[Qgis-community-team] http://qgis.osgeo.org/ is online for testing
Tim Sutton tim at linfiniti.com
Fri Jun 20 16:25:36 EDT 2008
Hi
Ok I'm back at home and had a look at the mock up. I have many many
comments, here is what I can manage before I fall asleep at the
keyboard :-) I appreciate that others may have different opinions,
these are just mine...
- When you navigate away from the front page there is nothing to tell
you what site you are on. Every page should have at minimum the qgis
icon and the words 'Quantum GIS' at the top of the page. I think this
may be best placed above the osgeo logo in the left cl, but Im not
sure without seeing it in reality. Then the osgeo logo could go under
it.
- The features list should be split into two, left aligned columns so
that the features appear 'above the fold'
- Articles on front page (and probably elsewhere) should not have date
/ time / pdf etc icons. For me it adds a lot of visual clutter and ads
no real benifit and in worst case makes it look like QGIS was born
this week only :-P
- I like the right aligned top menu bar and now I think the
accessibility icons are a) wasting space b) looking a bit strange
because the blue bar is wider then the menu bar below it and isnt
rounded like the bar below. I suggest to remove that current
accessibility bar and put the icons left aligned on the top menu bar
since we have the free space there.
- The QGIS screenie with the reflection in the intro to qgis paragraph
needs to be a) padded a little from the surrounding text b) aligned so
that the top of the image aligns to the top of the first row of the
intro paragraph
- OSGeo logo should be center aligned in its column
- It would be good to get rid of the main menu module on left all
together - I think the site still has too many things going on.
- When the main menu module is gone, can you put a custom module that
says something like 'Current Version Foo Bar, released 16 of June
2008. Download."
- Put the screenshots link in the top menu.
- When we settle on a plugin repository put the menu item as 'Plugins'
in the top menu.
- We need to get SEO urls working so that this isnt in address bar:
http://qgis.osgeo.org/index.php?option=com_content&task=blogcategory&id=97&Itemid=120
- I think its better to put 'the project' on the front page after the
features list (see comments relating to that above) and remove the
'the project' page.
- the black top menu bar on the right side is missing its rounded
corners like it has to the left side
- can we get rid of the light gray frames around the outside of the content?
- the module box titles (e.g. "Polls") and their content is
disproportionately large comared to the rest of the site.
- can you remove the word 'website' from the window title (i.e. the
site name in configuration) since its redundant to say that this is a
website.
I have many more suggestions but let me leave these ones with you for
general consideration and after the next round of updates Ill give
another round of comments.
Keep up the great work!
Regards
Tim
2008/6/19 Tim Sutton <tim at linfiniti.com>:
> Hi
> My suggestion is to import the users map data into postgis temporarily
> and then put itinto an ogr readable sqlite datbase - or two, one for
> placenames table (which wont need regular backups) and one for users
> (which can be backed up daily via email).
> regards
> Tim
> On 6/19/08, Stephan Reber <stephan.reber at sr-gis.de> wrote:
>> Hi Otto,
>> Otto Dassau schrieb:
>>> Hi Stephan,
>>> On Wed, 18 Jun 2008 08:48:39 +0200
>>>> Hallo!
>>>> After reordering the content from the qgis.org, a first version of the
>>>> website is online. I have rearranged the menus and modules. Now its a
>>>> 2-column layout and I made some modifications of the template.
>>> with a 2-column layout and because we only want to present the essentials,
>>> what
>>> about using a fixed-width (~800 pixel) for the website and commenting the
>>> fluid-width? Maybe it is only my personal preference, but I always find
>>> pages
>>> with a fixed-width easier to design, fill with content and look nice.
>> I prefer a fixed width, too. But to keep the look and feel of qgis
>> (website, wiki, forum, blog), I did not change it. I tested a fixed
>> width with buttons in the header on the right side. I think it looks
>> good - except the polls module.
>>>> Also I added a archive, which allows to search the unused contents of
>>>> qgis.org. But the search is not very comfortable.
>>>> Adding a directory for plugins is good idea. But what about the possible
>>>> security problems with third party components? Because I don't like the
>>>> idea of putting ads on the website for using a component, I have
>>>> searched another directory component with good reviews. I have added a
>>>> good and often used component just for testing and to see how such a
>>>> component works.
>>>> In the next days I will return to work on the alternatives for the
>>>> templates.
>>>> Take a look  at http://qgis.osgeo.org/
>>>> Name and password: qgisweb
>>> I took a first look and agree with Werner that it looks already clearer,
>>> but I
>>> will wait for your other templates and until you say "this is my final
>>> solution
>>> I propose", before we start the discussion.
>> I'm working on it.
>>> And also from my side. If you need help or have some tasks to
>>> share/assign, just
>>> tell us.
>> When I changed the joomlashack template there were two things I wanted
>> to change but I haven't found where to adjust them.
>> 1. I would like to display the topmenu on the right side or in the
>> middle. I think, it is too near to the main menu.
>> 2. The font size of the main menu should be greater.
>> Maybe, someone can do it or let me know where to adjust the template.
>> Thanks!
>> Now that the wiki works I will add/update the todo list and report the
>> things already done. This could take untill next week, because I am
>> offline at the weekend.
>> And something I asked myself when I rearranged the content is what to do
>> with the 1309 users of Joomla?
>> Another point is the usermap backup. I tried to install them without a
>> close look at the sql-script. But it did not work. Then I realized that
>> it is data for postgresql. Is postgresql also installed on the server
>> and if so can I get access to it?
>> Regards,
>> Stephan
>>> thanks a lot for your work so far!
>>> regards,
>>>  Otto
>>>> I'm looking forward to your feedback.
>>>> Regards
>>>> Stephan
>>>> _______________________________________________
>>>> Qgis-community-team mailing list
>>>> Qgis-community-team at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
> Sent from my mobile device
> Tim Sutton
> QGIS Project Steering Committee Member - Release  Manager
> Visit http://qgis.org for a great open source GIS
> openModeller Desktop Developer
> Visit http://openModeller.sf.net for a great open source ecological
> niche modelling tool
> Home Page: http://tim.linfiniti.com
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
Tim Sutton
Skype: timlinux
More information about the Qgis-community-team mailing list
