[Qgis-community-team] Re: add a gml layer
Tara Athan tara_athan at alt2is.com
Fri Jun 20 17:16:00 EDT 2008
I was able to get a lakes.gml file using the procedure Jürgen suggested,
using FW Tools.
It still does not load into QGIS v.10 (Windows XP) however.  The error
is the same as before-
...\lakes.gml is not a valid or recognized data source
However I checked with a Windows build of QGIS v.11 that I received on
6/6/08, and the layer DOES load!
I am guessing it is a re-emergence of closed Ticket #751 in the Io
Windows build.
Can anyone verify this?
Tara
Jürgen E. Fischer wrote:
> Hi Tara,
> On Fri, 20. Jun 2008 at 09:11:06 -0700, Tara Athan wrote:
>> I am attempting to add a gml layer to the QGIS dataset that will be used
>> in the next release of the QGIS manual (v 1.0).
>> I took the lakes.shp shapefile from the existing dataset and used ArcMap
>> to convert to gml (sorry, I couldn't figure out any other way.)
> You can do that using OGR
> ogr2ogr -f GML lakes.gml lakes.shp
> creates a GML file you can use with QGIS.
> Jürgen
More information about the Qgis-community-team mailing list
