[Qgis-community-team] help with manual revision
Otto Dassau otto.dassau at gmx.de
Mon May 26 10:20:31 EDT 2008
I think I found a solution installing MSYS (Minimal Bourne Shell) which is also
(partly) used in GRASS or QGIS under Windows, and provides the necessary
functionality. This way, we could keep the nice Makefiles.
I installed following packages (could maybe be improved):
- MiKTEX -> http://miktex.org/ (TeX implementation for Windows)
- MSYS -> http://www.mingw.org/msys.shtml (Minimal Bourne Shell)
- ImageMagick -> http://www.imagemagick.org/script/binary-releases.php#windows
  (Image editing tools (especially convert))
- Ghostscript and Ghostview -> http://pages.cs.wisc.edu/~ghost/
  (Viewer for EPS files)
here the procedure after installation to compile and create a PDF:
- start MSYS (Linux Shell)
- change into the qgis user_guide directory (cd ...)
- type 'make' (MiKTEX then installs a lot of additional packages from the
  internet and at least for me one package (floatflt.sty) was not available. By
  simply  clicking return I could skip some other "minor" errors, that also
  occur under  linux.
- Use Yap (DVI viewer inside of MiKTEX) for the .dvi output under Windows
- Convert user_guide.dvi to PDF with dvipdfm.exe in MSYS Shell.
I hope this helps so we can still use the comfortable Makefile under linux/mac
and adapt/extend it for windows.
Could you please check the procedure, if it is also working for you. I added the
notes to the wiki (ManualManagement). Can you please make changes and add your
experiences there, too.
regards,
  Otto
On Mon, 26 May 2008 12:20:31 +0200
Werner Macho <werner.macho at gmail.com> wrote:
> hi all!
> I tried to compile the manual (trunk) under windows AND linux and here
> are my experiences:
> Linux: easy as always but .. lets say only with Makefile .. :(
> Makefile (which is obviosly linux-only) does a convert with imagemagick
> all png or jpg to needed eps..
> eps files are much bigger than the png and jpg source files .. so what
> to do here? commit eps to svn too for windows users?
> after converting all pictures to .eps and trying it again under windows
> there are much less complaints with texmaker and miktex but .. i guess
> there are several other problems too..
> like:
> > ("C:\Programme\MiKTeX 2.7\tex\latex\tools\xspace.sty"
> > Package: xspace 2006/05/08 v1.12 Space after command names (DPC,MH)
> > ! Undefined control sequence.
> > \@fileswith at pti@ns ...served at b \reserved at a ,\@nil
> > ,}\fi \reserved at a
> > l.211
> > The control sequence at the end of the top line
> > of your error message was never \def'ed. If you have
> > misspelled it (e.g., `\hobx'), type `I' and the correct
> > spelling (e.g., `I\hbox'). Otherwise just continue,
> > and I'll forget about whatever was undefined.
> > Runaway definition?
> > ->\@onefilewithoptions hyperref[bookmarks=true, bookmarksnumbered=fal\ETC.
> > ! File ended while scanning definition of \reserved at a.
> > <inserted text>
> so i guess if we want windows user to help with latex documentation and
> manual writing we have to make sure that everything works under windows
> as well..
> the first problem i see is converting png and jpg to eps
> second is a lot of other "Undefined control sequence" and other failures..
> any suggestion how to deal with that problem.. we have to make sure that
> tex compiles without makefile
> regards werner
More information about the Qgis-community-team mailing list
