> Tel. 34 934095410
> Fax. 34 934110012
> email: Agustin.Lobo at ija.csic.es
> http://www.ija.csic.es/gt/obster
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
Blog: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
More information about the Qgis-community-team mailing list
